[Debian 7.4 i386]errory podczas startu systemu
taxiarz
Post autor: taxiarz »
Na DUG nie potrafią mi pomóc, więc piszę tutaj. Zainstalowałem drukarkę HP - HP P1102w poprzez Hplip ze źródeł. Teraz podczas uruchamiania
demona cupsd wyskakuje error. Podaje /var/log/kern.log
Feb 22 11:22:06 euklides kernel: [    0.244551] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP1._PRT]
Feb 22 11:22:06 euklides kernel: [    0.244609] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP2._PRT]
Feb 22 11:22:06 euklides kernel: [    0.244670] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP5._PRT]
Feb 22 11:22:06 euklides kernel: [    0.244738]  pci0000:00: Requesting ACPI _OSC control (0x1d)
Feb 22 11:22:06 euklides kernel: [    0.244741]  pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
Feb 22 11:22:06 euklides kernel: [    0.244743] ACPI _OSC control for PCIe not granted, disabling ASPM
Feb 22 11:22:06 euklides kernel: [    0.249758] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 9 10 11 12)
Feb 22 11:22:06 euklides kernel: [    0.249817] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 *11 12)
Feb 22 11:22:06 euklides kernel: [    0.249875] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 *11 12)
Feb 22 11:22:06 euklides kernel: [    0.249932] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12)
Feb 22 11:22:06 euklides kernel: [    0.249989] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
Feb 22 11:22:06 euklides kernel: [    0.250048] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 *10 11 12)
Feb 22 11:22:06 euklides kernel: [    0.250104] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 10 *11 12)
Feb 22 11:22:06 euklides kernel: [    0.250160] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 10 *11 12)
Feb 22 11:22:06 euklides kernel: [    0.250266] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
Feb 22 11:22:06 euklides kernel: [    0.250266] vgaarb: loaded
Feb 22 11:22:06 euklides kernel: [    0.250266] vgaarb: bridge control possible 0000:00:02.0
Feb 22 11:22:06 euklides kernel: [    0.250266] PCI: Using ACPI for IRQ routing
Feb 22 11:22:06 euklides kernel: [    0.252469] PCI: pci_cache_line_size set to 64 bytes
Feb 22 11:22:06 euklides kernel: [    0.252567] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
Feb 22 11:22:06 euklides kernel: [    0.252570] reserve RAM buffer: 00000000b7b6c000 - 00000000b7ffffff
Feb 22 11:22:06 euklides kernel: [    0.252573] reserve RAM buffer: 00000000b7c80000 - 00000000b7ffffff
Feb 22 11:22:06 euklides kernel: [    0.252575] reserve RAM buffer: 00000000b7cec000 - 00000000b7ffffff
Feb 22 11:22:06 euklides kernel: [    0.252577] reserve RAM buffer: 00000000b7d00000 - 00000000b7ffffff
Feb 22 11:22:06 euklides kernel: [    0.252691] HPET: 4 timers in total, 0 timers will be used for per-cpu timer
Feb 22 11:22:06 euklides kernel: [    0.252698] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
Feb 22 11:22:06 euklides kernel: [    0.252703] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
Feb 22 11:22:06 euklides kernel: [    0.256084] Switching to clocksource hpet
Feb 22 11:22:06 euklides kernel: [    0.257736] pnp: PnP ACPI init
Feb 22 11:22:06 euklides kernel: [    0.257755] ACPI: bus type pnp registered
Feb 22 11:22:06 euklides kernel: [    0.258187] pnp 00:00: [bus 00-ff]
Feb 22 11:22:06 euklides kernel: [    0.258190] pnp 00:00: [io  0x0000-0x0cf7 window]
Feb 22 11:22:06 euklides kernel: [    0.258193] pnp 00:00: [io  0x0cf8-0x0cff]
Feb 22 11:22:06 euklides kernel: [    0.258195] pnp 00:00: [io  0x0d00-0xffff window]
Feb 22 11:22:06 euklides kernel: [    0.258197] pnp 00:00: [mem 0x000a0000-0x000bffff window]
Feb 22 11:22:06 euklides kernel: [    0.258200] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
Feb 22 11:22:06 euklides kernel: [    0.258202] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
Feb 22 11:22:06 euklides kernel: [    0.258204] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
Feb 22 11:22:06 euklides kernel: [    0.258206] pnp 00:00: [mem 0x000cc000-0x000cffff window]
Feb 22 11:22:06 euklides kernel: [    0.258209] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
Feb 22 11:22:06 euklides kernel: [    0.258211] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
Feb 22 11:22:06 euklides kernel: [    0.258213] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
Feb 22 11:22:06 euklides kernel: [    0.258215] pnp 00:00: [mem 0x000dc000-0x000dffff window]
Feb 22 11:22:06 euklides kernel: [    0.258218] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
Feb 22 11:22:06 euklides kernel: [    0.258220] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
Feb 22 11:22:06 euklides kernel: [    0.258222] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
Feb 22 11:22:06 euklides kernel: [    0.258225] pnp 00:00: [mem 0x000ec000-0x000effff window]
Feb 22 11:22:06 euklides kernel: [    0.258227] pnp 00:00: [mem 0x000f0000-0x000fffff window]
Feb 22 11:22:06 euklides kernel: [    0.258229] pnp 00:00: [mem 0xc0000000-0xfebfffff window]
Feb 22 11:22:06 euklides kernel: [    0.258231] pnp 00:00: [mem 0xfed40000-0xfed44fff window]
Feb 22 11:22:06 euklides kernel: [    0.258304] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
Feb 22 11:22:06 euklides kernel: [    0.258451] pnp 00:01: [io  0x002e-0x002f]
Feb 22 11:22:06 euklides kernel: [    0.258453] pnp 00:01: [io  0x004e-0x004f]
Feb 22 11:22:06 euklides kernel: [    0.258455] pnp 00:01: [io  0x164e-0x164f]
