aptitude update && aptitude upgradeProsilbym o pomoc, z gory dzieki.
aptitude update && aptitude upgradeKod: Zaznacz cały
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11abgn ESSID:"TP-LINK_D7F796"
Mode:Managed Frequency:2.412 GHz Access Point: B0:48:7A :D 7:F7:96
Bit Rate=54 Mb/s Tx-Power=15 dBm
Retry short limit:7 RTS thr :o ff Fragment thr :o ff
Encryption key :o ff
Power Management :o ff
Link Quality=70/70 Signal level=-27 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:1 Invalid misc:0 Missed beacon:0
eth0 Link encap:Ethernet HWaddr e8:03:9a:b2:d5:e5 inet addr:192.168.1.3 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::ea03:9aff:feb2:d5e5/64 Scope:Link
RX packets:453588 errors:0 dropped:0 overruns:0 frame:0
TX packets:453509 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:362472279 (345.6 MiB) TX bytes:379323352 (361.7 MiB)
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:765 errors:0 dropped:0 overruns:0 frame:0
TX packets:765 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:75558 (73.7 KiB) TX bytes:75558 (73.7 KiB)
wlan0 Link encap:Ethernet HWaddr c4:85:08:1d:ba:fa
inet addr:192.168.1.2 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::c685:8ff:fe1d:bafa/64 Scope:Link
RX packets:1377 errors:0 dropped:0 overruns:0 frame:0
TX packets:755 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:167999 (164.0 KiB) TX bytes:63554 (62.0 KiB)Kod: Zaznacz cały
dmesg
lspci -n
lspci -kKod: Zaznacz cały
[ 0.000000] CPU0 microcode updated early to revision 0x1b, date = 2014-05-29[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.14-1-amd64 (debian-kernel@lists.debian.org) (gcc version 4.8.3 (Debian 4.8.3-4) ) #1 SMP Debian 3.14.12-1 (2014-07-11)
[ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-3.14-1-amd64 root=UUID=d4c14919-96c4-46c3-909b-a5760cb2e5da ro quiet
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000040005000-0x00000000c9f7afff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000c9f7b000-0x00000000ca24cfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ca24d000-0x00000000ca259fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000ca25a000-0x00000000ca40afff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ca40b000-0x00000000ca412fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000ca413000-0x00000000ca49ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ca4a0000-0x00000000ca561fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ca562000-0x00000000ca972fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ca973000-0x00000000ca973fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ca974000-0x00000000ca9b6fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ca9b7000-0x00000000cadbcfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cadbd000-0x00000000caff3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000caff4000-0x00000000caffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cb800000-0x00000000cf9fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000032f5fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: SAMSUNG ELECTRONICS CO., LTD. 550P5C/550P7C/SAMSUNG_NP1234567890, BIOS P08AAA.045.130418.dg 04/18/2013
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] No AGP bridge found
[ 0.000000] e820: last_pfn = 0x32f600 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask E00000000 write-back
[ 0.000000] 1 base 200000000 mask F00000000 write-back
[ 0.000000] 2 base 300000000 mask FC0000000 write-back
[ 0.000000] 3 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 4 base 0D0000000 mask FF0000000 uncachable
[ 0.000000] 5 base 0CC000000 mask FFC000000 uncachable
[ 0.000000] 6 base 0CB800000 mask FFF800000 uncachable
[ 0.000000] 7 base 330000000 mask FF0000000 uncachable
[ 0.000000] 8 base 32F800000 mask FFF800000 uncachable
[ 0.000000] 9 base 32F600000 mask FFFE00000 uncachable
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820: update [mem 0xcb800000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xcb000 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000fd840-0x000fd84f] mapped at [ffff8800000fd840]
[ 0.000000] Base memory trampoline at [ffff880000097000] 97000 size 24576
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[ 0.000000] BRK [0x01aa3000, 0x01aa3fff] PGTABLE
[ 0.000000] BRK [0x01aa4000, 0x01aa4fff] PGTABLE
[ 0.000000] BRK [0x01aa5000, 0x01aa5fff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x32f400000-0x32f5fffff]
[ 0.000000] [mem 0x32f400000-0x32f5fffff] page 2M
[ 0.000000] BRK [0x01aa6000, 0x01aa6fff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x32c000000-0x32f3fffff]
[ 0.000000] [mem 0x32c000000-0x32f3fffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x300000000-0x32bffffff]
[ 0.000000] [mem 0x300000000-0x32bffffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x00100000-0x1fffffff]
[ 0.000000] [mem 0x00100000-0x001fffff] page 4k
[ 0.000000] [mem 0x00200000-0x1fffffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x20200000-0x40003fff]
[ 0.000000] [mem 0x20200000-0x3fffffff] page 2M
[ 0.000000] [mem 0x40000000-0x40003fff] page 4k
[ 0.000000] BRK [0x01aa7000, 0x01aa7fff] PGTABLE
[ 0.000000] BRK [0x01aa8000, 0x01aa8fff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x40005000-0xc9f7afff]
[ 0.000000] [mem 0x40005000-0x401fffff] page 4k
[ 0.000000] [mem 0x40200000-0xc9dfffff] page 2M
[ 0.000000] [mem 0xc9e00000-0xc9f7afff] page 4k
[ 0.000000] init_memory_mapping: [mem 0xca413000-0xca49ffff]
[ 0.000000] [mem 0xca413000-0xca49ffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0xca973000-0xca973fff]
[ 0.000000] [mem 0xca973000-0xca973fff] page 4k
[ 0.000000] init_memory_mapping: [mem 0xca9b7000-0xcadbcfff]
[ 0.000000] [mem 0xca9b7000-0xca9fffff] page 4k
[ 0.000000] [mem 0xcaa00000-0xcabfffff] page 2M
[ 0.000000] [mem 0xcac00000-0xcadbcfff] page 4k
[ 0.000000] init_memory_mapping: [mem 0xcaff4000-0xcaffffff]
[ 0.000000] [mem 0xcaff4000-0xcaffffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x100000000-0x2ffffffff]
[ 0.000000] [mem 0x100000000-0x2ffffffff] page 2M
[ 0.000000] RAMDISK: [mem 0x364de000-0x37266fff]
[ 0.000000] ACPI: RSDP 00000000000f0490 000024 (v02 SECCSD)
[ 0.000000] ACPI: XSDT 00000000ca24d080 000084 (v01 SECCSD LH43STAR 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 00000000ca255998 00010C (v05 SECCSD LH43STAR 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 00000000ca24d198 008800 (v02 SECCSD LH43STAR 00000018 INTL 20051117)
[ 0.000000] ACPI: FACS 00000000ca560f80 000040
[ 0.000000] ACPI: APIC 00000000ca255aa8 000072 (v03 SECCSD LH43STAR 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 00000000ca255b20 000044 (v01 SECCSD LH43STAR 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG 00000000ca255b68 00003C (v01 SECCSD LH43STAR 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET 00000000ca255ba8 000038 (v01 SECCSD LH43STAR 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT 00000000ca255be0 00036D (v01 SataRe SataTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: SLIC 00000000ca255f50 000176 (v01 SECCSD LH43STAR 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 00000000ca2560c8 000980 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT 00000000ca256a48 000A7E (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT 00000000ca2574c8 0007CA (v01 SgRef SgTabl 00001000 INTL 20051117)
[ 0.000000] ACPI: SSDT 00000000ca257c98 001533 (v01 OptRef OptTabl 00001000 INTL 20051117)
[ 0.000000] ACPI: BGRT 00000000ca2591d0 000038 (v00 SECCSD LH43STAR 01072009 AMI 00010013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000032f5fffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x32f5fffff]
