Po instalacji sterowników nVidia system uruchamia si
spindelnspi
Po instalacji sterowników nVidia system uruchamia się w trybie tekstowym.
Post autor: spindelnspi »
System: elementaryOS 0.2 Luna 64bit (bazuje na Ubuntu+Debian)
Kernel: 3.2
Karta graficzna: ASUS GTS 450 1GB DirectCU
Werjsa sterownika: 304, instalowany przez ten program wbudowany w system
[    30.439]
X.Org X Server 1.11.3
Release Date: 2011-12-16
[    30.439] X Protocol Version 11, Revision 0
[    30.439] Build Operating System: Linux 2.6.42-37-generic x86_64 Ubuntu
[    30.439] Current Operating System: Linux RAMROD 3.2.0-51-generic #77-Ubuntu SMP Wed Jul 24 20:18:19 UTC 2013 x86_64
[     30.439] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-51-generic  root=UUID=010e751d-6572-4ce5-a10c-47c479f34f43 ro recovery nomodeset
[    30.439] Build Date: 11 April 2013  01:05:39PM
[    30.439] xorg-server 2:1.11.4-0ubuntu10.13 (For technical support please see http://www.ubuntu.com/support)
[    30.439] Current version of pixman: 0.24.4
[    30.439]     Before reporting problems, check http://wiki.x.org
[    30.439] Markers: (--) probed, (**) from config file, (==) default setting,
[    30.439] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Apr  2 17:47:12 2014
[    30.446] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    30.448] (==) No Layout section.  Using the first Screen section.
[    30.448] (==) No screen section available. Using defaults.
[    30.448] (**) |-->Screen "Default Screen Section" (0)
[    30.448] (**) |   |-->Monitor "<default monitor>"
[    30.448] (==) No monitor specified for screen "Default Screen Section".
    Using a default monitor configuration.
[    30.448] (==) Automatically adding devices
[    30.448] (==) Automatically enabling devices
[    30.448] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    30.448]     Entry deleted from font path.
[    30.448] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    30.448] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    30.449] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    30.449]     Entry deleted from font path.
[    30.449] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    30.458] (WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType".
[    30.458]     Entry deleted from font path.
[    30.458]     (Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType").
[    30.458] (==) FontPath set to:
    /usr/share/fonts/X11/misc,
    /usr/share/fonts/X11/Type1,
    built-ins
[     30.458] (==) ModulePath set to  "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    30.458] (II) The server relies on udev to provide the list of input devices.
[    30.458] (II) Loader magic: 0x7faaeb9cbb00
[    30.458] (II) Module ABI versions:
[    30.458]     X.Org ANSI C Emulation: 0.4
[    30.458]     X.Org Video Driver: 11.0
[    30.458]     X.Org XInput driver : 16.0
[    30.458]     X.Org Server Extension : 6.0
[     30.459] (--) PCI:*(0:1:0:0) 10de:0dc4:1043:8365 rev 161, Mem @  0xfc000000/16777216, 0xd0000000/134217728, 0xd8000000/33554432, I/O @  0x0000e000/128, BIOS @ 0x????????/524288
[    30.459] (II) Open ACPI successful (/var/run/acpid.socket)
[    30.459] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[    30.459] (II) "extmod" will be loaded by default.
[    30.459] (II) "dbe" will be loaded by default.
[    30.459] (II) "glx" will be loaded by default.
[    30.459] (II) "record" will be loaded by default.
[    30.459] (II) "dri" will be loaded by default.
[    30.459] (II) "dri2" will be loaded by default.