Feb 22 11:22:06 euklides kernel: [    0.258457] pnp 00:01: [io  0x0061]
Feb 22 11:22:06 euklides kernel: [    0.258459] pnp 00:01: [io  0x0070]
Feb 22 11:22:06 euklides kernel: [    0.258461] pnp 00:01: [io  0x0080]
Feb 22 11:22:06 euklides kernel: [    0.258463] pnp 00:01: [io  0x0092]
Feb 22 11:22:06 euklides kernel: [    0.258465] pnp 00:01: [io  0x00b2-0x00b3]
Feb 22 11:22:06 euklides kernel: [    0.258467] pnp 00:01: [io  0x0063]
Feb 22 11:22:06 euklides kernel: [    0.258469] pnp 00:01: [io  0x0065]
Feb 22 11:22:06 euklides kernel: [    0.258470] pnp 00:01: [io  0x0067]
Feb 22 11:22:06 euklides kernel: [    0.258472] pnp 00:01: [io  0x0800-0x080f]
Feb 22 11:22:06 euklides kernel: [    0.258474] pnp 00:01: [io  0x0810-0x0817]
Feb 22 11:22:06 euklides kernel: [    0.258476] pnp 00:01: [io  0x0820-0x0823]
Feb 22 11:22:06 euklides kernel: [    0.258478] pnp 00:01: [io  0x0400-0x047f]
Feb 22 11:22:06 euklides kernel: [    0.258480] pnp 00:01: [io  0x0500-0x057f]
Feb 22 11:22:06 euklides kernel: [    0.258482] pnp 00:01: [io  0x0062]
Feb 22 11:22:06 euklides kernel: [    0.258484] pnp 00:01: [io  0x0066]
Feb 22 11:22:06 euklides kernel: [    0.258486] pnp 00:01: [io  0x0068]
Feb 22 11:22:06 euklides kernel: [    0.258488] pnp 00:01: [io  0x006c]
Feb 22 11:22:06 euklides kernel: [    0.258490] pnp 00:01: [mem 0xf8000000-0xfbffffff]
Feb 22 11:22:06 euklides kernel: [    0.258492] pnp 00:01: [mem 0xfed1c000-0xfed1ffff]
Feb 22 11:22:06 euklides kernel: [    0.258494] pnp 00:01: [mem 0xfed10000-0xfed13fff]
Feb 22 11:22:06 euklides kernel: [    0.258496] pnp 00:01: [mem 0xfed18000-0xfed18fff]
Feb 22 11:22:06 euklides kernel: [    0.258498] pnp 00:01: [mem 0xfed19000-0xfed19fff]
Feb 22 11:22:06 euklides kernel: [    0.258501] pnp 00:01: [mem 0xfec00000-0xfec00fff]
Feb 22 11:22:06 euklides kernel: [    0.258503] pnp 00:01: [mem 0xfed20000-0xfed8ffff]
Feb 22 11:22:06 euklides kernel: [    0.258505] pnp 00:01: [mem 0xfee00000-0xfee00fff]
Feb 22 11:22:06 euklides kernel: [    0.258507] pnp 00:01: [mem 0xff800000-0xffffffff]
Feb 22 11:22:06 euklides kernel: [    0.258534] pnp 00:01: disabling [io  0x164e-0x164f] because it overlaps 0000:00:1c.4 BAR 13 [io  0x1000-0x1fff]
Feb 22 11:22:06 euklides kernel: [    0.258603] system 00:01: [io  0x0800-0x080f] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258607] system 00:01: [io  0x0810-0x0817] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258610] system 00:01: [io  0x0820-0x0823] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258613] system 00:01: [io  0x0400-0x047f] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258617] system 00:01: [io  0x0500-0x057f] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258621] system 00:01: [mem 0xf8000000-0xfbffffff] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258624] system 00:01: [mem 0xfed1c000-0xfed1ffff] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258627] system 00:01: [mem 0xfed10000-0xfed13fff] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258630] system 00:01: [mem 0xfed18000-0xfed18fff] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258633] system 00:01: [mem 0xfed19000-0xfed19fff] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258636] system 00:01: [mem 0xfec00000-0xfec00fff] could not be reserved
Feb 22 11:22:06 euklides kernel: [    0.258639] system 00:01: [mem 0xfed20000-0xfed8ffff] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258642] system 00:01: [mem 0xfee00000-0xfee00fff] has been reserved
Feb 22 11:22:06 euklides kernel: [    0.258645] system 00:01: [mem 0xff800000-0xffffffff] could Feb 22 11:22:06 euklides kernel: [    0.244551] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP1._PRT]
Feb 22 11:22:06 euklides kernel: [    0.258645] system 00:01: [mem 0xff800000-0xffffffff] could not be reserved
Feb 22 11:22:06 euklides kernel: [    0.258648] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
Feb 22 11:22:06 euklides kernel: [    0.258658] pnp 00:02: [io  0x0000-0x001f]
Feb 22 11:22:06 euklides kernel: [    0.258660] pnp 00:02: [io  0x0081-0x0091]
Feb 22 11:22:06 euklides kernel: [    0.258662] pnp 00:02: [io  0x0093-0x009f]
Feb 22 11:22:06 euklides kernel: [    0.258664] pnp 00:02: [io  0x00c0-0x00df]
Feb 22 11:22:06 euklides kernel: [    0.258667] pnp 00:02: [dma 4]
Feb 22 11:22:06 euklides kernel: [    0.258699] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
Feb 22 11:22:06 euklides kernel: [    0.258722] pnp 00:03: [io  0x0070-0x0077]
Feb 22 11:22:06 euklides kernel: [    0.258755] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
Feb 22 11:22:06 euklides kernel: [    0.258818] pnp 00:04: [irq 0 disabled]
Feb 22 11:22:06 euklides kernel: [    0.258830] pnp 00:04: [irq 8]
Feb 22 11:22:06 euklides kernel: [    0.258832] pnp 00:04: [mem 0xfed00000-0xfed003ff]
Feb 22 11:22:06 euklides kernel: [    0.258864] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
Feb 22 11:22:06 euklides kernel: [    0.258876] pnp 00:05: [io  0x00f0]
Feb 22 11:22:06 euklides kernel: [    0.258881] pnp 00:05: [irq 13]
Feb 22 11:22:06 euklides kernel: [    0.258914] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
Feb 22 11:22:06 euklides kernel: [    0.258932] pnp 00:06: [io  0x0060]
Feb 22 11:22:06 euklides kernel: [    0.258934] pnp 00:06: [io  0x0064]
Feb 22 11:22:06 euklides kernel: [    0.258939] pnp 00:06: [irq 1]
Feb 22 11:22:06 euklides kernel: [    0.258972] pnp 00:06: Plug and Play ACPI device, IDs PNP0303 (active)