[ 0.000000] NODE_DATA [mem 0x32f5ec000-0x32f5f0fff]
[ 0.000000] [ffffea0000000000-ffffea000b3fffff] PMD -> [ffff880322c00000-ffff88032d5fffff] on node 0
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x00001000-0x00ffffff]
[ 0.000000] DMA32 [mem 0x01000000-0xffffffff]
[ 0.000000] Normal [mem 0x100000000-0x32f5fffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00001000-0x0009cfff]
[ 0.000000] node 0: [mem 0x00100000-0x1fffffff]
[ 0.000000] node 0: [mem 0x20200000-0x40003fff]
[ 0.000000] node 0: [mem 0x40005000-0xc9f7afff]
[ 0.000000] node 0: [mem 0xca413000-0xca49ffff]
[ 0.000000] node 0: [mem 0xca973000-0xca973fff]
[ 0.000000] node 0: [mem 0xca9b7000-0xcadbcfff]
[ 0.000000] node 0: [mem 0xcaff4000-0xcaffffff]
[ 0.000000] node 0: [mem 0x100000000-0x32f5fffff]
[ 0.000000] On node 0 totalpages: 3119030
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3996 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 11264 pages used for memmap
[ 0.000000] DMA32 zone: 823834 pages, LIFO batch:31
[ 0.000000] Normal zone: 31325 pages used for memmap
[ 0.000000] Normal zone: 2291200 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x20000000-0x201fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x40004000-0x40004fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xc9f7b000-0xca24cfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xca24d000-0xca259fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xca25a000-0xca40afff]
[ 0.000000] PM: Registered nosave memory: [mem 0xca40b000-0xca412fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xca4a0000-0xca561fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xca562000-0xca972fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xca974000-0xca9b6fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcadbd000-0xcaff3fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcb000000-0xcb7fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcb800000-0xcf9fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcfa00000-0xf7ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.000000] e820: [mem 0xcfa00000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 29 pages/cpu @ffff88032f200000 s86080 r8192 d24512 u524288
[ 0.000000] pcpu-alloc: s86080 r8192 d24512 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 3076364
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-3.14-1-amd64 root=UUID=d4c14919-96c4-46c3-909b-a5760cb2e5da ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] xsave: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] Checking aperture...
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 12210332K/12476120K available (4912K kernel code, 704K rwdata, 1664K rodata, 1000K init, 960K bss, 265788K reserved)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS:33024 nr_irqs:712 16
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2494.192 MHz processor
[ 0.000030] Calibrating delay loop (skipped), value calculated using timer frequency.. 4988.38 BogoMIPS (lpj=9976768)
[ 0.000032] pid_max: default: 32768 minimum: 301
[ 0.000038] ACPI: Core revision 20131218
[ 0.005236] ACPI: All ACPI Tables successfully acquired
[ 0.022541] Security Framework initialized
[ 0.022545] AppArmor: AppArmor disabled by boot time parameter
[ 0.022546] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.023383] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.027278] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.029028] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.029061] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.029262] Initializing cgroup subsys memory
[ 0.029266] Initializing cgroup subsys devices
[ 0.029267] Initializing cgroup subsys freezer
[ 0.029268] Initializing cgroup subsys net_cls
[ 0.029269] Initializing cgroup subsys blkio
[ 0.029271] Initializing cgroup subsys perf_event
[ 0.029293] CPU: Physical Processor ID: 0
[ 0.029293] CPU: Processor Core ID: 0
[ 0.029297] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.029297] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.029653] mce: CPU supports 7 MCE banks
[ 0.029664] CPU0: Thermal monitoring enabled (TM1)
[ 0.029672] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[ 0.029672] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 0.029672] tlb_flushall_shift: 2
[ 0.029766] Freeing SMP alternatives memory: 20K (ffffffff819ac000 - ffffffff819b1000)
[ 0.031316] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.071043] smpboot: CPU0: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz (fam: 06, model: 3a, stepping: 09)
[ 0.071050] TSC deadline timer enabled
[ 0.071056] Performance Events: PEBS fmt1+, 16-deep LBR, IvyBridge events, full-width counters, Intel PMU driver.
[ 0.071062] ... version: 3
[ 0.071063] ... bit width: 48
[ 0.071063] ... generic registers: 4
[ 0.071064] ... value mask: 0000ffffffffffff
[ 0.071065] ... max period: 0000ffffffffffff
[ 0.071066] ... fixed-purpose events: 3
[ 0.071067] ... event mask: 000000070000000f
[ 0.071288] x86: Booting SMP configuration:
[ 0.071290] .... node #0, CPUs: #1
[ 0.081901] CPU1 microcode updated early to revision 0x1b, date = 2014-05-29
[ 0.084892] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.084976] #2 #3
[ 0.112094] x86: Booted up 1 node, 4 CPUs
[ 0.112098] smpboot: Total of 4 processors activated (19953.53 BogoMIPS)
[ 0.115103] devtmpfs: initialized
[ 0.118278] PM: Registering ACPI NVS region [mem 0xca4a0000-0xca561fff] (794624 bytes)
[ 0.118298] PM: Registering ACPI NVS region [mem 0xca974000-0xca9b6fff] (274432 bytes)
[ 0.118421] pinctrl core: initialized pinctrl subsystem
[ 0.118470] NET: Registered protocol family 16
[ 0.118550] cpuidle: using governor ladder
[ 0.118551] cpuidle: using governor menu
[ 0.118575] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.118576] ACPI: bus type PCI registered
[ 0.118578] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.118648] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.118650] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.126428] PCI: Using configuration type 1 for base access
[ 0.127215] bio: create slab <bio-0> at 0
[ 0.127314] ACPI: Added _OSI(Module Device)
[ 0.127316] ACPI: Added _OSI(Processor Device)
[ 0.127317] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.127318] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.129518] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.176219] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.177253] ACPI: SSDT 00000000ca3b8818 000775 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.177541] ACPI: Dynamic OEM Table Load:
[ 0.177543] ACPI: SSDT (null) 000775 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.188413] ACPI: SSDT 00000000ca3b9a98 000303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.188725] ACPI: Dynamic OEM Table Load:
[ 0.188726] ACPI: SSDT (null) 000303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.200310] ACPI: SSDT 00000000ca3bac18 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.200589] ACPI: Dynamic OEM Table Load:
[ 0.200590] ACPI: SSDT (null) 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.644729] ACPI: Interpreter enabled
[ 0.644736] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20131218/hwxface-580)
[ 0.644741] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20131218/hwxface-580)
[ 0.644754] ACPI: (supports S0 S3 S4 S5)
[ 0.644755] ACPI: Using IOAPIC for interrupt routing
[ 0.644783] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.644928] ACPI: No dock devices found.
