Konfigurowanie pakietu proftpd-basic (1.3.4a-5+deb7u1) ...insserv: warning: script 'K36cups' missing LSB tags and overrides
insserv: warning: script 'K01noip2' missing LSB tags and overrides
insserv: warning: script 'cups' missing LSB tags and overrides
insserv: warning: script 'noip2' missing LSB tags and overrides
insserv: There is a loop between service cups and mountnfs if started
insserv: loop involving service mountnfs at depth 10
insserv: loop involving service nfs-common at depth 9
insserv: Starting cups depends on rmnologin and therefore on system facility `$all' which can not be true!
insserv: There is a loop between service samba and cups if started
insserv: loop involving service cups at depth 12
insserv: loop involving service samba at depth 11
insserv: loop involving service exim4 at depth 11
insserv: There is a loop between service samba and urandom if started
insserv: loop involving service urandom at depth 6
insserv: loop involving service mountall at depth 5
insserv: loop involving service mountnfs-bootclean at depth 12
insserv: loop involving service networking at depth 8
insserv: loop involving service mountall-bootclean at depth 6
insserv: There is a loop between service rmnologin and checkroot if started
insserv: loop involving service checkroot at depth 3
insserv: loop involving service keyboard-setup at depth 2
insserv: There is a loop between service cups and checkfs if started
insserv: loop involving service checkfs at depth 5
insserv: loop involving service mtab at depth 4
insserv: loop involving service hwclock at depth 3
insserv: loop involving service apache2 at depth 14
insserv: Max recursions depth 99 reached
insserv: There is a loop at service rmnologin if started
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: błąd przetwarzania proftpd-basic (--configure):
podproces zainstalowany skrypt post-installation zwrócił kod błędu 1
dpkg: problemy z zależnościami uniemożliwiają skonfigurowanie pakietu proftpd-mod-vroot:
proftpd-mod-vroot zależy od proftpd-basic (>= 1.3.4~rc2-2~); jednakże:
Pakiet proftpd-basic nie jest jeszcze skonfigurowany.
proftpd-mod-vroot zależy od proftpd-abi-1.3.4a; jednakże:
Pakiet proftpd-abi-1.3.4a nie jest zainstalowany.
Pakiet proftpd-basic dostarcza proftpd-abi-1.3.4a, ale nie został jeszcze skonfigurowany.
dpkg: błąd przetwarzania proftpd-mod-vroot (--configure):
problemy z zależnościami - pozostawianie nieskonfigurowanego
proftpd-basic
proftpd-mod-vroot
E: Sub-process /usr/bin/dpkg returned an error code (1)Jak to naprawić ?
Proszę o pomoc
