Jakie modu
MrDarkenRahl
Jakie moduły do modemu E353u-2
Post autor: MrDarkenRahl »
Jak w temacie - jakie moduły w jajku są potrzebne do E353u-2?
root@mele:/dev# lsusb -v
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0001 1.1 root hub
  bcdDevice            3.00
  iManufacturer           3 Linux 3.0.42 ohci_hcd
  iProduct                2 SW USB2.0 'Open' Host Controller (OHCI) Driver
  iSerial                 1 sw-ohci
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0002  1x 2 bytes
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0012
    No power switching (usb 1.0)
    No overcurrent protection
  bPwrOn2PwrGood        2 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0100 power
Device Status:     0x0003
  Self Powered
  Remote Wakeup Enabled
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.00
  iSerial                 1 sw-ohci
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
Bus 003 Device 002: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0bda Realtek Semiconductor Corp.
  idProduct          0x8179 RTL8188EUS 802.11n Wireless Network Adapter
  bcdDevice            0.00
  iManufacturer           1 Realtek
  iProduct                2 802.11n NIC
  iSerial                 3 00E04C0001
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x03  EP 3 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0002
  (Bus Powered)
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idProduct          0x0002 2.0 root hub
  bcdDevice            3.00
  iManufacturer           3 Linux 3.0.42 ehci_hcd
  iProduct                2 SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  iSerial                 1 sw-ehci
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x000a
    Per-port overcurrent protection
  bPwrOn2PwrGood       10 * 2 milli seconds
 Hub Port Status:
   Port 1: 0000.0503 highspeed power enable connect
  Self Powered
Bus 001 Device 004: ID 12d1:1506 Huawei Technologies Co., Ltd. Modem/Networkcard
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2 ?
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x12d1 Huawei Technologies Co., Ltd.
  idProduct          0x1506 Modem/Networkcard
  bcdDevice            0.00
  iManufacturer           4 Huawei Technologies
  iProduct                3 HUAWEI Mobile
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength          201
    bNumInterfaces          7
    iConfiguration          2 Huawei Configuration
    bmAttributes         0xc0
      Self Powered
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceSubClass      1
      bInterfaceProtocol      1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               5
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval              32
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval              32
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         1
      bInterfaceCount         2
      bFunctionClass          2 Communications
      bFunctionSubClass       0
      bFunctionProtocol       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      9
      iInterface              0
      ** UNRECOGNIZED:  05 24 00 10 01
      ** UNRECOGNIZED:  0d 24 0f 01 00 00 00 00 08 06 01 00 00
      ** UNRECOGNIZED:  05 24 06 01 02
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               5
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceProtocol      8
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval              32
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval              32
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceProtocol      3
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x85  EP 5 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval              32
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval              32
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x86  EP 6 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval              32
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x04  EP 4 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval              32
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x87  EP 7 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x05  EP 5 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        6
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x06  EP 6 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x88  EP 8 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         2 ?
  bMaxPacketSize0        64
Device Status:     0x0000
  (Bus Powered)
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x05e3 Genesys Logic, Inc.