Feb 22 11:22:06 euklides kernel: [    0.258990] pnp 00:07: [irq 12]
Feb 22 11:22:06 euklides kernel: [    0.259025] pnp 00:07: Plug and Play ACPI device, IDs TOS0100 SYN1900 SYN0002 PNP0f13 (active)
Feb 22 11:22:06 euklides kernel: [    0.259155] pnp: PnP ACPI: found 8 devices
Feb 22 11:22:06 euklides kernel: [    0.259157] ACPI: ACPI bus type pnp unregistered
Feb 22 11:22:06 euklides kernel: [    0.259161] PnPBIOS: Disabled by ACPI PNP
Feb 22 11:22:06 euklides kernel: [    0.296261] PCI: max bus depth: 1 pci_try_num: 2
Feb 22 11:22:06 euklides kernel: [    0.296305] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
Feb 22 11:22:06 euklides kernel: [    0.296310] pci 0000:00:1c.0:   bridge window [io  0x3000-0x4fff]
Feb 22 11:22:06 euklides kernel: [    0.296316] pci 0000:00:1c.0:   bridge window [mem 0xd5600000-0xd66fffff]
Feb 22 11:22:06 euklides kernel: [    0.296321] pci 0000:00:1c.0:   bridge window [mem 0xd0400000-0xd13fffff 64bit pref]
Feb 22 11:22:06 euklides kernel: [    0.296329] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
Feb 22 11:22:06 euklides kernel: [    0.296333] pci 0000:00:1c.1:   bridge window [io  0x2000-0x2fff]
Feb 22 11:22:06 euklides kernel: [    0.296339] pci 0000:00:1c.1:   bridge window [mem 0xd4500000-0xd55fffff]
Feb 22 11:22:06 euklides kernel: [    0.296344] pci 0000:00:1c.1:   bridge window [mem 0xd1400000-0xd23fffff 64bit pref]
Feb 22 11:22:06 euklides kernel: [    0.296352] pci 0000:00:1c.4: PCI bridge to [bus 07-08]
Feb 22 11:22:06 euklides kernel: [    0.296356] pci 0000:00:1c.4:   bridge window [io  0x1000-0x1fff]
Feb 22 11:22:06 euklides kernel: [    0.296361] pci 0000:00:1c.4:   bridge window [mem 0xd3500000-0xd44fffff]
Feb 22 11:22:06 euklides kernel: [    0.296367] pci 0000:00:1c.4:   bridge window [mem 0xd2400000-0xd33fffff 64bit pref]
Feb 22 11:22:06 euklides kernel: [    0.296374] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
Feb 22 11:22:06 euklides kernel: [    0.296407] pci 0000:00:1c.0: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    0.296421] pci 0000:00:1c.1: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    0.296428] pci 0000:00:1c.4: enabling device (0000 -> 0003)
Feb 22 11:22:06 euklides kernel: [    0.296436] pci 0000:00:1c.4: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    0.296443] pci 0000:00:1e.0: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    0.296447] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7]
Feb 22 11:22:06 euklides kernel: [    0.296450] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff]
Feb 22 11:22:06 euklides kernel: [    0.296452] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
Feb 22 11:22:06 euklides kernel: [    0.296455] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xfebfffff]
Feb 22 11:22:06 euklides kernel: [    0.296458] pci_bus 0000:02: resource 0 [io  0x3000-0x4fff]
Feb 22 11:22:06 euklides kernel: [    0.296460] pci_bus 0000:02: resource 1 [mem 0xd5600000-0xd66fffff]
Feb 22 11:22:06 euklides kernel: [    0.296463] pci_bus 0000:02: resource 2 [mem 0xd0400000-0xd13fffff 64bit pref]
Feb 22 11:22:06 euklides kernel: [    0.296465] pci_bus 0000:03: resource 0 [io  0x2000-0x2fff]
Feb 22 11:22:06 euklides kernel: [    0.296468] pci_bus 0000:03: resource 1 [mem 0xd4500000-0xd55fffff]
Feb 22 11:22:06 euklides kernel: [    0.296470] pci_bus 0000:03: resource 2 [mem 0xd1400000-0xd23fffff 64bit pref]
Feb 22 11:22:06 euklides kernel: [    0.296473] pci_bus 0000:07: resource 0 [io  0x1000-0x1fff]
Feb 22 11:22:06 euklides kernel: [    0.296475] pci_bus 0000:07: resource 1 [mem 0xd3500000-0xd44fffff]
Feb 22 11:22:06 euklides kernel: [    0.296478] pci_bus 0000:07: resource 2 [mem 0xd2400000-0xd33fffff 64bit pref]
Feb 22 11:22:06 euklides kernel: [    0.296480] pci_bus 0000:04: resource 4 [io  0x0000-0x0cf7]
Feb 22 11:22:06 euklides kernel: [    0.296483] pci_bus 0000:04: resource 5 [io  0x0d00-0xffff]
Feb 22 11:22:06 euklides kernel: [    0.296485] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff]
Feb 22 11:22:06 euklides kernel: [    0.296488] pci_bus 0000:04: resource 7 [mem 0xc0000000-0xfebfffff]
Feb 22 11:22:06 euklides kernel: [    0.296546] NET: Registered protocol family 2
Feb 22 11:22:06 euklides kernel: [    0.296612] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Feb 22 11:22:06 euklides kernel: [    0.296839] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
Feb 22 11:22:06 euklides kernel: [    0.297234] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
Feb 22 11:22:06 euklides kernel: [    0.297502] TCP: Hash tables configured (established 131072 bind 65536)
Feb 22 11:22:06 euklides kernel: [    0.297504] TCP reno registered
Feb 22 11:22:06 euklides kernel: [    0.297508] UDP hash table entries: 512 (order: 2, 16384 bytes)
Feb 22 11:22:06 euklides kernel: [    0.297520] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Feb 22 11:22:06 euklides kernel: [    0.297649] NET: Registered protocol family 1
Feb 22 11:22:06 euklides kernel: [    0.297669] pci 0000:00:02.0: Boot video device
Feb 22 11:22:06 euklides kernel: [    1.896015] pci 0000:00:1a.7: EHCI: BIOS handoff failed (BIOS bug?) 01010001
Feb 22 11:22:06 euklides kernel: [    3.496016] pci 0000:00:1d.7: EHCI: BIOS handoff failed (BIOS bug?) 01010001
Feb 22 11:22:06 euklides kernel: [    3.496151] PCI: CLS 64 bytes, default 64
Feb 22 11:22:06 euklides kernel: [    3.496204] Unpacking initramfs...
