XBMC 12.3 / Debian 7.5 Wheezy amd64 na kernelu z backportów 3.13 crash programu.
neo86
Post autor: neo86 »
Tak jak w temacie następuje crash programu XBMC 12.3 na Wheezym z kernelem z Backportów w wersji 3.13 (inny kernel nie wchodzi w grę gdyż na innych oraz na oryginalny 3.2.x nie działa usypianie systemu a na 3.13 wszystko pięknie działa poza XBMC) w momencie kiedy wybieram z Weeb.Tv jakis kanał. W zasadzie crash jest w momencie chęci otworzenia czegokolwiek w XBMC...
Log od uruchomienia do crashu w terminalu:
dell@dell:~$ xbmc
Running DIL (3.22.0) Version
DtsDeviceOpen: Opening HW in mode 0
DtsDeviceOpen: Create File Failed
[flv @ 0x386e9e0] Estimating duration from bitrate, this may be inaccurate
Input #0, flv, from 'rtmp://95.211.215.132/channel/1200/live live=true pageUrl=token swfUrl=199844027':
  Metadata:
    author          :
    copyright       :
    description     :
    keywords        :
    rating          :
    title           :
    presetname      : Custom
    creationdate    : Fri Jun 13 11:16:44 2014
    videodevice     : Decklink Video Capture
    avclevel        : 31
    avcprofile      : 77
    videokeyframe_frequency: 5
    audiodevice     : Decklink Audio Capture
    audiochannels   : 2
    audioinputvolume: 75
  Duration: N/A, start: 0.000000, bitrate: 747 kb/s
    Stream #0:0: Video: h264 (Main), yuv420p, 720x576 [SAR 1:1 DAR 5:4], 665 kb/s, 25 tbr, 1k tbn, 50 tbc
    Stream #0:1: Audio: aac, 48000 Hz, stereo, fltp, 81 kb/s
libva: VA-API version 0.32.0
libva: va_getDriverName() returns 0
libva: Trying to open /usr/lib/x86_64-linux-gnu/dri/nouveau_drv_video.so
libva: va_openDriver() returns -1
Segmentation fault
Crash report available at /home/dell/xbmc_crashlog-20140614_214108.log
Log z xbmc_crashlog:
21:40:02 T:140658523543456  NOTICE: -----------------------------------------------------------------------
21:40:02 T:140658523543456  NOTICE: Starting XBMC (12.3 Git:Unknown), Platform: Linux (Debian 7.5 (wheezy), 3.13-0.bpo.1-amd64 x86_64). Built on Dec 28 2013
21:40:02 T:140658523543456  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
21:40:02 T:140658523543456  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/x86_64-linux-gnu/xbmc
21:40:02 T:140658523543456  NOTICE: special://masterprofile/ is mapped to: /home/dell/.xbmc/userdata
21:40:02 T:140658523543456  NOTICE: special://home/ is mapped to: /home/dell/.xbmc
21:40:02 T:140658523543456  NOTICE: special://temp/ is mapped to: /home/dell/.xbmc/temp
21:40:02 T:140658523543456  NOTICE: The executable running is: /usr/lib/x86_64-linux-gnu/xbmc/xbmc.bin
21:40:02 T:140658523543456  NOTICE: Local hostname: dell
21:40:02 T:140658523543456  NOTICE: Log File is located: /home/dell/.xbmc/temp/xbmc.log
21:40:02 T:140658523543456   ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
21:40:02 T:140658523543456  NOTICE: Found 1 Lists of Devices
21:40:02 T:140658523543456  NOTICE: Enumerated ALSA devices:
21:40:02 T:140658523543456  NOTICE:     Device 1
21:40:02 T:140658523543456  NOTICE:         m_deviceName      : default
21:40:02 T:140658523543456  NOTICE:         m_displayName     : Playback/recording through the PulseAudio sound server
21:40:02 T:140658523543456  NOTICE:         m_displayNameExtra:
21:40:02 T:140658523543456  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
21:40:02 T:140658523543456  NOTICE:         m_channels        : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
21:40:02 T:140658523543456  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
21:40:02 T:140658523543456  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
21:40:02 T:140658523543456  NOTICE:     Device 2
21:40:02 T:140658523543456  NOTICE:         m_deviceName      : @:CARD=Intel,DEV=0
21:40:02 T:140658523543456  NOTICE:         m_displayName     : HDA Intel
21:40:02 T:140658523543456  NOTICE:         m_displayNameExtra: 92HD71B7X Analog
21:40:02 T:140658523543456  NOTICE:         m_sampleRates     : 44100,48000,88200,96000,176400,192000
21:40:02 T:140658523543456  NOTICE:         m_dataFormats     : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
21:40:02 T:140658523543456  NOTICE: load settings...
21:40:02 T:140658523543456  NOTICE: special://profile/ is mapped to: special://masterprofile/
21:40:02 T:140658523543456  NOTICE: loading special://masterprofile/guisettings.xml
21:40:02 T:140658523543456  NOTICE: Getting hardware information now...
21:40:02 T:140658523543456  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:40:02 T:140658523543456  NOTICE: Loaded playercorefactory configuration
21:40:02 T:140658523543456  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:40:02 T:140658523543456  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:40:02 T:140658523543456  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
21:40:02 T:140658523543456  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
21:40:02 T:140658523543456  NOTICE: Default DVD Player: dvdplayer
21:40:02 T:140658523543456  NOTICE: Default Video Player: dvdplayer
21:40:02 T:140658523543456  NOTICE: Default Audio Player: paplayer
21:40:02 T:140658523543456  NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:40:02 T:140658523543456  NOTICE: Log level changed to 0
21:40:02 T:140658523543456  NOTICE: Loading media sources from special://masterprofile/sources.xml
21:40:02 T:140658150196992  NOTICE: Thread CSoftAE start, auto delete: false
21:40:02 T:140658523543456  NOTICE: Running database version Addons15
21:40:02 T:140658134869760  NOTICE: Thread XBMC Peripherals start, auto delete: false
21:40:02 T:140658523543456  NOTICE: Previous line repeats 1 times.
21:40:02 T:140658523543456  NOTICE: Setup SDL
21:40:02 T:140658523543456  NOTICE: Checking resolution 16
21:40:03 T:140658523543456  NOTICE: Using visual 0x240
21:40:03 T:140658523543456  NOTICE: GL_VENDOR = nouveau
21:40:03 T:140658523543456  NOTICE: GL_RENDERER = Gallium 0.4 on NV98
21:40:03 T:140658523543456  NOTICE: GL_VERSION = 2.1 Mesa 8.0.5
21:40:03 T:140658523543456  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
21:40:03 T:140658523543456  NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_fog_distance GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_ATI_texture_compression_3dc GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_rgtc GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_ATI_texture_mirror_once GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_compression_latc GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_ARB_ES2_compatibility GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_shader_texture_lod GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_robustness GL_ARB_texture_storage
21:40:03 T:140658523543456   ERROR: GLX: Same window as before, refreshing context
21:40:03 T:140658523543456  NOTICE: Running database version Addons15
21:40:03 T:140658523543456  NOTICE: Running database version ViewModes4
21:40:03 T:140658523543456  NOTICE: Running database version Textures13
21:40:03 T:140658523543456  NOTICE: Running database version MyMusic32
21:40:03 T:140658523543456  NOTICE: Running database version MyVideos75
21:40:03 T:140658523543456  NOTICE: Running database version TV22
21:40:03 T:140658523543456  NOTICE: Running database version Epg7
21:40:03 T:140658523543456  NOTICE: start dvd mediatype detection
21:40:03 T:140658523543456  NOTICE: initializing playlistplayer
21:40:03 T:140658523543456  NOTICE: DONE initializing playlistplayer
21:40:03 T:140658524944128  NOTICE: Thread CDetectDVDMedia start, auto delete: false
21:40:03 T:140658523543456  NOTICE: initialize done
21:40:03 T:140658523543456  NOTICE: Running the application...