[ 0.651509] ACPI: Power Resource [FN00] (off)
[ 0.651591] ACPI: Power Resource [FN01] (off)
[ 0.652111] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.652115] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.652318] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
[ 0.652439] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[ 0.653012] PCI host bridge to bus 0000:00
[ 0.653015] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 0.653017] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.653018] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.653020] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.653021] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
[ 0.653022] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[ 0.653024] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.653025] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.653027] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.653028] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.653029] pci_bus 0000:00: root bus resource [mem 0xcfa00000-0xfeafffff]
[ 0.653036] pci 0000:00:00.0: [8086:0154] type 00 class 0x060000
[ 0.653115] pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
[ 0.653145] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.653179] pci 0000:00:01.0: System wakeup disabled by ACPI
[ 0.653218] pci 0000:00:02.0: [8086:0166] type 00 class 0x030000
[ 0.653228] pci 0000:00:02.0: reg 0x10: [mem 0xf7400000-0xf77fffff 64bit]
[ 0.653234] pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.653239] pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
[ 0.653333] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
[ 0.653356] pci 0000:00:14.0: reg 0x10: [mem 0xf7900000-0xf790ffff 64bit]
[ 0.653425] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.653499] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
[ 0.653522] pci 0000:00:16.0: reg 0x10: [mem 0xf791a000-0xf791a00f 64bit]
[ 0.653597] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.653677] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
[ 0.653698] pci 0000:00:1a.0: reg 0x10: [mem 0xf7918000-0xf79183ff]
[ 0.653786] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.653861] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
[ 0.653876] pci 0000:00:1b.0: reg 0x10: [mem 0xf7910000-0xf7913fff 64bit]
[ 0.653949] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.654020] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
[ 0.654100] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.654141] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.654178] pci 0000:00:1c.3: [8086:1e16] type 01 class 0x060400
[ 0.654258] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.654298] pci 0000:00:1c.3: System wakeup disabled by ACPI
[ 0.654341] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[ 0.654363] pci 0000:00:1d.0: reg 0x10: [mem 0xf7917000-0xf79173ff]
[ 0.654451] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.654526] pci 0000:00:1f.0: [8086:1e59] type 00 class 0x060100
[ 0.654692] pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601
[ 0.654710] pci 0000:00:1f.2: reg 0x10: [io 0xf0b0-0xf0b7]
[ 0.654718] pci 0000:00:1f.2: reg 0x14: [io 0xf0a0-0xf0a3]
[ 0.654726] pci 0000:00:1f.2: reg 0x18: [io 0xf090-0xf097]
[ 0.654734] pci 0000:00:1f.2: reg 0x1c: [io 0xf080-0xf083]
[ 0.654742] pci 0000:00:1f.2: reg 0x20: [io 0xf060-0xf07f]
[ 0.654749] pci 0000:00:1f.2: reg 0x24: [mem 0xf7916000-0xf79167ff]
[ 0.654793] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.654860] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
[ 0.654876] pci 0000:00:1f.3: reg 0x10: [mem 0xf7915000-0xf79150ff 64bit]
[ 0.654895] pci 0000:00:1f.3: reg 0x20: [io 0xf040-0xf05f]
[ 0.655021] pci 0000:01:00.0: [10de:0de9] type 00 class 0x030000
[ 0.655028] pci 0000:01:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
[ 0.655035] pci 0000:01:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.655043] pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.655048] pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.655053] pci 0000:01:00.0: reg 0x30: [mem 0xf7000000-0xf707ffff pref]
[ 0.655095] pci 0000:01:00.0: System wakeup disabled by ACPI
[ 0.663758] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.663763] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.663780] pci 0000:00:01.0: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.663783] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.664033] pci 0000:02:00.0: [8086:088e] type 00 class 0x028000
[ 0.664183] pci 0000:02:00.0: reg 0x10: [mem 0xf7800000-0xf7801fff 64bit]
[ 0.664964] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.675866] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.675873] pci 0000:00:1c.0: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.676029] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.676098] pci 0000:03:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.676220] pci 0000:03:00.0: reg 0x18: [mem 0xf2104000-0xf2104fff 64bit pref]
[ 0.676295] pci 0000:03:00.0: reg 0x20: [mem 0xf2100000-0xf2103fff 64bit pref]
[ 0.676710] pci 0000:03:00.0: supports D1 D2
[ 0.676711] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.683844] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.683848] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
[ 0.683857] pci 0000:00:1c.3: bridge window [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.683902] acpi PNP0A08:00: Disabling ASPM (FADT indicates it is unsupported)
[ 0.684113] ACPI: PCI Interrupt Link [LNKA] (IRQs 5 7 10 *11)
[ 0.684159] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 7 *10 11)
[ 0.684203] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 7 *10 11)
[ 0.684245] ACPI: PCI Interrupt Link [LNKD] (IRQs *5 7 10 11)
[ 0.684287] ACPI: PCI Interrupt Link [LNKE] (IRQs 5 7 10 11) *0, disabled.
[ 0.684329] ACPI: PCI Interrupt Link [LNKF] (IRQs 5 7 10 11) *0, disabled.