Feb 22 11:22:06 euklides kernel: [    3.754281] Freeing initrd memory: 9916k freed
Feb 22 11:22:06 euklides kernel: [    3.759174] Simple Boot Flag value 0x5 read from CMOS RAM was invalid
Feb 22 11:22:06 euklides kernel: [    3.759177] Simple Boot Flag at 0x44 set to 0x1
Feb 22 11:22:06 euklides kernel: [    3.759614] audit: initializing netlink socket (disabled)
Feb 22 11:22:06 euklides kernel: [    3.759627] type=2000 audit(1393068111.752:1): initialized
Feb 22 11:22:06 euklides kernel: [    3.777903] highmem bounce pool size: 64 pages
Feb 22 11:22:06 euklides kernel: [    3.777908] HugeTLB registered 2 MB page size, pre-allocated 0 pages
Feb 22 11:22:06 euklides kernel: [    3.778718] VFS: Disk quotas dquot_6.5.2
Feb 22 11:22:06 euklides kernel: [    3.778752] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Feb 22 11:22:06 euklides kernel: [    3.778822] msgmni has been set to 1686
Feb 22 11:22:06 euklides kernel: [    3.778981] alg: No test for stdrng (krng)
Feb 22 11:22:06 euklides kernel: [    3.779008] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
Feb 22 11:22:06 euklides kernel: [    3.779011] io scheduler noop registered
Feb 22 11:22:06 euklides kernel: [    3.779013] io scheduler deadline registered
Feb 22 11:22:06 euklides kernel: [    3.779026] io scheduler cfq registered (default)
Feb 22 11:22:06 euklides kernel: [    3.779119] pcieport 0000:00:1c.0: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    3.779178] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
Feb 22 11:22:06 euklides kernel: [    3.779260] pcieport 0000:00:1c.1: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    3.779313] pcieport 0000:00:1c.1: irq 41 for MSI/MSI-X
Feb 22 11:22:06 euklides kernel: [    3.779391] pcieport 0000:00:1c.4: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    3.779444] pcieport 0000:00:1c.4: irq 42 for MSI/MSI-X
Feb 22 11:22:06 euklides kernel: [    3.779545] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Feb 22 11:22:06 euklides kernel: [    3.779566] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
Feb 22 11:22:06 euklides kernel: [    3.779568] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Feb 22 11:22:06 euklides kernel: [    3.779800] acpiphp: Slot [1] registered
Feb 22 11:22:06 euklides kernel: [    3.779900] intel_idle: does not run on family 6 model 23
Feb 22 11:22:06 euklides kernel: [    3.779928] ERST: Table is not found!
Feb 22 11:22:06 euklides kernel: [    3.779930] GHES: HEST is not enabled!
Feb 22 11:22:06 euklides kernel: [    3.779942] isapnp: Scanning for PnP cards...
Feb 22 11:22:06 euklides kernel: [    4.133824] isapnp: No Plug & Play device found
Feb 22 11:22:06 euklides kernel: [    4.133896] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Feb 22 11:22:06 euklides kernel: [    4.140316] Linux agpgart interface v0.103
Feb 22 11:22:06 euklides kernel: [    4.140447] agpgart-intel 0000:00:00.0: Intel GM45 Chipset
Feb 22 11:22:06 euklides kernel: [    4.140563] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
Feb 22 11:22:06 euklides kernel: [    4.141226] agpgart-intel 0000:00:00.0: detected 131072K stolen memory
Feb 22 11:22:06 euklides kernel: [    4.141350] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xc0000000
Feb 22 11:22:06 euklides kernel: [    4.141506] i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:MOUE] at 0x60,0x64 irq 1,12
Feb 22 11:22:06 euklides kernel: [    4.172074] serio: i8042 KBD port at 0x60,0x64 irq 1
Feb 22 11:22:06 euklides kernel: [    4.172083] serio: i8042 AUX port at 0x60,0x64 irq 12
Feb 22 11:22:06 euklides kernel: [    4.172220] mousedev: PS/2 mouse device common for all mice
Feb 22 11:22:06 euklides kernel: [    4.173201] rtc_cmos 00:03: RTC can wake from S4
Feb 22 11:22:06 euklides kernel: [    4.173331] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
Feb 22 11:22:06 euklides kernel: [    4.173363] rtc0: alarms up to one month, 242 bytes nvram, hpet irqs
Feb 22 11:22:06 euklides kernel: [    4.173372] cpuidle: using governor ladder
Feb 22 11:22:06 euklides kernel: [    4.173374] cpuidle: using governor menu
Feb 22 11:22:06 euklides kernel: [    4.173580] TCP cubic registered
Feb 22 11:22:06 euklides kernel: [    4.173621] NET: Registered protocol family 10
Feb 22 11:22:06 euklides kernel: [    4.174079] Mobile IPv6
Feb 22 11:22:06 euklides kernel: [    4.174082] NET: Registered protocol family 17
Feb 22 11:22:06 euklides kernel: [    4.174086] Registering the dns_resolver key type
Feb 22 11:22:06 euklides kernel: [    4.174108] Using IPI No-Shortcut mode
Feb 22 11:22:06 euklides kernel: [    4.174235] PM: Hibernation image not present or could not be loaded.