21:40:03 T:140657991698176  NOTICE: Thread Jobworker start, auto delete: true
21:40:03 T:140658523543456  NOTICE: ES: Starting event server
21:40:03 T:140657974912768  NOTICE: Thread CTCPServer start, auto delete: false
21:40:03 T:140658523543456  NOTICE: starting zeroconf publishing
21:40:03 T:140657983305472  NOTICE: Thread CEventServer start, auto delete: false
21:40:03 T:140657983305472  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
21:40:03 T:140657983305472  NOTICE: UDP: Listening on port 9777
21:40:03 T:140657888847616  NOTICE: Thread Jobworker start, auto delete: true
21:40:03 T:140657964685056  NOTICE: Thread CRssReader start, auto delete: false
21:40:05 T:140657867417344  NOTICE: Thread Background Loader start, auto delete: false
21:40:07 T:140657867417344  NOTICE: Thread XBPyThread start, auto delete: false
21:40:07 T:140657867417344  NOTICE: -->Python Interpreter Initialized<--
21:40:07 T:140657854772992  NOTICE: Thread Background Loader start, auto delete: false
21:40:09 T:140657867417344  NOTICE: Thread XBPyThread start, auto delete: false
21:40:09 T:140657867417344  NOTICE: -->Python Interpreter Initialized<--
21:40:09 T:140657867417344  NOTICE: Thread Background Loader start, auto delete: false
21:40:09 T:140657854772992  NOTICE: Thread Jobworker start, auto delete: true
21:40:14 T:140658084620032  NOTICE: Thread XBPyThread start, auto delete: false
21:40:14 T:140658084620032  NOTICE: -->Python Interpreter Initialized<--
21:40:14 T:140658084620032  NOTICE: Output rtmp link: rtmp://95.211.215.132/channel/1146/liveHI live=true pageUrl=token swfUrl=199839859
21:40:14 T:140658084620032  NOTICE: #Starting control VideoPlayer events#
21:40:15 T:140658523543456  NOTICE: DVDPlayer: Opening: rtmp://95.211.215.132/channel/1146/liveHI live=true pageUrl=token swfUrl=199839859
21:40:15 T:140658523543456 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
21:40:15 T:140657867417344  NOTICE: Thread CDVDPlayer start, auto delete: false
21:40:15 T:140657867417344  NOTICE: Creating InputStream
21:40:16 T:140657867417344  NOTICE: Creating Demuxer
21:40:16 T:140657867417344  NOTICE: Metadata:
21:40:16 T:140657867417344  NOTICE:   author
21:40:16 T:140657867417344  NOTICE:   copyright
21:40:16 T:140657867417344  NOTICE:   description
21:40:16 T:140657867417344  NOTICE:   keywords
21:40:16 T:140657867417344  NOTICE:   rating
21:40:16 T:140657867417344  NOTICE:   title
21:40:16 T:140657867417344  NOTICE:   presetname            Custom
21:40:16 T:140657867417344  NOTICE:   creationdate          Fri Jun 13 00:07:49 2014
21:40:16 T:140657867417344  NOTICE:   videodevice           Decklink Video Capture
21:40:16 T:140657867417344  NOTICE:   framerate             25.00
21:40:16 T:140657867417344  NOTICE:   width                 1280.00
21:40:16 T:140657867417344  NOTICE:   height                720.00
21:40:16 T:140657867417344  NOTICE:   videocodecid          avc1
21:40:16 T:140657867417344  NOTICE:   videodatarate         1800.00
21:40:16 T:140657867417344  NOTICE:   avclevel              42.00
21:40:16 T:140657867417344  NOTICE:   avcprofile            77.00
21:40:16 T:140657867417344  NOTICE:   videokeyframe_frequency2.00
21:40:16 T:140657867417344  NOTICE:   audiodevice           Decklink Audio Capture
21:40:16 T:140657867417344  NOTICE:   audiosamplerate       48000.00
21:40:16 T:140657867417344  NOTICE:   audiochannels         2.00
21:40:16 T:140657867417344  NOTICE:   audioinputvolume      75.00
21:40:16 T:140657867417344  NOTICE:   audiocodecid          mp4a
21:40:16 T:140657867417344  NOTICE:   audiodatarate         96.00
21:40:17 T:140657867417344   ERROR: RTMP_ReadPacket, failed to read RTMP packet header
21:40:17 T:140657867417344  NOTICE: Opening video stream: 0 source: 256
21:40:17 T:140657867417344  NOTICE: Creating video codec with codec id: 28
21:40:17 T:140657867417344  NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(1280x720, 28)
21:40:17 T:140657867417344  NOTICE: (VDPAU) Unable to get handle to libvdpau: libvdpau.so.1: cannot open shared object file: No such file or directory
21:40:17 T:140657867417344  NOTICE: CDVDVideoCodecFFmpeg::Open() Failed to get VDPAU device
21:40:17 T:140657867417344  NOTICE:  (VDPAU) Close
21:40:17 T:140657867417344  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
21:40:17 T:140657867417344  NOTICE: Creating video thread
21:40:17 T:140658058917632  NOTICE: Thread CDVDPlayerVideo start, auto delete: false
21:40:17 T:140658058917632  NOTICE: running thread: video_thread
21:40:17 T:140657867417344  NOTICE: Opening audio stream: 1 source: 256
21:40:17 T:140657867417344  NOTICE: Finding audio codec for: 86018
21:40:17 T:140657867417344  NOTICE: Creating audio thread
21:40:17 T:140658050524928  NOTICE: Thread CDVDPlayerAudio start, auto delete: false
21:40:17 T:140658058917632   ERROR: VAAPI - unable to initialize display -1 - unknown libva error
21:40:17 T:140658050524928  NOTICE: running thread: CDVDPlayerAudio::Process()
21:40:17 T:140658050524928  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
Przyznam się, że od dawna problemu nie miałem i nie wiem jak to rozwiązać... reinstalacja oraz usunięcie i na nowo utworzenie profilu w /home nic nie dała. Na oryginalnym kernelu 3.2 XBMC działa bez problemów ale na tym oryginalnym kernelu nie działa z kolei usypianie systemu natomiast na 3.13 działa... jestem w kropeczce. Pomożecie?
Jeśli to istotne to jak miałem Debian w wersji 7.4 i też kernel z Backportów też w wersji 3.13 to XBMC działało! Tylko w wersji 7.5 jest taka kiszka...
pone13
Post autor: pone13 »
Skompiluj XBMC z git'a http://wiki.xbmc.org/index.php?title=HO ... _for_Linux, działa o wiele lepiej bo bazuje na nowszych wersjach bibliotek (wersja z repo bazuje na bibliotekach dostarczonych przez zespół Debiana, a wiadomo że te wersje w większości będą prehistoryczne ;) ).
Przetestowane na salonowym HTPC z Debianem Jessie/Sid, powodzenia!
W backportach jest już nowszy kernel. Spróbuj na nim
yampress@debian ~]$ uname -a
Linux debian 3.14-0.bpo.1-amd64 #1 SMP Debian 3.14.5-1~bpo70+1 (2014-06-05) x86_64 GNU/Linux
[yampress@debian ~]$
neo86
Post autor: neo86 »
pone13 pisze:Skompiluj XBMC z git'a http://wiki.xbmc.org/index.php?title=HO ... _for_Linux, działa o wiele lepiej bo bazuje na nowszych wersjach bibliotek (wersja z repo bazuje na bibliotekach dostarczonych przez zespół Debiana, a wiadomo że te wersje w większości będą prehistoryczne ;) ).