[    30.459] (II) LoadModule: "extmod"
[    30.467] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[    30.467] (II) Module extmod: vendor="X.Org Foundation"
[    30.467]     compiled for 1.11.3, module version = 1.0.0
[    30.467]     Module class: X.Org Server Extension
[    30.467]     ABI class: X.Org Server Extension, version 6.0
[    30.467] (II) Loading extension MIT-SCREEN-SAVER
[    30.467] (II) Loading extension XFree86-VidModeExtension
[    30.467] (II) Loading extension XFree86-DGA
[    30.467] (II) Loading extension DPMS
[    30.467] (II) Loading extension XVideo
[    30.467] (II) Loading extension XVideo-MotionCompensation
[    30.467] (II) Loading extension X-Resource
[    30.467] (II) LoadModule: "dbe"
[    30.467] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[    30.467] (II) Module dbe: vendor="X.Org Foundation"
[    30.467] (II) Loading extension DOUBLE-BUFFER
[    30.467] (II) LoadModule: "glx"
[    30.467] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[    30.634] (II) Module glx: vendor="NVIDIA Corporation"
[    30.634]     compiled for 4.0.2, module version = 1.0.0
[    30.634]     Module class: X.Org Server Extension
[    30.634] (II) NVIDIA GLX Module  304.116  Mon Oct 28 20:59:08 PDT 2013
[    30.634] (II) Loading extension GLX
[    30.634] (II) LoadModule: "record"
[    30.634] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[    30.634] (II) Module record: vendor="X.Org Foundation"
[    30.634]     compiled for 1.11.3, module version = 1.13.0
[    30.634]     ABI class: X.Org Server Extension, version 6.0
[    30.635] (II) Loading extension RECORD
[    30.635] (II) LoadModule: "dri"
[    30.635] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[    30.635] (II) Module dri: vendor="X.Org Foundation"
[    30.635]     compiled for 1.11.3, module version = 1.0.0
[    30.635]     ABI class: X.Org Server Extension, version 6.0
[    30.635] (II) Loading extension XFree86-DRI
[    30.635] (II) LoadModule: "dri2"
[    30.635] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[    30.635] (II) Module dri2: vendor="X.Org Foundation"
[    30.635]     compiled for 1.11.3, module version = 1.2.0
[    30.635] (II) Loading extension DRI2
[    30.635] (==) Matched nvidia as autoconfigured driver 0
[    30.635] (==) Matched nouveau as autoconfigured driver 1
[    30.635] (==) Matched nv as autoconfigured driver 2
[    30.635] (==) Matched vesa as autoconfigured driver 3
[    30.635] (==) Matched fbdev as autoconfigured driver 4
[    30.635] (==) Assigned the driver to the xf86ConfigLayout
[    30.635] (II) LoadModule: "nvidia"
[    30.635] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[    30.649] (II) Module nvidia: vendor="NVIDIA Corporation"
[    30.649]     compiled for 4.0.2, module version = 1.0.0
[    30.649]     Module class: X.Org Video Driver
[    30.654] (II) LoadModule: "nouveau"
[    30.654] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    30.654] (II) Module nouveau: vendor="X.Org Foundation"
[    30.654]     compiled for 1.11.3, module version = 0.0.16
[    30.654]     Module class: X.Org Video Driver
[    30.654]     ABI class: X.Org Video Driver, version 11.0
[    30.654] (II) LoadModule: "nv"
[    30.655] (WW) Warning, couldn't open module nv
[    30.655] (II) UnloadModule: "nv"
[    30.655] (II) Unloading nv
[    30.655] (EE) Failed to load module "nv" (module does not exist, 0)
[    30.655] (II) LoadModule: "vesa"
[    30.655] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    30.655] (II) Module vesa: vendor="X.Org Foundation"
[    30.655]     compiled for 1.11.3, module version = 2.3.0
[    30.655]     Module class: X.Org Video Driver
[    30.655]     ABI class: X.Org Video Driver, version 11.0
[    30.655] (II) LoadModule: "fbdev"
[    30.655] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    30.655] (II) Module fbdev: vendor="X.Org Foundation"
[    30.655]     compiled for 1.11.3, module version = 0.4.2
[    30.655] (==) Matched nvidia as autoconfigured driver 0
[    30.655] (==) Matched nouveau as autoconfigured driver 1
[    30.655] (==) Matched nv as autoconfigured driver 2
[    30.655] (==) Matched vesa as autoconfigured driver 3
[    30.655] (==) Matched fbdev as autoconfigured driver 4
[    30.655] (==) Assigned the driver to the xf86ConfigLayout
[    30.655] (II) LoadModule: "nvidia"
[    30.655] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[    30.655] (II) Module nvidia: vendor="NVIDIA Corporation"
[    30.655]     compiled for 4.0.2, module version = 1.0.0
[    30.655] (II) UnloadModule: "nvidia"