[ 0.684371] ACPI: PCI Interrupt Link [LNKG] (IRQs 5 *7 10 11)
[ 0.684412] ACPI: PCI Interrupt Link [LNKH] (IRQs 5 7 10 *11)
[ 0.684669] ACPI: Enabled 4 GPEs in block 00 to 3F
[ 0.684706] ACPI : EC: GPE = 0x17, I/O: command/status = 0x66, data = 0x62
[ 0.684884] ACPI : EC: 0 stale EC events cleared
[ 0.684964] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.684968] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=none,locks=none
[ 0.684970] vgaarb: loaded
[ 0.684971] vgaarb: bridge control possible 0000:01:00.0
[ 0.684972] vgaarb: no bridge control possible 0000:00:02.0
[ 0.685007] PCI: Using ACPI for IRQ routing
[ 0.686483] PCI: pci_cache_line_size set to 64 bytes
[ 0.686531] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[ 0.686533] e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
[ 0.686534] e820: reserve RAM buffer [mem 0xc9f7b000-0xcbffffff]
[ 0.686536] e820: reserve RAM buffer [mem 0xca4a0000-0xcbffffff]
[ 0.686538] e820: reserve RAM buffer [mem 0xca974000-0xcbffffff]
[ 0.686539] e820: reserve RAM buffer [mem 0xcadbd000-0xcbffffff]
[ 0.686540] e820: reserve RAM buffer [mem 0xcb000000-0xcbffffff]
[ 0.686542] e820: reserve RAM buffer [mem 0x32f600000-0x32fffffff]
[ 0.686638] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.686642] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.688666] Switched to clocksource hpet
[ 0.690222] pnp: PnP ACPI init
[ 0.690233] ACPI: bus type PNP registered
[ 0.690303] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.690306] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.690315] pnp 00:01: [dma 4]
[ 0.690331] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.690351] pnp 00:02: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.690441] pnp 00:03: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.690479] system 00:04: [io 0x0680-0x069f] has been reserved
[ 0.690481] system 00:04: [io 0x0200-0x020f] has been reserved
[ 0.690483] system 00:04: [io 0xffff] has been reserved
[ 0.690485] system 00:04: [io 0xffff] has been reserved
[ 0.690486] system 00:04: [io 0x0400-0x0453] could not be reserved
[ 0.690488] system 00:04: [io 0x0458-0x047f] has been reserved
[ 0.690490] system 00:04: [io 0x0500-0x057f] has been reserved
[ 0.690491] system 00:04: [io 0x0a00-0x0a07] has been reserved
[ 0.690493] system 00:04: [io 0x164e-0x164f] has been reserved
[ 0.690495] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.690533] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.690575] system 00:06: [io 0x0454-0x0457] has been reserved
[ 0.690578] system 00:06: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.690631] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.690674] pnp 00:08: Plug and Play ACPI device, IDs PNP0f13 SYN0002 (active)
[ 0.690716] system 00:09: [io 0x04d0-0x04d1] has been reserved
[ 0.690719] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.690742] pnp 00:0a: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.690901] system 00:0b: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.690903] system 00:0b: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.690905] system 00:0b: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.690906] system 00:0b: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.690908] system 00:0b: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.690910] system 00:0b: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.690912] system 00:0b: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.690913] system 00:0b: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.690915] system 00:0b: [mem 0xff000000-0xffffffff] has been reserved
[ 0.690917] system 00:0b: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.690919] system 00:0b: [mem 0xcfa00000-0xcfa00fff] has been reserved
[ 0.690921] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.691253] system 00:0c: [mem 0x20000000-0x201fffff] has been reserved
[ 0.691255] system 00:0c: [mem 0x40004000-0x40004fff] has been reserved
[ 0.691257] system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.691268] pnp: PnP ACPI: found 13 devices
[ 0.691269] ACPI: bus type PNP unregistered
[ 0.697515] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.697518] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.697521] pci 0000:00:01.0: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.697524] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.697526] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.697531] pci 0000:00:1c.0: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.697540] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.697543] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
[ 0.697550] pci 0000:00:1c.3: bridge window [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.697557] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.697558] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.697560] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.697561] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.697563] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.697564] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.697566] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.697567] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.697568] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.697570] pci_bus 0000:00: resource 13 [mem 0xcfa00000-0xfeafffff]
[ 0.697571] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.697573] pci_bus 0000:01: resource 1 [mem 0xf6000000-0xf70fffff]
[ 0.697574] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.697576] pci_bus 0000:02: resource 1 [mem 0xf7800000-0xf78fffff]
[ 0.697578] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.697579] pci_bus 0000:03: resource 2 [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.697631] NET: Registered protocol family 2
[ 0.697836] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.698056] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.698172] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.698189] TCP: reno registered
[ 0.698205] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.698256] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.698357] NET: Registered protocol family 1
[ 0.698370] pci 0000:00:02.0: Boot video device
[ 0.698857] PCI: CLS 64 bytes, default 64
[ 0.698898] Unpacking initramfs...
[ 0.927067] Freeing initrd memory: 13860K (ffff8800364de000 - ffff880037267000)
[ 0.927072] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.927074] software IO TLB [mem 0xc5f7b000-0xc9f7b000] (64MB) mapped at [ffff8800c5f7b000-ffff8800c9f7afff]
[ 0.927258] RAPL PMU detected, hw unit 2^-16 Joules, API unit is 2^-32 Joules, 3 fixed counters 163840 ms ovfl timer
[ 0.927299] microcode: CPU0 sig=0x306a9, pf=0x10, revision=0x1b
[ 0.927308] microcode: CPU1 sig=0x306a9, pf=0x10, revision=0x1b
[ 0.927312] microcode: CPU2 sig=0x306a9, pf=0x10, revision=0x1b
[ 0.927318] microcode: CPU3 sig=0x306a9, pf=0x10, revision=0x1b
[ 0.927380] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.927606] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.927655] audit: initializing netlink subsys (disabled)
[ 0.927673] audit: type=2000 audit(1405519641.908:1): initialized
[ 0.940186] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.940359] VFS: Disk quotas dquot_6.5.2
[ 0.940378] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.940425] msgmni has been set to 23875
[ 0.940626] alg: No test for stdrng (krng)
[ 0.940649] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.940684] io scheduler noop registered
[ 0.940685] io scheduler deadline registered
[ 0.940701] io scheduler cfq registered (default)
[ 0.940856] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
[ 0.941132] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.941145] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.941174] intel_idle: MWAIT substates: 0x21120
[ 0.941175] intel_idle: v0.4 model 0x3A
[ 0.941176] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.941331] GHES: HEST is not enabled!
[ 0.941382] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.941796] Linux agpgart interface v0.103
[ 0.941880] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.947996] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.948001] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.948101] mousedev: PS/2 mouse device common for all mice
[ 0.948423] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.948451] rtc_cmos 00:05: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.948460] Intel P-state driver initializing.
[ 0.948468] Intel pstate controlling: cpu 0
[ 0.948483] Intel pstate controlling: cpu 1
[ 0.948496] Intel pstate controlling: cpu 2
[ 0.948512] Intel pstate controlling: cpu 3
[ 0.948534] AMD IOMMUv2 driver by Joerg Roedel <joerg.roedel@amd.com>
[ 0.948535] AMD IOMMUv2 functionality not available on this system
[ 0.948616] TCP: cubic registered
[ 0.948683] NET: Registered protocol family 10
[ 0.948869] mip6: Mobile IPv6
[ 0.948871] NET: Registered protocol family 17
[ 0.948873] mpls_gso: MPLS GSO support
[ 0.949112] registered taskstats version 1
[ 0.949499] rtc_cmos 00:05: setting system clock to 2014-07-16 14:07:22 UTC (1405519642)
[ 0.949570] PM: Hibernation image not present or could not be loaded.