Lipa! Nie działa! Doszedłem do pewnego etapu i kicha...
root@dell:~/xbmc# ./bootstrap
autoreconf -vif .
make: autoreconf: Polecenie nie znalezione
make: *** [configure] Błąd 127
root@dell:~/xbmc# ./configure
bash: ./configure: Nie ma takiego pliku ani katalogu
root@dell:~/xbmc# ls
addons          CONTRIBUTORS         LICENSE.GPL      sounds
bootstrap      copying.txt         m4              system
bootstrap.mk      docs             Makefile.in      tools
build-aux      doxygen_resources  Makefile.include.in  userdata
codegenerator.mk  gitrev.sh         media          xbmc
configure.in      language         project          XBMC.xcodeproj
CONTRIBUTING.md   lib             README          xbmc-xrandr.c
root@dell:~/xbmc#
Yampress pisze:W backportach jest już nowszy kernel. Spróbuj na nim
Próbowałem Kernel 3.14 z backportów ale jest do kitu... na moim Dell'u po uruchomieniu się systemu biały ekran i nic poza tym... więc do Kernela 3.13 na moim Dell'u wszystko OK (poza XBMC) natomiast przy oryginalnym Kernelu 3.2.x usypianie systemu tylko i aż nie działa... trudno chyba wróce do kernela 3.2 bo zależy mi na XBMC a usypianie trudno... nie będzie a szkoda :/ bo to przydatna funkcja...
Ubuntu z kolei wiesza się po pół godziny... kurcze zaczynam się bać! Czyżby linuksy z systemu pakietów *.deb schodziły na psy i olały starszy sprzęt?! A miałem taką nadzieję, że z Wheezym jak to ze stabilnym nawet z backportami problemów nie będzie a tu masz Ci los... Pół roku wspaniałego działania... ślicznie kompiluje się Milenę, Wine a od wczoraj z XBMC jest kiszka :/
trochę stary ten xbmc masz..często tak też mam chociaż ostatnio nie było problemów z nim ale to norma, że raz na jakiś czas się wywala i trzeba kombinować (popróbuj z innymi wersjami, najnowsza u mnie śmiga elegancko, instalnij z deb-multimedia sidowego, spinuj i po krzyku)..u mnie śmiga normalnie..
daimyo@shodan:~$ ac policy xbmc
xbmc:
  Zainstalowana: 4:13.1-dmo1
  Kandydująca:   4:13.1-dmo1
  Tabela wersji:
 *** 4:13.1-dmo1 0
        100 http://www.deb-multimedia.org/ unstable/main amd64 Packages
        100 http://www.deb-multimedia.org/ testing/main amd64 Packages
        100 /var/lib/dpkg/status
     2:13.1~rc1+dfsg1-1 0
        500 http://ftp.pl.debian.org/debian/ unstable/main amd64 Packages
     2:13.1~beta2+dfsg1-1 0
        130 http://ftp.pl.debian.org/debian/ testing/main amd64 Packages
ewentualnie wyczyść profil i na czystym bez wtyczek zobacz czy też się kraszuje, miałem kiedyś problem właśnie z tymi wtyczkami z weebtv (często też je aktualizują i co jakiś czas występują problemy z nimi) a to w sumie najważniejsza wtyczka i moja jedyna telewizja ale jak pisałem krasze xbmc to norma, nie ma się co zbytnio przejmować..zdarza się;>
pone13
# aptitude install dh-autoreconf
Musisz mieć zainstalowane wszystkie podane w linku zależności, w komunikacie błędu
jest podane czego brakuje...
neo86
Post autor: neo86 »
Pone13 dalej jakimiś błędami sypie... nawet ich tu nie wklejam. Nie mam czasu teraz na to! Ehhh nie chce mi się kombinować nie mam czasu na taka zabawę... Gdybym chciał się bawić w jakieś naprawianie i intensywne kombinowanie i szukanie problemów to bym zainstalował Debiana SID'a lub Testinga lub tez Ubuntu... nie po to instaluję Wheezego by się użerać z jakimś XBMC!!! Widocznie i Wheezy schodzi na psy (przynajmniej na Dell'u E6500 bo nie wiem jak na innych kompach jest...) XBMC bezbłędnie działa na Kernelu 3.2.x trudno najwyżej laptopa nie będę usypiał... a szkoda :/
Menelu drogi kompanie od butelki ;) Niestety XBMC 13.x jest jeszcze testowe (12.3 to najnowsza wersja stabilna z repozytorium Wheezego od Mati75) i pod nim mi nie działały wtyczki do TVN oraz iTVP oraz IPla... więc to jest bez sensu...
Możesz się pobawić ustawieniami w dziale Video => Acceleration, bo wygląda na to że gdzieś tam jest problem. Najlepiej będzie udać się na oficjalne forum XBMC.
Ewentualnie może wklej jeszcze log /var/log/Xorg.0.log.
neo86
Post autor: neo86 »
Rafal_F pisze:Ewentualnie może wklej jeszcze log /var/log/Xorg.0.log.
Please:
[    18.882]
X.Org X Server 1.12.4
Release Date: 2012-08-27
[    18.882] X Protocol Version 11, Revision 0
[    18.882] Build Operating System: Linux 3.11-2-amd64 x86_64 Debian
[    18.882] Current Operating System: Linux dell 3.13-0.bpo.1-amd64 #1 SMP Debian 3.13.10-1~bpo70+1 (2014-04-23) x86_64
[    18.882] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.13-0.bpo.1-amd64 root=UUID=2f4cb664-c6d7-4f5c-a6b9-8b024c4ac4a1 ro quiet splash
[    18.882] Build Date: 17 December 2013  07:37:58PM
[    18.882] xorg-server 2:1.12.4-6+deb7u2 (Julien Cristau <jcristau@debian.org>)
[    18.882] Current version of pixman: 0.26.0
[    18.882]     Before reporting problems, check http://wiki.x.org
[    18.882] Markers: (--) probed, (**) from config file, (==) default setting,
[    18.882] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jun 16 20:33:40 2014
[    18.945] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    19.102] (==) No Layout section.  Using the first Screen section.
[    19.102] (==) No screen section available. Using defaults.
[    19.102] (**) |-->Screen "Default Screen Section" (0)
[    19.102] (**) |   |-->Monitor "<default monitor>"
[    19.103] (==) No monitor specified for screen "Default Screen Section".
    Using a default monitor configuration.
[    19.103] (==) Automatically adding devices
[    19.103] (==) Automatically enabling devices
[    19.174] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    19.174]     Entry deleted from font path.
[    19.174] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    19.174] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    19.174] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[    19.174] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    19.174] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    19.174] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[    19.174] (==) FontPath set to:
    /usr/share/fonts/X11/misc,
    built-ins
[    19.174] (==) ModulePath set to "/usr/lib/xorg/modules"
[    19.174] (II) The server relies on udev to provide the list of input devices.
