Serwer Dns na przyk
miras_w
Serwer Dns na przykładzie binda9
Post autor: miras_w »
Witam postanowiłem postawic sobie serwer dns a raczej nauczyć sie jak to sie robi.
w internecie znalazłem piekny opis z tej strony
mam kilka wątpliwości i chciał bym aby jakis fachowiec rzucił okiem przedstawie moje pliki w katalogu /etc/bind
plik named.conf
more named.conf
// This is the primary configuration file for the BIND DNS server named.
// Please read /usr/share/doc/bind9/README.Debian.gz for information on the
// structure of BIND configuration files in Debian, *BEFORE* you customize
// this configuration file.
// If you are just adding zones, please do that in /etc/bind/named.conf.local
include "/etc/bind/named.conf.options";
// prime the server with knowledge of the root servers
zone "moja_domena" {
type master;
file "/etc/bind/moja_domena";
allow-transfer { 194.204.159.1; 194.204.152.34; };
notify yes;
zone "." {
        type hint;
        file "/etc/bind/db.root";
// be authoritative for the localhost forward and reverse zones, and for
// broadcast zones as per RFC 1912
zone "localhost" {
        type master;
        file "/etc/bind/db.local";
zone "127.in-addr.arpa" {
        type master;
        file "/etc/bind/db.127";
zone "0.in-addr.arpa" {
        type master;
        file "/etc/bind/db.0";
zone "255.in-addr.arpa" {
        type master;
        file "/etc/bind/db.255";
// zone "com" { type delegation-only; };
// zone "net" { type delegation-only; };
// From the release notes:
//  Because many of our users are uncomfortable receiving undelegated answers
//  from root or top level domains, other than a few for whom that behaviour
//  has been trusted and expected for quite some length of time, we have now
//  introduced the "root-delegations-only" feature which applies delegation-only
//  logic to all top level domains, and to the root domain.  An exception list
//  should be specified, including "MUSEUM" and "DE", and any other top level
//  domains from whom undelegated responses are expected and trusted.
// root-delegation-only exclude { "DE"; "MUSEUM"; };
include "/etc/bind/named.conf.local";
plik strefy
more moja_domena
$TTL 86400
$ORIGIN moja_domena.
@       IN      SOA     ns1.moja_domena. moja_domena. (
        2005070901 ; Serial
        10800      ; Refresh
        3600       ; Retry
        2419200    ; Expire
        10800 )    ; NXDOMAIN TTL
        IN      NS              ns1.moja_domena.
        IN      NS              ns2.moja_domena.
        IN      MX      5       mail.moja_domena.
@       IN      A               mój_zew_ip
www     IN      A             mój_zew_ip
mail    IN      A               mój_zew_ip
ftp     IN      CNAME       moja_domena
plik name.config.options
more named.conf.options
options {
directory "/var/cache/bind";
listen-on { any; };
listen-on-v6 { any; };
auth-nxdomain yes;
query-source address * port 53;
transfer-source * port 53;
notify-source * port 53;
version "Microsoft DNS Server v1.5 (WinME)";
forwarders { 194.204.159.1; 194.204.152.34; };
 more named.conf.local
// Do any local configuration here
// Consider adding the 1918 zones here, if they are not used in your
// organization
//include "/etc/bind/zones.rfc1918";
type master;
notify yes;
Jeśli wszystko ok to prosił bym abyście napisali jak powinny wyglądac moje pliki resolv.conf oraz hosts.conf i hosts jesli ma to jakies znaczenie.
[ Dodano: 2007-07-29, 21:45 ]
Dobrze na podstawie tej konfiguracji bind działa ale pojawił sie inny problem mianowiecie podczas restartu:
/etc/init.d/bind9 reload
Reloading domain name service...: bindrndc: connect failed: 127.0.0.1#953: connection refused
 failed!
