[+] nie dzia
[+] nie działa wifi w asus a9rp
Witam wszystkich,
zainstalowałem dzis najnowszego debiana z lxde na starym asusie a9rp i chyba nie ma sterownika karty wifi tzn nie działa napewno, pomoże ktoś?
- marcin1982
Podaj specyfikację sprzętu - wynik komendy z terminala / konsoli:
lspci -k
Używaj tagów Code.
ok podaję:
00:00.0 Host bridge: Advanced Micro Devices [AMD] nee ATI Device 5a31 (rev 01)
Subsystem: ASUSTeK Computer Inc. Device 13d7
00:01.0 PCI bridge: Advanced Micro Devices [AMD] nee ATI RS480 PCI Bridge
00:13.0 USB controller: Advanced Micro Devices [AMD] nee ATI IXP SB400 USB Host Controller (rev 80)
Kernel driver in use: ohci_hcd
00:13.1 USB controller: Advanced Micro Devices [AMD] nee ATI IXP SB400 USB Host Controller (rev 80)
00:13.2 USB controller: Advanced Micro Devices [AMD] nee ATI IXP SB400 USB2 Host Controller (rev 80)
00:14.0 SMBus: Advanced Micro Devices [AMD] nee ATI IXP SB400 SMBus Controller (rev 82)
Kernel driver in use: piix4_smbus
00:14.1 IDE interface: Advanced Micro Devices [AMD] nee ATI IXP SB400 IDE Controller (rev 80)
Kernel driver in use: pata_atiixp
00:14.2 Audio device: Advanced Micro Devices [AMD] nee ATI IXP SB4x0 High Definition Audio Controller (rev 01)
00:14.3 ISA bridge: Advanced Micro Devices [AMD] nee ATI IXP SB400 PCI-ISA Bridge (rev 80)
00:14.4 PCI bridge: Advanced Micro Devices [AMD] nee ATI IXP SB400 PCI-PCI Bridge (rev 80)
01:05.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI RC410 [Radeon Xpress 200M]
Subsystem: ASUSTeK Computer Inc. Device 1392
Kernel driver in use: radeon
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Subsystem: ASUSTeK Computer Inc. L8400B or L3C/S notebook
Kernel driver in use: 8139too
02:01.0 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev 8d)
Kernel driver in use: yenta_cardbus
02:01.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 13)
Kernel driver in use: sdhci-pci
02:01.2 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 04)
Kernel driver in use: r592
Pokaż jeszcze wyniki:
lspci -n
dmesg
Ok:
I jeszcze :
Sorry że tak wrzucam ale jeszcze nie wiem jaka komenda żeby było kod:
już szukam może doczytam
lspci -n
00:00.0 0600: 1002:5a31 (rev 01)
00:01.0 0604: 1002:5a3f
00:13.0 0c03: 1002:4374 (rev 80)
00:13.1 0c03: 1002:4375 (rev 80)
00:13.2 0c03: 1002:4373 (rev 80)
00:14.0 0c05: 1002:4372 (rev 82)
00:14.1 0101: 1002:4376 (rev 80)
00:14.2 0403: 1002:437b (rev 01)
00:14.3 0601: 1002:4377 (rev 80)
00:14.4 0604: 1002:4371 (rev 80)
01:05.0 0300: 1002:5a62
02:00.0 0200: 10ec:8139 (rev 10)
02:01.0 0607: 1180:0476 (rev 8d)
02:01.1 0805: 1180:0822 (rev 13)
02:01.2 0880: 1180:0592 (rev 04)
dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.65-1+deb7u1
[ 0.000000] Disabled fast string operations
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000037fd0000 (usable)
[ 0.000000] BIOS-e820: 0000000037fd0000 - 0000000037fde000 (ACPI data)
[ 0.000000] BIOS-e820: 0000000037fde000 - 0000000038000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff780000 - 0000000100000000 (reserved)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: ASUSTeK Computer Inc. A9Rp /A9Rp , BIOS 230 07/17/2007
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x37fd0 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-DFFFF uncachable
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 038000000 mask FF8000000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] found SMP MP-table at [c00ff780] ff780
[ 0.000000] initial memory mapped : 0 - 01a00000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000379fe000
[ 0.000000] 0000000000 - 0000200000 page 4k
[ 0.000000] 0000200000 - 0037800000 page 2M
[ 0.000000] 0037800000 - 00379fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 379fe000 @ 19f9000-1a00000
[ 0.000000] RAMDISK: 36c8a000 - 3763d000
[ 0.000000] ACPI: RSDP 000f8380 00014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 37fd0000 0003C (v01 A M I OEMRSDT 07000717 MSFT 00000097)
[ 0.000000] ACPI: FACP 37fd0200 00084 (v02 A M I OEMFACP 07000717 MSFT 00000097)
[ 0.000000] ACPI: DSDT 37fd05e0 065A9 (v01 A0598 A0598000 00000000 INTL 02002026)
[ 0.000000] ACPI: FACS 37fde000 00040
[ 0.000000] ACPI: APIC 37fd0390 0005C (v01 A M I OEMAPIC 07000717 MSFT 00000097)
[ 0.000000] ACPI: MCFG 37fd03f0 0003C (v01 A M I OEMMCFG 07000717 MSFT 00000097)
[ 0.000000] ACPI: BOOT 37fd05b0 00028 (v01 A M I OEMBOOT 07000717 MSFT 00000097)
[ 0.000000] ACPI: SLIC 37fd0430 00176 (v01 A M I OEMSLIC 07000717 MSFT 00000097)
[ 0.000000] ACPI: OEMB 37fde040 00056 (v01 A M I AMI_OEM 07000717 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 5MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000379fe
[ 0.000000] HighMem 0x000379fe -> 0x00037fd0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x00037fd0
[ 0.000000] On node 0 totalpages: 229215
[ 0.000000] free_area_init_node: node 0, pgdat c1412800, node_mem_map f658a200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1748 pages used for memmap
[ 0.000000] Normal zone: 221994 pages, LIFO batch:31
[ 0.000000] HighMem zone: 12 pages used for memmap
[ 0.000000] HighMem zone: 1478 pages, LIFO batch:0
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x81] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 21 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 2 CPUs, 1 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 38000000 (gap: 38000000:c6e00000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 14 pages/cpu @f79db000 s33280 r0 d24064 u57344
[ 0.000000] pcpu-alloc: s33280 r0 d24064 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 227423
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-686-pae root=UUID=b37d7f74-f136-41a6-a9f9-987bcf2b930d ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000379fe:00037fd0)
[ 0.000000] Memory: 893588k/917312k available (2859k kernel code, 23272k reserved, 1340k data, 420k init, 5960k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
[ 0.000000] pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
[ 0.000000] vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
[ 0.000000] .init : 0xc141b000 - 0xc1484000 ( 420 kB)
[ 0.000000] .data : 0xc12caf40 - 0xc141a200 (1340 kB)
[ 0.000000] .text : 0xc1000000 - 0xc12caf40 (2859 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f6006000 soft=f6008000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1866.976 MHz processor.
