W internecie wyczytałem, że to _może być_ problem z NFS.
Co mam zainstalowane z NFS (zarówno na komputerze, który udostępnia jak i na tym, który korzysta jest dokładnie to samo):
kodama@debian:~$ dpkg -l | grep nfs
ii libnfsidmap2:i386 0.25-4 i386 NFS idmapping library
ii nfs-common 1:1.2.6-4 i386 NFS support files common to client and server
ii nfs-kernel-server 1:1.2.6-4 i386 support for NFS kernel server
Zawartość /etc/fstab z tego komputera, na którym występuje błąd:
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda1 during installation
UUID=94e12c35-aea0-4090-ba92-93baed6d4bf0 / ext4 errors=remount-ro 0 1
# /home was on /dev/sda3 during installation
UUID=c362acd4-faeb-4df6-9d54-c3f4b9d62023 /home ext4 defaults 0 2
# swap was on /dev/sda2 during installation
UUID=b0bf3578-14b8-43e2-bec1-0dd9b5da016a none swap sw 0 0
/dev/sr0 /media/cdrom0 udf,iso9660 user,noauto 0 0
192.168.0.31:/home/kodama/Pobrane /media/Tomek nfs _netdev,auto 0 0
192.168.0.31:/home/kodama/Pulpit/Dom /media/Dom nfs _netdev,auto 0 0
/home/kodama/Pobrane 192.168.0.30(rw,sync,no_subtree_check)
/home/kodama/Pulpit/Dom 192.168.0.30(rw,sync,no_subtree_check)
Linux debian 3.2.0-4-686-pae #1 SMP Debian 3.2.51-1 i686 GNU/Linux
