Kompilacja nie zajęła mi więcej jak minutę, ale jak ktoś paczkę zrobi to się przyda :P (ja jeszcze o tworzeniu debów nie mam zielonego pojęcia :mrgreen: )
debian:/home/karol/Desktop/metatheme/metatheme-0.0.6# ./configure
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for g++... g++
checking for C++ compiler default output file name... a.out
checking whether the C++ compiler works... yes
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... gcc3
checking for gcc... gcc
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking for ranlib... ranlib
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... (cached) ranlib
checking for strip... strip
checking if gcc static flag works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for X... no
checking for ANSI C header files... (cached) yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for unistd.h... (cached) yes
checking for an ANSI C-conforming const... yes
checking for size_t... yes
checking for strdup... yes
checking for pkg-config... /usr/local/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for CAIRO_CFLAGS...
checking for CAIRO_LIBS...
checking for GTK2_CFLAGS...
checking for GTK2_LIBS...
checking for QT... no
checking for Java SDK... no
checking for GLIB_CFLAGS... -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/include
checking for GLIB_LIBS... -L/usr/local/lib -lglib-2.0
Configuration summary
Toolkit support:
* GTK2: no
* QT: no
* Java: no
Theme engines:
* Redmond 2000: yes
* Plastik: yes
* Highcolor: yes
* Industrial: yes
* Flat: yes
* MSSTYLE: no, GTK2 is required
Cairo support: no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating metatheme-install
config.status: creating metatheme/Makefile
config.status: creating themes/Makefile
config.status: creating themes/redmond/Makefile
config.status: creating themes/plastik/Makefile
config.status: creating themes/highcolor/Makefile
config.status: creating themes/industrial/Makefile
config.status: creating themes/flat/Makefile
config.status: creating themes/msstyle/Makefile
config.status: creating toolkits/Makefile
config.status: creating toolkits/gtk2/Makefile
config.status: creating toolkits/qt/Makefile
config.status: creating toolkits/java/Makefile
config.status: creating toolkits/java/metatheme/Makefile
config.status: creating toolkits/java/mt-java
config.status: creating config/Makefile
config.status: creating colors/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
debian:/home/karol/Desktop/metatheme/metatheme-0.0.6# make
make all-recursive
make[1]: Wejście do katalogu `/home/karol/Desktop/metatheme/metatheme-0.0.6'
Making all in metatheme
make[2]: Wejście do katalogu `/home/karol/Desktop/metatheme/metatheme-0.0.6/metatheme'
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -g -O2 -MT refresh.o -MD -MP -MF ".deps/refresh.Tpo" \
-c -o refresh.o `test -f 'refresh.c' || echo './'`refresh.c; \
then mv -f ".deps/refresh.Tpo" ".deps/refresh.Po"; \
else rm -f ".deps/refresh.Tpo"; exit 1; \
fi
refresh.c:24:19: error: X11/X.h: Nie ma takiego pliku ani katalogu
refresh.c:25:22: error: X11/Xlib.h: Nie ma takiego pliku ani katalogu
refresh.c:27: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
refresh.c:30: error: expected ‘ ;) ’ before ‘w’
refresh.c:52: error: expected ‘ ;) ’ before ‘w’
refresh.c:70: error: expected ‘ ;) ’ before ‘w’
refresh.c: In function ‘send_reload_messages’:
refresh.c:90: error: ‘Window’ undeclared (first use in this function)
refresh.c:90: error: (Each undeclared identifier is reported only once
refresh.c:90: error: for each function it appears in.)
refresh.c:90: error: expected ‘;’ before ‘dw1’
refresh.c:91: error: ‘dpy’ undeclared (first use in this function)
refresh.c:92: error: ‘Atom’ undeclared (first use in this function)
refresh.c:92: error: expected ‘;’ before ‘kde_atom’
refresh.c:94: error: ‘kde_atom’ undeclared (first use in this function)
refresh.c:94: error: ‘False’ undeclared (first use in this function)
refresh.c:97: error: expected ‘;’ before ‘root’
refresh.c:99: error: ‘root’ undeclared (first use in this function)
refresh.c:99: error: ‘dw1’ undeclared (first use in this function)
refresh.c:99: error: ‘dw2’ undeclared (first use in this function)
refresh.c:99: error: ‘rootwins’ undeclared (first use in this function)
refresh.c: At top level:
refresh.c:117: error: expected ‘ ;) ’ before ‘*’ token
make[2]: *** [refresh.o] Błąd 1
make[2]: Opuszczenie katalogu `/home/karol/Desktop/metatheme/metatheme-0.0.6/metatheme'
make[1]: *** [all-recursive] Błąd 1
make[1]: Opuszczenie katalogu `/home/karol/Desktop/metatheme/metatheme-0.0.6'
make: *** [all] Błąd 2
EDIT: Doinstalowałem qt3 i poszło bez błędów.
Czy potrzebne jest GTK2?
dpkg: w odniesieniu do metatheme_0.0.6-1_i386.deb zawierającego metatheme:
libgtk2.0-0 w konflikcie z metatheme (<< 0.9.7-3)
metatheme (wersja 0.0.6-1) jest przeznaczony do zainstalowania.
dpkg: błąd przetwarzania metatheme_0.0.6-1_i386.deb (--install):
konflikt pakietów - nie będzie instalowany metatheme
Make install zrobiłem i polecenie metatheme-install chodzi
¯adnych pomysłów??
Jak zaisntalować to GTK2?? Nie mogę sobie poradzić.
Przy kompilowaniu gtk+-2.0 chciał gliba, atk i pango. Więc skompilowałem gliba-2.10 a atk dalej chce gliba chociaż jest on już skompilowany. Bez sensu...
Ludzie trzymajcie mnie. Postanowiłem skompilować najnowsze wersje. To ściągnąłem:
Glib i pango ładnie się skompilowały. atk zawzięte chce gliba a i jeszcze gtk chce cairo a cairo chce libpng chociaż ta jest zainstalowana z repo. I jak tu się nie denerwować. Mam dość. POMOCY!