[    30.655] (II) Unloading nvidia
[    30.655] (II) Failed to load module "nvidia" (already loaded, 32682)
[    30.655] (II) LoadModule: "nouveau"
[    30.655] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    30.655] (II) Module nouveau: vendor="X.Org Foundation"
[    30.655]     compiled for 1.11.3, module version = 0.0.16
[    30.655] (II) UnloadModule: "nouveau"
[    30.655] (II) Unloading nouveau
[    30.655] (II) Failed to load module "nouveau" (already loaded, 32682)
[    30.655] (II) LoadModule: "nv"
[    30.656] (WW) Warning, couldn't open module nv
[    30.656] (II) UnloadModule: "nv"
[    30.656] (II) Unloading nv
[    30.656] (EE) Failed to load module "nv" (module does not exist, 0)
[    30.656] (II) LoadModule: "vesa"
[    30.656] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    30.656] (II) Module vesa: vendor="X.Org Foundation"
[    30.656]     compiled for 1.11.3, module version = 2.3.0
[    30.656]     Module class: X.Org Video Driver
[    30.656]     ABI class: X.Org Video Driver, version 11.0
[    30.656] (II) UnloadModule: "vesa"
[    30.656] (II) Unloading vesa
[    30.656] (II) Failed to load module "vesa" (already loaded, 0)
[    30.656] (II) LoadModule: "fbdev"
[    30.656] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    30.656] (II) Module fbdev: vendor="X.Org Foundation"
[    30.656]     compiled for 1.11.3, module version = 0.4.2
[    30.656] (II) UnloadModule: "fbdev"
[    30.656] (II) Unloading fbdev
[    30.656] (II) Failed to load module "fbdev" (already loaded, 0)
[    30.656] (II) NVIDIA dlloader X Driver  304.116  Mon Oct 28 20:40:38 PDT 2013
[    30.656] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    30.657] (II) NOUVEAU driver Date:   Wed Nov 30 18:56:54 2011 +0100
[    30.657] (II) NOUVEAU driver for NVIDIA chipset families :
[    30.657]     RIVA TNT        (NV04)
[    30.657]     RIVA TNT2       (NV05)
[    30.657]     GeForce 256     (NV10)
[    30.657]     GeForce 2       (NV11, NV15)
[    30.657]     GeForce 4MX     (NV17, NV18)
[    30.657]     GeForce 3       (NV20)
[    30.657]     GeForce 4Ti     (NV25, NV28)
[    30.657]     GeForce FX      (NV3x)
[    30.657]     GeForce 6       (NV4x)
[    30.657]     GeForce 7       (G7x)
[    30.657]     GeForce 8       (G8x)
[    30.657]     GeForce GTX 200 (NVA0)
[    30.657]     GeForce GTX 400 (NVC0)
[    30.657] (II) VESA: driver for VESA chipsets: vesa
[    30.657] (II) FBDEV: driver for framebuffer: fbdev
[    30.657] (++) using VT number 7
[    30.659] (II) Loading sub module "fb"
[    30.659] (II) LoadModule: "fb"
[    30.659] (II) Loading /usr/lib/xorg/modules/libfb.so
[    30.660] (II) Module fb: vendor="X.Org Foundation"
[    30.660]     compiled for 1.11.3, module version = 1.0.0
[    30.660]     ABI class: X.Org ANSI C Emulation, version 0.4
[    30.660] (II) Loading sub module "wfb"
[    30.660] (II) LoadModule: "wfb"
[    30.660] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    30.663] (II) Module wfb: vendor="X.Org Foundation"
[    30.663]     compiled for 1.11.3, module version = 1.0.0
[    30.663]     ABI class: X.Org ANSI C Emulation, version 0.4
[    30.663] (II) Loading sub module "ramdac"
[    30.663] (II) LoadModule: "ramdac"
[    30.663] (II) Module "ramdac" already built-in
[    30.666] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[    30.666] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    30.666] (II) Loading /usr/lib/xorg/modules/libfb.so
[    30.668] (WW) Falling back to old probe method for vesa
[    30.668] (WW) Falling back to old probe method for fbdev
[    30.668] (II) Loading sub module "fbdevhw"
[    30.668] (II) LoadModule: "fbdevhw"
[    30.669] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    30.669] (II) Module fbdevhw: vendor="X.Org Foundation"
[    30.669]     compiled for 1.11.3, module version = 0.0.2
[    30.669]     ABI class: X.Org Video Driver, version 11.0
[    30.669] (EE) open /dev/fb0: No such file or directory
[    30.669] (II) NVIDIA(0): Creating default Display subsection in Screen section
    "Default Screen Section" for depth/fbbpp 24/32
[    30.669] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    30.669] (==) NVIDIA(0): RGB weight 888
[    30.669] (==) NVIDIA(0): Default visual is TrueColor
[    30.669] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    30.669] (**) NVIDIA(0): Enabling 2D acceleration
[    31.487] (II) NVIDIA(GPU-0): Display (LG Electronics 19LS4R (CRT-1)) does not support
[    31.487] (II) NVIDIA(GPU-0):     NVIDIA 3D Vision stereo.
