Kompilacja serwera TFS 0.3.6pl1
Paolo
Post autor: Paolo »
Witam, mam pewien problem z kompilacja silnika TFS 0.3.6pl1 na Debianie Squeeze 64 bit.
Wywala mi, że brakuje boostów.
autoreconf: Entering directory `.'autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal --force
autoreconf: configure.ac: tracing
autoreconf: configure.ac: not using Libtool
autoreconf: running: /usr/bin/autoconf --force
autoreconf: running: /usr/bin/autoheader --force
autoreconf: running: automake --add-missing --copy --force-missing
autoreconf: Leaving directory `.'
root@VPS:~/tfs# ./configure --enable-mysql --enable-remote-control --enable-server-diag
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for g++... g++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for stdint.h... (cached) yes
checking for stdlib.h... (cached) yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/timeb.h usability... yes
checking sys/timeb.h presence... yes
checking for sys/timeb.h... yes
checking for stdbool.h that conforms to C99... yes
checking for _Bool... no
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for size_t... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking for uint8_t... yes
checking for ptrdiff_t... yes
checking for GNU libc compatible malloc... yes
checking for working memcmp... yes
checking for GNU libc compatible realloc... yes
checking for floor... yes
checking for ftime... yes
checking for gethostbyname... yes
checking for gethostname... yes
checking for memset... yes
checking for pow... yes
checking for sqrt... yes
checking for strcasecmp... yes
checking for strncasecmp... yes
checking for strstr... yes
checking for strtol... yes
checking for xml2-config... /usr/bin/xml2-config
checking for libxml - version >= 2.6.5... yes (version 2.7.8)
checking gmp.h usability... yes
checking gmp.h presence... yes
checking for gmp.h... yes
checking for __gmpz_init2 in -lgmp... yes
checking for main in -lboost_thread-gcc-mt... no
checking for main in -lboost_thread-mt... yes
checking for main in -lboost_regex-gcc-mt... no
checking for main in -lboost_regex-mt... yes
checking for main in -lboost_system-gcc-mt... no
checking for main in -lboost_system-mt... yes
checking for main in -lboost_date_time-gcc-mt... no
checking for main in -lboost_date_time-mt... yes
checking for main in -lboost_filesystem-gcc-mt... no
checking for main in -lboost_filesystem-mt... yes
checking boost/asio.hpp usability... yes
checking boost/asio.hpp presence... yes
checking for boost/asio.hpp... yes
checking boost/tr1/unordered_set.hpp usability... yes
checking boost/tr1/unordered_set.hpp presence... yes
checking for boost/tr1/unordered_set.hpp... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for LUA... yes
checking mysql/mysql.h usability... yes
checking mysql/mysql.h presence... yes
checking for mysql/mysql.h... yes
checking for main in -lmysqlclient... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
theforgottenserver 0.3.5
Server diagnostics.......... : yes
Login server mode........... : no
Remote control.............. : yes
Root run permission......... : no
Home-directory configuration : no
OTServ custom allocator..... : no
Debug build................. : no
Build with MySQL............ : yes
Build with SQLite........... : no
Build with PostgreSQL....... : no
Build with ODBC............. : no
Configure complete, now you may type 'make'.
Wzorowałem się na tym poradniku z Otland.net, [HTML]http://otland.net/threads/linux-ultimat ... uded.2868/[/HTML]
Mógłby ktoś mi wytłumaczyć co muszę doinstalować albo zmienić ??
Nic Ci nie wywala:
Paolo pisze:
[B]Configure complete[/B], now you may [B]type 'make'[/B].
Paolo
Post autor: Paolo »
Rafal_F pisze:Nic Ci nie wywala:
Wszędzie gdzie piszę "NO" to już jest błąd i nie wykonam kompilacji.
Skoro konfiguracja zakończyła się powodzeniem, to znaczy że wszystkie wymagane biblioteki są zainstalowane i kompilacja powinna się powieść. Jeżeli z kompilacją jest coś nie tak, to wklej listing z kompilacji.
./configure --help
i przejrzyj wtedy