[ 0.004002] Calibrating delay loop (skipped), value calculated using timer frequency.. 3733.95 BogoMIPS (lpj=7467904)
[ 0.004008] pid_max: default: 32768 minimum: 301
[ 0.004054] Security Framework initialized
[ 0.004063] AppArmor: AppArmor disabled by boot time parameter
[ 0.004082] Mount-cache hash table entries: 512
[ 0.004230] Initializing cgroup subsys cpuacct
[ 0.004237] Initializing cgroup subsys memory
[ 0.004247] Initializing cgroup subsys devices
[ 0.004250] Initializing cgroup subsys freezer
[ 0.004252] Initializing cgroup subsys net_cls
[ 0.004255] Initializing cgroup subsys blkio
[ 0.004263] Initializing cgroup subsys perf_event
[ 0.004295] Disabled fast string operations
[ 0.004303] mce: CPU supports 6 MCE banks
[ 0.004314] CPU0: Thermal monitoring enabled (TM2)
[ 0.004318] using mwait in idle threads.
[ 0.004383] SMP alternatives: switching to UP code
[ 0.009884] ACPI: Core revision 20110623
[ 0.016077] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.016509] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.058899] CPU0: Intel(R) Celeron(R) M CPU 440 @ 1.86GHz stepping 0c
[ 0.060003] Performance Events: Core events, core PMU driver.
[ 0.060003] ... version: 1
[ 0.060003] ... bit width: 40
[ 0.060003] ... generic registers: 2
[ 0.060003] ... value mask: 000000ffffffffff
[ 0.060003] ... max period: 000000007fffffff
[ 0.060003] ... fixed-purpose events: 0
[ 0.060003] ... event mask: 0000000000000003
[ 0.060003] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.060003] Brought up 1 CPUs
[ 0.060003] Total of 1 processors activated (3733.95 BogoMIPS).
[ 0.060003] devtmpfs: initialized
[ 0.060003] PM: Registering ACPI NVS region at 37fde000 (139264 bytes)
[ 0.060003] print_constraints: dummy:
[ 0.060003] NET: Registered protocol family 16
[ 0.060003] ACPI: bus type pci registered
[ 0.060003] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.060003] PCI: not using MMCONFIG
[ 0.060003] PCI : PCI BIOS aera is rw and x. Use pci=nobios if you want it NX.
[ 0.060003] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=3
[ 0.060003] PCI: Using configuration type 1 for base access
[ 0.060003] bio: create slab <bio-0> at 0
[ 0.060003] ACPI: Added _OSI(Module Device)
[ 0.060003] ACPI: Added _OSI(Processor Device)
[ 0.060003] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.060003] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.060379] ACPI: EC: Look up EC in DSDT
[ 0.061837] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.064654] ACPI: Interpreter enabled
[ 0.064675] ACPI: (supports S0 S3 S4 S5)
[ 0.064700] ACPI: Using IOAPIC for interrupt routing
[ 0.064785] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.065892] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.065895] PCI: Using MMCONFIG for extended config space
[ 0.071809] ACPI: EC: GPE = 0x18, I/O: command/status = 0x66, data = 0x62
[ 0.071962] ACPI: No dock devices found.
[ 0.071965] HEST: Table not found.
[ 0.071973] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.072067] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.072236] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.072240] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.072244] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.072247] pci_root PNP0A03:00: host bridge window [mem 0x000d0000-0x000dffff] (ignored)
[ 0.072251] pci_root PNP0A03:00: host bridge window [mem 0x38000000-0xffffffff] (ignored)
[ 0.072266] pci 0000:00:00.0: [1002:5a31] type 0 class 0x000600
[ 0.072289] pci 0000:00:00.0: reg 1c: [mem 0xe0000000-0xffffffff 64bit]
[ 0.072318] pci 0000:00:01.0: [1002:5a3f] type 1 class 0x000604
[ 0.072406] pci 0000:00:13.0: [1002:4374] type 0 class 0x000c03
[ 0.072429] pci 0000:00:13.0: reg 10: [mem 0xfebff000-0xfebfffff]
[ 0.072538] pci 0000:00:13.1: [1002:4375] type 0 class 0x000c03
[ 0.072561] pci 0000:00:13.1: reg 10: [mem 0xfebfe000-0xfebfefff]
[ 0.072676] pci 0000:00:13.2: [1002:4373] type 0 class 0x000c03
[ 0.072704] pci 0000:00:13.2: reg 10: [mem 0xfebfd000-0xfebfdfff]
[ 0.072829] pci 0000:00:13.2: supports D1 D2
[ 0.072832] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[ 0.072868] pci 0000:00:14.0: [1002:4372] type 0 class 0x000c05
[ 0.072888] pci 0000:00:14.0: reg 10: [io 0x0b00-0x0b0f]
[ 0.072903] pci 0000:00:14.0: reg 14: [mem 0x00000000-0x000003ff]
[ 0.072975] HPET not enabled in BIOS. You might try hpet=force boot option
[ 0.073007] pci 0000:00:14.1: [1002:4376] type 0 class 0x000101
[ 0.073035] pci 0000:00:14.1: reg 10: [io 0x01f0-0x01f7]
[ 0.073051] pci 0000:00:14.1: reg 14: [io 0x03f4-0x03f7]
[ 0.073067] pci 0000:00:14.1: reg 18: [io 0x0170-0x0177]
[ 0.073083] pci 0000:00:14.1: reg 1c: [io 0x0374-0x0377]
[ 0.073099] pci 0000:00:14.1: reg 20: [io 0xff00-0xff0f]
[ 0.073203] pci 0000:00:14.2: [1002:437b] type 0 class 0x000403
[ 0.073243] pci 0000:00:14.2: reg 10: [mem 0xfebf8000-0xfebfbfff 64bit]
[ 0.073373] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[ 0.073403] pci 0000:00:14.3: [1002:4377] type 0 class 0x000601
[ 0.073529] pci 0000:00:14.4: [1002:4371] type 1 class 0x000604
[ 0.073648] pci 0000:01:05.0: [1002:5a62] type 0 class 0x000300
[ 0.073663] pci 0000:01:05.0: reg 10: [mem 0xc0000000-0xcfffffff pref]
[ 0.073672] pci 0000:01:05.0: reg 14: [io 0x9800-0x98ff]
[ 0.073680] pci 0000:01:05.0: reg 18: [mem 0xfe1f0000-0xfe1fffff]
[ 0.073704] pci 0000:01:05.0: reg 30: [mem 0xfe1c0000-0xfe1dffff pref]
[ 0.073730] pci 0000:01:05.0: supports D1 D2
[ 0.073757] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.073763] pci 0000:00:01.0: bridge window [io 0x9000-0x9fff]
[ 0.073767] pci 0000:00:01.0: bridge window [mem 0xfe100000-0xfe1fffff]