  idProduct          0x0608 USB-2.0 4-Port HUB
  bcdDevice           77.64
  iManufacturer           0
  iProduct                1 USB2.0 Hub
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
  wHubCharacteristic 0x00e0
    Ganged power switching
    Ganged overcurrent protection
    TT think time 32 FS bits
    Port indicators
  bPwrOn2PwrGood       50 * 2 milli seconds
  bHubContrCurrent    100 milli Ampere
 Hub Port Status:
   Port 2: 0000.0100 power
   Port 3: 0000.0503 highspeed power enable connect
   Port 4: 0000.0100 power
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.00
  iSerial                 1 sw-ehci
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
root@mele:/dev# dmesg[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.0.42 (root@minibud2) (gcc version 4.7.2 (Debian 4.7.2-5) ) #5 PREEMPT Thu Apr 4 04:24:58 CEST 2013
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun4i
[    0.000000] Memory cut off:
[    0.000000]  MALI : 0x5c000000 - 0x5fffffff  (  64 MB)
[    0.000000] Ignoring unrecognised tag 0x00000000
[    0.000000] Memory Reserved:
[    0.000000]  SYS  : 0x43000000 - 0x4300ffff  (  64 kB)
[    0.000000]  VE   : 0x44000000 - 0x48ffffff  (  80 MB)
[    0.000000]  G2D  : 0x58000000 - 0x58ffffff  (  16 MB)
[    0.000000]  LCD  : 0x5a000000 - 0x5bffffff  (  32 MB)
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] BROM Ver: 1100 1100 1623
[    0.000000] On node 0 totalpages: 245760
[    0.000000] free_area_init_node: node 0, pgdat c0718b9c, node_mem_map c074f000
[    0.000000]   Normal zone: 1280 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 162560 pages, LIFO batch:31
[    0.000000]   HighMem zone: 640 pages used for memmap
[    0.000000]   HighMem zone: 81280 pages, LIFO batch:15
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 243840
[    0.000000] Kernel command line: root=/dev/nandb mem=960M rootwait console=ttyS0,115200
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 960MB = 960MB total
[    0.000000] Memory: 835896k/835896k available, 147144k reserved, 327680K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
[    0.000000]     vmalloc : 0xe8800000 - 0xf0000000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe8000000   ( 640 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .init : 0xc0008000 - 0xc0030000   ( 160 kB)
[    0.000000]       .text : 0xc0030000 - 0xc06db000   (6828 kB)
[    0.000000]       .data : 0xc06dc000 - 0xc0719540   ( 246 kB)
[    0.000000]        .bss : 0xc0719564 - 0xc074e0c0   ( 211 kB)
[    0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:96 nr_irqs:96 96
[    0.000000] timer0: Periodic Mode
[    0.000000] Console: colour dummy device 80x30
[    0.000000] Calibrating delay loop... 383.38 BogoMIPS (lpj=1916928)
[    0.050000] pid_max: default: 32768 minimum: 301
[    0.050000] Mount-cache hash table entries: 512
[    0.050000] Initializing cgroup subsys cpuacct
[    0.050000] Initializing cgroup subsys devices
[    0.050000] Initializing cgroup subsys freezer
[    0.050000] Initializing cgroup subsys blkio
[    0.050000] CPU: Testing write buffer coherency: ok
[    0.050000] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[    0.050000] devtmpfs: initialized
[    0.050000] print_constraints: dummy:
[    0.050000] NET: Registered protocol family 16
[    0.050000] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.050000] [ccmu] try to set apb1 parent to sata_pll failed!
[    0.050000] SOFTWINNER DMA Driver, (c) 2003-2004,2006 Simtec Electronics
[    0.050000] Initialize DMAC OK
[    0.050000] bio: create slab <bio-0> at 0
[    0.050000] SCSI subsystem initialized
[    0.050000] libata version 3.00 loaded.
[    0.050000] usbcore: registered new interface driver usbfs
[    0.050000] usbcore: registered new interface driver hub
[    0.050000] usbcore: registered new device driver usb
[    0.050000] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.060000] Bluetooth: Core ver 2.16
[    0.060000] NET: Registered protocol family 31
[    0.060000] Bluetooth: HCI device and connection manager initialized
[    0.060000] Bluetooth: HCI socket layer initialized
[    0.060000] Bluetooth: L2CAP socket layer initialized
[    0.060000] Bluetooth: SCO socket layer initialized
[    0.060000] cfg80211: Calling CRDA to update world regulatory domain
[    0.060000] Init eGon pin module V2.0
[    0.060000] Switching to clocksource aw 64bits couter
[    0.060000] FS-Cache: Loaded
[    0.060000] CacheFiles: Loaded
[    0.070000] Switched to NOHz mode on CPU #0
[    0.070000] [usb_manager]: CONFIG_USB_SW_SUN4I_USB0_OTG
[    0.070000] [sw_hcd0]: usb host driver initialize........
[    0.070000] [sw_hcd0]: open_usb_clock
[    0.090000] [sw_hcd0]: host_init_state = 0
[    0.090000] [sw_hcd0]: platform is usb host
[    0.090000] WRN:L1440(drivers/usb/sun4i_usb/hcd/hcd0/sw_hcd0.c):ERR: request_irq 38 failed!