[    19.174] (II) Loader magic: 0x7f2e14f1aae0
[    19.174] (II) Module ABI versions:
[    19.174]     X.Org ANSI C Emulation: 0.4
[    19.174]     X.Org Video Driver: 12.1
[    19.174]     X.Org XInput driver : 16.0
[    19.174]     X.Org Server Extension : 6.0
[    19.176] (--) PCI:*(0:1:0:0) 10de:06eb:1028:024f rev 161, Mem @ 0xf5000000/16777216, 0xe0000000/268435456, 0xf2000000/33554432, I/O @ 0x0000df00/128, BIOS @ 0x????????/131072
[    19.176] (II) Open ACPI successful (/var/run/acpid.socket)
[    19.176] (II) LoadModule: "extmod"
[    19.235] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[    19.251] (II) Module extmod: vendor="X.Org Foundation"
[    19.251]     compiled for 1.12.4, module version = 1.0.0
[    19.251]     Module class: X.Org Server Extension
[    19.251]     ABI class: X.Org Server Extension, version 6.0
[    19.251] (II) Loading extension SELinux
[    19.251] (II) Loading extension MIT-SCREEN-SAVER
[    19.251] (II) Loading extension XFree86-VidModeExtension
[    19.251] (II) Loading extension XFree86-DGA
[    19.251] (II) Loading extension DPMS
[    19.251] (II) Loading extension XVideo
[    19.251] (II) Loading extension XVideo-MotionCompensation
[    19.251] (II) Loading extension X-Resource
[    19.251] (II) LoadModule: "dbe"
[    19.251] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[    19.269] (II) Module dbe: vendor="X.Org Foundation"
[    19.269]     compiled for 1.12.4, module version = 1.0.0
[    19.269]     Module class: X.Org Server Extension
[    19.269]     ABI class: X.Org Server Extension, version 6.0
[    19.269] (II) Loading extension DOUBLE-BUFFER
[    19.269] (II) LoadModule: "glx"
[    19.269] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    19.290] (II) Module glx: vendor="X.Org Foundation"
[    19.290]     compiled for 1.12.4, module version = 1.0.0
[    19.290]     ABI class: X.Org Server Extension, version 6.0
[    19.290] (==) AIGLX enabled
[    19.290] (II) Loading extension GLX
[    19.290] (II) LoadModule: "record"
[    19.290] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[    19.291] (II) Module record: vendor="X.Org Foundation"
[    19.291]     compiled for 1.12.4, module version = 1.13.0
[    19.291]     Module class: X.Org Server Extension
[    19.291]     ABI class: X.Org Server Extension, version 6.0
[    19.291] (II) Loading extension RECORD
[    19.291] (II) LoadModule: "dri"
[    19.291] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[    19.307] (II) Module dri: vendor="X.Org Foundation"
[    19.307]     compiled for 1.12.4, module version = 1.0.0
[    19.307]     ABI class: X.Org Server Extension, version 6.0
[    19.307] (II) Loading extension XFree86-DRI
[    19.307] (II) LoadModule: "dri2"
[    19.307] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[    19.308] (II) Module dri2: vendor="X.Org Foundation"
[    19.308]     compiled for 1.12.4, module version = 1.2.0
[    19.308]     ABI class: X.Org Server Extension, version 6.0
[    19.308] (II) Loading extension DRI2
[    19.308] (==) Matched nouveau as autoconfigured driver 0
[    19.308] (==) Matched nv as autoconfigured driver 1
[    19.308] (==) Matched vesa as autoconfigured driver 2
[    19.308] (==) Matched fbdev as autoconfigured driver 3
[    19.308] (==) Assigned the driver to the xf86ConfigLayout
[    19.308] (II) LoadModule: "nouveau"
[    19.309] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    19.326] (II) Module nouveau: vendor="X.Org Foundation"
[    19.326]     compiled for 1.12.4, module version = 1.0.1
[    19.326]     Module class: X.Org Video Driver
[    19.326]     ABI class: X.Org Video Driver, version 12.1
[    19.326] (II) LoadModule: "nv"
[    19.326] (WW) Warning, couldn't open module nv
[    19.326] (II) UnloadModule: "nv"
[    19.326] (II) Unloading nv
[    19.326] (EE) Failed to load module "nv" (module does not exist, 0)
[    19.326] (II) LoadModule: "vesa"
[    19.326] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    19.462] (II) Module vesa: vendor="X.Org Foundation"
[    19.462]     compiled for 1.12.1, module version = 2.3.1
[    19.462]     Module class: X.Org Video Driver
[    19.462]     ABI class: X.Org Video Driver, version 12.0
[    19.462] (II) LoadModule: "fbdev"
[    19.462] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    19.469] (II) Module fbdev: vendor="X.Org Foundation"
[    19.469]     compiled for 1.12.1, module version = 0.4.2
[    19.469]     ABI class: X.Org Video Driver, version 12.0
[    19.469] (II) NOUVEAU driver Date:   Fri Jul 6 16:23:50 2012 +1000
[    19.469] (II) NOUVEAU driver for NVIDIA chipset families :
[    19.469]     RIVA TNT        (NV04)
[    19.469]     RIVA TNT2       (NV05)
[    19.469]     GeForce 256     (NV10)
[    19.469]     GeForce 2       (NV11, NV15)
[    19.469]     GeForce 4MX     (NV17, NV18)
[    19.469]     GeForce 3       (NV20)
[    19.469]     GeForce 4Ti     (NV25, NV28)
[    19.469]     GeForce FX      (NV3x)
[    19.469]     GeForce 6       (NV4x)
[    19.469]     GeForce 7       (G7x)
[    19.469]     GeForce 8       (G8x)
[    19.469]     GeForce GTX 200 (NVA0)
[    19.469]     GeForce GTX 400 (NVC0)
[    19.469] (II) VESA: driver for VESA chipsets: vesa
[    19.469] (II) FBDEV: driver for framebuffer: fbdev
[    19.469] (++) using VT number 7
[    19.469] drmOpenDevice: node name is /dev/dri/card0
[    19.469] drmOpenDevice: open result is 8, (OK)
[    19.469] drmOpenByBusid: Searching for BusID pci:0000:01:00.0
[    19.469] drmOpenByBusid: drmOpenMinor returns 8
[    19.469] drmOpenByBusid: drmGetBusid reports pci:0000:01:00.0
[    19.469] (II) [drm] nouveau interface version: 1.1.1
[    19.469] (WW) Falling back to old probe method for vesa
[    19.469] (WW) Falling back to old probe method for fbdev
[    19.469] (II) Loading sub module "fbdevhw"
[    19.469] (II) LoadModule: "fbdevhw"
[    19.469] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    19.479] (II) Module fbdevhw: vendor="X.Org Foundation"
[    19.479]     compiled for 1.12.4, module version = 0.0.2
[    19.479]     ABI class: X.Org Video Driver, version 12.1
[    19.480] (II) Loading sub module "dri"
[    19.480] (II) LoadModule: "dri"
[    19.480] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[    19.480] (II) Module dri: vendor="X.Org Foundation"
[    19.480]     compiled for 1.12.4, module version = 1.0.0
[    19.480]     ABI class: X.Org Server Extension, version 6.0
[    19.480] (II) NOUVEAU(0): Loaded DRI module
[    19.480] drmOpenDevice: node name is /dev/dri/card0
[    19.480] drmOpenDevice: open result is 9, (OK)
[    19.480] drmOpenByBusid: Searching for BusID pci:0000:01:00.0
[    19.480] drmOpenByBusid: drmOpenMinor returns 9
[    19.480] drmOpenByBusid: drmGetBusid reports pci:0000:01:00.0
[    19.480] (II) [drm] DRM interface version 1.4
[    19.480] (II) [drm] DRM open master succeeded.
[    19.480] (--) NOUVEAU(0): Chipset: "NVIDIA NV98"
[    19.480] (II) NOUVEAU(0): Creating default Display subsection in Screen section
    "Default Screen Section" for depth/fbbpp 24/32
[    19.480] (==) NOUVEAU(0): Depth 24, (--) framebuffer bpp 32
[    19.480] (==) NOUVEAU(0): RGB weight 888
[    19.480] (==) NOUVEAU(0): Default visual is TrueColor
[    19.480] (==) NOUVEAU(0): Using HW cursor
[    19.480] (==) NOUVEAU(0): GLX sync to VBlank disabled.
