Free cycka nie widzi.
uname -a
FreeBSD hermes 10.0-RELEASE-p7 FreeBSD 10.0-RELEASE-p7 #0: Tue Jul 8 06:34:23 UTC 2014 root@amd64-builder.daemonology.net:/usr/obj/usr/src/sys/GENERIC i386
ifconfig
rl0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=2008<VLAN_MTU,WOL_MAGIC>
ether 00:1f:1f:14:66:9f
inet 192.168.32.3 netmask 0xfffffff8 broadcast 192.168.32.7
nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL>
media: Ethernet autoselect (100baseTX <full-duplex>)
status: active
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
inet 127.0.0.1 netmask 0xff000000
nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>Kod: Zaznacz cały
pciconf -lvbc
hostb0@pci0:0:0:0: class=0x060000 card=0x00000000 chip=0x1a308086 rev=0x11 hdr=0x00
vendor = 'Intel Corporation'
device = '82845 845 [Brookdale] Chipset Host Bridge'
class = bridge
subclass = HOST-PCI
bar [10] = type Prefetchable Memory, range 32, base 0xe0000000, size 67108864, enabled
cap 09[e4] = vendor (length 4) Intel cap 10 version 1
cap 02[a0] = AGP 4x 2x 1x SBA disabled
pcib1@pci0:0:1:0: class=0x060400 card=0x00000000 chip=0x1a318086 rev=0x11 hdr=0x01
device = '82845 845 [Brookdale] Chipset AGP Bridge'
class = bridge
subclass = PCI-PCI
uhci0@pci0:0:29:0: class=0x0c0300 card=0x56611462 chip=0x24c28086 rev=0x01 hdr=0x00
device = '82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller'
class = serial bus
subclass = USB
bar [20] = type I/O Port, range 32, base 0xd400, size 32, enabled
uhci1@pci0:0:29:1: class=0x0c0300 card=0x56611462 chip=0x24c48086 rev=0x01 hdr=0x00
class = serial bus
subclass = USB
bar [20] = type I/O Port, range 32, base 0xd800, size 32, enabled
uhci2@pci0:0:29:2: class=0x0c0300 card=0x56611462 chip=0x24c78086 rev=0x01 hdr=0x00
class = serial bus
subclass = USB
bar [20] = type I/O Port, range 32, base 0xdc00, size 32, enabled
ehci0@pci0:0:29:7: class=0x0c0320 card=0x39811462 chip=0x24cd8086 rev=0x01 hdr=0x00
device = '82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller'
class = serial bus
subclass = USB
bar [10] = type Memory, range 32, base 0xdffffc00, size 1024, enabled
cap 01[50] = powerspec 2 supports D0 D3 current D0
cap 0a[58] = EHCI Debug Port at offset 0x80 in map 0x14
pcib2@pci0:0:30:0: class=0x060400 card=0x00000000 chip=0x244e8086 rev=0x81 hdr=0x01
device = '82801 PCI Bridge'
class = bridge
subclass = PCI-PCI
isab0@pci0:0:31:0: class=0x060100 card=0x00000000 chip=0x24c08086 rev=0x01 hdr=0x00
device = '82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge'
class = bridge
subclass = PCI-ISA
atapci0@pci0:0:31:1: class=0x01018a card=0x56611462 chip=0x24cb8086 rev=0x01 hdr=0x00
device = '82801DB (ICH4) IDE Controller'
class = mass storage
subclass = ATA
bar [20] = type I/O Port, range 32, base 0xfc00, size 16, enabled
bar [24] = type Memory, range 32, base 0, size 1024, enabled
none0@pci0:0:31:3: class=0x0c0500 card=0x56611462 chip=0x24c38086 rev=0x01 hdr=0x00
device = '82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller'
class = serial bus
subclass = SMBus
bar [20] = type I/O Port, range 32, base 0xc00, size 32, enabled
pcm0@pci0:0:31:5: class=0x040100 card=0x56611462 chip=0x24c58086 rev=0x01 hdr=0x00
device = '82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller'
class = multimedia
subclass = audio
bar [10] = type I/O Port, range 32, base 0xd000, size 256, enabled
bar [14] = type I/O Port, range 32, base 0xcc00, size 64, enabled
bar [18] = type Memory, range 32, base 0xdffffa00, size 512, enabled
bar [1c] = type Memory, range 32, base 0xdffff900, size 256, enabled
vgapci0@pci0:1:0:0: class=0x030000 card=0x34281458 chip=0x02e110de rev=0xa2 hdr=0x00
vendor = 'NVIDIA Corporation'
device = 'G73 [GeForce 7600 GS]'
class = display
subclass = VGA
bar [10] = type Memory, range 32, base 0xde000000, size 16777216, enabled
bar [14] = type Prefetchable Memory, range 32, base 0xc0000000, size 268435456, enabled
bar [18] = type Memory, range 32, base 0xdd000000, size 16777216, enabled
cap 01[60] = powerspec 2 supports D0 D3 current D0
cap 02[44] = AGP 4x 2x 1x SBA disabled
rl0@pci0:3:4:0: class=0x020000 card=0x813910ec chip=0x813910ec rev=0x10 hdr=0x00
vendor = 'Realtek Semiconductor Co., Ltd.'