[    0.090000] sw_hcd_dma_remove
[    0.090000] WRN:L1493(drivers/usb/sun4i_usb/hcd/hcd0/sw_hcd0.c):ERR: sw_hcd_init_controller failed with status -19
[    0.090000] WRN:L1699(drivers/usb/sun4i_usb/hcd/hcd0/sw_hcd0.c):ERR: sw_hcd_init_controller failed
[    0.090000] [sw_udc]: udc_init: version 20080411
[    0.090000] NET: Registered protocol family 2
[    0.090000] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.090000] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.100000] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
[    0.100000] TCP: Hash tables configured (established 131072 bind 65536)
[    0.100000] TCP reno registered
[    0.100000] UDP hash table entries: 512 (order: 1, 8192 bytes)
[    0.100000] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[    0.100000] NET: Registered protocol family 1
[    0.100000] [pm]aw_pm_init!
[    0.100000] audit: initializing netlink socket (disabled)
[    0.100000] type=2000 audit(0.099:1): initialized
[    0.100000] highmem bounce pool size: 64 pages
[    0.110000] VFS: Disk quotas dquot_6.5.2
[    0.110000] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.120000] NTFS driver 2.1.30 [Flags: R/W].
[    0.120000] fuse init (API version 7.16)
[    0.120000] msgmni has been set to 992
[    0.130000] alg: No test for stdrng (krng)
[    0.130000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.130000] io scheduler noop registered
[    0.130000] io scheduler deadline registered
[    0.130000] io scheduler cfq registered (default)
[    0.130000] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.150000] serial8250.0: ttyS0 at MMIO 0x1c28000 (irq = 1) is a U6_16550A
[    0.710000] console [ttyS0] enabled
[    0.720000] [uart]: used uart info.: 0x05
[    0.740000] sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 1) is a U6_16550A
[    0.750000] [uart]: serial probe 0, membase   (null) irq 1 mapbase 0x01c28000
[    0.780000] sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 3) is a U6_16550A
[    0.780000] [uart]: serial probe 2, membase   (null) irq 3 mapbase 0x01c28800
[    0.790000] G2D: drv_g2d_init
[    0.790000] G2D: g2dmem: g2d_start=58000000, g2d_size=1000000
[    0.800000] G2D: head:d8000000,tail:d9000000
[    0.800000] G2D: Module initialized.major:252
[    0.800000] [drm] Initialized drm 1.1.0 20060810
[    0.810000] brd: module loaded
[    0.820000] loop: module loaded
[    0.820000] [NAND]nand driver, init.
[    0.830000] cmu_clk is 360
[    0.830000] nand clk init end
[    0.830000] offset 0xc:  0x6041
[    0.830000] offset 0x14:  0x82000008
[    0.840000] [NAND] nand gpio_request
[    0.840000] [NAND] nand driver version: 0x2 0x9
[    0.850000] nand interrupte register ok
[    0.850000] ret of NFC_ChangMode is 0
[    0.850000] dma_hdle  is 0
[    0.860000] dma_hdle  is 10000008
[    0.860000] cmu_clk is 360
[    0.860000] nand clk init end
[    0.870000] offset 0xc:  0x6041
[    0.870000] offset 0x14:  0x8200000b
[    0.940000] The 0 disk name = DEVICE, class name = NAND, disk start = 0, disk size = 7782400
[    0.950000] The 1 disk name = bootloader, class name = DISK, disk size = 32768
[    0.960000] The 2 disk name = LROOTFS, class name = DISK, disk size = 4069376
[    0.960000] The 2 disk size = 7716864
[    0.970000] part total count = 3
[    0.970000]  nand: unknown partition table
[    0.980000]  nanda:
[    1.330000]  nandb: unknown partition table
[    1.330000] benn: nand probe enter
[    1.340000] [NAND]nand driver, ok.