[    19.480] (==) NOUVEAU(0): Page flipping enabled
[    19.480] (==) NOUVEAU(0): Swap limit set to 2 [Max allowed 2]
[    19.536] (II) NOUVEAU(0): Output LVDS-1 has no monitor section
[    19.558] (II) NOUVEAU(0): Output VGA-1 has no monitor section
[    19.560] (II) NOUVEAU(0): Output DP-1 has no monitor section
[    19.562] (II) NOUVEAU(0): Output DP-2 has no monitor section
[    19.607] (II) NOUVEAU(0): EDID for output LVDS-1
[    19.607] (II) NOUVEAU(0): Manufacturer: SEC  Model: 5442  Serial#: 0
[    19.607] (II) NOUVEAU(0): Year: 2008  Week: 0
[    19.607] (II) NOUVEAU(0): EDID Version: 1.3
[    19.607] (II) NOUVEAU(0): Digital Display Input
[    19.607] (II) NOUVEAU(0): Max Image Size [cm]: horiz.: 33  vert.: 21
[    19.607] (II) NOUVEAU(0): Gamma: 2.20
[    19.607] (II) NOUVEAU(0): No DPMS capabilities specified
[    19.607] (II) NOUVEAU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    19.607] (II) NOUVEAU(0): First detailed timing is preferred mode
[    19.607] (II) NOUVEAU(0): redX: 0.580 redY: 0.340   greenX: 0.310 greenY: 0.550
[    19.607] (II) NOUVEAU(0): blueX: 0.155 blueY: 0.155   whiteX: 0.313 whiteY: 0.329
[    19.607] (II) NOUVEAU(0): Manufacturer's mask: 0
[    19.607] (II) NOUVEAU(0): Supported detailed timing:
[    19.607] (II) NOUVEAU(0): clock: 108.0 MHz   Image Size:  331 x 207 mm
[    19.607] (II) NOUVEAU(0): h_active: 1440  h_sync: 1504  h_sync_end 1536 h_blank_end 1976 h_border: 0
[    19.607] (II) NOUVEAU(0): v_active: 900  v_sync: 903  v_sync_end 906 v_blanking: 912 v_border: 0
[    19.607] (II) NOUVEAU(0): clock: 72.1 MHz   Image Size:  331 x 207 mm
[    19.607] (II) NOUVEAU(0):  XP971154BT
[    19.607] (II) NOUVEAU(0): Unknown vendor-specific block 0
[    19.607] (II) NOUVEAU(0): EDID (in hex):
[    19.607] (II) NOUVEAU(0):     00ffffffffffff004ca3425400000000
[    19.607] (II) NOUVEAU(0):     00120103902115780a87f594574f8c27
[    19.607] (II) NOUVEAU(0):     27505400000001010101010101010101
[    19.607] (II) NOUVEAU(0):     010101010101302aa01852840c304020
[    19.607] (II) NOUVEAU(0):     33004bcf1000001a281ca01852840c30
[    19.607] (II) NOUVEAU(0):     402033004bcf1000001a000000fe0058
[    19.607] (II) NOUVEAU(0):     503937318131353442540a2000000000
[    19.607] (II) NOUVEAU(0):     000c10171b3669a9ff02010a202000fb
[    19.607] (II) NOUVEAU(0): EDID vendor "SEC", prod id 21570
[    19.607] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[    19.607] (II) NOUVEAU(0): Modeline "1440x900"x0.0  108.00  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (54.7 kHz eP)
[    19.607] (II) NOUVEAU(0): Modeline "1440x900"x0.0   72.08  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (36.5 kHz e)
[    19.608] (II) NOUVEAU(0): Printing probed modes for output LVDS-1
[    19.608] (II) NOUVEAU(0): Modeline "1440x900"x59.9  108.00  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (54.7 kHz eP)
[    19.608] (II) NOUVEAU(0): Modeline "1440x900"x40.0   72.08  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (36.5 kHz e)
[    19.608] (II) NOUVEAU(0): Modeline "1152x864"x60.0   81.75  1152 1216 1336 1520  864 867 871 897 -hsync +vsync (53.8 kHz e)
[    19.608] (II) NOUVEAU(0): Modeline "1024x768"x59.9   63.50  1024 1072 1176 1328  768 771 775 798 -hsync +vsync (47.8 kHz e)
[    19.608] (II) NOUVEAU(0): Modeline "800x600"x59.9   38.25  800 832 912 1024  600 603 607 624 -hsync +vsync (37.4 kHz e)
[    19.608] (II) NOUVEAU(0): Modeline "640x480"x59.4   23.75  640 664 720 800  480 483 487 500 -hsync +vsync (29.7 kHz e)
[    19.608] (II) NOUVEAU(0): Modeline "720x400"x59.6   22.25  720 744 808 896  400 403 413 417 -hsync +vsync (24.8 kHz e)
[    19.608] (II) NOUVEAU(0): Modeline "640x400"x60.0   20.00  640 664 720 800  400 403 409 417 -hsync +vsync (25.0 kHz e)
[    19.608] (II) NOUVEAU(0): Modeline "640x350"x59.8   17.50  640 664 720 800  350 353 363 366 -hsync +vsync (21.9 kHz e)
[    19.631] (II) NOUVEAU(0): EDID for output VGA-1
[    19.633] (II) NOUVEAU(0): EDID for output DP-1
[    19.636] (II) NOUVEAU(0): EDID for output DP-2
[    19.636] (II) NOUVEAU(0): Output LVDS-1 connected
[    19.636] (II) NOUVEAU(0): Output VGA-1 disconnected
[    19.636] (II) NOUVEAU(0): Output DP-1 disconnected
[    19.636] (II) NOUVEAU(0): Output DP-2 disconnected
[    19.636] (II) NOUVEAU(0): Using exact sizes for initial modes
[    19.636] (II) NOUVEAU(0): Output LVDS-1 using initial mode 1440x900
[    19.636] (II) NOUVEAU(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[    19.636] (--) NOUVEAU(0): Virtual size is 1440x900 (pitch 0)
[    19.636] (**) NOUVEAU(0):  Driver mode "1440x900": 108.0 MHz (scaled from 0.0 MHz), 54.7 kHz, 59.9 Hz
[    19.636] (II) NOUVEAU(0): Modeline "1440x900"x59.9  108.00  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (54.7 kHz eP)
[    19.636] (**) NOUVEAU(0):  Driver mode "1440x900": 72.1 MHz (scaled from 0.0 MHz), 36.5 kHz, 40.0 Hz
[    19.636] (II) NOUVEAU(0): Modeline "1440x900"x40.0   72.08  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (36.5 kHz e)
[    19.636] (**) NOUVEAU(0):  Driver mode "1152x864": 81.8 MHz (scaled from 0.0 MHz), 53.8 kHz, 60.0 Hz
[    19.636] (II) NOUVEAU(0): Modeline "1152x864"x60.0   81.75  1152 1216 1336 1520  864 867 871 897 -hsync +vsync (53.8 kHz e)
[    19.636] (**) NOUVEAU(0):  Driver mode "1024x768": 63.5 MHz (scaled from 0.0 MHz), 47.8 kHz, 59.9 Hz
[    19.636] (II) NOUVEAU(0): Modeline "1024x768"x59.9   63.50  1024 1072 1176 1328  768 771 775 798 -hsync +vsync (47.8 kHz e)
[    19.636] (**) NOUVEAU(0):  Driver mode "800x600": 38.2 MHz (scaled from 0.0 MHz), 37.4 kHz, 59.9 Hz
[    19.636] (II) NOUVEAU(0): Modeline "800x600"x59.9   38.25  800 832 912 1024  600 603 607 624 -hsync +vsync (37.4 kHz e)
[    19.636] (**) NOUVEAU(0):  Driver mode "640x480": 23.8 MHz (scaled from 0.0 MHz), 29.7 kHz, 59.4 Hz
[    19.636] (II) NOUVEAU(0): Modeline "640x480"x59.4   23.75  640 664 720 800  480 483 487 500 -hsync +vsync (29.7 kHz e)
[    19.636] (**) NOUVEAU(0):  Driver mode "720x400": 22.2 MHz (scaled from 0.0 MHz), 24.8 kHz, 59.6 Hz
[    19.636] (II) NOUVEAU(0): Modeline "720x400"x59.6   22.25  720 744 808 896  400 403 413 417 -hsync +vsync (24.8 kHz e)
[    19.636] (**) NOUVEAU(0):  Driver mode "640x400": 20.0 MHz (scaled from 0.0 MHz), 25.0 kHz, 60.0 Hz