[ 0.950060] Freeing unused kernel memory: 1000K (ffffffff818b2000 - ffffffff819ac000)
[ 0.950062] Write protecting the kernel read-only data: 8192k
[ 0.954011] Freeing unused kernel memory: 1220K (ffff8800014cf000 - ffff880001600000)
[ 0.954882] Freeing unused kernel memory: 384K (ffff8800017a0000 - ffff880001800000)
[ 0.958881] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 0.963416] systemd-udevd[70]: starting version 208
[ 0.963686] random: systemd-udevd urandom read with 4 bits of entropy available
[ 0.975187] ACPI: Invalid active2 threshold
[ 0.975448] ACPI: bus type USB registered
[ 0.975467] usbcore: registered new interface driver usbfs
[ 0.975475] usbcore: registered new interface driver hub
[ 0.975547] usbcore: registered new device driver usb
[ 0.975550] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.975552] ACPI: Thermal Zone [TZ00] (54 C)
[ 0.975940] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.976070] ehci-pci: EHCI PCI platform driver
[ 0.976190] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.976198] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 0.976313] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.976313] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.976315] ACPI: Thermal Zone [TZ01] (54 C)
[ 0.976341] xhci_hcd 0000:00:14.0: irq 41 for MSI/MSI-X
[ 0.976448] ACPI: Fan [FAN0] (off)
[ 0.976498] ACPI: Fan [FAN1] (off)
[ 0.976550] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.976553] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.976555] usb usb1: Product: xHCI Host Controller
[ 0.976556] usb usb1: Manufacturer: Linux 3.14-1-amd64 xhci_hcd
[ 0.976558] usb usb1: SerialNumber: 0000:00:14.0
[ 0.976676] hub 1-0:1.0: USB hub found
[ 0.976693] hub 1-0:1.0: 4 ports detected
[ 0.976763] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.976769] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 0.976992] r8169 0000:03:00.0: irq 42 for MSI/MSI-X
[ 0.977098] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.977101] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 0.977147] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.977150] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.977151] usb usb2: Product: xHCI Host Controller
[ 0.977153] usb usb2: Manufacturer: Linux 3.14-1-amd64 xhci_hcd
[ 0.977155] usb usb2: SerialNumber: 0000:00:14.0
[ 0.977211] r8169 0000:03:00.0 eth0: RTL8168evl/8111evl at 0xffffc9000000e000, e8:03:9a:b2:d5:e5, XID 0c900800 IRQ 42
[ 0.977214] r8169 0000:03:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 0.977464] hub 2-0:1.0: USB hub found
[ 0.977478] hub 2-0:1.0: 4 ports detected
[ 0.977956] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.977961] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 0.977973] ehci-pci 0000:00:1a.0: debug port 2
[ 0.978256] SCSI subsystem initialized
[ 0.979019] libata version 3.00 loaded.
[ 0.981869] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.981991] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7918000
[ 0.993031] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.993066] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.993068] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.993070] usb usb3: Product: EHCI Host Controller
[ 0.993072] usb usb3: Manufacturer: Linux 3.14-1-amd64 ehci_hcd
[ 0.993073] usb usb3: SerialNumber: 0000:00:1a.0
[ 0.993195] hub 3-0:1.0: USB hub found
[ 0.993202] hub 3-0:1.0: 2 ports detected
[ 0.993390] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.993395] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 0.993407] ehci-pci 0000:00:1d.0: debug port 2
[ 0.997296] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.997316] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7917000
[ 1.009088] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.009118] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.009120] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.009122] usb usb4: Product: EHCI Host Controller
[ 1.009124] usb usb4: Manufacturer: Linux 3.14-1-amd64 ehci_hcd
[ 1.009125] usb usb4: SerialNumber: 0000:00:1d.0
[ 1.009335] hub 4-0:1.0: USB hub found
[ 1.009342] hub 4-0:1.0: 2 ports detected
[ 1.009446] ahci 0000:00:1f.2: version 3.0
[ 1.009573] ahci 0000:00:1f.2: irq 43 for MSI/MSI-X
[ 1.025147] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x5 impl SATA mode
[ 1.025151] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[ 1.033642] scsi0 : ahci
[ 1.033753] scsi1 : ahci
[ 1.033837] scsi2 : ahci
[ 1.033918] scsi3 : ahci
[ 1.033999] scsi4 : ahci
[ 1.034082] scsi5 : ahci
[ 1.034117] ata1: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916100 irq 43
[ 1.034119] ata2: DUMMY
[ 1.034121] ata3: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916200 irq 43
[ 1.034122] ata4: DUMMY
[ 1.034123] ata5: DUMMY
[ 1.034123] ata6: DUMMY
[ 1.289465] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.353486] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.353512] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.358526] ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.358532] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.358535] ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.358838] ata3.00: ATAPI: TSSTcorp CDDVDW SN-208BB, SC00, max UDMA/100
[ 1.360155] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.360161] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.360165] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.362866] ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.362871] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.362875] ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.363184] ata3.00: configured for UDMA/100
[ 1.366661] ata1.00: ATA-8: ST1000LM024 HN-M101MBB, 2AR10002, max UDMA/133
[ 1.366666] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.373367] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.373373] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.373377] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.379840] ata1.00: configured for UDMA/133
[ 1.380111] scsi 0:0:0:0: Direct-Access ATA ST1000LM024 HN-M 2AR1 PQ: 0 ANSI: 5
[ 1.382848] scsi 2:0:0:0: CD-ROM TSSTcorp CDDVDW SN-208BB SC00 PQ: 0 ANSI: 5
[ 1.386945] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 1.386950] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.387071] sd 0:0:0:0: [sda] Write Protect is off
[ 1.387077] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.387120] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.400466] sr0: scsi3-mmc drive: 16x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.400472] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.400713] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 1.401656] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.401738] sr 2:0:0:0: Attached scsi generic sg1 type 5
[ 1.452854] sda: sda1 sda2 sda3 sda4 < sda5 >
[ 1.454489] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.926143] tsc: Refined TSC clocksource calibration: 2494.334 MHz
[ 2.126441] PM: Starting manual resume from disk
[ 2.126447] PM: Hibernation image partition 8:2 present
[ 2.126449] PM: Looking for hibernation image.
[ 2.185967] PM: Image not found (code -22)
[ 2.185970] PM: Hibernation image not present or could not be loaded.
[ 2.227279] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 2.927467] Switched to clocksource tsc
[ 2.997469] random: nonblocking pool is initialized
[ 3.414951] systemd[1]: systemd 208 running in system mode. (+PAM +LIBWRAP +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ)
[ 3.763008] systemd[1]: Inserted module 'autofs4'
[ 3.772825] systemd[1]: Set hostname to <Debian>.
[ 5.905430] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 5.905897] systemd[1]: Starting Syslog Socket.
[ 5.905959] systemd[1]: Listening on Syslog Socket.
[ 5.905981] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 5.906066] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.906083] systemd[1]: Starting Remote File Systems (Pre).
[ 5.906099] systemd[1]: Reached target Remote File Systems (Pre).
[ 5.906114] systemd[1]: Starting Delayed Shutdown Socket.
[ 5.906147] systemd[1]: Listening on Delayed Shutdown Socket.
[ 5.906161] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 5.906189] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.906205] systemd[1]: Starting Encrypted Volumes.