[ 0.073772] pci 0000:00:01.0: bridge window [mem 0xbdf00000-0xddefffff pref]
[ 0.073812] pci 0000:02:00.0: [10ec:8139] type 0 class 0x000200
[ 0.073845] pci 0000:02:00.0: reg 10: [io 0xb800-0xb8ff]
[ 0.073864] pci 0000:02:00.0: reg 14: [mem 0xfeaffc00-0xfeaffcff]
[ 0.073997] pci 0000:02:00.0: supports D1 D2
[ 0.074000] pci 0000:02:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.074037] pci 0000:02:01.0: [1180:0476] type 2 class 0x000607
[ 0.074072] pci 0000:02:01.0: reg 10: [mem 0x00000000-0x00000fff]
[ 0.074125] pci 0000:02:01.0: supports D1 D2
[ 0.074128] pci 0000:02:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.074164] pci 0000:02:01.1: [1180:0822] type 0 class 0x000805
[ 0.074196] pci 0000:02:01.1: reg 10: [mem 0xfeaff800-0xfeaff8ff]
[ 0.074343] pci 0000:02:01.1: supports D1 D2
[ 0.074346] pci 0000:02:01.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.074382] pci 0000:02:01.2: [1180:0592] type 0 class 0x000880
[ 0.074415] pci 0000:02:01.2: reg 10: [mem 0xfeaff400-0xfeaff4ff]
[ 0.074561] pci 0000:02:01.2: supports D1 D2
[ 0.074564] pci 0000:02:01.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.074662] pci 0000:00:14.4: PCI bridge to [bus 02-03] (subtractive decode)
[ 0.074673] pci 0000:00:14.4: bridge window [io 0xa000-0xbfff]
[ 0.074680] pci 0000:00:14.4: bridge window [mem 0xfe200000-0xfeafffff]
[ 0.074687] pci 0000:00:14.4: bridge window [mem 0xddf00000-0xdfefffff pref]
[ 0.074690] pci 0000:00:14.4: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.074694] pci 0000:00:14.4: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.074760] pci_bus 0000:03: [bus 03-06] partially hidden behind transparent bridge 0000:02 [bus 02-03]
[ 0.074778] pci_bus 0000:00: on NUMA node 0
[ 0.074783] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.074859] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.074931] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT]
[ 0.075063] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.075067] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[ 0.075070] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.079084] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.079143] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.079199] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.079255] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.079310] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.079364] ACPI: PCI Interrupt Link [LNKF] (IRQs 9) *0, disabled.
[ 0.079416] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.079471] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.079608] vgaarb: device added: PCI:0000:01:05.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.079613] vgaarb: loaded
[ 0.079615] vgaarb: bridge control possible 0000:01:05.0
[ 0.079668] PCI: Using ACPI for IRQ routing
[ 0.079672] PCI: pci_cache_line_size set to 64 bytes
[ 0.079682] pci 0000:00:00.0: address space collision: [mem 0xe0000000-0xffffffff 64bit] conflicts with PCI Bus 0000:01 [mem 0xfe100000-0xfe1fffff]
[ 0.079759] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.079762] reserve RAM buffer: 0000000037fd0000 - 0000000037ffffff
[ 0.082201] pnp: PnP ACPI init
[ 0.082227] ACPI: bus type pnp registered
[ 0.082370] pnp 00:00: [bus 00-ff]
[ 0.082374] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.082377] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.082380] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.082383] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.082386] pnp 00:00: [mem 0x000d0000-0x000dffff window]
[ 0.082389] pnp 00:00: [mem 0x38000000-0xffffffff window]
[ 0.082465] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.082513] pnp 00:01: [dma 4]
[ 0.082515] pnp 00:01: [io 0x0000-0x000f]
[ 0.082518] pnp 00:01: [io 0x0081-0x0083]
[ 0.082520] pnp 00:01: [io 0x0087]
[ 0.082523] pnp 00:01: [io 0x0089-0x008b]
[ 0.082525] pnp 00:01: [io 0x008f]
[ 0.082528] pnp 00:01: [io 0x00c0-0x00df]
[ 0.082564] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.082577] pnp 00:02: [io 0x0070-0x0071]
[ 0.082595] pnp 00:02: [irq 8]
[ 0.082636] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.082648] pnp 00:03: [io 0x0061]
[ 0.082683] pnp 00:03: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.082694] pnp 00:04: [io 0x00f0-0x00ff]
[ 0.082700] pnp 00:04: [irq 13]
[ 0.082738] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.082816] pnp 00:05: [io 0x0000-0xffffffffffffffff disabled]
[ 0.082820] pnp 00:05: [io 0x0500-0x053f]
[ 0.082884] system 00:05: [io 0x0500-0x053f] has been reserved
[ 0.082888] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.083067] pnp 00:06: [io 0x0010-0x001f]
[ 0.083070] pnp 00:06: [io 0x0022-0x003f]
[ 0.083073] pnp 00:06: [io 0x0063]
[ 0.083075] pnp 00:06: [io 0x0065]
[ 0.083077] pnp 00:06: [io 0x0067-0x006f]
[ 0.083080] pnp 00:06: [io 0x0072-0x007f]
[ 0.083082] pnp 00:06: [io 0x0080]
[ 0.083085] pnp 00:06: [io 0x0084-0x0086]
[ 0.083087] pnp 00:06: [io 0x0088]
[ 0.083090] pnp 00:06: [io 0x008c-0x008e]
[ 0.083092] pnp 00:06: [io 0x0090-0x009f]
[ 0.083095] pnp 00:06: [io 0x00a2-0x00bf]
[ 0.083097] pnp 00:06: [io 0x00b1]
[ 0.083100] pnp 00:06: [io 0x00e0-0x00ef]
[ 0.083102] pnp 00:06: [io 0x04d0-0x04d1]
[ 0.083105] pnp 00:06: [io 0x040b]
[ 0.083107] pnp 00:06: [io 0x04d6]
[ 0.083109] pnp 00:06: [io 0x0c00-0x0c01]
[ 0.083112] pnp 00:06: [io 0x0c14]
[ 0.083114] pnp 00:06: [io 0x0c50-0x0c51]
[ 0.083117] pnp 00:06: [io 0x0c52]
[ 0.083119] pnp 00:06: [io 0x0c6c]
[ 0.083122] pnp 00:06: [io 0x0c6f]
[ 0.083124] pnp 00:06: [io 0x0cd4-0x0cd5]
[ 0.083127] pnp 00:06: [io 0x0cd6-0x0cd7]
