LibClamAV Error: Database Directory: /var/lib/clamav/ not locked
chown 2000:2001 /var/lib/clamav
chmod 755 /var/lib/clamav
freshclam
ClamAV update process started at Mon Jul 23 15:25:32 2007
WARNING: Your ClamAV installation is OUTDATED!
WARNING: Local version: 0.90.1 Recommended version: 0.91.1
DON'T PANIC! Read [url]http://www.clamav.net/support/faq[/url]
main.inc is up to date (version: 44, sigs: 133163, f-level: 20, builder: sven)
ERROR: chdir_inc: Can't create directory daily.inc
WARNING: Incremental update failed, trying to download daily.cvd
ERROR: getfile: Can't create new file ./clamav-fa3994ac441bc10f10902868a7643fad in /var/lib/clamav
Hint: The database directory must be writable for UID 109 or GID 114
ERROR: Can't download daily.cvd from db.local.clamav.net
chown 755 /var/lib/clamav
chmod -R +rwx /var/lib/clamav
freshclam
Zawsze to jakieś rozwiązanie. :mrgreen:Czy recznie ściągnąc bazy wirusów ?