Feb 22 11:22:06 euklides kernel: [    4.174245] registered taskstats version 1
Feb 22 11:22:06 euklides kernel: [    4.174965] rtc_cmos 00:03: setting system clock to 2014-02-22 11:21:52 UTC (1393068112)
Feb 22 11:22:06 euklides kernel: [    4.175029] Initializing network drop monitor service
Feb 22 11:22:06 euklides kernel: [    4.175120] Freeing unused kernel memory: 420k freed
Feb 22 11:22:06 euklides kernel: [    4.175294] Write protecting the kernel text: 2856k
Feb 22 11:22:06 euklides kernel: [    4.175327] Write protecting the kernel read-only data: 1084k
Feb 22 11:22:06 euklides kernel: [    4.175329] NX-protecting the kernel data: 3288k
Feb 22 11:22:06 euklides kernel: [    4.201249] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
Feb 22 11:22:06 euklides kernel: [    4.219687] usbcore: registered new interface driver usbfs
Feb 22 11:22:06 euklides kernel: [    4.219713] usbcore: registered new interface driver hub
Feb 22 11:22:06 euklides kernel: [    4.219775] SCSI subsystem initialized
Feb 22 11:22:06 euklides kernel: [    4.238740] atl1c 0000:02:00.0: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    4.248210] usbcore: registered new device driver usb
Feb 22 11:22:06 euklides kernel: [    4.248662] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Feb 22 11:22:06 euklides kernel: [    4.248714] ehci_hcd 0000:00:1a.7: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    4.248718] ehci_hcd 0000:00:1a.7: EHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.248744] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
Feb 22 11:22:06 euklides kernel: [    4.248779] ehci_hcd 0000:00:1a.7: debug port 1
Feb 22 11:22:06 euklides kernel: [    4.252673] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
Feb 22 11:22:06 euklides kernel: [    4.254343] libata version 3.00 loaded.
Feb 22 11:22:06 euklides kernel: [    4.259818] ehci_hcd 0000:00:1a.7: irq 19, io mem 0xd6704400
Feb 22 11:22:06 euklides kernel: [    4.264841] uhci_hcd: USB Universal Host Controller Interface driver
Feb 22 11:22:06 euklides kernel: [    4.269774] ACPI: Fan [FAN] (on)
Feb 22 11:22:06 euklides kernel: [    4.270998] thermal LNXTHERM:00: registered as thermal_zone0
Feb 22 11:22:06 euklides kernel: [    4.271002] ACPI: Thermal Zone [THRM] (52 C)
Feb 22 11:22:06 euklides kernel: [    4.276088] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
Feb 22 11:22:06 euklides kernel: [    4.276123] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Feb 22 11:22:06 euklides kernel: [    4.276126] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 22 11:22:06 euklides kernel: [    4.276128] usb usb1: Product: EHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.276130] usb usb1: Manufacturer: Linux 3.2.0-4-686-pae ehci_hcd
Feb 22 11:22:06 euklides kernel: [    4.276132] usb usb1: SerialNumber: 0000:00:1a.7
Feb 22 11:22:06 euklides kernel: [    4.276279] hub 1-0:1.0: USB hub found
Feb 22 11:22:06 euklides kernel: [    4.276285] hub 1-0:1.0: 4 ports detected
Feb 22 11:22:06 euklides kernel: [    4.276382] ata_piix 0000:00:1f.2: version 2.13
Feb 22 11:22:06 euklides kernel: [    4.276403] ata_piix 0000:00:1f.2: MAP [ P0 -- P1 -- ]
Feb 22 11:22:06 euklides kernel: [    4.364690] atl1c 0000:02:00.0: version 1.0.1.0-NAPI
Feb 22 11:22:06 euklides kernel: [    4.432043] ata_piix 0000:00:1f.2: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    4.432306] scsi0 : ata_piix
Feb 22 11:22:06 euklides kernel: [    4.432399] scsi1 : ata_piix
Feb 22 11:22:06 euklides kernel: [    4.433019] ata1: SATA max UDMA/133 cmd 0x5138 ctl 0x5154 bmdma 0x5110 irq 19
Feb 22 11:22:06 euklides kernel: [    4.433024] ata2: SATA max UDMA/133 cmd 0x5130 ctl 0x5150 bmdma 0x5118 irq 19
Feb 22 11:22:06 euklides kernel: [    4.433055] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
Feb 22 11:22:06 euklides kernel: [    4.588021] usb 1-2: new high-speed USB device number 2 using ehci_hcd
Feb 22 11:22:06 euklides kernel: [    4.588037] ata_piix 0000:00:1f.5: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    4.588273] scsi2 : ata_piix
Feb 22 11:22:06 euklides kernel: [    4.588339] scsi3 : ata_piix
Feb 22 11:22:06 euklides kernel: [    4.588890] ata3: SATA max UDMA/133 cmd 0x5128 ctl 0x514c bmdma 0x50f0 irq 19
Feb 22 11:22:06 euklides kernel: [    4.588895] ata4: SATA max UDMA/133 cmd 0x5120 ctl 0x5148 bmdma 0x50f8 irq 19
Feb 22 11:22:06 euklides kernel: [    4.588930] uhci_hcd 0000:00:1a.0: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    4.588934] uhci_hcd 0000:00:1a.0: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.588952] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 2
Feb 22 11:22:06 euklides kernel: [    4.588999] uhci_hcd 0000:00:1a.0: irq 16, io base 0x000050c0
Feb 22 11:22:06 euklides kernel: [    4.589039] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
Feb 22 11:22:06 euklides kernel: [    4.589042] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 22 11:22:06 euklides kernel: [    4.589044] usb usb2: Product: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.589046] usb usb2: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd
Feb 22 11:22:06 euklides kernel: [    4.589049] usb usb2: SerialNumber: 0000:00:1a.0
Feb 22 11:22:06 euklides kernel: [    4.589174] hub 2-0:1.0: USB hub found
Feb 22 11:22:06 euklides kernel: [    4.589179] hub 2-0:1.0: 2 ports detected
Feb 22 11:22:06 euklides kernel: [    4.589271] uhci_hcd 0000:00:1a.1: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    4.589276] uhci_hcd 0000:00:1a.1: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.589285] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 3
Feb 22 11:22:06 euklides kernel: [    4.589324] uhci_hcd 0000:00:1a.1: irq 21, io base 0x000050a0
Feb 22 11:22:06 euklides kernel: [    4.589356] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
