mam kolejny problem z serwerem pocztowym. Podczas wysyłania wiadomości pokazuje się błąd zapisu wiadomości w folderze Wysłane.
Serwer mam w OVH. Moje logi:
Jun 21 21:59:25 vps73857 postfix/smtpd[935]: warning: 195.242.xxx.xx: address not listed for hostname mail.hubitru.pl
Jun 21 21:59:25 vps73857 postfix/smtpd[935]: connect from unknown[195.242.xxx.xx]
Jun 21 21:59:25 vps73857 postfix/smtpd[935]: 863AFF41F86: client=unknown[195.242.xxx.xx], sasl_method=PLAIN, sasl_username=testmail
Jun 21 21:59:25 vps73857 postfix/cleanup[941]: 863AFF41F86: message-id=<53A5E41C.5000902@hubitru.pl>
Jun 21 21:59:25 vps73857 postfix/qmgr[896]: 863AFF41F86: from=<testmail@hubitru.pl>, size=550, nrcpt=1 (queue active)
Jun 21 21:59:25 vps73857 postfix/smtpd[935]: disconnect from unknown[195.242.xxx.xx]
Jun 21 21:59:26 vps73857 postfix/smtp[942]: 863AFF41F86: to=<hubitru@gmail.com>, relay=gmail-smtp-in.l.google.com[173.194.66.27]:25, delay=0.99, delays=0.16/0.02/0.45/0.36, dsn=2.0.0, status=sent (250 2.0.0 OK 1403380766 bb8si8526795wib.1 - gsmtp)
Jun 21 21:59:26 vps73857 postfix/qmgr[896]: 863AFF41F86: removed
Jun 21 22:00:35 vps73857 postfix/smtpd[935]: connect from unknown[unknown]
Jun 21 22:00:35 vps73857 postfix/smtpd[935]: lost connection after CONNECT from unknown[unknown]
Jun 21 22:00:35 vps73857 postfix/smtpd[935]: disconnect from unknown[unknown]
Jun 21 22:03:55 vps73857 postfix/anvil[939]: statistics: max connection rate 1/60s for (smtp:195.242.xxx.xx) at Jun 21 21:59:25
Jun 21 22:03:55 vps73857 postfix/anvil[939]: statistics: max connection count 1 for (smtp:195.242.xxx.xx) at Jun 21 21:59:25
Jun 21 22:03:55 vps73857 postfix/anvil[939]: statistics: max cache size 1 at Jun 21 21:59:25
Jun 21 22:05:30 vps73857 postfix/smtpd[998]: connect from unknown[unknown]
Jun 21 22:05:30 vps73857 postfix/smtpd[998]: lost connection after CONNECT from unknown[unknown]
Jun 21 22:05:30 vps73857 postfix/smtpd[998]: disconnect from unknown[unknown]
Jun 21 22:05:50 vps73857 postfix/smtpd[998]: warning: 195.242.xxx.xx: address not listed for hostname mail.hubitru.pl
Jun 21 22:05:50 vps73857 postfix/smtpd[998]: connect from unknown[195.242.xxx.xx]
Jun 21 22:05:51 vps73857 postfix/smtpd[998]: 4121DF41F86: client=unknown[195.242.xxx.xx], sasl_method=PLAIN, sasl_username=testmail
Jun 21 22:05:51 vps73857 postfix/cleanup[1006]: 4121DF41F86: message-id=<53A5E59E.404@hubitru.pl>
Jun 21 22:05:51 vps73857 postfix/qmgr[896]: 4121DF41F86: from=<testmail@hubitru.pl>, size=546, nrcpt=1 (queue active)
Jun 21 22:05:51 vps73857 postfix/smtpd[998]: disconnect from unknown[195.242.xxx.xx]
Jun 21 22:05:52 vps73857 postfix/smtp[1007]: 4121DF41F86: to=<hubitru@gmail.com>, relay=gmail-smtp-in.l.google.com[173.194.66.27]:25, delay=0.83, delays=0.15/0.01/0.17/0.49, dsn=2.0.0, status=sent (250 2.0.0 OK 1403381152 c9si3425086wix.3 - gsmtp)
Jun 21 22:05:52 vps73857 postfix/qmgr[896]: 4121DF41F86: removed
Z góry dziękuję za pomoc.
Używaj tagów
do cytowania logów!
