mam problemy z uruchomieniem klawiatury USB. Jest to klawiatura z zintegrowanym trackballem, posiada wbudowany hub USB. Całość oparta na chipie firmy Alcor AU9462.
Klawiatura czasem się włącza i działa bezproblemowo, ale po wyjęciu wtyczki USB i ponownym podłączeniu przestaje reagować.
Kiedy działa, wynik komendy lsusb wygląda tak:
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 004: ID 13fe:4200 Kingston Technology Company Inc.
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 004: ID 058f:9462 Alcor Micro Corp.
Bus 005 Device 002: ID 046d:c077 Logitech, Inc.
Bus 002 Device 008: ID 058f:6387 Alcor Micro Corp. Flash Drive
Bus 004 Device 009: ID 058f:9462 Alcor Micro Corp.
Bus 004 Device 010: ID 1241:1111 Belkin MouseKod: Zaznacz cały
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 8
idVendor 0x058f Alcor Micro Corp.
idProduct 0x9462
bcdDevice 1.22
iManufacturer 1 ALCOR
iProduct 2 USB Multimedia Keyboard Hub
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 2 USB Multimedia Keyboard Hub
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 50mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 255
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 3
wHubCharacteristic 0x0004
Ganged power switching
Compound device
Ganged overcurrent protection
bPwrOn2PwrGood 22 * 2 milli seconds
bHubContrCurrent 50 milli Ampere
DeviceRemovable 0x02
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0103 power enable connect
Port 2: 0000.0100 power
Port 3: 0000.0303 lowspeed power enable connect
Device Status: 0x0000
(Bus Powered)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idProduct 0x6387 Flash Drive
bcdDevice 1.01
iManufacturer 1 Generic
iProduct 2 Mass Storage
iSerial 3 1B74BE07
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
(Bus Powered)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idProduct 0x9462
bcdDevice 1.22
iSerial 3 USB Multimedia Keyboard
bLength 9
bDescriptorType 2
wTotalLength 59
bNumInterfaces 2
iConfiguration 3 USB Multimedia Keyboard
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 50mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 1 Keyboard
iInterface 3 USB Multimedia Keyboard
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 65
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 10
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
bLength 9
bDescriptorType 33
bcdHID 1.10
bNumDescriptors 1
wDescriptorLength 123
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 255
(Bus Powered)
[ 3188.598202] usb 4-1: unable to read config index 0 descriptor/all
[ 3188.598221] usb 4-1: can't read configurations, error -62
[ 3188.736128] usb 4-1: new full-speed USB device number 51 using ohci_hcd
[ 3188.900196] usb 4-1: device descriptor read/all, error -62
[ 3189.040128] usb 4-1: new full-speed USB device number 52 using ohci_hcd
[ 3189.072203] usb 4-1: device descriptor read/all, error -62
[ 3189.212124] usb 4-1: new full-speed USB device number 53 using ohci_hcd
[ 3189.244199] usb 4-1: device descriptor read/all, error -62
[ 3189.248122] hub 4-0:1.0: unable to enumerate USB device on port 1
Szukałem rozwiązania, ale jedyne rozwiązanie, które rozwiązywało podobne problemy (modyfikacja pliku w /lib/udev) u mnie nie zadziałało.
Z góry dziękuję za wszelkie sugestie.