[    31.489] (II) NVIDIA(0): NVIDIA GPU GeForce GTS 450 (GF106) at PCI:1:0:0 (GPU-0)
[    31.489] (--) NVIDIA(0): Memory: 1048576 kBytes
[    31.489] (--) NVIDIA(0): VideoBIOS: 70.06.13.00.00
[    31.489] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    31.489] (--) NVIDIA(0): Interlaced video modes are supported on this GPU
[    31.496] (--) NVIDIA(0): Valid display device(s) on GeForce GTS 450 at PCI:1:0:0
[    31.496] (--) NVIDIA(0):     CRT-0
[    31.496] (--) NVIDIA(0):     LG Electronics 19LS4R (CRT-1) (connected)
[    31.496] (--) NVIDIA(0):     DFP-0
[    31.496] (--) NVIDIA(0):     DFP-1
[    31.496] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[    31.496] (--) NVIDIA(0): LG Electronics 19LS4R (CRT-1): 400.0 MHz maximum pixel clock
[    31.496] (--) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[    31.496] (--) NVIDIA(0): DFP-0: Internal Single Link TMDS
[    31.496] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[    31.496] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
[    31.496] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    31.496] (**) NVIDIA(0):     device LG Electronics 19LS4R (CRT-1) (Using EDID
[    31.496] (**) NVIDIA(0):     frequencies has been enabled on all display devices.)
[    31.496] (==) NVIDIA(0):
[    31.496] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    31.496] (==) NVIDIA(0):     will be used as the requested mode.
[    31.496] (II) NVIDIA(0): Validated MetaModes:
[    31.496] (II) NVIDIA(0):     "CRT-1:nvidia-auto-select"
[    31.496] (II) NVIDIA(0): Virtual screen size determined to be 1440 x 900
[    31.518] (--) NVIDIA(0): DPI set to (89, 87); computed from "UseEdidDpi" X config
[    31.518] (--) NVIDIA(0):     option
[    31.518] (II) UnloadModule: "nouveau"
[    31.518] (II) Unloading nouveau
[    31.518] (II) UnloadModule: "vesa"
[    31.518] (II) Unloading vesa
[    31.518] (II) UnloadModule: "fbdev"
[    31.518] (II) Unloading fbdev
[    31.518] (II) UnloadModule: "fbdevhw"
[    31.518] (II) Unloading fbdevhw
[    31.518] (--) Depth 24 pixmap format is 32 bpp
[    31.518] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[    31.518] (II) NVIDIA:     access.
[    31.521] (II) NVIDIA(0): Setting mode "CRT-1:nvidia-auto-select"
[    31.558] (II) Loading extension NV-GLX
[    31.618] (==) NVIDIA(0): Disabling shared memory pixmaps
[    31.618] (==) NVIDIA(0): Backing store disabled
[    31.618] (==) NVIDIA(0): Silken mouse enabled
[    31.619] (==) NVIDIA(0): DPMS enabled
[    31.619] (II) Loading extension NV-CONTROL
[    31.619] (II) Loading extension XINERAMA
[    31.619] (II) Loading sub module "dri2"
[    31.619] (II) LoadModule: "dri2"
[    31.619] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[    31.619] (II) Module dri2: vendor="X.Org Foundation"
[    31.619]     compiled for 1.11.3, module version = 1.2.0
[    31.619]     ABI class: X.Org Server Extension, version 6.0
[    31.619] (II) NVIDIA(0): [DRI2] Setup complete
[    31.619] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    31.619] (--) RandR disabled
[    31.619] (II) Initializing built-in extension Generic Event Extension
[    31.619] (II) Initializing built-in extension SHAPE
[    31.619] (II) Initializing built-in extension MIT-SHM
[    31.619] (II) Initializing built-in extension XInputExtension
[    31.619] (II) Initializing built-in extension XTEST
[    31.619] (II) Initializing built-in extension BIG-REQUESTS
[    31.619] (II) Initializing built-in extension SYNC
[    31.619] (II) Initializing built-in extension XKEYBOARD
[    31.619] (II) Initializing built-in extension XC-MISC
[    31.619] (II) Initializing built-in extension SECURITY
[    31.619] (II) Initializing built-in extension XINERAMA
[    31.619] (II) Initializing built-in extension XFIXES
[    31.619] (II) Initializing built-in extension RENDER
[    31.619] (II) Initializing built-in extension RANDR
[    31.619] (II) Initializing built-in extension COMPOSITE
[    31.619] (II) Initializing built-in extension DAMAGE
[    31.621] (II) Initializing extension GLX
[    31.667] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[    31.669] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    31.669] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    31.669] (II) LoadModule: "evdev"
[    31.670] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    31.670] (II) Module evdev: vendor="X.Org Foundation"
[    31.670]     compiled for 1.11.3, module version = 2.7.0
[    31.670]     Module class: X.Org XInput Driver
[    31.670]     ABI class: X.Org XInput driver, version 16.0
[    31.670] (II) Using input driver 'evdev' for 'Power Button'
