Dźwi
torrmen
Dźwięk audio tylko w VLC i SMPlayer
Post autor: torrmen »
jak w temacie. Dźwięk nie występuje w zadnym odtwarzaczu typu foobnix, banshee itp. Chodzi o pliki audio. Aby je odtworzyć trzeba korzystać z wymienionych aplikacji.
W załączniku mała informacja z systemu. Może coś pomoże.
http://www.alsa-project.org/db/?f=6e751 ... f77af8a0cf
[ATTACH]4907[/ATTACH]
Podaj informacje: jaka wersja Debiana, jakie środowisko graficzne? Czy GStreamer jest zainstalowany?
torrmen
xfce
Debian jessie/sid
torrmen: dpkg -l | grep gstreamer
ii  gir1.2-gstreamer-0.10                        0.10.36-1.4                            i386         Description: GObject introspection data for the GStreamer library
ii  gir1.2-gstreamer-1.0                         1.4.3-1.2                              i386         Description: GObject introspection data for the GStreamer library
ii  gstreamer0.10-alsa:i386                      0.10.36-2                              i386         GStreamer plugin for ALSA
ii  gstreamer0.10-gconf:i386                     0.10.31-3+nmu4+b1                      i386         GStreamer plugin for getting the sink/source information from GConf
ii  gstreamer0.10-plugins-base:i386              0.10.36-2                              i386         GStreamer plugins from the "base" set
ii  gstreamer0.10-plugins-good:i386              0.10.31-3+nmu4+b1                      i386         GStreamer plugins from the "good" set
ii  gstreamer0.10-x:i386                         0.10.36-2                              i386         GStreamer plugins for X11 and Pango
ii  gstreamer1.0-plugins-base:i386               1.4.3-1.1                              i386         GStreamer plugins from the "base" set
ii  gstreamer1.0-plugins-good:i386               1.4.3-2                                i386         GStreamer plugins from the "good" set
ii  gstreamer1.0-plugins-ugly:i386               1.4.3-1                                i386         GStreamer plugins from the "ugly" set
ii  gstreamer1.0-pulseaudio:i386                 1.4.3-2                                i386         GStreamer plugin for PulseAudio
ii  gstreamer1.0-x:i386                          1.4.3-1.1                              i386         GStreamer plugins for X11 and Pango
ii  libgstreamer-plugins-base0.10-0:i386         0.10.36-2                              i386         GStreamer libraries from the "base" set
ii  libgstreamer-plugins-base1.0-0:i386          1.4.3-1.1                              i386         GStreamer libraries from the "base" set
ii  libgstreamer0.10-0:i386                      0.10.36-1.4                            i386         Core GStreamer libraries and elements
ii  libgstreamer1.0-0:i386                       1.4.3-1.2                              i386         Core GStreamer libraries and elements
ii  libreoffice-avmedia-backend-gstreamer        1:4.3.3~rc2-1                          i386         GStreamer backend for LibreOffice
Mam nadzieję że troszkę naświetli sprawę :)