[ 5.906219] systemd[1]: Reached target Encrypted Volumes.
[ 5.906269] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 5.906398] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.906419] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 5.906463] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.906482] systemd[1]: Starting Journal Socket.
[ 5.906533] systemd[1]: Listening on Journal Socket.
[ 5.906555] systemd[1]: Starting Syslog.
[ 5.906569] systemd[1]: Reached target Syslog.
[ 5.906726] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 5.986934] systemd[1]: Starting Load Kernel Modules...
[ 5.987445] systemd[1]: Mounting Debug File System...
[ 6.095400] systemd[1]: Started Set Up Additional Binary Formats.
[ 6.128195] systemd[1]: Starting Apply Kernel Variables...
[ 6.128768] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.129297] systemd[1]: Starting Journal Service...
[ 6.129990] systemd[1]: Started Journal Service.
[ 7.607085] lp: driver loaded but no devices found
[ 7.621766] systemd-udevd[178]: starting version 208
[ 7.831807] ppdev: user-space parallel port driver
[ 8.303553] fuse init (API version 7.22)
[ 11.159429] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 11.289522] ACPI Warning: SystemIO range 0x000000000000f040-0x000000000000f05f conflicts with OpRegion 0x000000000000f040-0x000000000000f04f (\_SB_.PCI0.SBUS.SMBI) (20131218/utaddress-258)
[ 11.289529] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 11.334680] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042f conflicts with OpRegion 0x0000000000000400-0x000000000000047f (\PMIO) (20131218/utaddress-258)
[ 11.334685] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 11.334689] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053f conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20131218/utaddress-258)
[ 11.334691] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053f conflicts with OpRegion 0x0000000000000500-0x000000000000055f (\_SB_.PCI0.PEG0.PEGP.GPIO) (20131218/utaddress-258)
[ 11.334693] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 11.334694] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052f conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20131218/utaddress-258)
[ 11.334696] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052f conflicts with OpRegion 0x0000000000000500-0x000000000000055f (\_SB_.PCI0.PEG0.PEGP.GPIO) (20131218/utaddress-258)
[ 11.334698] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 11.334699] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 11.343359] mei_me 0000:00:16.0: irq 44 for MSI/MSI-X
[ 11.396677] [drm] Initialized drm 1.1.0 20060810
[ 11.470105] ACPI: Battery Slot [BAT1] (battery present)
[ 11.470191] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input3
[ 11.470217] ACPI: Lid Switch [LID0]
[ 11.470275] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input4
[ 11.470279] ACPI: Power Button [PWRB]
[ 11.470341] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 11.470343] ACPI: Power Button [PWRF]
[ 11.470347] ACPI: AC Adapter [ADP1] (on-line)
[ 11.554943] wmi: Mapper loaded
[ 11.561754] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ 11.680579] samsung_laptop: detected SABI interface: SwSmi@
[ 11.680582] samsung_laptop: Backlight controlled by ACPI video driver
[ 11.687797] cfg80211: Calling CRDA to update world regulatory domain
[ 11.753520] Intel(R) Wireless WiFi driver for Linux, in-tree:
[ 11.753522] Copyright(c) 2003- 2014 Intel Corporation
[ 11.753625] iwlwifi 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 11.753684] iwlwifi 0000:02:00.0: irq 45 for MSI/MSI-X
[ 11.761508] snd_hda_intel 0000:00:1b.0: irq 46 for MSI/MSI-X
[ 11.868933] EXT4-fs (sda3): re-mounted. Opts: errors=remount-ro
[ 11.942983] iTCO_vendor_support: vendor-support=0
[ 12.066243] iwlwifi 0000:02:00.0: firmware: direct-loading firmware iwlwifi-6000g2b-6.ucode
[ 12.066480] iwlwifi 0000:02:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm
[ 12.195640] psmouse serio1: synaptics: Touchpad model: 1, fw: 7.5, id: 0x1e0b1, caps: 0xf00133/0x240000/0xa2400, board id: 1874, fw id: 1066450
[ 12.228586] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.10
[ 12.228647] iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
[ 12.228842] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 12.237237] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input2
[ 12.406639] [drm] Memory usable by graphics device = 2048M
[ 12.490228] i915 0000:00:02.0: irq 47 for MSI/MSI-X
[ 12.490242] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 12.490244] [drm] Driver supports precise vblank timestamp query.
[ 12.490391] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=none :o wns=none
[ 12.501611] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUG disabled
[ 12.501617] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUGFS disabled
[ 12.501620] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEVICE_TRACING disabled
[ 12.501624] iwlwifi 0000:02:00.0: Detected Intel(R) Centrino(R) Advanced-N 6235 AGN, REV=0xB0
[ 12.501678] iwlwifi 0000:02:00.0: L1 Disabled; Enabling L0S
[ 12.518504] [drm] Wrong MCH_SSKPD value: 0x20100406
[ 12.518507] [drm] This can cause pipe underruns and display issues.
[ 12.518509] [drm] Please upgrade your BIOS to fix this.
[ 12.536616] fbcon: inteldrmfb (fb0) is primary device
[ 12.587872] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 12.605257] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 12.605612] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 12.606112] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 12.642576] MXM: GUID detected in BIOS
[ 12.642643] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)
[ 12.642687] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)
[ 12.642822] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power,
[ 12.642824] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.PEG0.PEGP handle
[ 12.745554] AVX version of gcm_enc/dec engaged.
[ 12.747906] alg: No test for __gcm-aes-aesni (__driver-gcm-aes-aesni)
[ 13.069491] alg: No test for crc32 (crc32-pclmul)
[ 13.258766] Console: switching to colour frame buffer device 170x48
[ 13.262209] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 13.262211] i915 0000:00:02.0: registered panic notifier
[ 13.262264] nouveau 0000:01:00.0: enabling device (0006 -> 0007)
[ 13.262517] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 13.263399] ACPI: Video Device [PEGP] (multi-head: yes rom: yes post: no)
[ 13.656986] cfg80211: World regulatory domain updated:
[ 13.656994] cfg80211: DFS Master region: unset
[ 13.656996] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 13.657000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 13.657002] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 13.657004] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 13.657006] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 13.657008] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 13.657010] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 13.812142] [drm] Enabling RC6 states: RC6 on, RC6p on, RC6pp off
[ 14.271027] Adding 5859324k swap on /dev/sda2. Priority:-1 extents:1 across:5859324k
[ 14.769155] acpi device:10: registered as cooling_device7
[ 14.769250] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/device:0e/LNXVIDEO:00/input/input10
[ 14.770597] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 15.753105] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 15.940973] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 15.949861] systemd-journald[163]: Received request to flush runtime journal from PID 1
[ 16.274816] acpi device:1e: registered as cooling_device8
[ 16.274900] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:01/input/input11
[ 16.275002] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 16.275134] [drm] hdmi device not found 1 0 1
[ 16.275393] nouveau [ DEVICE][0000:01:00.0] BOOT0 : 0x0c1480a1
[ 16.275397] nouveau [ DEVICE][0000:01:00.0] Chipset: GF108 (NVC1)
[ 16.275399] nouveau [ DEVICE][0000:01:00.0] Family : NVC0
[ 16.278713] nouveau [ VBIOS][0000:01:00.0] checking PRAMIN for image...