[    31.670] (**) Power Button: always reports core events
[    31.670] (**) evdev: Power Button: Device: "/dev/input/event1"
[    31.670] (--) evdev: Power Button: Vendor 0 Product 0x1
[    31.670] (--) evdev: Power Button: Found keys
[    31.670] (II) evdev: Power Button: Configuring as keyboard
[    31.670] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[    31.670] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    31.670] (**) Option "xkb_rules" "evdev"
[    31.670] (**) Option "xkb_model" "pc105"
[    31.670] (**) Option "xkb_layout" "pl"
[    31.671] (II) XKB: reuse xkmfile /var/lib/xkb/server-61818C6B46DD4F01AE1F641F27B555591612208F.xkm
[    31.672] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    31.672] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    31.672] (II) Using input driver 'evdev' for 'Power Button'
[    31.672] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    31.672] (**) Power Button: always reports core events
[    31.672] (**) evdev: Power Button: Device: "/dev/input/event0"
[    31.672] (--) evdev: Power Button: Vendor 0 Product 0x1
[    31.672] (--) evdev: Power Button: Found keys
[    31.672] (II) evdev: Power Button: Configuring as keyboard
[    31.672] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[    31.672] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    31.672] (**) Option "xkb_rules" "evdev"
[    31.672] (**) Option "xkb_model" "pc105"
[    31.672] (**) Option "xkb_layout" "pl"
[    31.672] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event12)
[    31.672] (II) No input driver specified, ignoring this device.
[    31.672] (II) This device may have been added with another device file.
[    31.672] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event13)
[    31.673] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event14)
[    31.673] (II) No input driver specified, ignoring this device.
[    31.673] (II) This device may have been added with another device file.
[    31.673] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event15)
[    31.673] (II) config/udev: Adding input device Webcam C170 (/dev/input/event5)
[    31.673] (**) Webcam C170: Applying InputClass "evdev keyboard catchall"
[    31.673] (II) Using input driver 'evdev' for 'Webcam C170'
[    31.673] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    31.673] (**) Webcam C170: always reports core events
[    31.673] (**) evdev: Webcam C170: Device: "/dev/input/event5"
[    31.673] (--) evdev: Webcam C170: Vendor 0x46d Product 0x82b
[    31.673] (--) evdev: Webcam C170: Found keys
[    31.673] (II) evdev: Webcam C170: Configuring as keyboard
[    31.673] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:10.0/usb6/6-2/6-2:1.0/input/input5/event5"
[    31.673] (II) XINPUT: Adding extended input device "Webcam C170" (type: KEYBOARD, id 8)
[    31.673] (**) Option "xkb_rules" "evdev"
[    31.673] (**) Option "xkb_model" "pc105"
[    31.673] (**) Option "xkb_layout" "pl"
[    31.673] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event2)
[    31.673] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[    31.673] (II) Using input driver 'evdev' for 'Logitech USB Receiver'
[    31.674] (**) Logitech USB Receiver: always reports core events
[    31.674] (**) evdev: Logitech USB Receiver: Device: "/dev/input/event2"
[    31.674] (--) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc52e
[    31.674] (--) evdev: Logitech USB Receiver: Found keys
[    31.674] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[    31.674] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-5/3-5:1.0/input/input2/event2"
[    31.674] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 9)
[    31.674] (**) Option "xkb_rules" "evdev"
[    31.674] (**) Option "xkb_model" "pc105"
[    31.674] (**) Option "xkb_layout" "pl"
[    31.674] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event3)
[    31.674] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[    31.674] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[    31.674] (II) Using input driver 'evdev' for 'Logitech USB Receiver'
[    31.674] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    31.674] (**) evdev: Logitech USB Receiver: Device: "/dev/input/event3"
[    31.674] (--) evdev: Logitech USB Receiver: Found 20 mouse buttons
[    31.674] (--) evdev: Logitech USB Receiver: Found scroll wheel(s)
[    31.674] (--) evdev: Logitech USB Receiver: Found relative axes
[    31.674] (--) evdev: Logitech USB Receiver: Found x and y relative axes
[    31.674] (--) evdev: Logitech USB Receiver: Found absolute axes
[    31.674] (II) evdev: Logitech USB Receiver: Forcing absolute x/y axes to exist.