[ 0.083129] pnp 00:06: [io 0x0cd8-0x0cdf]
[ 0.083132] pnp 00:06: [io 0x0800-0x089f]
[ 0.083134] pnp 00:06: [io 0x0480-0x04bf]
[ 0.083137] pnp 00:06: [io 0x0900-0x090f]
[ 0.083141] pnp 00:06: [io 0x0910-0x091f]
[ 0.083143] pnp 00:06: [io 0x4000-0x4004]
[ 0.083146] pnp 00:06: [io 0x4005-0x40ff]
[ 0.083149] pnp 00:06: [mem 0xfff80000-0xffffffff]
[ 0.083225] system 00:06: [io 0x04d0-0x04d1] has been reserved
[ 0.083229] system 00:06: [io 0x040b] has been reserved
[ 0.083233] system 00:06: [io 0x04d6] has been reserved
[ 0.083236] system 00:06: [io 0x0c00-0x0c01] has been reserved
[ 0.083240] system 00:06: [io 0x0c14] has been reserved
[ 0.083243] system 00:06: [io 0x0c50-0x0c51] has been reserved
[ 0.083247] system 00:06: [io 0x0c52] has been reserved
[ 0.083250] system 00:06: [io 0x0c6c] has been reserved
[ 0.083254] system 00:06: [io 0x0c6f] has been reserved
[ 0.083257] system 00:06: [io 0x0cd4-0x0cd5] has been reserved
[ 0.083261] system 00:06: [io 0x0cd6-0x0cd7] has been reserved
[ 0.083264] system 00:06: [io 0x0cd8-0x0cdf] has been reserved
[ 0.083268] system 00:06: [io 0x0800-0x089f] has been reserved
[ 0.083271] system 00:06: [io 0x0480-0x04bf] has been reserved
[ 0.083275] system 00:06: [io 0x0900-0x090f] has been reserved
[ 0.083278] system 00:06: [io 0x0910-0x091f] has been reserved
[ 0.083282] system 00:06: [io 0x4000-0x4004] has been reserved
[ 0.083286] system 00:06: [io 0x4005-0x40ff] has been reserved
[ 0.083290] system 00:06: [mem 0xfff80000-0xffffffff] has been reserved
[ 0.083294] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.083331] pnp 00:07: [io 0x0060]
[ 0.083334] pnp 00:07: [io 0x0064]
[ 0.083341] pnp 00:07: [irq 1]
[ 0.083389] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.083445] pnp 00:08: [irq 12]
[ 0.083486] pnp 00:08: Plug and Play ACPI device, IDs SYN0a06 SYN0a00 SYN0002 PNP0f03 PNP0f13 PNP0f12 (active)
[ 0.083545] pnp 00:09: [mem 0xfec00000-0xfec00fff]
[ 0.083548] pnp 00:09: [mem 0xfee00000-0xfee00fff]
[ 0.083551] pnp 00:09: [io 0x0250-0x025f]
[ 0.083604] system 00:09: [io 0x0250-0x025f] has been reserved
[ 0.083608] system 00:09: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.083612] system 00:09: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.083615] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.083665] pnp 00:0a: [mem 0xe0000000-0xefffffff]
[ 0.083718] system 00:0a: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.083722] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.083904] pnp 00:0b: [mem 0x00000000-0x0009ffff]
[ 0.083908] pnp 00:0b: [mem 0x000c0000-0x000cffff]
[ 0.083911] pnp 00:0b: [mem 0x000e0000-0x000fffff]
[ 0.083913] pnp 00:0b: [mem 0x00100000-0x37ffffff]
[ 0.083916] pnp 00:0b: [mem 0x00000000-0xffffffffffffffff disabled]
[ 0.083924] pnp 00:0b: disabling [mem 0x00000000-0x0009ffff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
[ 0.083929] pnp 00:0b: disabling [mem 0x000c0000-0x000cffff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
[ 0.083933] pnp 00:0b: disabling [mem 0x000e0000-0x000fffff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
[ 0.083938] pnp 00:0b: disabling [mem 0x00100000-0x37ffffff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
[ 0.084022] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.084165] pnp: PnP ACPI: found 12 devices
[ 0.084168] ACPI: ACPI bus type pnp unregistered
[ 0.084173] PnPBIOS: Disabled by ACPI PNP
[ 0.121031] Switching to clocksource acpi_pm
[ 0.121057] PCI: max bus depth: 2 pci_try_num: 3
[ 0.121092] pci 0000:00:14.0: BAR 1: assigned [mem 0x38000000-0x380003ff]
[ 0.121101] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.121105] pci 0000:00:01.0: bridge window [io 0x9000-0x9fff]
[ 0.121110] pci 0000:00:01.0: bridge window [mem 0xfe100000-0xfe1fffff]
[ 0.121115] pci 0000:00:01.0: bridge window [mem 0xbdf00000-0xddefffff pref]
[ 0.121125] pci 0000:02:01.0: BAR 0: assigned [mem 0x3c000000-0x3c000fff]
[ 0.121135] pci 0000:02:01.0: BAR 16: assigned [mem 0x40000000-0x43ffffff]
[ 0.121141] pci 0000:02:01.0: BAR 15: assigned [mem 0x44000000-0x47ffffff pref]
[ 0.121145] pci 0000:02:01.0: BAR 14: assigned [io 0xa000-0xa0ff]
[ 0.121148] pci 0000:02:01.0: BAR 13: assigned [io 0xa400-0xa4ff]
[ 0.121151] pci 0000:02:01.0: CardBus bridge to [bus 03-06]
[ 0.121154] pci 0000:02:01.0: bridge window [io 0xa400-0xa4ff]
[ 0.121161] pci 0000:02:01.0: bridge window [io 0xa000-0xa0ff]
[ 0.121169] pci 0000:02:01.0: bridge window [mem 0x44000000-0x47ffffff pref]
[ 0.121176] pci 0000:02:01.0: bridge window [mem 0x40000000-0x43ffffff]
[ 0.121184] pci 0000:00:14.4: PCI bridge to [bus 02-03]
[ 0.121188] pci 0000:00:14.4: bridge window [io 0xa000-0xbfff]
[ 0.121197] pci 0000:00:14.4: bridge window [mem 0xfe200000-0xfeafffff]
[ 0.121203] pci 0000:00:14.4: bridge window [mem 0xddf00000-0xdfefffff pref]
[ 0.121259] pci_bus 0000:00: resource 0 [io 0x0000-0xffff]
[ 0.121262] pci_bus 0000:00: resource 1 [mem 0x00000000-0xffffffff]
[ 0.121265] pci_bus 0000:01: resource 0 [io 0x9000-0x9fff]
[ 0.121268] pci_bus 0000:01: resource 1 [mem 0xfe100000-0xfe1fffff]
[ 0.121271] pci_bus 0000:01: resource 2 [mem 0xbdf00000-0xddefffff pref]
[ 0.121275] pci_bus 0000:02: resource 0 [io 0xa000-0xbfff]
[ 0.121278] pci_bus 0000:02: resource 1 [mem 0xfe200000-0xfeafffff]
[ 0.121281] pci_bus 0000:02: resource 2 [mem 0xddf00000-0xdfefffff pref]
[ 0.121284] pci_bus 0000:02: resource 4 [io 0x0000-0xffff]
[ 0.121287] pci_bus 0000:02: resource 5 [mem 0x00000000-0xffffffff]
[ 0.121290] pci_bus 0000:03: resource 0 [io 0xa400-0xa4ff]
[ 0.121293] pci_bus 0000:03: resource 1 [io 0xa000-0xa0ff]