[    19.636] (II) NOUVEAU(0): Modeline "640x400"x60.0   20.00  640 664 720 800  400 403 409 417 -hsync +vsync (25.0 kHz e)
[    19.636] (**) NOUVEAU(0):  Driver mode "640x350": 17.5 MHz (scaled from 0.0 MHz), 21.9 kHz, 59.8 Hz
[    19.636] (II) NOUVEAU(0): Modeline "640x350"x59.8   17.50  640 664 720 800  350 353 363 366 -hsync +vsync (21.9 kHz e)
[    19.636] (**) NOUVEAU(0): Display dimensions: (330, 210) mm
[    19.636] (**) NOUVEAU(0): DPI set to (110, 108)
[    19.636] (II) Loading sub module "fb"
[    19.636] (II) LoadModule: "fb"
[    19.636] (II) Loading /usr/lib/xorg/modules/libfb.so
[    19.649] (II) Module fb: vendor="X.Org Foundation"
[    19.649]     compiled for 1.12.4, module version = 1.0.0
[    19.649]     ABI class: X.Org ANSI C Emulation, version 0.4
[    19.649] (II) Loading sub module "exa"
[    19.650] (II) LoadModule: "exa"
[    19.650] (II) Loading /usr/lib/xorg/modules/libexa.so
[    19.651] (II) Module exa: vendor="X.Org Foundation"
[    19.651]     compiled for 1.12.4, module version = 2.5.0
[    19.651]     ABI class: X.Org Video Driver, version 12.1
[    19.651] (II) Loading sub module "shadowfb"
[    19.651] (II) LoadModule: "shadowfb"
[    19.651] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[    19.660] (II) Module shadowfb: vendor="X.Org Foundation"
[    19.660]     compiled for 1.12.4, module version = 1.0.0
[    19.660]     ABI class: X.Org ANSI C Emulation, version 0.4
[    19.660] (II) UnloadModule: "vesa"
[    19.660] (II) Unloading vesa
[    19.660] (II) UnloadModule: "fbdev"
[    19.660] (II) Unloading fbdev
[    19.660] (II) UnloadSubModule: "fbdevhw"
[    19.660] (II) Unloading fbdevhw
[    19.660] (--) Depth 24 pixmap format is 32 bpp
[    19.661] (II) NOUVEAU(0): Opened GPU channel 0
[    19.666] (II) NOUVEAU(0): [DRI2] Setup complete
[    19.666] (II) NOUVEAU(0): [DRI2]   DRI driver: nouveau
[    19.666] (II) NOUVEAU(0): [DRI2]   VDPAU driver: nouveau
[    19.684] (II) EXA(0): Driver allocated offscreen pixmaps
[    19.684] (II) EXA(0): Driver registered support for the following operations:
[    19.684] (II)         Solid
[    19.684] (II)         Copy
[    19.684] (II)         Composite (RENDER acceleration)
[    19.684] (II)         UploadToScreen
[    19.684] (II)         DownloadFromScreen
[    19.684] (==) NOUVEAU(0): Backing store disabled
[    19.684] (==) NOUVEAU(0): Silken mouse enabled
[    19.696] (II) NOUVEAU(0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[    19.696] (II) NOUVEAU(0): [XvMC] Extension initialized.
[    19.696] (==) NOUVEAU(0): DPMS enabled
[    19.696] (II) NOUVEAU(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    19.697] (--) RandR disabled
[    19.697] (II) Initializing built-in extension Generic Event Extension
[    19.697] (II) Initializing built-in extension SHAPE
[    19.697] (II) Initializing built-in extension MIT-SHM
[    19.697] (II) Initializing built-in extension XInputExtension
[    19.697] (II) Initializing built-in extension XTEST
[    19.697] (II) Initializing built-in extension BIG-REQUESTS
[    19.697] (II) Initializing built-in extension SYNC
[    19.697] (II) Initializing built-in extension XKEYBOARD
[    19.697] (II) Initializing built-in extension XC-MISC
[    19.697] (II) Initializing built-in extension SECURITY
[    19.697] (II) Initializing built-in extension XINERAMA
[    19.697] (II) Initializing built-in extension XFIXES
[    19.697] (II) Initializing built-in extension RENDER
[    19.697] (II) Initializing built-in extension RANDR
[    19.697] (II) Initializing built-in extension COMPOSITE
[    19.697] (II) Initializing built-in extension DAMAGE
[    19.697] (II) SELinux: Disabled on system
[    20.313] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[    20.313] (II) AIGLX: enabled GLX_INTEL_swap_event
[    20.313] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[    20.313] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[    20.314] (II) AIGLX: Loaded and initialized nouveau
[    20.314] (II) GLX: Initialized DRI2 GL provider for screen 0
[    20.318] (II) NOUVEAU(0): NVEnterVT is called.
[    20.347] (II) NOUVEAU(0): Setting screen physical size to 381 x 238
[    20.347] resize called 1440 900
[    20.681] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[    20.681] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    20.681] (II) LoadModule: "evdev"
[    20.681] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    20.778] (II) Module evdev: vendor="X.Org Foundation"
[    20.778]     compiled for 1.12.1, module version = 2.7.0
[    20.778]     Module class: X.Org XInput Driver
[    20.778]     ABI class: X.Org XInput driver, version 16.0
[    20.778] (II) Using input driver 'evdev' for 'Video Bus'
[    20.778] (**) Video Bus: always reports core events
[    20.778] (**) evdev: Video Bus: Device: "/dev/input/event5"
[    20.778] (--) evdev: Video Bus: Vendor 0 Product 0x6
[    20.778] (--) evdev: Video Bus: Found keys
[    20.778] (II) evdev: Video Bus: Configuring as keyboard
[    20.778] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A03:00/device:36/LNXVIDEO:00/input/input7/event5"
[    20.778] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[    20.778] (**) Option "xkb_rules" "evdev"
[    20.778] (**) Option "xkb_model" "pc105"
[    20.778] (**) Option "xkb_layout" "us,pl"
[    20.778] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[    20.836] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    20.836] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    20.836] (II) Using input driver 'evdev' for 'Power Button'
[    20.836] (**) Power Button: always reports core events
[    20.836] (**) evdev: Power Button: Device: "/dev/input/event2"
[    20.836] (--) evdev: Power Button: Vendor 0 Product 0x1
[    20.836] (--) evdev: Power Button: Found keys
[    20.836] (II) evdev: Power Button: Configuring as keyboard
[    20.836] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input3/event2"
[    20.836] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    20.836] (**) Option "xkb_rules" "evdev"
[    20.836] (**) Option "xkb_model" "pc105"
[    20.836] (**) Option "xkb_layout" "us,pl"
[    20.836] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[    20.836] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[    20.836] (II) No input driver specified, ignoring this device.