[    31.674] (II) evdev: Logitech USB Receiver: Configuring as mouse
[    31.674] (II) evdev: Logitech USB Receiver: Adding scrollwheel support
[    31.674] (**) evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[    31.674] (**) evdev: Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    31.674] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-5/3-5:1.1/input/input3/event3"
[    31.674] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 10)
[    31.674] (II) evdev: Logitech USB Receiver: initialized for relative axes.
[    31.674] (WW) evdev: Logitech USB Receiver: ignoring absolute axes.
[    31.675] (**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
[    31.675] (**) Logitech USB Receiver: (accel) acceleration profile 0
[    31.675] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[    31.675] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[    31.675] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[    31.675] (II) No input driver specified, ignoring this device.
[    31.675] (II) This device may have been added with another device file.
[    31.675] (II) config/udev: Adding input device ROCCAT ROCCAT Kova[+] (/dev/input/event4)
[    31.675] (**) ROCCAT ROCCAT Kova[+]: Applying InputClass "evdev pointer catchall"
[    31.675] (**) ROCCAT ROCCAT Kova[+]: Applying InputClass "evdev keyboard catchall"
[    31.675] (II) Using input driver 'evdev' for 'ROCCAT ROCCAT Kova[+]'
[    31.675] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    31.675] (**) ROCCAT ROCCAT Kova[+]: always reports core events
[    31.675] (**) evdev: ROCCAT ROCCAT Kova[+]: Device: "/dev/input/event4"
[    31.675] (--) evdev: ROCCAT ROCCAT Kova[+]: Vendor 0x1e7d Product 0x2d50
[    31.675] (--) evdev: ROCCAT ROCCAT Kova[+]: Found 9 mouse buttons
[    31.675] (--) evdev: ROCCAT ROCCAT Kova[+]: Found scroll wheel(s)
[    31.675] (--) evdev: ROCCAT ROCCAT Kova[+]: Found relative axes
[    31.675] (--) evdev: ROCCAT ROCCAT Kova[+]: Found x and y relative axes
[    31.675] (--) evdev: ROCCAT ROCCAT Kova[+]: Found absolute axes
[    31.675] (II) evdev: ROCCAT ROCCAT Kova[+]: Forcing absolute x/y axes to exist.
[    31.675] (--) evdev: ROCCAT ROCCAT Kova[+]: Found keys
[    31.675] (II) evdev: ROCCAT ROCCAT Kova[+]: Configuring as mouse
[    31.675] (II) evdev: ROCCAT ROCCAT Kova[+]: Configuring as keyboard
[    31.675] (II) evdev: ROCCAT ROCCAT Kova[+]: Adding scrollwheel support
[    31.675] (**) evdev: ROCCAT ROCCAT Kova[+]: YAxisMapping: buttons 4 and 5
[    31.675] (**) evdev: ROCCAT ROCCAT Kova[+]: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    31.675] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:13.0/usb4/4-5/4-5:1.0/input/input4/event4"
[    31.675] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kova[+]" (type: KEYBOARD, id 11)
[    31.675] (**) Option "xkb_rules" "evdev"
[    31.675] (**) Option "xkb_model" "pc105"
[    31.675] (**) Option "xkb_layout" "pl"
[    31.675] (II) evdev: ROCCAT ROCCAT Kova[+]: initialized for relative axes.
[    31.675] (WW) evdev: ROCCAT ROCCAT Kova[+]: ignoring absolute axes.
[    31.675] (**) ROCCAT ROCCAT Kova[+]: (accel) keeping acceleration scheme 1
[    31.675] (**) ROCCAT ROCCAT Kova[+]: (accel) acceleration profile 0
[    31.675] (**) ROCCAT ROCCAT Kova[+]: (accel) acceleration factor: 2.000
[    31.675] (**) ROCCAT ROCCAT Kova[+]: (accel) acceleration threshold: 4
[    31.676] (II) config/udev: Adding input device ROCCAT ROCCAT Kova[+] (/dev/input/mouse1)
[    31.676] (II) No input driver specified, ignoring this device.
[    31.676] (II) This device may have been added with another device file.
