root@komputer-kwantowy:~# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 045e:076c Microsoft Corp.
Bus 003 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 003: ID 5986:0296 Acer, Inc
Bus 001 Device 007: ID 0cf3:9271 Atheros Communications, Inc. AR9271 802.11n
root@komputer-kwantowy:~# ifconfig -a
eth0 Link encap:Ethernet HWaddr dc:0e:a1:ee:47:0f
inet addr:192.168.0.201 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::de0e:a1ff:feee:470f/64 Scope:Link
RX packets:133878 errors:0 dropped:0 overruns:0 frame:0
TX packets:124330 errors:0 dropped:0 overruns:0 carrier:1
collisions:0 txqueuelen:1000
RX bytes:165950070 (158.2 MiB) TX bytes:12755586 (12.1 MiB)
Interrupt:16
lo Link encap:Local Loopback
RX packets:390 errors:0 dropped:0 overruns:0 frame:0
TX packets:390 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:53692 (52.4 KiB) TX bytes:53692 (52.4 KiB)
wlan0 Link encap:Ethernet HWaddr 9c:4e:36:17:92:18
root@komputer-kwantowy:~# iwconfig
lo no wireless extensions.
wlan0 IEEE 802.11bgn ESSID :o ff/any
Mode:Managed Access Point: Not-Associated Tx-Power=15 dBm
Retry long limit:7 RTS thr :o ff Fragment thr :o ff
Encryption key :o ff
Power Management :o ff
eth0 no wireless extensions.
root@komputer-kwantowy:~# cat /etc/resolv.conf
# Generated by NetworkManager
nameserver 62.179.1.62
nameserver 62.179.1.63
root@komputer-kwantowy:~# cat /etc/network/interfaces
auto lo
iface lo inet loopback
root@komputer-kwantowy:~# dmesg
[ 7315.984017] usb 1-3: new high-speed USB device number 7 using xhci_hcd
[ 7316.008701] usb 1-3: New USB device found, idVendor=0cf3, idProduct=9271
[ 7316.008708] usb 1-3: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[ 7316.008712] usb 1-3: Product: USB2.0 WLAN
[ 7316.008715] usb 1-3: Manufacturer: ATHEROS
[ 7316.008718] usb 1-3: SerialNumber: 12345
[ 7316.014126] usb 1-3: firmware: agent loaded htc_9271.fw into memory
[ 7316.296753] usb 1-3: ath9k_htc: Transferred FW: htc_9271.fw, size: 51272
[ 7316.296969] xhci_hcd 0000:00:14.0: ERROR no room on ep ring
[ 7316.299856] usb 1-3: ath9k_htc: Unable to allocate URBs
[ 7316.299893] ath9k_htc: probe of 1-3:1.0 failed with error -22