[    1.340000] wemac Ethernet Driver, V1.01 in file:drivers/net/sun4i/sun4i_wemac.c
[    1.350000] [EMAC] ahb clk enable
[    1.350000] [EMAC] ahb gate clk: 0x26041
[    1.390000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.390000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.400000] [sw-ehci1]: probe, pdev->name: sw-ehci, pdev->id: 1, sw_ehci: 0xc0748588
[    1.410000] [sw-ehci1]: open clock
[    1.430000] [sw-ehci1]: Set USB Power ON
[    1.440000] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.440000] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 1
[    1.450000] sw-ehci sw-ehci.1: irq 39, io mem 0xf1c14000
[    1.480000] sw-ehci sw-ehci.1: USB 0.0 started, EHCI 1.00
[    1.480000] ehci_irq: port change detect
[    1.490000] hub 1-0:1.0: USB hub found
[    1.490000] hub 1-0:1.0: 1 port detected
[    1.490000] [sw-ohci1]: probe, pdev->name: sw-ohci, pdev->id: 1, sw_ohci: 0xc0748698
[    1.500000] [sw-ohci1]: open clock
[    1.530000] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.530000] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 2
[    1.540000] sw-ohci sw-ohci.1: irq 64, io mem 0xf1c14400
[    1.600000] hub 2-0:1.0: USB hub found
[    1.600000] hub 2-0:1.0: 1 port detected
[    1.610000] [sw-ehci2]: probe, pdev->name: sw-ehci, pdev->id: 2, sw_ehci: 0xc07487ac
[    1.620000] [sw-ehci2]: open clock
[    1.640000] [sw-ehci2]: Set USB Power ON
[    1.640000] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.650000] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 3
[    1.660000] sw-ehci sw-ehci.2: irq 40, io mem 0xf1c1c000
[    1.680000] sw-ehci sw-ehci.2: USB 0.0 started, EHCI 1.00
[    1.680000] ehci_irq: port change detect
[    1.690000] hub 3-0:1.0: USB hub found
[    1.690000] hub 3-0:1.0: 1 port detected
[    1.690000] [sw-ehci2]: sw_usb_disable_ehci
[    1.700000] [sw-ehci2]: remove, pdev->name: sw-ehci, pdev->id: 2, sw_ehci: 0xc07487ac
[    1.710000] sw-ehci sw-ehci.2: remove, state 1
[    1.710000] usb usb3: USB disconnect, device number 1
[    1.720000] sw-ehci sw-ehci.2: USB bus 3 deregistered
[    1.720000] [sw-ehci2]: Set USB Power OFF
[    1.730000] [sw-ehci2]: close clock
[    1.730000] [sw-ohci2]: probe, pdev->name: sw-ohci, pdev->id: 2, sw_ohci: 0xc07488bc
[    1.740000] [sw-ohci2]: open clock
[    1.760000] [sw-ohci2]: Set USB Power ON
[    1.760000] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.770000] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 3
[    1.780000] sw-ohci sw-ohci.2: irq 65, io mem 0xf1c1c400
[    1.810000] usb 1-1: new high speed USB device number 2 using sw-ehci
[    1.840000] hub 3-0:1.0: USB hub found
[    1.840000] hub 3-0:1.0: 1 port detected
[    1.850000] [sw-ohci2]: sw_usb_disable_ohci
[    1.850000] [sw-ohci2]: remove, pdev->name: sw-ohci, pdev->id: 2, sw_ohci: 0xc07488bc
[    1.860000] sw-ohci sw-ohci.2: remove, state 1
[    1.860000] usb usb3: USB disconnect, device number 1
[    1.870000] sw-ohci sw-ohci.2: USB bus 3 deregistered
[    1.880000] [sw-ohci2]: Set USB Power OFF
[    1.880000] [sw-ohci2]: close clock
[    1.880000] Initializing USB Mass Storage driver...
[    1.890000] usbcore: registered new interface driver usb-storage
[    1.890000] USB Mass Storage support registered.
[    1.900000] usbcore: registered new interface driver ums-alauda
[    1.910000] usbcore: registered new interface driver ums-cypress
[    1.910000] usbcore: registered new interface driver ums-datafab
[    1.920000] usbcore: registered new interface driver ums_eneub6250
[    1.920000] usbcore: registered new interface driver ums-freecom
[    1.930000] usbcore: registered new interface driver ums-isd200
[    1.940000] usbcore: registered new interface driver ums-jumpshot
[    1.940000] usbcore: registered new interface driver ums-karma
[    1.950000] usbcore: registered new interface driver ums-onetouch
[    1.950000] usbcore: registered new interface driver ums-realtek
[    1.960000] usbcore: registered new interface driver ums-sddr09