device = 'RTL-8139/8139C/8139C+'
class = network
subclass = ethernet
bar [10] = type I/O Port, range 32, base 0xbc00, size 256, enabled
bar [14] = type Memory, range 32, base 0xdfefff00, size 256, enabled
cap 01[50] = powerspec 2 supports D0 D1 D2 D3 current D0Kod: Zaznacz cały
dmesg
Copyright (c) 1992-2014 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD clang version 3.3 (tags/RELEASE_33/final 183502) 20130610
CPU: Intel(R) Pentium(R) 4 CPU 2.00GHz (2004.59-MHz 686-class CPU)
Origin = "GenuineIntel" Id = 0xf24 Family = 0xf Model = 0x2 Stepping = 4
Features=0x3febfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM>
real memory = 1610612736 (1536 MB)
avail memory = 1557536768 (1485 MB)
Event timer "LAPIC" quality 400
ACPI APIC Table: <AMIINT INTEL845>
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
random: <Software, Yarrow> initialized
acpi0: <AMIINT INTEL845> on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
acpi_button0: <Power Button> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pcib0: Length mismatch for 3 range: 9fe00000 vs 9ec00000
pci0: <ACPI PCI bus> on pcib0
agp0: <Intel 82845 host to AGP bridge> on hostb0
pcib1: <PCI-PCI bridge> at device 1.0 on pci0
pci1: <PCI bus> on pcib1
vgapci0: <VGA-compatible display> mem 0xde000000-0xdeffffff,0xc0000000-0xcfffffff,0xdd000000-0xddffffff irq 16 at device 0.0 on pci1
vgapci0: Boot video device
uhci0: <Intel 82801DB (ICH4) USB controller USB-A> port 0xd400-0xd41f irq 16 at device 29.0 on pci0
uhci0: LegSup = 0x2f00
usbus0 on uhci0
uhci1: <Intel 82801DB (ICH4) USB controller USB-B> port 0xd800-0xd81f irq 19 at device 29.1 on pci0
uhci1: LegSup = 0x2f00
usbus1 on uhci1
uhci2: <Intel 82801DB (ICH4) USB controller USB-C> port 0xdc00-0xdc1f irq 18 at device 29.2 on pci0
uhci2: LegSup = 0x2f00
usbus2 on uhci2
ehci0: <Intel 82801DB/L/M (ICH4) USB 2.0 controller> mem 0xdffffc00-0xdfffffff irq 23 at device 29.7 on pci0
usbus3: EHCI version 1.0
usbus3 on ehci0
pcib2: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci3: <ACPI PCI bus> on pcib2
rl0: <RealTek 8139 10/100BaseTX> port 0xbc00-0xbcff mem 0xdfefff00-0xdfefffff irq 16 at device 4.0 on pci3
miibus0: <MII bus> on rl0
rlphy0: <RealTek internal media interface> PHY 0 on miibus0
rlphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
rl0: Ethernet address: 00:1f:1f:14:66:9f
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <Intel ICH4 UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xfc00-0xfc0f at device 31.1 on pci0
ata0: <ATA channel> at channel 0 on atapci0
ata1: <ATA channel> at channel 1 on atapci0
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
pcm0: <Intel ICH4 (82801DB)> port 0xd000-0xd0ff,0xcc00-0xcc3f mem 0xdffffa00-0xdffffbff,0xdffff900-0xdffff9ff irq 17 at device 31.5 on pci0
pcm0: <Avance Logic ALC202 AC97 Codec>
acpi_button1: <Sleep Button> on acpi0
fdc0: <floppy drive controller> port 0x3f2-0x3f3,0x3f4-0x3f5,0x3f7 irq 6 drq 2 on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
ppc0: <Parallel port> port 0x378-0x37f,0x778-0x77b irq 7 drq 3 on acpi0
ppc0: SMC-like chipset (ECP/EPP/PS2/NIBBLE) in COMPATIBLE mode
ppc0: FIFO with 16/16/9 bytes threshold
ppbus0: <Parallel port bus> on ppc0
lpt0: <Printer> on ppbus0
lpt0: Interrupt-driven port
ppi0: <Parallel I/O> on ppbus0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
pmtimer0 on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
Timecounters tick every 1.000 msec
random: unblocking device.