Feb 22 11:22:06 euklides kernel: [    4.589359] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 22 11:22:06 euklides kernel: [    4.589362] usb usb3: Product: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.589364] usb usb3: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd
Feb 22 11:22:06 euklides kernel: [    4.589366] usb usb3: SerialNumber: 0000:00:1a.1
Feb 22 11:22:06 euklides kernel: [    4.589481] hub 3-0:1.0: USB hub found
Feb 22 11:22:06 euklides kernel: [    4.589486] hub 3-0:1.0: 2 ports detected
Feb 22 11:22:06 euklides kernel: [    4.589568] uhci_hcd 0000:00:1d.0: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    4.589572] uhci_hcd 0000:00:1d.0: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.589581] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
Feb 22 11:22:06 euklides kernel: [    4.589622] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00005080
Feb 22 11:22:06 euklides kernel: [    4.589657] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
Feb 22 11:22:06 euklides kernel: [    4.589659] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 22 11:22:06 euklides kernel: [    4.589662] usb usb4: Product: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.589664] usb usb4: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd
Feb 22 11:22:06 euklides kernel: [    4.589666] usb usb4: SerialNumber: 0000:00:1d.0
Feb 22 11:22:06 euklides kernel: [    4.589786] hub 4-0:1.0: USB hub found
Feb 22 11:22:06 euklides kernel: [    4.589791] hub 4-0:1.0: 2 ports detected
Feb 22 11:22:06 euklides kernel: [    4.589871] uhci_hcd 0000:00:1d.1: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    4.589875] uhci_hcd 0000:00:1d.1: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.589882] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 5
Feb 22 11:22:06 euklides kernel: [    4.589913] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00005060
Feb 22 11:22:06 euklides kernel: [    4.589946] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
Feb 22 11:22:06 euklides kernel: [    4.589949] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 22 11:22:06 euklides kernel: [    4.589952] usb usb5: Product: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.589954] usb usb5: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd
Feb 22 11:22:06 euklides kernel: [    4.589956] usb usb5: SerialNumber: 0000:00:1d.1
Feb 22 11:22:06 euklides kernel: [    4.590157] hub 5-0:1.0: USB hub found
Feb 22 11:22:06 euklides kernel: [    4.590161] hub 5-0:1.0: 2 ports detected
Feb 22 11:22:06 euklides kernel: [    4.590248] uhci_hcd 0000:00:1d.2: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    4.590252] uhci_hcd 0000:00:1d.2: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.590262] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 6
Feb 22 11:22:06 euklides kernel: [    4.590294] uhci_hcd 0000:00:1d.2: irq 16, io base 0x00005040
Feb 22 11:22:06 euklides kernel: [    4.590329] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
Feb 22 11:22:06 euklides kernel: [    4.590331] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 22 11:22:06 euklides kernel: [    4.590334] usb usb6: Product: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.590336] usb usb6: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd
Feb 22 11:22:06 euklides kernel: [    4.590338] usb usb6: SerialNumber: 0000:00:1d.2
Feb 22 11:22:06 euklides kernel: [    4.591199] hub 6-0:1.0: USB hub found
Feb 22 11:22:06 euklides kernel: [    4.591204] hub 6-0:1.0: 2 ports detected
Feb 22 11:22:06 euklides kernel: [    4.591307] uhci_hcd 0000:00:1d.3: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    4.591311] uhci_hcd 0000:00:1d.3: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.591321] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 7
Feb 22 11:22:06 euklides kernel: [    4.591364] uhci_hcd 0000:00:1d.3: irq 18, io base 0x00005020
Feb 22 11:22:06 euklides kernel: [    4.591405] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
Feb 22 11:22:06 euklides kernel: [    4.591408] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 22 11:22:06 euklides kernel: [    4.591410] usb usb7: Product: UHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.591412] usb usb7: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd
Feb 22 11:22:06 euklides kernel: [    4.591414] usb usb7: SerialNumber: 0000:00:1d.3
Feb 22 11:22:06 euklides kernel: [    4.591639] hub 7-0:1.0: USB hub found
Feb 22 11:22:06 euklides kernel: [    4.591644] hub 7-0:1.0: 2 ports detected
Feb 22 11:22:06 euklides kernel: [    4.591990] ehci_hcd 0000:00:1d.7: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    4.591995] ehci_hcd 0000:00:1d.7: EHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.592030] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 8
Feb 22 11:22:06 euklides kernel: [    4.592062] ehci_hcd 0000:00:1d.7: debug port 1
Feb 22 11:22:06 euklides kernel: [    4.595935] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
Feb 22 11:22:06 euklides kernel: [    4.595945] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xd6704000
Feb 22 11:22:06 euklides kernel: [    4.712018] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
Feb 22 11:22:06 euklides kernel: [    4.712066] usb usb8: New USB device found, idVendor=1d6b, idProduct=0002
Feb 22 11:22:06 euklides kernel: [    4.712068] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 22 11:22:06 euklides kernel: [    4.712071] usb usb8: Product: EHCI Host Controller
Feb 22 11:22:06 euklides kernel: [    4.712073] usb usb8: Manufacturer: Linux 3.2.0-4-686-pae ehci_hcd
Feb 22 11:22:06 euklides kernel: [    4.712075] usb usb8: SerialNumber: 0000:00:1d.7
Feb 22 11:22:06 euklides kernel: [    4.712216] hub 8-0:1.0: USB hub found
Feb 22 11:22:06 euklides kernel: [    4.712220] hub 8-0:1.0: 8 ports detected
Feb 22 11:22:06 euklides kernel: [    4.763154] ata1: SATA link down (SStatus 0 SControl 300)
Feb 22 11:22:06 euklides kernel: [    4.763180] Refined TSC clocksource calibration: 2294.508 MHz.
