Aby zobrazować zalety wynikające ze stosowania tych magicznych tagów posłużę się przykładem. Odpowiedzcie sobie na pytanie, który zapis jest dla was bardziej czytelny (przykładowy plik /etc/pacman.conf):
1. Tekst wstawiony na forum bez użycia jakiegokolwiek formatowania:
[marcin@archlinux ~]$ cat /etc/pacman.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
#CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
HoldPkg = pacman glibc
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg =
#IgnoreGroup =
# IgnorePkg = glib2
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#TotalDownload
CheckSpace
#VerbosePkgLists
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
# SigLevel = Required DatabaseOptional
SigLevel = Never
# LocalFileSigLevel = Optional
# RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Arch Linux
# packagers with `pacman-key --populate archlinux`.
# REPOSITORIES
# - can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
#[testing]
#Include = /etc/pacman.d/mirrorlist
[core]
[extra]
#[community-testing]
[community]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
#[multilib-testing]
[multilib]
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
[archlinuxfr]
SigLevel = Never
Server = http://repo.archlinux.fr/x86_64
# REPOZYTORIUM ŚRODOWISKA MATE
# [mate]
# SigLevel = Optional TrustAll
# Server = http://repo.mate-desktop.org/archlinux/$arch
# [core]
# Server = http://ftp.nluug.nl/pub/os/Linux/distr/ ... able/core/$arch
2. Tekst ujęty w tagi Code:
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir = /
#UseDelta = 0.7
Architecture = auto
#IgnorePkg =
#IgnoreGroup =
# IgnorePkg = glib2
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#TotalDownload
CheckSpace
#VerbosePkgLists
SigLevel = Never
# REPOSITORIES
# [repo-name]
#[testing]
[core]
[extra]
[community]
#[multilib-testing]
[multilib]
#[custom]
[archlinuxfr]
SigLevel = Never
Server = [URL]http://repo.archlinux.fr/x86_64[/URL]
# [mate]
# [core]
# Server = http://ftp.nluug.nl/pub/os/Linux/distr/manjaro/unstable/core/$arch
Sposób 1.
Podczas pisania postu wciskamy przycisk 'hash' # na pasku ikon okna edycji tekstu i pomiędzy znaczniki wklejamy tekst, który chcemy w nich umieścić.
Sposób 2.
Podczas pisania postu ręcznie wprowadzamy tagi Code - pokazują to obrazki poniżej:
W znacznikach "Code" należy ujmować ważne treści, a w szczególności wyniki poleceń z terminala, komendy polecane do wykonania innym użytkownikom, a także cytowane pliki / fragmenty plików konfiguracyjnych systemu.
Niechlujnie napisanym postem nikt się nawet nie zainteresuje, a wręcz powinien go zgłosić do moderacji.
ZAVRĚNO!