[ 16.288451] nouveau [ VBIOS][0000:01:00.0] ... signature not found
[ 16.288455] nouveau [ VBIOS][0000:01:00.0] checking PROM for image...
[ 16.288511] nouveau [ VBIOS][0000:01:00.0] ... signature not found
[ 16.288514] nouveau [ VBIOS][0000:01:00.0] checking ACPI for image...
[ 16.418723] usb 1-1: device descriptor read/64, error -110
[ 16.522886] xhci_hcd 0000:00:14.0: Setup ERROR: setup context command for slot 1.
[ 16.635094] usb 1-1: new high-speed USB device number 3 using xhci_hcd
[ 16.763375] usb 1-1: New USB device found, idVendor=abcd, idProduct=1234
[ 16.763381] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 16.763384] usb 1-1: Product: UDisk
[ 16.763387] usb 1-1: Manufacturer: General
[ 16.763390] usb 1-1: SerialNumber: 0906090619366938950015
[ 16.848078] r8169 0000:03:00.0: firmware: failed to load rtl_nic/rtl8168e-3.fw (-2)
[ 16.848119] r8169 0000:03:00.0: Direct firmware load failed with error -2
[ 16.848121] r8169 0000:03:00.0: Falling back to user helper
[ 16.866314] r8169 0000:03:00.0 eth0: unable to load firmware patch rtl_nic/rtl8168e-3.fw (-2)
[ 16.875271] usb 1-4: new low-speed USB device number 4 using xhci_hcd
[ 16.881306] r8169 0000:03:00.0 eth0: link down
[ 16.881332] r8169 0000:03:00.0 eth0: link down
[ 16.881359] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.007175] usb 1-4: New USB device found, idVendor=045e, idProduct=0782
[ 17.007182] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 17.007186] usb 1-4: Product: Microsoft USB Optical Mouse
[ 17.007189] usb 1-4: Manufacturer: PixArt
[ 17.007386] usb 1-4: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 17.119512] usb 3-1: new high-speed USB device number 2 using ehci-pci
[ 17.231744] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 17.231889] scsi6 : usb-storage 1-1:1.0
[ 17.232041] usbcore: registered new interface driver usb-storage
[ 17.252195] usb 3-1: New USB device found, idVendor=8087, idProduct=0024
[ 17.252201] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 17.252587] hub 3-1:1.0: USB hub found
[ 17.252758] hub 3-1:1.0: 6 ports detected
[ 17.272560] hidraw: raw HID events driver (C) Jiri Kosina
[ 17.282975] usbcore: registered new interface driver usbhid
[ 17.282980] usbhid: USB HID core driver
[ 17.293396] input: PixArt Microsoft USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:045E:0782.0001/input/input12
[ 17.293792] hid-generic 0003:045E:0782.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Microsoft USB Optical Mouse] on usb-0000:00:14.0-4/input0
[ 17.465727] RPC: Registered named UNIX socket transport module.
[ 17.465732] RPC: Registered udp transport module.
[ 17.465734] RPC: Registered tcp transport module.
[ 17.465735] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 17.506982] FS-Cache: Loaded
[ 17.524905] FS-Cache: Netfs 'nfs' registered for caching
[ 17.595266] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 18.233298] scsi 6:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 18.234022] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 18.234103] sd 6:0:0:0: [sdb] 15728640 512-byte logical blocks: (8.05 GB/7.50 GiB)
[ 18.234249] sd 6:0:0:0: [sdb] Write Protect is off
[ 18.234254] sd 6:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 18.234375] sd 6:0:0:0: [sdb] No Caching mode page found
[ 18.234421] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 18.236658] sd 6:0:0:0: [sdb] No Caching mode page found
[ 18.236700] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 18.288477] sdb: unknown partition table
[ 18.289390] sd 6:0:0:0: [sdb] No Caching mode page found
[ 18.289438] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 18.289482] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 19.026330] r8169 0000:03:00.0 eth0: link up
[ 19.026345] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.596095] nouveau [ VBIOS][0000:01:00.0] ... appears to be valid
[ 20.596108] nouveau [ VBIOS][0000:01:00.0] using image from ACPI
[ 20.596396] nouveau [ VBIOS][0000:01:00.0] BIT signature found
[ 20.596416] nouveau [ VBIOS][0000:01:00.0] version 70.08.a8.00.a9
[ 20.597867] nouveau [ DEVINIT][0000:01:00.0] adaptor not initialised
[ 20.597879] nouveau [ VBIOS][0000:01:00.0] running init tables
[ 20.705010] nouveau 0000:01:00.0: irq 48 for MSI/MSI-X
[ 20.705024] nouveau [ PMC][0000:01:00.0] MSI interrupts enabled
[ 20.705054] nouveau W[ PFB][0000:01:00.0][0x00000000][ffff880321064000] reclocking of this ram type unsupported
[ 20.705056] nouveau [ PFB][0000:01:00.0] RAM type: DDR3
[ 20.705058] nouveau [ PFB][0000:01:00.0] RAM size: 1024 MiB
[ 20.705059] nouveau [ PFB][0000:01:00.0] ZCOMP: 0 tags
[ 20.711651] nouveau [ VOLT][0000:01:00.0] GPU voltage: 937500uv
[ 20.715585] usb 4-1: new high-speed USB device number 2 using ehci-pci
[ 20.734953] nouveau [ PTHERM][0000:01:00.0] FAN control: none / external
[ 20.734959] nouveau [ PTHERM][0000:01:00.0] fan management: automatic
[ 20.734963] nouveau [ PTHERM][0000:01:00.0] internal sensor: yes
[ 20.734987] nouveau [ CLK][0000:01:00.0] 07: core 270 MHz memory 405 MHz
[ 20.734993] nouveau [ CLK][0000:01:00.0] 0f: core 475 MHz memory 900 MHz
[ 20.735130] nouveau [ CLK][0000:01:00.0] --: core 270 MHz memory 405 MHz
[ 20.738765] vga_switcheroo: enabled
[ 20.738865] [TTM] Zone kernel: Available graphics memory: 6113408 kiB
[ 20.738867] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 20.738868] [TTM] Initializing pool allocator
[ 20.738872] [TTM] Initializing DMA pool allocator
[ 20.738881] nouveau [ DRM] VRAM: 1024 MiB
[ 20.738882] nouveau [ DRM] GART: 1048576 MiB
[ 20.738886] nouveau [ DRM] TMDS table version 2.0
[ 20.738887] nouveau [ DRM] DCB version 4.0
[ 20.738889] nouveau [ DRM] DCB outp 00: 02000300 00000000
[ 20.738890] nouveau [ DRM] DCB conn 00: 00000000
[ 20.739565] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 20.739566] [drm] Driver supports precise vblank timestamp query.