Feb 22 11:22:06 euklides kernel: [    4.763186] Switching to clocksource tsc
Feb 22 11:22:06 euklides kernel: [    4.908131] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Feb 22 11:22:06 euklides kernel: [    4.919145] ata3: SATA link down (SStatus 0 SControl 300)
Feb 22 11:22:06 euklides kernel: [    4.960395] ata2.00: ATA-8: TOSHIBA MK3276GSXN, GB001M, max UDMA/100
Feb 22 11:22:06 euklides kernel: [    4.960398] ata2.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 0/32)
Feb 22 11:22:06 euklides kernel: [    4.968321] ata2.00: configured for UDMA/100
Feb 22 11:22:06 euklides kernel: [    4.968435] scsi 1:0:0:0: Direct-Access     ATA      TOSHIBA MK3276GS GB00 PQ: 0 ANSI: 5
Feb 22 11:22:06 euklides kernel: [    5.064058] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Feb 22 11:22:06 euklides kernel: [    5.072155] ata4.00: ATAPI: MATSHITADVD-RAM UJ890AS, 1.40, max UDMA/100
Feb 22 11:22:06 euklides kernel: [    5.088156] ata4.00: configured for UDMA/100
Feb 22 11:22:06 euklides kernel: [    5.092138] scsi 3:0:0:0: CD-ROM            MATSHITA DVD-RAM UJ890AS  1.40 PQ: 0 ANSI: 5
Feb 22 11:22:06 euklides kernel: [    5.098678] sd 1:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
Feb 22 11:22:06 euklides kernel: [    5.098745] sd 1:0:0:0: [sda] Write Protect is off
Feb 22 11:22:06 euklides kernel: [    5.098749] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
Feb 22 11:22:06 euklides kernel: [    5.098769] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Feb 22 11:22:06 euklides kernel: [    5.102231] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
Feb 22 11:22:06 euklides kernel: [    5.102234] cdrom: Uniform CD-ROM driver Revision: 3.20
Feb 22 11:22:06 euklides kernel: [    5.102455] sr 3:0:0:0: Attached scsi CD-ROM sr0
Feb 22 11:22:06 euklides kernel: [    5.209255]  sda: sda1 sda2 sda3 < sda5 sda6 >
Feb 22 11:22:06 euklides kernel: [    5.209645] sd 1:0:0:0: [sda] Attached SCSI disk
Feb 22 11:22:06 euklides kernel: [    5.211748] sd 1:0:0:0: Attached scsi generic sg0 type 0
Feb 22 11:22:06 euklides kernel: [    5.211796] sr 3:0:0:0: Attached scsi generic sg1 type 5
Feb 22 11:22:06 euklides kernel: [    5.949008] usb 1-2: New USB device found, idVendor=10f1, idProduct=1a2a
Feb 22 11:22:06 euklides kernel: [    5.949012] usb 1-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
Feb 22 11:22:06 euklides kernel: [    5.949014] usb 1-2: Product: USB Camera
Feb 22 11:22:06 euklides kernel: [    5.949016] usb 1-2: Manufacturer: Generic
Feb 22 11:22:06 euklides kernel: [    5.949018] usb 1-2: SerialNumber: MU418ASA
Feb 22 11:22:06 euklides kernel: [    6.072017] usb 1-3: new high-speed USB device number 3 using ehci_hcd
Feb 22 11:22:06 euklides kernel: [    6.098483] PM: Starting manual resume from disk
Feb 22 11:22:06 euklides kernel: [    6.098487] PM: Hibernation image partition 8:5 present
Feb 22 11:22:06 euklides kernel: [    6.098489] PM: Looking for hibernation image.
Feb 22 11:22:06 euklides kernel: [    6.107766] PM: Image not found (code -22)
Feb 22 11:22:06 euklides kernel: [    6.107768] PM: Hibernation image not present or could not be loaded.
