sudo apt-get install apt-show-versionsKod: Zaznacz cały
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
apt-show-versions
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/34.9 kB of archives.
After this operation, 169 kB of additional disk space will be used.
Selecting previously unselected package apt-show-versions.
(Reading database ... 32517 files and directories currently installed.)
Unpacking apt-show-versions (from .../apt-show-versions_0.20_all.deb) ...
Processing triggers for man-db ...
Setting up apt-show-versions (0.20) ...
** initializing cache. This may take a while **
Error: No information about packages! (Maybe no deb entries?)
dpkg: error processing apt-show-versions (--configure):
subprocess installed post-installation script returned error exit status 255
Errors were encountered while processing:
apt-show-versions
apt-get -f install
