W logach (syslog) pojawia się coś takiego:
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820033] ------------[ cut here ]------------Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820051] WARNING: at /build/linux-FpPMO6/linux-3.2.54/net/sched/sch_generic.c:256 dev_watchdog+0xf2/0x151()
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820058] Hardware name: System Product Name
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820064] NETDEV WATCHDOG: eth0 (via-rhine): transmit queue 0 timed out
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820068] Modules linked in: ppdev lp binfmt_misc loop usblp i2c_viapro i2c_core psmouse evdev powernow_k8 pcspkr mperf serio_raw k8temp edac_mce_amd edac_core shpchp parport_pc asus_atk0110 parport processor button thermal_sys ext4 crc16 jbd2 mbcache sg sr_mod sd_mod crc_t10dif cdrom ata_generic pata_via sata_via libata uhci_hcd ehci_hcd via_rhine mii usbcore scsi_mod usb_common [last unloaded: scsi_wait_scan]
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820132] Pid: 0, comm: swapper/0 Not tainted 3.2.0-4-amd64 #1 Debian 3.2.54-2
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820137] Call Trace:
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820142] <IRQ> [<ffffffff81046cb5>] ? warn_slowpath_common+0x78/0x8c
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820159] [<ffffffff81046d61>] ? warn_slowpath_fmt+0x45/0x4a
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820168] [<ffffffff812a762d>] ? netif_tx_lock+0x40/0x75
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820179] [<ffffffff812a779d>] ? dev_watchdog+0xf2/0x151
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820187] [<ffffffff810524d0>] ? run_timer_softirq+0x19a/0x261
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820196] [<ffffffff8106b84d>] ? tick_handle_oneshot_broadcast+0xbc/0xfa
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820204] [<ffffffff812a76ab>] ? netif_tx_unlock+0x49/0x49
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820213] [<ffffffff8104c346>] ? __do_softirq+0xb9/0x177
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820221] [<ffffffff81356fec>] ? call_softirq+0x1c/0x30
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820231] [<ffffffff8100f8c5>] ? do_softirq+0x3c/0x7b
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820238] [<ffffffff8104c5ae>] ? irq_exit+0x3c/0x99
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820245] [<ffffffff8100f5f5>] ? do_IRQ+0x82/0x98
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820254] [<ffffffff8135006e>] ? common_interrupt+0x6e/0x6e
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820258] <EOI> [<ffffffffa00a2398>] ? arch_local_irq_enable+0x4/0x8 [processor]
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820281] [<ffffffffa00a302a>] ? acpi_idle_enter_simple+0xc6/0x102 [processor]
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820292] [<ffffffff8127050d>] ? cpuidle_idle_call+0xec/0x179
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820300] [<ffffffff8100d242>] ? cpu_idle+0xa5/0xf2
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820309] [<ffffffff816abb36>] ? start_kernel+0x3b8/0x3c3
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820317] [<ffffffff816ab140>] ? early_idt_handlers+0x140/0x140
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820325] [<ffffffff816ab3c4>] ? x86_64_start_kernel+0x104/0x111
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820331] ---[ end trace efb76e0a5b0b8a6e ]---
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820484] via-rhine 0000:00:12.0: eth0: Transmit timed out, status 1003, PHY status 786d, resetting...
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.820604] via-rhine 0000:00:12.0: eth0: Reset not complete yet. Trying harder.
Apr 20 15:21:41 SerwerDomowy kernel: [ 3274.821244] via-rhine 0000:00:12.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1Kod: Zaznacz cały
Apr 20 15:22:35 SerwerDomowy kernel: [ 3328.820182] via-rhine 0000:00:12.0: eth0: Transmit timed out, status 0003, PHY status 786d, resetting...
Apr 20 15:22:35 SerwerDomowy kernel: [ 3328.820299] via-rhine 0000:00:12.0: eth0: Reset not complete yet. Trying harder.
Apr 20 15:22:35 SerwerDomowy kernel: [ 3328.820892] via-rhine 0000:00:12.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1Apr 20 15:23:23 SerwerDomowy kernel: [ 3376.820169] via-rhine 0000:00:12.0: eth0: Transmit timed out, status 0003, PHY status 786d, resetting...
Apr 20 15:23:23 SerwerDomowy kernel: [ 3376.820873] via-rhine 0000:00:12.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Apr 20 15:23:35 SerwerDomowy kernel: [ 3388.820180] via-rhine 0000:00:12.0: eth0: Transmit timed out, status 0003, PHY status 786d, resetting...
Apr 20 15:23:35 SerwerDomowy kernel: [ 3388.820887] via-rhine 0000:00:12.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1Pliki są przesyłane po WebDAV w OwnCloud. "Chmurę" zainstalowałem na Apache2.