[ 0.121296] pci_bus 0000:03: resource 2 [mem 0x44000000-0x47ffffff pref]
[ 0.121300] pci_bus 0000:03: resource 3 [mem 0x40000000-0x43ffffff]
[ 0.121365] NET: Registered protocol family 2
[ 0.123319] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.123734] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.125326] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.126373] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.126378] TCP reno registered
[ 0.126386] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.126422] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.126669] NET: Registered protocol family 1
[ 0.126699] pci 0000:00:01.0: MSI quirk detected; subordinate MSI disabled
[ 0.288089] pci 0000:01:05.0: Boot video device
[ 0.288110] PCI: CLS 64 bytes, default 64
[ 0.288218] Unpacking initramfs...
[ 0.650394] Freeing initrd memory: 9932k freed
[ 0.673864] Simple Boot Flag at 0xff set to 0x1
[ 0.674520] audit: initializing netlink socket (disabled)
[ 0.674541] type=2000 audit(1422106444.671:1): initialized
[ 0.693658] highmem bounce pool size: 64 pages
[ 0.693666] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.694454] VFS: Disk quotas dquot_6.5.2
[ 0.694493] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.694581] msgmni has been set to 1753
[ 0.694795] alg: No test for stdrng (krng)
[ 0.694830] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.694836] io scheduler noop registered
[ 0.694838] io scheduler deadline registered
[ 0.694848] io scheduler cfq registered (default)
[ 0.694977] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.695002] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.695005] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.695375] intel_idle: does not run on family 6 model 14
[ 0.695417] ERST: Table is not found!
[ 0.695419] GHES: HEST is not enabled!
[ 0.695435] isapnp: Scanning for PnP cards...
[ 1.049989] isapnp: No Plug & Play device found
[ 1.050072] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.050630] Linux agpgart interface v0.103
[ 1.050874] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.053000] i8042: Detected active multiplexing controller, rev 1.1
[ 1.054397] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.054406] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.054444] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.054475] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.054509] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.054647] mousedev: PS/2 mouse device common for all mice
[ 1.054725] rtc_cmos 00:02: RTC can wake from S4
[ 1.054855] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 1.054887] rtc0: alarms up to one month, 114 bytes nvram
[ 1.054906] cpuidle: using governor ladder
[ 1.054908] cpuidle: using governor menu
[ 1.055149] TCP cubic registered
[ 1.055179] NET: Registered protocol family 10
[ 1.055729] Mobile IPv6
[ 1.055733] NET: Registered protocol family 17
[ 1.055738] Registering the dns_resolver key type
[ 1.055766] Using IPI No-Shortcut mode
[ 1.055874] PM: Hibernation image not present or could not be loaded.
[ 1.055887] registered taskstats version 1
[ 1.056353] rtc_cmos 00:02: setting system clock to 2015-01-24 13:34:05 UTC (1422106445)
[ 1.056399] Initializing network drop monitor service
[ 1.056560] Freeing unused kernel memory: 420k freed
[ 1.056907] Write protecting the kernel text: 2860k
[ 1.056944] Write protecting the kernel read-only data: 1084k
[ 1.056946] NX-protecting the kernel data: 3284k
[ 1.073286] udevd[44]: starting version 175
[ 1.087860] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.143135] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 1.143169] 8139cp 0000:02:00.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
[ 1.143621] 8139too: 8139too Fast Ethernet driver 0.9.28
[ 1.150758] sdhci: Secure Digital Host Controller Interface driver
[ 1.150762] sdhci: Copyright(c) Pierre Ossman
[ 1.158767] usbcore: registered new interface driver usbfs
[ 1.158801] usbcore: registered new interface driver hub
[ 1.193731] usbcore: registered new device driver usb
[ 1.194288] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.194364] ehci_hcd 0000:00:13.2: EHCI Host Controller
[ 1.194400] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 1
[ 1.194477] ehci_hcd 0000:00:13.2: irq 19, io mem 0xfebfd000
[ 1.197631] 8139too 0000:02:00.0: eth0: RealTek RTL8139 at 0xb800, 00:18:f3:33:40:06, IRQ 20
[ 1.199159] SCSI subsystem initialized
[ 1.200112] sdhci-pci 0000:02:01.1: SDHCI controller found [1180:0822] (rev 13)
[ 1.201193] sdhci-pci 0000:02:01.1: Will use DMA mode even though HW doesn't fully claim to support it.
[ 1.201229] mmc0: no vmmc regulator found
[ 1.202275] Registered led device: mmc0::
[ 1.207032] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 1.207129] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.207132] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.207136] usb usb1: Product: EHCI Host Controller
[ 1.207139] usb usb1: Manufacturer: Linux 3.2.0-4-686-pae ehci_hcd
[ 1.207141] usb usb1: SerialNumber: 0000:00:13.2
[ 1.207309] hub 1-0:1.0: USB hub found
[ 1.207316] hub 1-0:1.0: 8 ports detected
[ 1.207932] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.207995] ohci_hcd 0000:00:13.0: OHCI Host Controller
[ 1.223866] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 2
[ 1.223901] ohci_hcd 0000:00:13.0: irq 19, io mem 0xfebff000
[ 1.256851] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.256855] ACPI: Thermal Zone [THRM] (83 C)
[ 1.269394] mmc0: SDHCI controller on PCI [0000:02:01.1] using DMA
[ 1.282305] libata version 3.00 loaded.
