Witam serdecznie!
Mam problem z konfiguracją HUAWEI E3372, karta oraz modem z T-Mobile.
Które logi mam wysłać?
Z góry serdecznie dziękuje za pomoc.
Modem HUAWEI E3372 T-Mobile internet problemy z konfiguracj
- marcin1982
Podaj podstawowe informacje o systemie, wyniki poleceń z konsoli:
Do tego ostatniego trzeba zainstalować pakiet wireless-tools.
cat /etc/debian_version
uname -r
lsusb
cat /etc/network/interfaces
iwlist scan
Dziękuję za odpowiedź.
marcin1982 pisze:Kod: Zaznacz cały
uname -r
3.2.0-4-amd64
lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 004: ID 12d1:1506 Huawei Technologies Co., Ltd. E398 LTE/UMTS/GSM Modem/Networkcard
Bus 001 Device 003: ID 04f2:b2fa Chicony Electronics Co., Ltd
Bus 001 Device 004: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
auto lo
iface lo inet loopback
iwlist scan
lo Interface doesn't support scanning.
wlan0 Scan completed :
Cell 01 - Address: 64:66:B3:6C:F0:66
Channel:1
Frequency:2.412 GHz (Channel 1)
Quality=58/70 Signal level=-52 dBm
Encryption key :o n
ESSID:"ST@NISLAW"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
9 Mb/s; 12 Mb/s; 18 Mb/s
Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=0000000000000000
Extra: Last beacon: 88ms ago
IE: Unknown: 00095354404E49534C4157
IE: Unknown: 010882848B960C121824
IE: Unknown: 030101
IE: Unknown: 0706504C20010D14
IE: Unknown: 2A0100
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
IE: Unknown: 32043048606C
IE: Unknown: 2D1A6E1103FF00000000000000000000000000000000000000000000
IE: Unknown: 3D16010D0600000000000000000000000000000000000000
IE: Unknown: DD180050F2020101820003A4000027A4000042435E0062322F00
IE: Unknown: DD1E00904C336E1103FF00000000000000000000000000000000000000000000
IE: Unknown: DD1A00904C34010D0600000000000000000000000000000000000000
IE: Unknown: DD0900037F01010000FF7F
IE: Unknown: DD990050F204104A0001101044000102103B00010310470010000000000000100000006466B36CF0101021000754502D4C494E4B10230009544C2D57523734304E10240003342E3010420003312E301054000800060050F204000110110019576972656C65737320526F7574657220544C2D57523734304E100800020086103C000101104900140024E26002000101600000020001600100020001
Cell 02 - Address: 00:19:E0:6D:BA:56
Channel:5
Frequency:2.432 GHz (Channel 5)
Quality=18/70 Signal level=-92 dBm
Encryption key :o n
ESSID:"SIEC"
12 Mb/s; 24 Mb/s; 36 Mb/s
Bit Rates:9 Mb/s; 18 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
IE: Unknown: 000453494543
IE: Unknown: 010882848B960C183048
IE: Unknown: 030105
IE: Unknown: 050400010000
IE: Unknown: 07065A5720010D14
IE: Unknown: 2A0100
IE: Unknown: 32041224606C
Group Cipher : TKIP
Pairwise Ciphers (1) : TKIP
Preauthentication Supported
IE: Unknown: DD0900037F01010008FF7F
IE: Unknown: DD1A00037F03010000000019E06DBA560219E06DBA5664002C010808
eth0 Interface doesn't support scanning.
