Konwersja filmu .webm do .avi/.mpeg
mike26
Post autor: mike26 »
Witam, nagrałem krótki film programem Cheese został on skonwertowany jako .webm chciałbym go jednak zapisać jako .avi lub .mpeg
Znalazłem program .ffmpeg jednak podczas konwersji wyskakuje błąd
[B]root@debian:/home/wojtek/Pobrane# ffmpeg -i 2014-04-01-094702.webm film.avi[/B]
WARNING: gnome-keyring:: couldn't connect to: /home/wojtek/.cache/keyring-k9h3aX/pkcs11: No such file or directory
ffmpeg version 1.0.8 Copyright (c) 2000-2013 the FFmpeg developers
  built on Sep 12 2013 11:57:09 with gcc 4.7 (Debian 4.7.2-5)
  configuration: --prefix=/usr --extra-cflags='-g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security ' --extra-ldflags='-Wl,-z,relro' --cc='ccache cc' --enable-shared --enable-libmp3lame --enable-gpl --enable-nonfree --enable-libvorbis --enable-pthreads --enable-libfaac --enable-libxvid --enable-postproc --enable-x11grab --enable-libgsm --enable-libtheora --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libx264 --enable-libspeex --enable-nonfree --disable-stripping --enable-libvpx --enable-libschroedinger --disable-encoder=libschroedinger --enable-version3 --enable-libopenjpeg --enable-librtmp --enable-avfilter --enable-libfreetype --enable-libvo-aacenc --disable-decoder=amrnb --enable-libvo-amrwbenc --enable-libaacplus --libdir=/usr/lib/x86_64-linux-gnu --disable-vda --enable-libbluray --enable-libcdio --enable-gnutls --enable-frei0r --enable-openssl --enable-libass --enable-libopus --enable-fontconfig --enable-libfdk-aac --enable-libdc1394 --disable-altivec --dis  libavutil      51. 73.101 / 51. 73.101
  libavcodec     54. 59.100 / 54. 59.100
  libavformat    54. 29.104 / 54. 29.104
  libavdevice    54.  2.101 / 54.  2.101
  libavfilter     3. 17.100 /  3. 17.100
  libswscale      2.  1.101 /  2.  1.101
  libswresample   0. 15.100 /  0. 15.100
  libpostproc    52.  0.100 / 52.  0.100
2014-04-01-094702.webm: Invalid data found when processing input
[B]root@debian:/home/wojtek/Pobrane# ffmpeg -i 2014-04-01-094702.webm film.mpeg[/B]
Szukałem programów ale są głównie dla Windowsa.
Strzał na ślepo - sprawdź czy masz zainstalowany pakiet libvpx1.
Co do innych programów:
http://www.webmproject.org/tools/
https://packages.debian.org/jessie/transmageddon - korzysta z gstreamer'a.
mike26
Mam zainstalowany pakiet libvpx1, program transmageddon przekodował film bez problemu. Mam jednak pytanie otóż w kilku miejscach chciałbym usunąć dźwięk czy można coś takiego zrobić? Czy zostaje jedynie opcja albo dźwięk jest albo go nie ma ?
Może spróbuj jakiś bardziej zaawansowany edytor wideo: http://www.ubuntu-pomoc.org/edytory-wideo-na-ubuntu/
Użyj mencodera
mencoder NAZWA-TWOJEGO-PLIKU -ovc xvid -xvidencopts bitrate=900 -oac mp3lame -srate 44100 -o film.avi -lameopts vbr=3
lub
mencoder NAZWA-TWOJEGO-PLIKU -oac mp3lame -lameopts preset=128 -ovc lavc -lavcopts vcodec=mpeg4:vbitrate=1200
-ofps 25 -of avi -o plik.avi