[ 20.739568] nouveau [ DRM] ACPI backlight interface available, not registering our own
[ 20.745554] nouveau [ DRM] MM: using COPY0 for buffer copies
[ 20.787682] nouveau [ DRM] allocated 1024x768 fb: 0x60000, bo ffff8803219f1800
[ 20.787808] nouveau 0000:01:00.0: fb1: nouveaufb frame buffer device
[ 20.787819] [drm] Initialized nouveau 1.1.1 20120801 for 0000:01:00.0 on minor 1
[ 20.848107] usb 4-1: New USB device found, idVendor=8087, idProduct=0024
[ 20.848115] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 20.848410] hub 4-1:1.0: USB hub found
[ 20.848474] hub 4-1:1.0: 6 ports detected
[ 20.919935] usb 3-1.2: new low-speed USB device number 3 using ehci-pci
[ 21.018457] usb 3-1.2: New USB device found, idVendor=1c4f, idProduct=0016
[ 21.018464] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 21.018467] usb 3-1.2: Product: USB Keyboard
[ 21.018470] usb 3-1.2: Manufacturer: SIGMACHIP
[ 21.022025] input: SIGMACHIP USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.2/3-1.2:1.0/0003:1C4F:0016.0002/input/input13
[ 21.022336] hid-generic 0003:1C4F:0016.0002: input,hidraw1: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-0000:00:1a.0-1.2/input0
[ 25.865574] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)
[ 25.865742] ACPI: \_SB_.PCI0.PEG0.PEGP: failed to evaluate _DSM
[ 25.865749] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)
[ 28.811728] iwlwifi 0000:02:00.0: L1 Disabled; Enabling L0S
[ 28.818323] iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0
[ 29.089969] iwlwifi 0000:02:00.0: L1 Disabled; Enabling L0S
[ 29.096572] iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0
[ 29.182106] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 31.035686] hid-generic 0003:1C4F:0016.0003: usb_submit_urb(ctrl) failed: -1
[ 31.036364] hid-generic 0003:1C4F:0016.0003: timeout initializing reports
[ 31.036595] input: SIGMACHIP USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.2/3-1.2:1.1/0003:1C4F:0016.0003/input/input14
[ 31.036876] hid-generic 0003:1C4F:0016.0003: input,hidraw2: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-0000:00:1a.0-1.2/input1
[ 31.107503] usb 3-1.4: new high-speed USB device number 4 using ehci-pci
[ 31.319605] usb 3-1.4: New USB device found, idVendor=2232, idProduct=1029
[ 31.319609] usb 3-1.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 31.319611] usb 3-1.4: Product: WebCam SC-13HDL11939N
[ 31.319613] usb 3-1.4: Manufacturer: Generic
[ 31.319615] usb 3-1.4: SerialNumber: 200901010001
[ 31.362993] media: Linux media interface: v0.10
[ 31.373799] Linux video capture interface: v2.00
[ 31.395909] usb 4-1.5: new full-speed USB device number 3 using ehci-pci
[ 31.408403] uvcvideo: Found UVC 1.00 device WebCam SC-13HDL11939N (2232:1029)
[ 31.419733] input: WebCam SC-13HDL11939N as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.4/3-1.4:1.0/input/input15
[ 31.419909] usbcore: registered new interface driver uvcvideo
[ 31.419913] USB Video Class driver (1.1.1)
[ 31.492619] usb 4-1.5: New USB device found, idVendor=8087, idProduct=07da
[ 31.492635] usb 4-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 31.789695] Bluetooth: Core ver 2.18
[ 31.789723] NET: Registered protocol family 31
[ 31.789725] Bluetooth: HCI device and connection manager initialized
[ 31.789735] Bluetooth: HCI socket layer initialized
[ 31.789738] Bluetooth: L2CAP socket layer initialized
[ 31.789750] Bluetooth: SCO socket layer initialized
[ 31.830007] usbcore: registered new interface driver btusb
[ 32.393960] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 32.393966] Bluetooth: BNEP filters: protocol multicast
[ 32.393977] Bluetooth: BNEP socket layer initialized
[ 39.881572] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)
[ 39.881709] ACPI: \_SB_.PCI0.PEG0.PEGP: failed to evaluate _DSM
[ 39.881715] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)
[ 56.876953] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)
[ 56.877155] ACPI: \_SB_.PCI0.PEG0.PEGP: failed to evaluate _DSM
[ 56.877164] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)
[ 840.293510] loop: module loaded
[ 842.449058] UDF-fs: warning (device loop0): udf_load_vrs: No anchor found
[ 842.449063] UDF-fs: Rescanning with blocksize 2048
[ 842.452031] UDF-fs: warning (device loop1): udf_load_vrs: No anchor found
[ 842.452035] UDF-fs: Rescanning with blocksize 2048
[ 842.453918] UDF-fs: INFO Mounting volume 'Sabayon KDE', timestamp 2014/07/13 06:19 (1078)
[ 1486.666378] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)
[ 1486.666560] ACPI: \_SB_.PCI0.PEG0.PEGP: failed to evaluate _DSM
[ 1486.666567] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)Kod: Zaznacz cały
lspci -k00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
Subsystem: Samsung Electronics Co Ltd Device c0d1
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
Kernel driver in use: i915
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
Kernel driver in use: xhci_hcd
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
Kernel driver in use: mei_me
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.3 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 4 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM76 Express Chipset LPC Controller (rev 04)
Kernel driver in use: lpc_ich
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 630M] (rev a1)
Kernel driver in use: nouveau
02:00.0 Network controller: Intel Corporation Centrino Advanced-N 6235 (rev 24)
Subsystem: Intel Corporation Centrino Advanced-N 6235 AGN
Kernel driver in use: iwlwifi
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
Kernel driver in use: r8169Kod: Zaznacz cały
lspci -n00:00.0 0600: 8086:0154 (rev 09)
00:01.0 0604: 8086:0151 (rev 09)
00:02.0 0300: 8086:0166 (rev 09)
00:14.0 0c03: 8086:1e31 (rev 04)
00:16.0 0780: 8086:1e3a (rev 04)
00:1a.0 0c03: 8086:1e2d (rev 04)
00:1b.0 0403: 8086:1e20 (rev 04)
00:1c.0 0604: 8086:1e10 (rev c4)
00:1c.3 0604: 8086:1e16 (rev c4)
00:1d.0 0c03: 8086:1e26 (rev 04)
00:1f.0 0601: 8086:1e59 (rev 04)
00:1f.2 0106: 8086:1e03 (rev 04)
00:1f.3 0c05: 8086:1e22 (rev 04)
01:00.0 0300: 10de:0de9 (rev a1)
02:00.0 0280: 8086:088e (rev 24)
03:00.0 0200: 10ec:8168 (rev 06)
