Problem z wifi na debianie 6.0.6
KUBAJAK
Post autor: KUBAJAK »
Mam problem ze skonfigurowaniem sieci WIFI.
System wykrywa kartę WIFI, ping-ując na www.wp.pl też wszystko działa, lecz jak uruchomię przeglądarkę to nie może wyświetlić strony.
iptables -L
Chain INPUT
target prot opt source destination
Chain FORWARD
Chain OUTPUT
lspci -k
00:00.0 Host bridge: nVidia Corporation nForce2 IGP2 (rev c1)
    Kernel driver in use: agpgart-nvidia
00:00.1 RAM memory: nVidia Corporation nForce2 Memory Controller 1 (rev c1)
    Subsystem: Micro-Star International Co., Ltd. Device 5700
00:00.2 RAM memory: nVidia Corporation nForce2 Memory Controller 4 (rev c1)
00:00.3 RAM memory: nVidia Corporation nForce2 Memory Controller 3 (rev c1)
00:00.4 RAM memory: nVidia Corporation nForce2 Memory Controller 2 (rev c1)
00:00.5 RAM memory: nVidia Corporation nForce2 Memory Controller 5 (rev c1)
00:01.0 ISA bridge: nVidia Corporation nForce2 ISA Bridge (rev a3)
00:01.1 SMBus: nVidia Corporation nForce2 SMBus (MCP) (rev a2)
    Kernel driver in use: nForce2_smbus
00:02.0 USB Controller: nVidia Corporation nForce2 USB Controller (rev a3)
    Kernel driver in use: ohci_hcd
00:02.1 USB Controller: nVidia Corporation nForce2 USB Controller (rev a3)
00:02.2 USB Controller: nVidia Corporation nForce2 USB Controller (rev a3)
00:08.0 PCI bridge: nVidia Corporation nForce2 External PCI Bridge (rev a3)
00:09.0 IDE interface: nVidia Corporation nForce2 IDE (rev a2)
    Kernel driver in use: pata_amd
00:1e.0 PCI bridge: nVidia Corporation nForce2 AGP (rev c1)
01:07.0 Multimedia audio controller: Creative Labs SB Live! EMU10k1 (rev 07)
    Subsystem: Creative Labs SBLive! 5.1 Model SB0100
    Kernel driver in use: EMU10K1_Audigy
01:07.1 Input device controller: Creative Labs SB Live! Game Port (rev 07)
    Subsystem: Creative Labs Gameport Joystick
    Kernel driver in use: Emu10k1_gameport
01:08.0 FireWire (IEEE 1394): NEC Corporation uPD72873 IEEE1394 OHCI 1.1 2-port Host Controller (rev 01)
    Subsystem: NEC Corporation Device 00ce
    Kernel driver in use: firewire_ohci
01:09.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
    Subsystem: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+
    Kernel driver in use: 8139too
02:00.0 VGA compatible controller: ATI Technologies Inc Radeon RV250 If [Radeon 9000] (rev 01)
    Subsystem: Giga-byte Technology Device 4010
    Kernel driver in use: radeon
lsusb
Bus 003 Device 002: ID 09da:0006 A4 Tech Co., Ltd Optical Mouse WOP-35 / Trust 450L Optical Mouse
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) 64MB QDI U2 DISK
Bus 001 Device 002: ID 07d1:3c03 D-Link System AirPlus G DWL-G122 Wireless Adapter(rev.C1) [Ralink RT73]
uname -r
2.6.32-5-686
iwconfig
eth1      no wireless extensions.
wlan0     IEEE 802.11bg  ESSID:"ZLO2"
          Mode:Managed  Frequency:2.462 GHz  Access Point: 78:54:2E:93:AF:C6
          Bit Rate=54 Mb/s   Tx-Power=21 dBm
          Retry  long limit:7   RTS thr :o ff   Fragment thr :o ff
          Encryption key :o ff
          Power Management :o n
          Link Quality=42/70  Signal level=-68 dBm
ifconfig
eth1      Link encap:Ethernet  HWaddr 00:30:4f:38:3d:eb
          collisions:0 txqueuelen:1000
          Interrupt:19 Base address:0xc800
          RX packets:24 errors:0 dropped:0 overruns:0 frame:0
          TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1684 (1.6 KiB)  TX bytes:1684 (1.6 KiB)
wlan0     Link encap:Ethernet  HWaddr 00:19:5b:ff:a8:c6
          inet addr:192.168.0.53  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::219:5bff:feff:a8c6/64 Scope:Link
          RX packets:769 errors:0 dropped:0 overruns:0 frame:0
          TX packets:333 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:175347 (171.2 KiB)  TX bytes:51375 (50.1 KiB)
ping www.wp.pl
PING www.wp.pl (212.77.100.101) 56(84) bytes of data.
64 bytes from www.wp.pl (212.77.100.101): icmp_req=1 ttl=246 time=1009 ms
64 bytes from www.wp.pl (212.77.100.101): icmp_req=2 ttl=246 time=53.9 ms
64 bytes from www.wp.pl (212.77.100.101): icmp_req=3 ttl=246 time=52.8 ms
64 bytes from www.wp.pl (212.77.100.101): icmp_req=4 ttl=246 time=51.5 ms
64 bytes from www.wp.pl (212.77.100.101): icmp_req=5 ttl=246 time=52.0 ms
64 bytes from www.wp.pl (212.77.100.101): icmp_req=6 ttl=246 time=49.0 ms
64 bytes from www.wp.pl (212.77.100.101): icmp_req=7 ttl=246 time=48.9 ms
^C
--- www.wp.pl ping statistics ---
7 packets transmitted, 7 received, 0% packet loss, time 6013ms
rtt min/avg/max/mdev = 48.918/188.222/1009.323/335.217 ms, pipe 2
Podaj podstawowe informacje o sprzęcie - wyniki poleceń z terminala / konsoli:
lspci -k
lsusb
uname -r
cat /etc/debian_version
Napisz czy to jest laptop czy komputer stacjonarny, czy karta jest wbudowana w laptopa czy jakiś adapter na USB.
Do prezentacji wyników z konsoli używaj tagów Code.