[    31.676] (II) config/udev: Adding input device ROCCAT ROCCAT Kova[+] (/dev/input/event11)
[    31.676] (**) ROCCAT ROCCAT Kova[+]: Applying InputClass "evdev keyboard catchall"
[    31.676] (II) Using input driver 'evdev' for 'ROCCAT ROCCAT Kova[+]'
[    31.676] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    31.676] (**) ROCCAT ROCCAT Kova[+]: always reports core events
[    31.676] (**) evdev: ROCCAT ROCCAT Kova[+]: Device: "/dev/input/event11"
[    31.676] (--) evdev: ROCCAT ROCCAT Kova[+]: Vendor 0x1e7d Product 0x2d50
[    31.676] (--) evdev: ROCCAT ROCCAT Kova[+]: Found keys
[    31.676] (II) evdev: ROCCAT ROCCAT Kova[+]: Configuring as keyboard
[    31.676] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:13.0/usb4/4-5/4-5:1.1/input/input11/event11"
[    31.676] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kova[+]" (type: KEYBOARD, id 12)
[    31.676] (**) Option "xkb_rules" "evdev"
[    31.676] (**) Option "xkb_model" "pc105"
[    31.676] (**) Option "xkb_layout" "pl"
[    31.676] (II) config/udev: Adding input device HD-Audio Generic Line-Out (/dev/input/event10)
[    31.677] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event6)
[    31.677] (II) No input driver specified, ignoring this device.
[    31.677] (II) This device may have been added with another device file.
[    31.677] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event7)
[    31.677] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event8)
[    31.677] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event9)
[    32.172] (II) NVIDIA(GPU-0): Display (LG Electronics 19LS4R (CRT-1)) does not support
[    32.172] (II) NVIDIA(GPU-0):     NVIDIA 3D Vision stereo.
[    32.172] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    32.172] (**) NVIDIA(0):     device LG Electronics 19LS4R (CRT-1) (Using EDID
[    32.172] (**) NVIDIA(0):     frequencies has been enabled on all display devices.)
[    34.991] (II) NVIDIA(GPU-0): Display (LG Electronics 19LS4R (CRT-1)) does not support
[    34.991] (II) NVIDIA(GPU-0):     NVIDIA 3D Vision stereo.
[    34.991] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    34.991] (**) NVIDIA(0):     device LG Electronics 19LS4R (CRT-1) (Using EDID
[    34.991] (**) NVIDIA(0):     frequencies has been enabled on all display devices.)
[    40.733] (II) XKB: reuse xkmfile /var/lib/xkb/server-A08FD83AD8727839541EF8306FA3BE9378B423D0.xkm
[    40.845] (II) NVIDIA(GPU-0): Display (LG Electronics 19LS4R (CRT-1)) does not support
[    40.845] (II) NVIDIA(GPU-0):     NVIDIA 3D Vision stereo.
[    40.845] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    40.845] (**) NVIDIA(0):     device LG Electronics 19LS4R (CRT-1) (Using EDID
[    40.845] (**) NVIDIA(0):     frequencies has been enabled on all display devices.)
[    41.097] (II) NVIDIA(GPU-0): Display (LG Electronics 19LS4R (CRT-1)) does not support
[    41.097] (II) NVIDIA(GPU-0):     NVIDIA 3D Vision stereo.
[    41.097] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    41.097] (**) NVIDIA(0):     device LG Electronics 19LS4R (CRT-1) (Using EDID
[    41.097] (**) NVIDIA(0):     frequencies has been enabled on all display devices.)
[    41.357] (II) XKB: reuse xkmfile /var/lib/xkb/server-A08FD83AD8727839541EF8306FA3BE9378B423D0.xkm
[    62.298] (II) NVIDIA(GPU-0): Display (LG Electronics 19LS4R (DFP-0)) does not support
[    62.298] (II) NVIDIA(GPU-0):     NVIDIA 3D Vision stereo.
[    62.298] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    62.298] (**) NVIDIA(0):     device LG Electronics 19LS4R (DFP-0) (Using EDID
[    62.298] (**) NVIDIA(0):     frequencies has been enabled on all display devices.)
[    62.298] (WW) NVIDIA(GPU-0): The EDID for LG Electronics 19LS4R (DFP-0) contradicts itself:
[    62.298] (WW) NVIDIA(GPU-0):     mode "1920x1080" is specified in the EDID; however, the
[    62.298] (WW) NVIDIA(GPU-0):     EDID's valid VertRefresh range (58.000-63.000 Hz) would
[    62.298] (WW) NVIDIA(GPU-0):     exclude this mode's VertRefresh (50.0 Hz); ignoring
[    62.298] (WW) NVIDIA(GPU-0):     VertRefresh check for mode "1920x1080".