[    1.970000] usbcore: registered new interface driver ums-sddr55
[    1.970000] usbcore: registered new interface driver ums-usbat
[    1.980000] mousedev: PS/2 mouse device common for all mice
[    1.990000] sunxi RTC version 0.1
[    1.990000] sunxi-rtc sunxi-rtc: sunxi_rtc_probe tmp_data = 380239881
[    2.000000] sunxi-rtc sunxi-rtc: sunxi_rtc_gettime
[    2.000000] hub 1-1:1.0: USB hub found
[    2.010000] sunxi-rtc sunxi-rtc: read time 2010-1-1 0:0:12
[    2.010000] using rtc device, rtc, for alarms
[    2.020000] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0
[    2.020000] i2c /dev entries driver
[    2.030000] hub 1-1:1.0: 4 ports detected
[    2.030000] !!! base_Addr = 0xe88d2c00
[    2.030000] config i2c gpio with gpio_config api
[    2.040000] twi0, apb clock = 24000000
[    2.050000] axp_mfd 0-0034: AXP (CHIP ID: 0x21) detected
[    2.050000] I2C: i2c-0: AW16XX I2C adapter
[    2.060000] **********start************
[    2.060000] 0x40
[    2.060000] 0xf8
[    2.060000] 0x28
[    2.070000] 0x0
[    2.070000] 0x0
[    2.070000] **********end************
[    2.070000] !!! base_Addr = 0xe88d4000
[    2.080000] twi1, apb clock = 24000000
[    2.080000] I2C: i2c-1: AW16XX I2C adapter
[    2.090000] **********start************
[    2.090000] 0x40
[    2.090000] 0xf8
[    2.090000] 0x58
[    2.100000] 0x0
[    2.100000] 0x0
[    2.100000] **********end************
[    2.100000] !!! base_Addr = 0xe88d6400
[    2.110000] twi2, apb clock = 24000000
[    2.110000] I2C: i2c-2: AW16XX I2C adapter
[    2.120000] **********start************
[    2.120000] 0x40
[    2.120000] 0xf8
[    2.120000] 0x58
[    2.130000] 0x0
[    2.130000] 0x0
[    2.130000] **********end************
[    2.130000] lirc_dev: IR Remote Control driver registered, major 251
[    2.140000] IR NEC protocol handler initialized
[    2.140000] IR RC5(x) protocol handler initialized
[    2.150000] IR RC6 protocol handler initialized
[    2.150000] IR JVC protocol handler initialized
[    2.160000] IR Sony protocol handler initialized
[    2.160000] IR RC5 (streamzap) protocol handler initialized
[    2.170000] IR LIRC bridge handler initialized
[    2.170000] Linux video capture interface: v2.00
[    2.180000] [cedar dev]: install start!!!
[    2.180000] [cedar dev]: install end!!!
[    2.190000] [ace_drv] start!!!
[    2.190000] [ace_drv] init end!!!
[    2.190000] [pa_drv] start!!!
[    2.200000] [pa_drv] init end!!!
[    2.200000] print_constraints: axp20_ldo1: 1300 mV
[    2.210000] print_constraints: axp20_ldo2: 1800 <--> 3300 mV at 3000 mV
[    2.210000] print_constraints: axp20_ldo3: 700 <--> 3500 mV at 2800 mV
[    2.220000] print_constraints: axp20_ldo4: 1250 <--> 3300 mV at 2800 mV
[    2.230000] print_constraints: axp20_buck2: 700 <--> 2275 mV at 1400 mV
[    2.240000] print_constraints: axp20_buck3: 700 <--> 3500 mV at 1250 mV
[    2.250000] print_constraints: axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV
[    2.250000] input: axp20-supplyer as /devices/platform/sun4i-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input0
[    2.280000] Bluetooth: HCI UART driver ver 2.2
[    2.280000] Bluetooth: HCI H4 protocol initialized
[    2.290000] Bluetooth: HCI BCSP protocol initialized
[    2.290000] Bluetooth: HCILL protocol initialized
[    2.300000] Bluetooth: HCIATH3K protocol initialized
[    2.300000] cpuidle: using governor ladder
[    2.310000] cpuidle: using governor menu
[    2.310000] [mmc_pm]: no sdio card used in configuration
[    2.320000] [mmc]: sunximmc_init
[    2.320000] [mmc]: sunxi mmc controller using config : 0xb
[    2.330000] [mmc]: sunxi-mmc.0: pdev->name: sunxi-mmc, pdev->id: 0
[    2.330000] [mmc]: mmc 0 power off !!
[    2.340000] [mmc]: mmc0 Probe: base:0xe88de000 irq:32 dma:0 pdes:0xe7ba8000, ret 0.
[    2.350000] [mmc]: sunxi-mmc.1: pdev->name: sunxi-mmc, pdev->id: 1
[    2.350000] [mmc]: mmc 1 power off !!
[    2.360000] [mmc]: mmc1 Probe: base:0xe88e0000 irq:33 dma:0 pdes:0xe7bb0000, ret 0.
