mam mały problem zainstalowałem clamav razem clamfs, skonfigurowałem chyba dobrze. Napotykając już na samym początku problem przy freshclam - rozwiązany. Mam tylko małe pytanie , bo chyba to jest błąd:
Fri Oct 24 22:15:38 2014 -> +++ Started at Fri Oct 24 22:15:38 2014
Fri Oct 24 22:15:38 2014 -> Received 1 file descriptor(s) from systemd.
Fri Oct 24 22:15:38 2014 -> clamd daemon 0.98.5-rc1 (OS: linux-gnu, ARCH: i386, CPU: i586)
Fri Oct 24 22:15:38 2014 -> Running as user root (UID 0, GID 0)
Fri Oct 24 22:15:38 2014 -> Log file size limited to 4294967295bytes.
Fri Oct 24 22:15:38 2014 -> Reading databases from /var/lib/clamav
Fri Oct 24 22:15:38 2014 -> Bytecode: Security mode set to "Paranoid".
Fri Oct 24 22:16:23 2014 -> Loaded 4251535 signatures.
Fri Oct 24 22:16:30 2014 -> TCP: No tcp AF_INET SOCK_STREAM socket received from systemd.
Fri Oct 24 22:16:30 2014 -> LOCAL: Received AF_UNIX SOCK_STREAM socket from systemd.
Fri Oct 24 22:16:30 2014 -> Limits: Global size limit set to 104857600 bytes.
Fri Oct 24 22:16:30 2014 -> Limits: File size limit set to 26214400 bytes.
"TCP: No tcp AF_INET SOCK_STREAM socket received from systemd. LOCAL: Received AF_UNIX SOCK_STREAM socket from systemd." ?
ps. problem rozwiązany, trzeba było cofnąć całego clamav do testinga
