Garść informacji:
root@banana:~# uname -aLinux banana 3.4.90+ #1 SMP PREEMPT Tue Jul 22 10:22:36 CEST 2014 armv7l GNU/Linux
root@banana:~# dpkg --print-architecture
armhf
root@banana:~# lsusb | grep X
Bus 001 Device 005: ID 0bc7:0006 X10 Wireless Technology, Inc. Wireless Transceiver (ACPI-compliant)
Moduł ati_remote został dodany do /etc/modprobe.d/blacklist.root@banana:~# cat /etc/lirc/hardware.conf# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
FORCE_NONINTERACTIVE_RECONFIGURATION="false"
LIRCD_ARGS=""
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD=false
#Don't start irexec, even if a good config file seems to exist.
#START_IREXEC=false
#Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
DRIVER="devinput"
# usually /dev/lirc0 is the correct setting for systems using udev
DEVICE="/dev/lirc0"
MODULES="lirc_atiusb"
# Default configuration files for your hardware if any
LIRCD_CONF=""
LIRCMD_CONF=""