[ 1.304748] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.304753] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.304756] usb usb2: Product: OHCI Host Controller
[ 1.304759] usb usb2: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 1.304762] usb usb2: SerialNumber: 0000:00:13.0
[ 1.305207] hub 2-0:1.0: USB hub found
[ 1.305218] hub 2-0:1.0: 4 ports detected
[ 1.305389] pata_atiixp 0000:00:14.1: setting latency timer to 64
[ 1.310042] scsi0 : pata_atiixp
[ 1.315059] scsi1 : pata_atiixp
[ 1.315938] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xff00 irq 14
[ 1.315942] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xff08 irq 15
[ 1.316156] ohci_hcd 0000:00:13.1: OHCI Host Controller
[ 1.316171] ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 3
[ 1.316201] ohci_hcd 0000:00:13.1: irq 19, io mem 0xfebfe000
[ 1.376091] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.376096] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.376100] usb usb3: Product: OHCI Host Controller
[ 1.376103] usb usb3: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 1.376105] usb usb3: SerialNumber: 0000:00:13.1
[ 1.376397] hub 3-0:1.0: USB hub found
[ 1.376408] hub 3-0:1.0: 4 ports detected
[ 1.488639] ata2.00: ATA-6: HTS541080G9AT00, MB4OA60A, max UDMA/100
[ 1.488644] ata2.00: 156301488 sectors, multi 16: LBA48
[ 1.505200] ata1.01: ATAPI: TSSTcorpCD/DVDW TS-L632D, AS05, max UDMA/33
[ 1.505299] ata2.00: configured for UDMA/100
[ 1.516026] usb 1-6: new high-speed USB device number 2 using ehci_hcd
[ 1.536599] ata1.01: configured for UDMA/33
[ 1.552953] scsi 0:0:1:0: CD-ROM TSSTcorp CD/DVDW TS-L632D AS05 PQ: 0 ANSI: 5
[ 1.553349] scsi 1:0:0:0: Direct-Access ATA HTS541080G9AT00 MB4O PQ: 0 ANSI: 5
[ 1.596269] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.596275] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.596722] sr 0:0:1:0: Attached scsi CD-ROM sr0
[ 1.597189] sd 1:0:0:0: [sda] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 1.597251] sd 1:0:0:0: [sda] Write Protect is off
[ 1.597255] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.597283] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.644848] sda: sda1 sda2 < sda5 >
[ 1.645352] sd 1:0:0:0: [sda] Attached SCSI disk
[ 1.649207] usb 1-6: New USB device found, idVendor=0b05, idProduct=171b
[ 1.649212] usb 1-6: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[ 1.649216] usb 1-6: Product: USB2.0 WLAN
[ 1.649218] usb 1-6: Manufacturer: ASUS
[ 1.653638] sr 0:0:1:0: Attached scsi generic sg0 type 5
[ 1.653739] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 1.692030] Refined TSC clocksource calibration: 1866.732 MHz.
[ 1.692039] Switching to clocksource tsc
[ 1.934293] PM: Starting manual resume from disk
[ 1.934299] PM: Hibernation image partition 8:5 present
[ 1.934301] PM: Looking for hibernation image.
[ 1.934585] PM: Image not found (code -22)
[ 1.934588] PM: Hibernation image not present or could not be loaded.
[ 1.986000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.438974] udevd[308]: starting version 175
[ 5.155951] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 5.155963] ACPI: Power Button [PWRB]
[ 5.156091] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 5.156096] ACPI: Sleep Button [SLPB]
[ 5.156165] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input3
[ 5.158089] ACPI: Lid Switch [LID]
[ 5.158183] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 5.158190] ACPI: Power Button [PWRF]
[ 5.317457] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 5.376390] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 5.612790] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 5.613463] ACPI: AC Adapter [AC0] (on-line)
[ 5.697263] [drm] Initialized drm 1.1.0 20060810
[ 5.744080] Marking TSC unstable due to TSC halts in idle
[ 5.744101] ACPI: acpi_idle registered with cpuidle
[ 5.746353] Switching to clocksource acpi_pm
[ 5.828648] ACPI: Battery Slot [BAT0] (battery absent)
[ 5.833660] acpi device:02: registered as cooling_device1
[ 5.833805] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:00/LNXVIDEO:00/input/input6
[ 5.833915] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 6.025272] yenta_cardbus 0000:02:01.0: CardBus bridge found [1043:13d7]
[ 6.095150] asus_laptop: Asus Laptop Support version 0.42
[ 6.095295] asus_laptop: BSTS called, 0x7f returned
[ 6.095311] asus_laptop: A9Rp model detected
[ 6.095425] asus_laptop: Backlight controlled by ACPI video driver
[ 6.095504] input: Asus Laptop extra buttons as /devices/platform/asus_laptop/input/input7
[ 6.096916] Registered led device: asus::mail
[ 6.127318] [drm] radeon kernel modesetting enabled.
[ 6.127758] [drm] initializing kernel modesetting (RS400 0x1002:0x5A62 0x1043:0x1392).
[ 6.127780] [drm] register mmio base: 0xFE1F0000
[ 6.127782] [drm] register mmio size: 65536
[ 6.127940] [drm] Generation 2 PCI interface, using max accessible memory
[ 6.127947] radeon 0000:01:05.0: VRAM: 128M 0x0000000038000000 - 0x000000003FFFFFFF (128M used)
[ 6.127951] radeon 0000:01:05.0: GTT: 512M 0x0000000040000000 - 0x000000005FFFFFFF
[ 6.128546] [drm] Detected VRAM RAM=128M, BAR=256M
[ 6.128550] [drm] RAM width 128bits DDR
[ 6.128637] [TTM] Zone kernel: Available graphics memory: 448990 kiB
[ 6.128640] [TTM] Zone highmem: Available graphics memory: 451970 kiB
[ 6.128642] [TTM] Initializing pool allocator
[ 6.128650] [TTM] Initializing DMA pool allocator
[ 6.128689] [drm] radeon: 128M of VRAM memory ready
[ 6.128692] [drm] radeon: 512M of GTT memory ready.
[ 6.128718] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 6.154217] yenta_cardbus 0000:02:01.0: ISA IRQ mask 0x0cb8, PCI irq 16
[ 6.154223] yenta_cardbus 0000:02:01.0: Socket status: 30000006
[ 6.154228] pci_bus 0000:02: Raising subordinate bus# of parent bus (#02) from #03 to #06
[ 6.154243] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge window: [io 0xa000-0xbfff]
[ 6.154247] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa000-0xbfff: excluding 0xa000-0xa0ff 0xa400-0xa4ff
[ 6.160056] [drm] radeon: ib pool ready.