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 480Mbps High Speed USB v2.0
ugen1.1: <Intel> at usbus1
uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen0.1: <Intel> at usbus0
uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen3.1: <Intel> at usbus3
uhub2: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
ugen2.1: <Intel> at usbus2
uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ata1: DMA limited to UDMA33, controller found non-ATA66 cable
ada0 at ata0 bus 0 scbus0 target 0 lun 0
ada0: <ST3120026A 8.54> ATA-6 device
ada0: Serial Number 5JS5ABRF
ada0: 100.000MB/s transfers (UDMA5, PIO 8192bytes)
ada0: 114473MB (234441648 512 byte sectors: 16H 255S/T 16383C)
ada0: Previously was known as ad0
cd0 at ata1 bus 0 scbus1 target 0 lun 0
cd0: <HL-DT-ST DVD-RAM GH22LP20 1.04> Removable CD-ROM SCSI-0 device
cd0: 33.300MB/s transfers (UDMA2, ATAPI 12bytes, PIO 65534bytes)
cd0: Attempt to query device size failed: NOT READY, Medium not present - tray closed
Timecounter "TSC" frequency 2004593404 Hz quality 800
Root mount waiting for: usbus3 usbus2 usbus1 usbus0
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
uhub3: 2 ports with 2 removable, self powered
uhub2: 6 ports with 6 removable, self powered
ugen3.2: <ATHEROS> at usbus3
Trying to mount root from ufs:/dev/ada0p2 [rw]...
ugen0.2: <vendor 0x04f3> at usbus0
ums0: <vendor 0x04f3 OM, class 0/0, rev 1.10/24.58, addr 2> on usbus0
ums0: 3 buttons and [XYZ] coordinates ID=0
pid 1118 (kactivitymanagerd), uid 1002: exited on signal 4 (core dumped)
ugen3.2: <ATHEROS> at usbus3 (disconnected)
pid 1119 (kactivitymanagerd), uid 1002: exited on signal 4 (core dumped)
Waiting (max 60 seconds) for system process `vnlru' to stop...done
Waiting (max 60 seconds) for system process `bufdaemon' to stop...done
Waiting (max 60 seconds) for system process `syncer' to stop...
Syncing disks, vnodes remaining...12 8 0 0 0 0 done
All buffers synced.
Uptime: 50m35s
usbus0: Controller shutdown
uhub1: at usbus0, port 1, addr 1 (disconnected)
ugen0.2: <vendor 0x04f3> at usbus0 (disconnected)
ums0: at uhub1, port 1, addr 2 (disconnected)
usbus0: Controller shutdown complete
usbus1: Controller shutdown
uhub0: at usbus1, port 1, addr 1 (disconnected)
usbus1: Controller shutdown complete
usbus2: Controller shutdown
uhub3: at usbus2, port 1, addr 1 (disconnected)
usbus2: Controller shutdown complete
usbus3: Controller shutdown
uhub2: at usbus3, port 1, addr 1 (disconnected)
usbus3: Controller shutdown complete
Rebooting...
kbd1 at kbdmux0
usbus0 on uhci0
usbus1 on uhci1
usbus2 on uhci2
usbus3 on ehci0
kbd0 at atkbd0
pmtimer0 on isa0
Timecounter "TSC" frequency 2004592188 Hz quality 800
pid 1105 (kactivitymanagerd), uid 1002: exited on signal 4 (core dumped)
pid 1106 (kactivitymanagerd), uid 1002: exited on signal 4 (core dumped)
Syncing disks, vnodes remaining...11 11 7 1 1 0 done
All buffers synced.
Uptime: 1h41m22s
Rebooting...
kbd1 at kbdmux0
usbus0 on uhci0
usbus1 on uhci1
usbus2 on uhci2
usbus3 on ehci0
kbd0 at atkbd0
pmtimer0 on isa0
Timecounter "TSC" frequency 2004587016 Hz quality 800
pid 1111 (kactivitymanagerd), uid 1002: exited on signal 4 (core dumped)
root@hermes:/mnt # dmesg
kbd1 at kbdmux0
usbus0 on uhci0
usbus1 on uhci1
usbus2 on uhci2
usbus3 on ehci0
kbd0 at atkbd0
pmtimer0 on isa0
All buffers synced.
Uptime: 50m35s
Rebooting...
kbd1 at kbdmux0
usbus0 on uhci0
usbus1 on uhci1
usbus2 on uhci2
usbus3 on ehci0
kbd0 at atkbd0
pmtimer0 on isa0
All buffers synced.
Uptime: 1h41m22s
Rebooting...
kbd1 at kbdmux0
usbus0 on uhci0
usbus1 on uhci1
usbus2 on uhci2
usbus3 on ehci0
kbd0 at atkbd0
pmtimer0 on isa0
pid 1111 (kactivitymanagerd), uid 1002: exited on signal 4 (core dumped)Kod: Zaznacz cały
pciconf -vl
class = bridge
subclass = HOST-PCI
class = bridge
subclass = PCI-PCI
class = serial bus
subclass = USB
class = serial bus
subclass = USB
class = serial bus
subclass = USB
class = serial bus
subclass = USB
class = bridge
subclass = PCI-PCI
class = bridge
subclass = PCI-ISA
subclass = ATA
class = serial bus
subclass = SMBus
class = multimedia
subclass = audio
class = display
subclass = VGA
class = network
subclass = ethernet