[    2.360000] [mmc]: sunxi-mmc.3: pdev->name: sunxi-mmc, pdev->id: 3
[    2.370000] [mmc]: mmc 3 power off !!
[    2.370000] [mmc]: mmc3 Probe: base:0xe88e2000 irq:35 dma:0 pdes:0xe7bb4000, ret 0.
[    2.380000] usbcore: registered new interface driver usbhid
[    2.390000] usbhid: USB HID core driver
[    2.390000] line6usb driver version 0.9.1beta (revision 690)
[    2.400000] usbcore: registered new interface driver line6usb
[    2.410000] enter sun4i Audio codec!!!
[    2.410000] sun4i audio support initialized
[    2.410000] sun4i Audio codec successfully loaded..
[    2.420000] asoc: sndhdmi <-> sun4i-hdmiaudio.0 mapping ok
[    2.430000] ALSA device list:
[    2.430000]   #0: sun4i-CODEC  Audio Codec
[    2.440000]   #1: sun4i-sndhdmi
[    2.440000] IPv4 over IPv4 tunneling driver
[    2.440000] Initializing XFRM netlink socket
[    2.450000] NET: Registered protocol family 10
[    2.460000] NET: Registered protocol family 17
[    2.460000] NET: Registered protocol family 15
[    2.460000] Bluetooth: RFCOMM TTY layer initialized
[    2.470000] Bluetooth: RFCOMM socket layer initialized
[    2.470000] Bluetooth: RFCOMM ver 1.11
[    2.480000] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.480000] Bluetooth: BNEP filters: protocol multicast
[    2.490000] 802.1Q VLAN Support v1.8
[    2.490000] [mmc_pm]: No sdio card, please check your config !!
[    2.500000] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    2.510000] Registering SWP/SWPB emulation handler
[    2.510000] registered taskstats version 1
[    2.520000] regulator_init_complete: axp20_buck3: incomplete constraints, leaving on
[    2.530000] regulator_init_complete: axp20_buck2: incomplete constraints, leaving on
[    2.530000] regulator_init_complete: axp20_ldo4: incomplete constraints, leaving on
[    2.540000] regulator_init_complete: axp20_ldo3: incomplete constraints, leaving on
[    2.550000] regulator_init_complete: axp20_ldo2: incomplete constraints, leaving on
[    2.560000] regulator_init_complete: axp20_ldo1: incomplete constraints, leaving on
[    2.570000] sunxi-rtc sunxi-rtc: sunxi_rtc_gettime
[    2.570000] sunxi-rtc sunxi-rtc: read time 2010-1-1 0:0:13
[    2.580000] sunxi-rtc sunxi-rtc: setting system clock to 2010-01-01 00:00:13 UTC (1262304013)
[    2.590000] EXT3-fs (nandb): error: couldn't mount because of unsupported optional features (240)
[    2.600000] EXT2-fs (nandb): error: couldn't mount because of unsupported optional features (244)
[    5.030000] usb 1-1.3: new high speed USB device number 3 using sw-ehci
[    5.220000] ====usb_stor_huawei_e220_init===>
[    5.230000] ====usb_stor_huawei_e220_init===>
[    5.910000] EXT4-fs (nandb): recovery complete
[    5.920000] EXT4-fs (nandb): mounted filesystem with ordered data mode. Opts: (null)
[    5.930000] VFS: Mounted root (ext4 filesystem) on device 93:16.