[ 6.160145] [drm] radeon: 1 quad pipes, 1 z pipes initialized.
[ 6.166179] [drm] PCIE GART of 512M enabled (table at 0x0000000034980000).
[ 6.170965] radeon 0000:01:05.0: WB enabled
[ 6.170970] [drm] fence driver on ring 0 use gpu addr 0x40000000 and cpu addr 0xf4ea2000
[ 6.170976] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 6.170979] [drm] Driver supports precise vblank timestamp query.
[ 6.170996] [drm] radeon: irq initialized.
[ 6.171702] [drm] Loading R300 Microcode
[ 6.177602] 0xb800-0xb8ff
[ 6.181674] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge window: [mem 0xfe200000-0xfeafffff]
[ 6.181679] pcmcia_socket pcmcia_socket0: cs: memory probe 0xfe200000-0xfeafffff: excluding 0xfea70000-0xfeafffff
[ 6.181696] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge window: [mem 0xddf00000-0xdfefffff pref]
[ 6.181699] pcmcia_socket pcmcia_socket0: cs: memory probe 0xddf00000-0xdfefffff: excluding 0xddf00000-0xdfefffff
[ 6.217703] cfg80211: Calling CRDA to update world regulatory domain
[ 6.261316] platform radeon_cp.0: firmware: agent aborted loading radeon/R300_cp.bin (not found?)
[ 6.261568] [drm:r100_cp_init] *ERROR* Failed to load firmware!
[ 6.261620] radeon 0000:01:05.0: failed initializing CP (-2).
[ 6.261669] radeon 0000:01:05.0: Disabling GPU acceleration
[ 6.261721] [drm] radeon: cp finalized
[ 6.261755] radeon 0000:01:05.0: f4949000 unpin not necessary
[ 6.262605] [drm] Panel ID String: AUO
[ 6.262609] [drm] Panel Size 1024x768
[ 6.276597] [drm] radeon legacy LVDS backlight initialized
[ 6.276600] [drm] Radeon Display Connectors
[ 6.276603] [drm] Connector 0:
[ 6.276605] [drm] VGA
[ 6.276607] [drm] DDC: 0x68 0x68 0x68 0x68 0x68 0x68 0x68 0x68
[ 6.276610] [drm] Encoders:
[ 6.276612] [drm] CRT1: INTERNAL_DAC2
[ 6.276614] [drm] Connector 1:
[ 6.276615] [drm] LVDS
[ 6.276618] [drm] DDC: 0x198 0x198 0x19c 0x19c 0x1a0 0x1a0 0x1a4 0x1a4
[ 6.276620] [drm] Encoders:
[ 6.276622] [drm] LCD1: INTERNAL_LVDS
[ 6.285065] [drm] radeon: power management initialized
[ 6.368428] [drm] fb mappable at 0xC0040000
[ 6.368432] [drm] vram apper at 0xC0000000
[ 6.368434] [drm] size 3145728
[ 6.368436] [drm] fb depth is 24
[ 6.368438] [drm] pitch is 4096
[ 6.368587] fbcon: radeondrmfb (fb0) is primary device
[ 6.414151] r592 0000:02:01.2: setting latency timer to 64
[ 6.415176] r592: driver successfully loaded
[ 6.422991] Console: switching to colour frame buffer device 128x48
[ 6.427682] fb0: radeondrmfb frame buffer device
[ 6.427684] drm: registered panic notifier
[ 6.427960] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:05.0 on minor 0
[ 6.520944] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: excluding 0x170-0x177 0x1f0-0x1f7 0x250-0x25f 0x370-0x377
[ 6.523424] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: excluding 0x3f0-0x3f7 0x408-0x40f 0x480-0x4bf 0x4d0-0x4d7
[ 6.524235] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: excluding 0x820-0x89f
[ 6.524630] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: excluding 0xc00-0xc07 0xc10-0xc17 0xc50-0xc57 0xc68-0xc6f 0xcd0-0xcdf
[ 6.525427] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff: excluding 0xc0000-0xcffff 0xe0000-0xfffff
[ 6.525463] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: clean.
[ 6.525498] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff: clean.
[ 6.525532] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 6.549505] input: PS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input8
[ 6.812936] snd_hda_intel 0000:00:14.2: irq 40 for MSI/MSI-X
[ 6.968043] usb 1-6: reset high-speed USB device number 2 using ehci_hcd
[ 6.993560] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:14.2/input/input9
[ 7.134560] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 7.135187] zd1211rw 1-6:1.0: phy0
[ 7.135215] usbcore: registered new interface driver zd1211rw
[ 7.676932] cfg80211: World regulatory domain updated:
[ 7.676938] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 7.676942] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 7.676945] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 7.676948] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 7.676951] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 7.676954] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 7.676958] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 7.676961] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 7.676964] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 9.348526] Adding 1830908k swap on /dev/sda5. Priority:-1 extents:1 across:1830908k
[ 9.366690] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 9.622919] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 9.814496] loop: module loaded
[ 11.714070] RPC: Registered named UNIX socket transport module.
[ 11.714075] RPC: Registered udp transport module.
[ 11.714077] RPC: Registered tcp transport module.
[ 11.714079] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 11.772703] FS-Cache: Loaded
[ 11.832812] FS-Cache: Netfs 'nfs' registered for caching
[ 11.862053] Installing knfsd (copyright (C) 1996 [EMAIL="okir@monad.swb.de"]okir@monad.swb.de[/EMAIL]).