[    20.836] (II) This device may have been added with another device file.
[    20.836] (II) config/udev: Adding input device Sleep Button (/dev/input/event3)
[    20.836] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    20.836] (II) Using input driver 'evdev' for 'Sleep Button'
[    20.836] (**) Sleep Button: always reports core events
[    20.836] (**) evdev: Sleep Button: Device: "/dev/input/event3"
[    20.836] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[    20.836] (--) evdev: Sleep Button: Found keys
[    20.836] (II) evdev: Sleep Button: Configuring as keyboard
[    20.836] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input4/event3"
[    20.836] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[    20.837] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[    20.837] (II) config/udev: Adding input device HID 413c:8157 (/dev/input/event16)
[    20.837] (**) HID 413c:8157: Applying InputClass "evdev keyboard catchall"
[    20.837] (II) Using input driver 'evdev' for 'HID 413c:8157'
[    20.837] (**) HID 413c:8157: always reports core events
[    20.837] (**) evdev: HID 413c:8157: Device: "/dev/input/event16"
[    20.837] (--) evdev: HID 413c:8157: Vendor 0x413c Product 0x8157
[    20.837] (--) evdev: HID 413c:8157: Found keys
[    20.837] (II) evdev: HID 413c:8157: Configuring as keyboard
[    20.837] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input17/event16"
[    20.837] (II) XINPUT: Adding extended input device "HID 413c:8157" (type: KEYBOARD, id 9)
[    20.837] (**) Option "xkb_rules" "evdev"
[    20.837] (**) Option "xkb_model" "pc105"
[    20.837] (**) Option "xkb_layout" "us,pl"
[    20.838] (II) config/udev: Adding input device Integrated_Webcam_2M (/dev/input/event14)
[    20.838] (**) Integrated_Webcam_2M: Applying InputClass "evdev keyboard catchall"
[    20.838] (II) Using input driver 'evdev' for 'Integrated_Webcam_2M'
[    20.838] (**) Integrated_Webcam_2M: always reports core events
[    20.838] (**) evdev: Integrated_Webcam_2M: Device: "/dev/input/event14"
[    20.838] (--) evdev: Integrated_Webcam_2M: Vendor 0xc45 Product 0x63f0
[    20.838] (--) evdev: Integrated_Webcam_2M: Found keys
[    20.838] (II) evdev: Integrated_Webcam_2M: Configuring as keyboard
[    20.838] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.7/usb7/7-6/7-6:1.0/input/input15/event14"
[    20.838] (II) XINPUT: Adding extended input device "Integrated_Webcam_2M" (type: KEYBOARD, id 10)
[    20.838] (**) Option "xkb_rules" "evdev"
[    20.838] (**) Option "xkb_model" "pc105"
[    20.838] (**) Option "xkb_layout" "us,pl"
[    20.838] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[    20.838] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event9)
[    20.838] (II) No input driver specified, ignoring this device.
[    20.838] (II) This device may have been added with another device file.
[    20.838] (II) config/udev: Adding input device HDA Intel Dock Mic (/dev/input/event13)
[    20.839] (II) config/udev: Adding input device HDA Intel Mic (/dev/input/event12)
[    20.839] (II) No input driver specified, ignoring this device.
[    20.839] (II) This device may have been added with another device file.
[    20.839] (II) config/udev: Adding input device HDA Intel Dock Line Out (/dev/input/event11)
[    20.839] (II) config/udev: Adding input device HDA Intel Headphone (/dev/input/event10)
[    20.839] (II) config/udev: Adding input device Genius Optical Mouse (/dev/input/event15)
[    20.839] (**) Genius Optical Mouse: Applying InputClass "evdev pointer catchall"
[    20.839] (II) Using input driver 'evdev' for 'Genius Optical Mouse'
[    20.839] (**) Genius Optical Mouse: always reports core events
[    20.839] (**) evdev: Genius Optical Mouse: Device: "/dev/input/event15"
[    20.839] (--) evdev: Genius Optical Mouse: Vendor 0x458 Product 0x3a
[    20.839] (--) evdev: Genius Optical Mouse: Found 3 mouse buttons
[    20.839] (--) evdev: Genius Optical Mouse: Found scroll wheel(s)
[    20.839] (--) evdev: Genius Optical Mouse: Found relative axes
[    20.839] (--) evdev: Genius Optical Mouse: Found x and y relative axes
[    20.839] (II) evdev: Genius Optical Mouse: Configuring as mouse
[    20.839] (II) evdev: Genius Optical Mouse: Adding scrollwheel support
[    20.839] (**) evdev: Genius Optical Mouse: YAxisMapping: buttons 4 and 5
[    20.839] (**) evdev: Genius Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    20.839] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb4/4-2/4-2:1.0/input/input16/event15"
[    20.839] (II) XINPUT: Adding extended input device "Genius Optical Mouse" (type: MOUSE, id 11)
[    20.840] (II) evdev: Genius Optical Mouse: initialized for relative axes.
[    20.840] (**) Genius Optical Mouse: (accel) keeping acceleration scheme 1
[    20.840] (**) Genius Optical Mouse: (accel) acceleration profile 0
[    20.840] (**) Genius Optical Mouse: (accel) acceleration factor: 2.000
[    20.840] (**) Genius Optical Mouse: (accel) acceleration threshold: 4
[    20.840] (II) config/udev: Adding input device Genius Optical Mouse (/dev/input/mouse2)
[    20.840] (II) No input driver specified, ignoring this device.
[    20.840] (II) This device may have been added with another device file.
[    20.840] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[    20.840] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    20.840] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[    20.840] (**) AT Translated Set 2 keyboard: always reports core events
[    20.840] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[    20.840] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[    20.840] (--) evdev: AT Translated Set 2 keyboard: Found keys
[    20.840] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[    20.840] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[    20.840] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[    20.840] (**) Option "xkb_rules" "evdev"
[    20.840] (**) Option "xkb_model" "pc105"
[    20.840] (**) Option "xkb_layout" "us,pl"
[    20.840] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[    20.841] (II) config/udev: Adding input device AlpsPS/2 ALPS DualPoint TouchPad (/dev/input/event8)
[    20.841] (**) AlpsPS/2 ALPS DualPoint TouchPad: Applying InputClass "evdev touchpad catchall"
[    20.841] (**) AlpsPS/2 ALPS DualPoint TouchPad: Applying InputClass "touchpad catchall"
[    20.841] (**) AlpsPS/2 ALPS DualPoint TouchPad: Applying InputClass "Default clickpad buttons"
[    20.841] (II) LoadModule: "synaptics"
[    20.841] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[    20.897] (II) Module synaptics: vendor="X.Org Foundation"
[    20.897]     compiled for 1.12.4, module version = 1.6.2
[    20.897]     Module class: X.Org XInput Driver
[    20.897]     ABI class: X.Org XInput driver, version 16.0
[    20.897] (II) Using input driver 'synaptics' for 'AlpsPS/2 ALPS DualPoint TouchPad'
[    20.897] (**) AlpsPS/2 ALPS DualPoint TouchPad: always reports core events
[    20.897] (**) Option "Device" "/dev/input/event8"
[    21.072] (--) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: x-axis range 0 - 1023
[    21.072] (--) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: y-axis range 0 - 767
[    21.072] (--) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: pressure range 0 - 127
[    21.072] (II) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: device does not report finger width.