[    5.940000] devtmpfs: mounted
[    5.940000] Freeing init memory: 160K
[   12.650000] systemd-udevd[157]: starting version 204
[   15.790000] usb 1-1.3: USB disconnect, device number 3
[   16.030000] EXT4-fs (nandb): re-mounted. Opts: (null)
[   16.420000] EXT4-fs (nandb): re-mounted. Opts: discard,errors=remount-ro
[   18.390000] sw_usb_enable_hcd: usbc_num = 2
[   18.400000] [sw-ehci2]: sw_usb_enable_ehci
[   18.400000] [sw-ehci2]: probe, pdev->name: sw-ehci, pdev->id: 2, sw_ehci: 0xc07487ac
[   18.410000] [sw-ehci2]: open clock
[   18.440000] [sw-ehci2]: Set USB Power ON
[   18.440000] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   18.450000] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 3
[   18.460000] sw-ehci sw-ehci.2: irq 40, io mem 0xf1c1c000
[   18.480000] sw-ehci sw-ehci.2: USB 0.0 started, EHCI 1.00
[   18.480000] ehci_irq: port change detect
[   18.490000] hub 3-0:1.0: USB hub found
[   18.510000] hub 3-0:1.0: 1 port detected
[   18.510000] [sw-ohci2]: sw_usb_enable_ohci
[   18.520000] [sw-ohci2]: probe, pdev->name: sw-ohci, pdev->id: 2, sw_ohci: 0xc07488bc
[   18.530000] [sw-ohci2]: open clock
[   18.550000] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   18.560000] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 4
[   18.560000] sw-ohci sw-ohci.2: irq 65, io mem 0xf1c1c400
[   18.640000] hub 4-0:1.0: USB hub found
[   18.640000] hub 4-0:1.0: 1 port detected
[   18.650000]
[   18.650000] rtw driver version=v3.3.2_3192.20120103
[   18.650000] usbcore: registered new interface driver rtl8192cu
[   18.730000] sun4i gpio driver init
[   18.790000] err: gpio count < =0 ,gpio_count is: 0
[   18.810000] sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP
[   18.810000] sw_ahci sw_ahci.0: forcing PORTS_IMPL to 0x1
[   18.820000] sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[   18.830000] usb 3-1: new high speed USB device number 2 using sw-ehci
[   18.840000] sw_ahci sw_ahci.0: flags: ncq sntf pm led clo only pio slum part ccc
[   18.850000] scsi2 : sw_ahci_platform
[   18.860000] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 56
[   19.210000] ata1: SATA link down (SStatus 0 SControl 300)
[   19.570000] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_A_CUT_1T1R_RomVer(0)
[   19.620000] usb 1-1.3: new high speed USB device number 4 using sw-ehci
[   19.630000] usbcore: registered new interface driver r8188eu
[   19.800000] ====usb_stor_huawei_e220_init===>
[   19.830000] ====usb_stor_huawei_e220_init===>
[   19.860000] ====usb_stor_huawei_e220_init===>
[   21.640000] usbcore: registered new interface driver usbserial
[   21.660000] usbserial: USB Serial Driver core
[   21.720000] USB Serial support registered for GSM modem (1-port)
[   21.750000] option 1-1.3:1.0: GSM modem (1-port) converter detected
[   21.770000] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB0
[   21.790000] option 1-1.3:1.3: GSM modem (1-port) converter detected
[   21.820000] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB1
[   21.820000] option 1-1.3:1.4: GSM modem (1-port) converter detected
[   21.840000] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
[   21.840000] usbcore: registered new interface driver option
[   21.860000] option: v0.7.2:USB Driver for GSM modems
[   26.550000] wemac wemac.0: WARNING: no IRQ resource flags set.
[   26.650000] wemac wemac.0: eth0: link down
[   26.650000] ADDRCONF(NETDEV_UP): eth0: link is not ready
[  115.210000] R8188EU: Firmware Version 11, SubVersion 1, Signature 0x88e1
[  115.830000] MAC Address = 00:b7:05:00:24:4d
[  115.860000] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  115.900000] R8188EU: ERROR indicate disassoc
[  115.940000] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  119.780000] R8188EU: ERROR assoc success
[  119.800000] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  129.880000] wlan0: no IPv6 routers present
  1. Po instalacji tego system może już nie wstać.
  2. Nie wiem jak wygląda struktura tego sytemu. Ale zdaje się, że powinieneś mieć 2 partycje. Na jednej jest jądro, na drugiej reszta.
    Zamontuj pierwszą partycje i skopiuj na nią plik uImage (możesz sobie zostawić w ramach kopi bezpieczeństwa oryginał). Na drugą partycję trzeba skopiować resztę plików (tylko inteligentnie). Zmień nazwę katalogu /lib/modules/3.0.42 na np. /lib/modules/3.0.42.kopia. Następnie skopiuj tam zawartość z archiwum: /jajko/output/lib/modules/3.0.42. Podobnie zrób z katalogiem firmware. Może trochę poplątałem, ale jak zobaczysz struktury katalogów, to powinieneś się połapać.
  3. Oczywiście będzie konieczna ponowna instalacja modułu karty sieciowej.
  4. Nie wiem dokładnie jakie moduły muszą być włączone aby modem zadziałał. Włączyłem tylko wszystko co związane z ppp i jakiś moduł dotyczący USB.