Jul 30 10:14:54 maksior named[28352]: starting BIND 9.4.1-P1 -u bind -t /var/lib/named
Jul 30 10:14:54 maksior named[28352]: found 1 CPU, using 1 worker thread
Jul 30 10:14:54 maksior named[28352]: loading configuration from '/etc/bind/named.conf'
Jul 30 10:14:54 maksior named[28352]: /etc/bind/named.conf.local:8: zone 'maksior.zadupie.eu': already exists previous definition: /etc/bind/named.conf:13
Jul 30 10:14:54 maksior named[28352]: loading configuration: failure
Jul 30 10:14:54 maksior named[28352]: exiting (due to fatal error)
ShinnRa
Post autor: ShinnRa »
miras_w pisze:Kod:
failed!
najprawdopodobniej iptables blokuje ci dostęp jeśli masz policy DROP dla INPUT. Ja to rozwiązałem tak:
iptables -A INPUT -s 127.0.0.0/8 -j ACCEPT
miras_w pisze:Kod:
masz dwa razy zdefiniowaną domenę w named.conf i named.conf.local
miras_w
dzięki juz poprawione :)
Narkoza
Post autor: Narkoza »
Przepraszam, że odkopuję temat. Ale mam problem z bindem (DNS) zainstalowałem i niby skonfigurowałem wg strony w pierwszym temacie. Stworzyłem virtual hosta, który umieściłem w sites-available czy jakoś tak:
<VirtualHost IP:80>
	ServerAdmin email
	ServerName [url]www.nazwadomeny.pl[/url]
	ServerAlias *.nazwadomeny.pl
	DocumentRoot /var/www/nazwadomeny.pl/
	<Directory />
		Options FollowSymLinks
		AllowOverride None
	</Directory>
	<Directory /var/www/nazwadomeny.pl/>
		AllowOverride all
		Order allow,deny
		allow from all
	</Directory>
#			      PhpMyAdmin			      #
    Alias /phpmyadmin "/var/www/phpmyadmin/"
	<Directory /var/www/phpmyadmin/>
		AllowOverride None
		Order allow,deny
		allow from all
	</Directory>
	ErrorLog /var/log/apache2/error_nazwadomeny.log
	# Possible values include: debug, info, notice, warn, error, crit,
	# alert, emerg.
	LogLevel warn
	CustomLog /var/log/apache2/access_nazwadomeny.log combined
	ServerSignature On
</VirtualHost>
########=-BEZ WWW=-################
<VirtualHost IP:80>
	ServerAdmin email
	ServerName nazwadomeny.pl
	<Directory />
		AllowOverride None
	</Directory>
		AllowOverride all
		Order allow,deny
		allow from all
	</Directory>
#				POCZTA				      #
    Alias /poczta "/var/www/poczta/"
	<Directory /var/www/poczta/>
		AllowOverride None
		Order allow,deny
		allow from all
	</Directory>
#			      PhpMyAdmin			      #
		AllowOverride None
		Order allow,deny
		allow from all
	</Directory>
	ErrorLog /var/log/apache2/error_nazwadomeny.pl.log
	# alert, emerg.
	LogLevel warn
	CustomLog /var/log/apache2/access_nazwadomeny.pl.log combined
	ServerSignature On
</VirtualHost>
Domenę przekierowałem na adres IP serwera i nie działa. Wiem że można na IP bo kiedyś mój znajomy tak robił. Jeśli ktoś może to proszę o wstawieni tutaj plików konfiguracyjnych z /etc/bind <-chyba
Bo nie wiem co i jak. Z góry dziękuję.
Pozdrawiam £ukasz
 $TTL 86400
        2005070901 ; Serial
        10800      ; Refresh
        3600       ; Retry
        2419200    ; Expire
@       IN      A               mój_zew_ip
www     IN      A             mój_zew_ip
ns1   IN    A                    ip
ns2   IN     A                   ip
miras_w
blazejwiecha
Post autor: blazejwiecha »
Zrobiłem wszystko według http://www.debian.one.pl/index.php?url=12 i niby działa. Dostęp do domeny z poza sieci lokalnej jest, lecz jak w sieci wpiszę adres domeny to nie znajduje jej.
Posiadam dwa serwery 1 to router z secondary dns, a 2 serwer to promary dns.
traczu
Post autor: traczu »
Ja mam pytanko żeby nie zakładać nowego tematu. Czy wykupioną domenę lepiej przekierować na adres nadany przez firmę hostingową czy jakoś po dns ją podpiąć?
Wydaje mi się że przekierowanie nie jest do końca dobrym rozwiązaniem bo o wiele dłużej się czeka na otwieranie strony niz jakby to było bezpośrednio.
Czyli na serwerze np. w DirectAdminie tworzę jakąś domenę którą sobie wykupiłem i spinam domenę z serwerem ale jak to dokładnie działa?
Jak zmienić ns1 i ns2? Czy to to samo co dns?
W home.pl podaje DNS serwera i powinno się spiąć?