[    21.072] (--) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: buttons: left right middle
[    21.072] (--) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: Vendor 0x2 Product 0x8
[    21.072] (--) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: invalid finger width range.  defaulting to 0 - 15
[    21.072] (--) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: touchpad found
[    21.072] (**) AlpsPS/2 ALPS DualPoint TouchPad: always reports core events
[    21.167] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input6/event8"
[    21.168] (II) XINPUT: Adding extended input device "AlpsPS/2 ALPS DualPoint TouchPad" (type: TOUCHPAD, id 13)
[    21.168] (**) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[    21.168] (**) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: MaxSpeed is now 1.75
[    21.168] (**) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: AccelFactor is now 0.156
[    21.169] (**) AlpsPS/2 ALPS DualPoint TouchPad: (accel) keeping acceleration scheme 1
[    21.169] (**) AlpsPS/2 ALPS DualPoint TouchPad: (accel) acceleration profile 1
[    21.169] (**) AlpsPS/2 ALPS DualPoint TouchPad: (accel) acceleration factor: 2.000
[    21.169] (**) AlpsPS/2 ALPS DualPoint TouchPad: (accel) acceleration threshold: 4
[    21.169] (--) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: touchpad found
[    21.169] (II) config/udev: Adding input device AlpsPS/2 ALPS DualPoint TouchPad (/dev/input/mouse1)
[    21.170] (**) AlpsPS/2 ALPS DualPoint TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
[    21.170] (II) config/udev: Adding input device DualPoint Stick (/dev/input/event7)
[    21.170] (**) DualPoint Stick: Applying InputClass "evdev pointer catchall"
[    21.170] (II) Using input driver 'evdev' for 'DualPoint Stick'
[    21.170] (**) DualPoint Stick: always reports core events
[    21.170] (**) evdev: DualPoint Stick: Device: "/dev/input/event7"
[    21.170] (--) evdev: DualPoint Stick: Vendor 0x2 Product 0x8
[    21.170] (--) evdev: DualPoint Stick: Found 3 mouse buttons
[    21.170] (--) evdev: DualPoint Stick: Found relative axes
[    21.170] (--) evdev: DualPoint Stick: Found x and y relative axes
[    21.170] (II) evdev: DualPoint Stick: Configuring as mouse
[    21.170] (**) evdev: DualPoint Stick: YAxisMapping: buttons 4 and 5
[    21.171] (**) evdev: DualPoint Stick: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    21.171] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input9/event7"
[    21.171] (II) XINPUT: Adding extended input device "DualPoint Stick" (type: MOUSE, id 14)
[    21.171] (II) evdev: DualPoint Stick: initialized for relative axes.
[    21.171] (**) DualPoint Stick: (accel) keeping acceleration scheme 1
[    21.171] (**) DualPoint Stick: (accel) acceleration profile 0
[    21.171] (**) DualPoint Stick: (accel) acceleration factor: 2.000
[    21.171] (**) DualPoint Stick: (accel) acceleration threshold: 4
[    21.172] (II) config/udev: Adding input device DualPoint Stick (/dev/input/mouse0)
[    21.172] (II) No input driver specified, ignoring this device.
[    21.172] (II) This device may have been added with another device file.
[    21.172] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[    21.174] (II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event17)
[    21.174] (**) ACPI Virtual Keyboard Device: Applying InputClass "evdev keyboard catchall"
[    21.174] (II) Using input driver 'evdev' for 'ACPI Virtual Keyboard Device'
[    21.174] (**) ACPI Virtual Keyboard Device: always reports core events
[    21.174] (**) evdev: ACPI Virtual Keyboard Device: Device: "/dev/input/event17"
[    21.174] (--) evdev: ACPI Virtual Keyboard Device: Vendor 0 Product 0
[    21.174] (--) evdev: ACPI Virtual Keyboard Device: Found keys
[    21.174] (II) evdev: ACPI Virtual Keyboard Device: Configuring as keyboard
[    21.174] (**) Option "config_info" "udev:/sys/devices/virtual/input/input19/event17"
[    21.174] (II) XINPUT: Adding extended input device "ACPI Virtual Keyboard Device" (type: KEYBOARD, id 15)
[    21.174] (**) Option "xkb_rules" "evdev"
[    21.174] (**) Option "xkb_model" "pc105"
[    21.174] (**) Option "xkb_layout" "us,pl"
[    21.174] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[    21.175] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event6)
[    21.175] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    21.175] (II) Using input driver 'evdev' for 'Dell WMI hotkeys'
[    21.175] (**) Dell WMI hotkeys: always reports core events
[    21.175] (**) evdev: Dell WMI hotkeys: Device: "/dev/input/event6"
[    21.176] (--) evdev: Dell WMI hotkeys: Vendor 0 Product 0
[    21.176] (--) evdev: Dell WMI hotkeys: Found keys
[    21.176] (II) evdev: Dell WMI hotkeys: Configuring as keyboard
[    21.176] (**) Option "config_info" "udev:/sys/devices/virtual/input/input8/event6"
[    21.176] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 16)
[    21.176] (**) Option "xkb_rules" "evdev"
[    21.176] (**) Option "xkb_model" "pc105"
[    21.176] (**) Option "xkb_layout" "us,pl"
[    21.176] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[    25.190] (II) NOUVEAU(0): EDID vendor "SEC", prod id 21570
[    25.190] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[    25.190] (II) NOUVEAU(0): Modeline "1440x900"x0.0  108.00  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (54.7 kHz eP)
[    25.190] (II) NOUVEAU(0): Modeline "1440x900"x0.0   72.08  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (36.5 kHz e)
[    25.307] (II) NOUVEAU(0): EDID vendor "SEC", prod id 21570
[    25.307] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[    25.307] (II) NOUVEAU(0): Modeline "1440x900"x0.0  108.00  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (54.7 kHz eP)
[    25.307] (II) NOUVEAU(0): Modeline "1440x900"x0.0   72.08  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (36.5 kHz e)
[    25.446] (II) NOUVEAU(0): EDID vendor "SEC", prod id 21570
[    25.446] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[    25.446] (II) NOUVEAU(0): Modeline "1440x900"x0.0  108.00  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (54.7 kHz eP)
[    25.446] (II) NOUVEAU(0): Modeline "1440x900"x0.0   72.08  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (36.5 kHz e)
[    25.561] (II) NOUVEAU(0): EDID vendor "SEC", prod id 21570
[    25.561] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[    25.561] (II) NOUVEAU(0): Modeline "1440x900"x0.0  108.00  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (54.7 kHz eP)
[    25.561] (II) NOUVEAU(0): Modeline "1440x900"x0.0   72.08  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (36.5 kHz e)
[    32.108] (II) NOUVEAU(0): EDID vendor "SEC", prod id 21570
[    32.108] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[    32.108] (II) NOUVEAU(0): Modeline "1440x900"x0.0  108.00  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (54.7 kHz eP)
[    32.108] (II) NOUVEAU(0): Modeline "1440x900"x0.0   72.08  1440 1504 1536 1976  900 903 906 912 +hsync -vsync (36.5 kHz e)
neo86 chodzi Ci o wtyczki z tego repo xbmc
http://sd-xbmc.org/pl/content/repozytorium-wersja-200
no tam jest ipla tvn itd itp..i wszystko chodzi na najnowszym xbmc z deb-multimedia sidowego i na starszych też. Może masz stare repo xbmc to 1.0.2 i przestarzałych wtyczek używasz??
nawiasem mówiąc to wolisz kompilować i robić syf niż przejść na testinga/sida i mieć z głowy, najnowszy soft bez zbędnej zabawy działający,zawsze na bieżąco, roling relase w przypadku sida i oczywiście zero problemów, bo początkujący nie jesteś to se go ogarniesz..same plusy..;>
