Postawiłem sobie serwer poczty który działał
po jakimś czasie wyskoczył błąd (4h) - serwer przestał wysyłać i odbierać poczty
mail.log
mail.errService shutting down, closing channel (in reply to RCPT TO command))
Apr 25 23:05:02 budma24 dovecot: imap-login: Disconnected (disconnected before greeting, waited 0 secs): user=<>, rip=::1, lip=::1, secured, session=<kzG8UeT33wAAAAAAAAAAAAAAAAAAAAAB>
Apr 25 23:05:02 budma24 postfix/smtpd[8244]: warning: hostname localhost does not resolve to address ::1: No address associated with hostname
Apr 25 23:05:02 budma24 postfix/smtpd[8244]: connect from unknown[::1]
Apr 25 23:05:02 budma24 postfix/smtpd[8244]: lost connection after CONNECT from unknown[::1]
Apr 25 23:05:02 budma24 postfix/smtpd[8244]: disconnect from unknown[::1]
Apr 25 23:05:02 budma24 dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=::1, lip=::1, secured, session=<Dae/UeT3VgAAAAAAAAAAAAAAAAAAAAAB>
Apr 25 23:06:15 budma24 postfix/pickup[7432]: 63AB024C3041: uid=1000 from=<uh>
Apr 25 23:06:15 budma24 postfix/cleanup[8286]: 63AB024C3041: message-id=<20140425210615.63AB024C3041@budma24.pl>
Apr 25 23:06:15 budma24 postfix/qmgr[7433]: 63AB024C3041: from=<uh@budma24.pl>, size=278, nrcpt=1 (queue active)
Apr 25 23:06:15 budma24 amavis[7269]: (07269-01) (!)connect_to_sql: unable to connect to DSN 'DBI:mysql:database=dbispconfig;host=127.0.0.2;port=3306': Can't connect to MySQL server on '127.0.0.2' (111)
Apr 25 23:06:15 budma24 amavis[7269]: (07269-01) (!!)TROUBLE in process_request: connect_to_sql: unable to connect to any dataset at (eval 111) line 247.
Apr 25 23:06:15 budma24 amavis[7269]: (07269-01) (!)Requesting process rundown after fatal error
Apr 25 23:06:15 budma24 postfix/smtp[8289]: 63AB024C3041: to=<uh4@o2.pl>, relay=127.0.0.1[127.0.0.1]:10024, delay=0.89, delays=0.79/0.02/0.01/0.07, dsn=4.3.2, status=deferred (host 127.0.0.1[127.0.0.1] said: 421 4.3.2 Service shutting down, closing channel (in reply to RCPT TO command))
Nie wiem gdzie szukać rozwiązania
Apr 25 23:03:23 budma24 amavis[7195]: (07195-01) (!!)TROUBLE in process_request: connect_to_sql: unable to connect to any dataset at (eval 111) line 247.
Apr 25 23:08:23 budma24 amavis[7452]: (07452-01) (!!)TROUBLE in process_request: connect_to_sql: unable to connect to any dataset at (eval 111) line 247.
Apr 25 23:08:23 budma24 amavis[8293]: (08293-01) (!!)TROUBLE in process_request: connect_to_sql: unable to connect to any dataset at (eval 111) line 247.
Apr 25 23:08:23 budma24 amavis[8325]: (08325-01) (!!)TROUBLE in process_request: connect_to_sql: unable to connect to any dataset at (eval 111) line 247.
Apr 25 23:08:23 budma24 amavis[8326]: (08326-01) (!!)TROUBLE in process_request: connect_to_sql: unable to connect to any dataset at (eval 111) line 247.