[    62.298] (WW) NVIDIA(GPU-0):     mode "1280x720" is specified in the EDID; however, the
[    62.298] (WW) NVIDIA(GPU-0):     VertRefresh check for mode "1280x720".
[    62.299] (WW) NVIDIA(GPU-0): The EDID for LG Electronics 19LS4R (DFP-0) contradicts itself:
[    62.299] (WW) NVIDIA(GPU-0):     mode "720x576" is specified in the EDID; however, the
[    62.299] (WW) NVIDIA(GPU-0):     EDID's valid VertRefresh range (58.000-63.000 Hz) would
[    62.299] (WW) NVIDIA(GPU-0):     exclude this mode's VertRefresh (50.0 Hz); ignoring
[    62.299] (WW) NVIDIA(GPU-0):     VertRefresh check for mode "720x576".
[    62.299] (WW) NVIDIA(GPU-0):     mode "720x480" is specified in the EDID; however, the
[    62.299] (WW) NVIDIA(GPU-0):     EDID's valid HorizSync range (28.000-83.000 kHz) would
[    62.299] (WW) NVIDIA(GPU-0):     exclude this mode's HorizSync (15.7 kHz); ignoring
[    62.299] (WW) NVIDIA(GPU-0):     HorizSync check for mode "720x480".
[    62.299] (WW) NVIDIA(GPU-0):     exclude this mode's HorizSync (15.6 kHz); ignoring
[    62.299] (WW) NVIDIA(GPU-0):     HorizSync check for mode "720x576".
[    62.299] (WW) NVIDIA(GPU-0):     mode "1920x1080" is specified in the EDID; however, the
[    62.299] (WW) NVIDIA(GPU-0):     VertRefresh check for mode "1920x1080".
[    62.299] (WW) NVIDIA(GPU-0):     mode "1280x720" is specified in the EDID; however, the
[    62.299] (WW) NVIDIA(GPU-0):     VertRefresh check for mode "1280x720".
[    62.472] (II) NVIDIA(0): Setting mode "DVI-I-1: nvidia-auto-select @1440x900 +0+0"
Po instalacji sterowników nVidia system uruchamia się w trybie tekstowym. Po zalogowaniu się i wydaniu komendy startx pojawia się okno z komunikatem Failed to load gnome. System uruchamia się w trybie ratunkowym normalnie i z akceleracją 3D.
Chyba musisz jakiś z poniższych pakietów zainstalować i odpalić tylko 1x polecenie konfiguracyjne
[yampress@debian ~]$ aptitude search nvidia |grep configp nvidia-settings - tool for configuring the NVIDIA graphics d
p nvidia-settings-legacy-173xx - tool for configuring the NVIDIA graphics d
p nvidia-settings-legacy-304xx - tool for configuring the NVIDIA graphics d
p nvidia-settings-legacy-96xx - tool for configuring the NVIDIA graphics d
p nvidia-xconfig - X configuration tool for non-free NVIDIA d
Jaka to wersja gnome? I z jakiego menedżera logowania to korzysta?
Zobacz czy nie ma nic interesującego w logach:
~/.xsession-errors
~/.cache/gdm/session.log
spindelnspi
elementary OS @ Wikipedia: klik
elementary OS @ DistroWatch: klik
Pantheon Greeter: Session manager based on LightDM
gnome-shell (3.12.0)
edit: zaktualizowałem kernel do 3.11.10-03111001-generic i sterowniki do 331.20 i na 10 uruchomien za każdym razem startuje poprawnie.
Jeszcze pytanie o mysz. Czy na linuxie występuje akceleracja wsteczna w myszkach ? (Roccat KOVA) i jak zmienić ilość DPI w myszce ?
Myszka obsługuje zmianę DPI? Jeżeli tak, to zazwyczaj są na niej umieszczone mechaniczne przełączniki. Co do zmiany przyspieszenia to poszukaj w ustawieniach systemowych. Ostatecznie zawsze można użyć narzędzi xorg:
xset -q
Wypisze urządzenia, wraz z parametrami:
Pointer Control:
  acceleration:  2/1    threshold:  4
Ustawia się to tak:
xset m 2/1 4
W opcji acceleration można podać ułamki mniejsze od 1, np 1/100, ale u mnie nie wiele to zmienia (jest tak samo jakbym ustawił po prostu 1). Sprawdź sam.