[ 13.842288] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input10
[ 15.567904] Bluetooth: Core ver 2.16
[ 15.567949] NET: Registered protocol family 31
[ 15.567952] Bluetooth: HCI device and connection manager initialized
[ 15.567956] Bluetooth: HCI socket layer initialized
[ 15.567959] Bluetooth: L2CAP socket layer initialized
[ 15.568703] Bluetooth: SCO socket layer initialized
[ 15.596068] Bluetooth: RFCOMM TTY layer initialized
[ 15.596075] Bluetooth: RFCOMM socket layer initialized
[ 15.596078] Bluetooth: RFCOMM ver 1.11
[ 15.597614] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.597619] Bluetooth: BNEP filters: protocol multicast
[ 15.884315] lp: driver loaded but no devices found
[ 16.015833] ppdev: user-space parallel port driver
[ 19.567022] 8139too 0000:02:00.0: eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 30.200106] eth0: no IPv6 routers present
[ 3333.048197] ata1.01: qc timeout (cmd 0xa0)
[ 3333.048209] ata1.01: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[ 3333.048216] sr 0:0:1:0: CDB: Test Unit Ready: 00 00 00 00 00 00
[ 3333.048229] ata1.01: cmd a0/00:00:00:00:00/00:00:00:00:00/b0 tag 0
[ 3333.048231] res 51/20:03:00:00:00/00:00:00:00:00/b0 Emask 0x5 (timeout)
[ 3333.048235] ata1.01: status: { DRDY ERR }
[ 3338.088065] ata1: link is slow to respond, please be patient (ready=0)
[ 3343.072064] ata1: device not ready (errno=-16), forcing hardreset
[ 3343.072079] ata1: soft resetting link
[ 3343.292569] ata1.01: configured for UDMA/33
[ 3343.300469] ata1: EH complete
[ 3383.008097] ata1.01: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[ 3383.008107] sr 0:0:1:0: CDB: Get event status notification: 4a 01 00 00 10 00 00 00 08 00
[ 3383.008123] ata1.01: cmd a0/00:00:00:08:00/00:00:00:00:00/b0 tag 0 pio 16392 in
[ 3383.008125] res 40/00:03:00:00:00/00:00:00:00:00/b0 Emask 0x4 (timeout)
[ 3383.008128] ata1.01: status: { DRDY }
[ 3388.048053] ata1: link is slow to respond, please be patient (ready=0)
[ 3393.032054] ata1: device not ready (errno=-16), forcing hardreset
[ 3393.032069] ata1: soft resetting link
[ 3393.244573] ata1.01: configured for UDMA/33
[ 3393.245461] ata1: EH complete
[ 5741.032186] ata1.01: qc timeout (cmd 0xa0)
[ 5741.032198] ata1.01: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[ 5741.032206] sr 0:0:1:0: CDB: Test Unit Ready: 00 00 00 00 00 00
[ 5741.032219] ata1.01: cmd a0/00:00:00:00:00/00:00:00:00:00/b0 tag 0
[ 5741.032220] res 51/20:03:00:00:00/00:00:00:00:00/b0 Emask 0x5 (timeout)
[ 5741.032224] ata1.01: status: { DRDY ERR }
[ 5746.072038] ata1: link is slow to respond, please be patient (ready=0)
[ 5751.056214] ata1: device not ready (errno=-16), forcing hardreset
[ 5751.056228] ata1: soft resetting link
[ 5751.284545] ata1.01: configured for UDMA/33
[ 5751.285109] ata1: EH complete
[ 6327.024185] ata1.01: qc timeout (cmd 0xa0)
[ 6327.024197] ata1.01: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[ 6327.024205] sr 0:0:1:0: CDB: Test Unit Ready: 00 00 00 00 00 00
[ 6327.024218] ata1.01: cmd a0/00:00:00:00:00/00:00:00:00:00/b0 tag 0
[ 6327.024220] res 51/20:03:00:00:00/00:00:00:00:00/b0 Emask 0x5 (timeout)
[ 6327.024223] ata1.01: status: { DRDY ERR }
[ 6332.064042] ata1: link is slow to respond, please be patient (ready=0)
[ 6337.048059] ata1: device not ready (errno=-16), forcing hardreset
[ 6337.048073] ata1: soft resetting link
[ 6337.260551] ata1.01: configured for UDMA/33
[ 6337.268448] ata1: EH complete
[ 7871.032223] ata1.01: qc timeout (cmd 0xa0)
[ 7871.032236] ata1.01: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[ 7871.032245] sr 0:0:1:0: CDB: Test Unit Ready: 00 00 00 00 00 00
[ 7871.032259] ata1.01: cmd a0/00:00:00:00:00/00:00:00:00:00/b0 tag 0
[ 7871.032260] res 51/20:03:00:00:00/00:00:00:00:00/b0 Emask 0x5 (timeout)
[ 7871.032264] ata1.01: status: { DRDY ERR }
[ 7876.072043] ata1: link is slow to respond, please be patient (ready=0)
[ 7881.056045] ata1: device not ready (errno=-16), forcing hardreset
[ 7881.056060] ata1: soft resetting link
[ 7881.276558] ata1.01: configured for UDMA/33
[ 7881.277418] ata1: EH complete
[ 7889.024460] ata1.01: qc timeout (cmd 0xa0)
[ 7889.024472] ata1.01: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[ 7889.024481] sr 0:0:1:0: CDB: Test Unit Ready: 00 00 00 00 00 00
[ 7889.024494] ata1.01: cmd a0/00:00:00:00:00/00:00:00:00:00/b0 tag 0
[ 7889.024495] res 51/20:03:00:00:00/00:00:00:00:00/b0 Emask 0x5 (timeout)
[ 7889.024499] ata1.01: status: { DRDY ERR }
[ 7894.064048] ata1: link is slow to respond, please be patient (ready=0)
[ 7899.048037] ata1: device not ready (errno=-16), forcing hardreset
[ 7899.048051] ata1: soft resetting link
[ 7899.260560] ata1.01: configured for UDMA/33
[ 7899.261115] ata1: EH complete
- marcin1982
Pokaż w takim razie jeszcze wynik:
Jak używać tagów Code dla kilometrowych logów masz w moim podpisie.
lsusb
ifconfig -a
lsusb
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 0b05:171b ASUSTek Computer, Inc. A9T wireless 802.11bg
ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:18:f3:33:40:06
inet addr:####### Bcast:###### Mask:#####
inet6 addr: fe80::218:f3ff:fe33:4006/64 Scope:Link
RX packets:53680 errors:3 dropped:3 overruns:3 frame:0
TX packets:51806 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:44296893 (42.2 MiB) TX bytes:5529511 (5.2 MiB)
Interrupt:20 Base address:0xb800
lo Link encap:Local Loopback
collisions:0 txqueuelen:0
wlan0 Link encap:Ethernet HWaddr 00:1a:92:4c:a0:25
BROADCAST MULTICAST MTU:1500 Metric:1
- marcin1982
Podpięte draństwo pod magistralę USB.
Po nitku do kłębki zajrzyj tutaj:
https://wiki.debian.org/zd1211rw .
Mam już te stery u siebie nie wiem jeszcze jak zrobić skrypt żeby ładowały się przy starcie systemu
To chodzi o te dwa wpisy tak ? czy raczej mam edytować sources.list i dodać tam ścieżkę do sterowników które ściągnąłem?
- Add a "non-free" component to /etc/apt/sources.list
Jak mam dodać wpis do sources.list ?Kod: Zaznacz cały
# Debian 7 "Wheezy" deb http://http.debian.net/debian/ wheezy main contrib non-free
apt-get update && apt-get install zd1211-firmware
- marcin1982
Nic nie masz nigdzie dodawać, podaj wynik polecenia:
cat /etc/apt/sources.list
cat /etc/debian_version
dpkg -l | grep zd1211