Link: https://www.dropbox.com/s/ysqwruponwbi8k1/jajko.7z
MrDarkenRahl
Dobra, system powstał, ale PPP dalej nie działa. Tzn jest ok, ładnie próbuje się łączyć, ale nie może - pewnie zła konfiguracja.
root@mele:/dev# pon.wvdial aero2root@mele:/dev# --> WvDial: Internet dialer version 1.61
--> Initializing modem.
--> Sending: AT+CGDCONT=1,"IP","darmowy"
OK
--> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
OK
--> Modem initialized.
--> Sending: ATDT*99#
--> Waiting for carrier.
ATDT*99#
CONNECT 21600000
--> Carrier detected.  Starting PPP immediately.
--> Starting pppd at Sun Feb 23 16:10:01 2014
--> Pid of pppd: 1863
--> Using interface ppp0
--> pppd: 0[0f]▒
--> pppd: 0[0f]▒
--> pppd: 0[0f]▒
--> pppd: 0[0f]▒
--> pppd: 0[0f]▒
--> pppd: 0[0f]▒
--> Disconnecting at Sun Feb 23 16:10:04 2014
--> The PPP daemon has died: A modem hung up the phone (exit code = 16)
--> man pppd explains pppd error codes in more detail.
--> Try again and look into /var/log/messages and the wvdial and pppd man pages for more information.
--> Auto Reconnect will be attempted in 5 seconds
root@mele:/dev# cat /etc/wvdial.conf
[Dialer aero2]
Modem = /dev/ttyUSB0
Init1 = AT+CGDCONT=1,"IP","darmowy"
Phone = *99#
Stupid mode = yes
Username = "aero"
Password = "aero"
Dial Attempts = 0
[Dialer Defaults]
Init1 = ATZ
Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
Modem Type = Analog Modem
Baud = 9600
New PPPD = yes
ISDN = 0
; Phone = <Target Phone Number>
; Password = <Your Password>
; Username = <Your Login Name>
Niewiele z tym miałem do czynienia, ale sprawdzałeś inne urządzenia ttyUSB? Fragment Twojego dmesg:
Sprawdź jeszcze raz w dmesg, czy po aktualizacji jądra nic się w tej materii nie zmieniło i spróbuj na pozostałych urządzeniach ttyUSB.
MrDarkenRahl
Na pozostałych są inne interfejsy. 0 to modem, 1 to PCUI (komunikacja z oprogramowaniem na Windows) i 2 to port diagnostyczny. Na OpenWRT działało pod USB0, więc to raczej kwestia konfiguracji. A co do dmesg - nic się nie zmieniło.
A co jest na końcu /var/log/messages po próbie połączenia się?
Dodane: tutaj: http://www.aero2.pl/Bezplatny-Internet/ ... nie-do-BDI jest napisane, że pola użytkownik i hasło powinny być puste.
MrDarkenRahl
root@mele:/dev# cat /var/log/messages
cat: /var/log/messages: Nie ma takiego pliku ani katalogu
hmmm...
EDIT
--> Configuration does not specify a valid login name.
--> Configuration does not specify a valid password.
Więc musi być tam cokolwiek wpisane, więc dałem spacje oraz dopisałem w confie opcję BAUD = 9600
root@mele:~# wvdial aero2
OK
OK
ATDT*99#
CONNECT 21600000
--> Starting pppd at Fri Jan  1 01:50:18 2010
--> Pid of pppd: 1833
--> pppd: @jm
--> pppd: @jm
--> pppd: @jm
--> pppd: @jm
--> pppd: @jm
--> pppd: @jm
--> local  IP address 37.209.134.145
--> pppd: @jm
--> remote IP address 10.64.64.64
--> pppd: @jm
--> primary   DNS address 193.41.112.14
--> pppd: @jm
--> secondary DNS address 193.41.112.18
--> pppd: @jm
Wygląda dobrze, bo błędów nie wysypuje, ale kiedy loguje się na innej konsoli, to i tak nie mogę spingować żadnego hosta (tzn oprócz lokalnych).
A jak zostawisz username i password puste, czyli ""?
MrDarkenRahl
Spóźniłem się z edycją postu, wyżej napisałem ;)
Spróbuj ping na DNS'a:
ping 193.41.112.14
ping 8.8.8.8
