[+] Plymouth-drm brak kandyduj
Aykan
[+] Plymouth-drm brak kandydującej wersji.
Post autor: Aykan »
Chciałem zainstalować plymouth. Używałem tego tutoriala: https://wiki.debian.org/plymouth. Ale podczas instalacji plymouth-drm wyskoczył mi ten błąd.
Brak kandydującej wersji plymouth-drm
Konfig Gruba:
# If you change this file, run 'update-grub' afterwards to update# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=1024x600
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
/etc/initramfs-tools/modules:
# List of modules that you want to include in your initramfs.# They will be loaded at boot time in the order below.
# Syntax:  module_name [args ...]
# You must run update-initramfs(8) to effect this change.
# Examples:
# raid1
# sd_mod
# KMS
  intel_agp
  drm
  i915 modeset=1
Log aptitude:
Stary  http://www.deb-multimedia.org sid InReleaseStary  ftp://ftp.pl.debian.org sid InRelease
Stary  http://www.deb-multimedia.org sid/main Sources
Stary  http://www.deb-multimedia.org sid/non-free Sources
Stary  http://www.deb-multimedia.org sid/main i386 Packages
Stary  http://www.deb-multimedia.org sid/non-free i386 Packages
Stary  ftp://ftp.pl.debian.org sid/main Sources/DiffIndex
Stary  ftp://ftp.pl.debian.org sid/non-free Sources/DiffIndex
Stary  ftp://ftp.pl.debian.org sid/contrib Sources/DiffIndex
Stary  ftp://ftp.pl.debian.org sid/main i386 Packages/DiffIndex
Stary  ftp://ftp.pl.debian.org sid/non-free i386 Packages/DiffIndex
Stary  ftp://ftp.pl.debian.org sid/contrib i386 Packages/DiffIndex
Stary  ftp://ftp.pl.debian.org sid/contrib Translation-en/DiffIndex
Stary  ftp://ftp.pl.debian.org sid/main Translation-pl/DiffIndex
Stary  ftp://ftp.pl.debian.org sid/main Translation-en/DiffIndex
Ign.   http://www.deb-multimedia.org sid/main Translation-pl_PL
Ign.   http://www.deb-multimedia.org sid/main Translation-en
Ign.   http://www.deb-multimedia.org sid/non-free Translation-pl_PL
Stary  ftp://ftp.pl.debian.org sid/non-free Translation-en/DiffIndex
Ign.   http://www.deb-multimedia.org sid/non-free Translation-en
Czytanie list pakietów...
Budowanie drzewa zależności...
Odczyt informacji o stanie...
Odczyt dodatkowych informacji o stanie...
Inicjalizacja stanów pakietów...
Odczyt opisów zadań...
Budowanie bazy znaczników...
Nie zostaną zainstalowane, zaktualizowane ani usunięte żadne pakiety.
0 pakietów aktualizowanych, 0 instalowanych, 0 do usunięcia i 0 nieaktualizowanych.
Do pobrania 0 B archiwów. Zajęte po rozpakowaniu: 0 B.
Zapisywanie dodatkowych informacji o stanie...
Pokaż zawartość pliku /etc/apt/sources.list
Aykan
Post autor: Aykan »
#~Sid~#deb ftp://ftp.pl.debian.org/debian/ sid main non-free contrib
deb-src ftp://ftp.pl.debian.org/debian/ sid main non-free contrib
#~~~~~~Deb-multimedia~~~~~~#
deb http://www.deb-multimedia.org/ sid main non-free
deb-src http://www.deb-multimedia.org/ sid main non-free
wpisy z frazą "deb-src" wyłącz albo usuń nie powinny Cię one w ogóle obchodzić a jak chcesz więcej o co w tym chodzi to poczytaj apt-src
popraw wpisy i zaktualizuj system poprawnie (jeżeli nie jest)..
W tej wersji nie powinno być tej zależności:
* Move the frame-buffer and drm renderers into the main plymouth package and always install them in the initramfs, this should fix the issue where the splash is not shown for some users (Closes: #752752)
* Move the libply-splash-graphics library to the main package and the themes related .so files to the -themes package, this is effectively killing the -drm package
To błąd w pakiecie. Ale nie jest to zależność a pakiet sugerowany, więc możesz spróbować to zainstalować z przełącznikiem -R
aptitude -R install plymouth
Powyższe nadpisze ustawienia w plikach konfiguracyjnych. Jak Ci zależy to musisz je ręcznie zmienić z powrotem, albo zainstalować coś z przełącznikiem -r. Więcej w manualu.
-R, --without-recommends
Nie traktuje pakietów polecanych jako zależności, podczas instalowania nowych pakietów (nadpisuje ustawienie w
/etc/apt/apt.conf i ~/.aptitude/config). Pakiety zainstalowane uprzednio w związku z zależnością polecania nie
będą usunięte.
This corresponds to the pair of configuration options Apt::Install-Recommends and
Apt::AutoRemove::RecommendsImportant.
-r, --with-recommends
Traktuje polecane pakiety jako zależności, podczas instalowania nowych pakietów (nadpisuje ustawienie w
Jest to odpowiednik opcji konfiguracyjnej Apt::Install-Recommends
Aykan
Post autor: Aykan »
Ok. Ale nadal jak klepnę
/usr/sbin/plymouth-set-default-theme joy
to wynik jest taki:
/usr/lib/i386-linux-gnu/plymouth/script.so does not exist
I nadal nie wiem jak zainstalować plymouth-drm. Acha I
aptitude install -R
pokazuje mi to:
Nie zostaną zainstalowane, zaktualizowane ani usunięte żadne pakiety.0 pakietów aktualizowanych, 0 instalowanych, 0 do usunięcia i 0 nieaktualizowanych.
Jak już napisałem pakiet plymouth-drm nie jest już potrzebny/udostępniany. Plik:
znajduje się w pakiecie: plymouth-themes - zainstaluj go.
Pełna składnia aptitude we wspomnianym przez Ciebie przypadku wygląda tak:
aptitude -R install nazwa_pakietu
Znaczy to zainstaluj pakiet "nazwa_pakietu" bez pakietów rekomendowanych.
PS. Ten opis: https://wiki.debian.org/plymouth został napisany dla stabilnej wersji systemu. Ty używasz niestabilnej wersji Debiana. Różnice i inne problemy będą się tu zdarzały.
Aykan
Post autor: Aykan »
OK. Dzięki. Wszystko działa.
