qmial nie filtruje maili za pomoc
raczkowski1
qmial nie filtruje maili za pomocą rblsmtp
Post autor: raczkowski1 »
Mam problem z qmail'em, nie chce filtrować poczty przez rblsmtp.
Wycinek skryptu uruchamiającego qmail'a:
logger="splogger qmail 2"       # facility mail == 2
#logger="|accustamp >>/var/log/qmail.log"   # If you have accustamp installed.
logger=">>/var/log/qmail.log"              # Does not give timing info.
# If you uncommented one of the lines that appends to /var/log/qmail.log, you
# need to uncomment the following two lines.
touch /var/log/qmail.log
chown qmaill /var/log/qmail.log
# If you want to use one or more of the Relay Black Lists, uncomment
# the appropriate lines.
#rblmsg=
#rblsmtpd=
rblmsg=" (with rblsmtpd)"
#rblsmtpd="/usr/bin/rblsmtpd -r relays.ordb.org"
#rblsmtpd="/usr/bin/rblsmtpd -b -r bl.spamcop.net"
#-r ralays.ordb.org"
rblsmtpd="/usr/bin/rblsmtpd -r sbl.spamhaus.org"
# End of configuration
test -x /usr/sbin/qmail-start || exit 0
test -x /usr/sbin/qmail-send || exit 0
case "$1" in
    start)
        sleep 3
        echo -n "Starting mail-transfer agent: qmail" $rblmsg
        sh -c "start-stop-daemon --start --quiet --user qmails \
                 --exec /usr/sbin/qmail-send \
                 --startas /usr/sbin/qmail-start -- \"$alias_empty\" $logger &"
        # prevent denial-of-service attacks, with ulimit
        #ulimit -v 8192
 #            $rblsmtpd \
        sh -c "start-stop-daemon --start --quiet --user qmaild \
            --exec /usr/bin/tcpserver -- -R -H \
            -u `id -u qmaild` -g `id -g nobody` -x /etc/tcp.smtp.cdb 0 smtp  $rblsmtpd \
            /usr/sbin/qmail-smtpd domena.pl /bin/cmd5checkpw /bin/true 2>&1 \
            | $logger &"
        # Uncomment the following lines to automatically start the pop3 server
        sh -c "start-stop-daemon --start --quiet --user root \
            0 pop-3 /usr/sbin/qmail-popup `hostname`.`dnsdomainname` \
            /usr/bin/checkpassword /usr/sbin/qmail-pop3d Maildir &"
        echo "."
    stop)
W logach nie ma śladu o rblsmtp.
Testowy mail z adresu nelson-sbl-test@crynwr.com dochodzi.
Jakieś propozycje?
raczkowski1
Czy ktoś ma jakieś sugestie gdzie szukać rozwiązania?