Feb 22 11:22:06 euklides kernel: [    6.120348] EXT4-fs (sda6): INFO: recovery required on readonly filesystem
Feb 22 11:22:06 euklides kernel: [    6.120352] EXT4-fs (sda6): write access will be enabled during recovery
Feb 22 11:22:06 euklides kernel: [    6.176156] EXT4-fs (sda6): recovery complete
Feb 22 11:22:06 euklides kernel: [    6.176579] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
Feb 22 11:22:06 euklides kernel: [    6.463511] usb 1-3: New USB device found, idVendor=0bda, idProduct=0138
Feb 22 11:22:06 euklides kernel: [    6.463515] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb 22 11:22:06 euklides kernel: [    6.463517] usb 1-3: Product: USB2.0-CRW
Feb 22 11:22:06 euklides kernel: [    6.463519] usb 1-3: Manufacturer: Generic
Feb 22 11:22:06 euklides kernel: [    6.463521] usb 1-3: SerialNumber: 20090516388200000
Feb 22 11:22:06 euklides kernel: [    6.892016] usb 4-1: new low-speed USB device number 2 using uhci_hcd
Feb 22 11:22:06 euklides kernel: [    7.067663] usb 4-1: New USB device found, idVendor=0458, idProduct=00f7
Feb 22 11:22:06 euklides kernel: [    7.067667] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Feb 22 11:22:06 euklides kernel: [    7.067669] usb 4-1: Product: 2.4G Wireless Mouse
Feb 22 11:22:06 euklides kernel: [    7.067671] usb 4-1: Manufacturer: Genius
Feb 22 11:22:06 euklides kernel: [    9.338770] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
Feb 22 11:22:06 euklides kernel: [    9.338776] ACPI: Power Button [PWRB]
Feb 22 11:22:06 euklides kernel: [    9.338831] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
Feb 22 11:22:06 euklides kernel: [    9.342427] ACPI: Lid Switch [LID0]
Feb 22 11:22:06 euklides kernel: [    9.342516] ACPI: Requesting acpi_cpufreq
Feb 22 11:22:06 euklides kernel: [    9.342770] Monitor-Mwait will be used to enter C-1 state
Feb 22 11:22:06 euklides kernel: [    9.342777] Monitor-Mwait will be used to enter C-2 state
Feb 22 11:22:06 euklides kernel: [    9.342781] Marking TSC unstable due to TSC halts in idle
Feb 22 11:22:06 euklides kernel: [    9.342787] ACPI: acpi_idle registered with cpuidle
Feb 22 11:22:06 euklides kernel: [    9.343437] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
Feb 22 11:22:06 euklides kernel: [    9.343443] ACPI: Power Button [PWRF]
Feb 22 11:22:06 euklides kernel: [    9.344499] Switching to clocksource hpet
Feb 22 11:22:06 euklides kernel: [    9.392663] input: PC Speaker as /devices/platform/pcspkr/input/input4
Feb 22 11:22:06 euklides kernel: [    9.429212] ACPI: Battery Slot [BAT0] (battery present)
Feb 22 11:22:06 euklides kernel: [    9.429327] ACPI: AC Adapter [ADP0] (off-line)
Feb 22 11:22:06 euklides kernel: [    9.652961] cfg80211: Calling CRDA to update world regulatory domain
Feb 22 11:22:06 euklides kernel: [    9.703208] ath9k 0000:03:00.0: power state changed by ACPI to D0
Feb 22 11:22:06 euklides kernel: [    9.703220] ath9k 0000:03:00.0: power state changed by ACPI to D0
Feb 22 11:22:06 euklides kernel: [    9.703244] ath9k 0000:03:00.0: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [    9.747440] toshiba_acpi: Toshiba Laptop ACPI Extras version 0.19
Feb 22 11:22:06 euklides kernel: [    9.748693] input: Toshiba input device as /devices/virtual/input/input5
Feb 22 11:22:06 euklides kernel: [    9.756295] ath: EEPROM regdomain: 0x65
Feb 22 11:22:06 euklides kernel: [    9.756297] ath: EEPROM indicates we should expect a direct regpair map
Feb 22 11:22:06 euklides kernel: [    9.756301] ath: Country alpha2 being used: 00
Feb 22 11:22:06 euklides kernel: [    9.756302] ath: Regpair used: 0x65
Feb 22 11:22:06 euklides kernel: [    9.761719] Registered led device: toshiba::illumination
Feb 22 11:22:06 euklides kernel: [    9.807808] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Feb 22 11:22:06 euklides kernel: [    9.808393] Registered led device: ath9k-phy0
Feb 22 11:22:06 euklides kernel: [    9.808399] ieee80211 phy0: Atheros AR9285 Rev:2 mem=0xf8700000, irq=17
Feb 22 11:22:06 euklides kernel: [   10.086291] iTCO_vendor_support: vendor-support=0
Feb 22 11:22:06 euklides kernel: [   10.095710] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
Feb 22 11:22:06 euklides kernel: [   10.095819] iTCO_wdt: Found a ICH9M TCO device (Version=2, TCOBASE=0x0460)
Feb 22 11:22:06 euklides kernel: [   10.096341] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Feb 22 11:22:06 euklides kernel: [   10.293500] snd_hda_intel 0000:00:1b.0: irq 43 for MSI/MSI-X
Feb 22 11:22:06 euklides kernel: [   10.293536] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [   10.382507] [drm] Initialized drm 1.1.0 20060810
Feb 22 11:22:06 euklides kernel: [   10.485885] psmouse serio1: synaptics: Touchpad model: 1, fw: 7.2, id: 0x1c0b1, caps: 0xd04733/0xa40000/0xa0000
Feb 22 11:22:06 euklides kernel: [   10.485893] psmouse serio1: synaptics: Toshiba Satellite C650 detected, limiting rate to 40pps.
Feb 22 11:22:06 euklides kernel: [   10.558496] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input6
Feb 22 11:22:06 euklides kernel: [   10.704272] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input7
Feb 22 11:22:06 euklides kernel: [   10.706107] i915 0000:00:02.0: setting latency timer to 64
Feb 22 11:22:06 euklides kernel: [   10.733523] i915 0000:00:02.0: irq 44 for MSI/MSI-X
Feb 22 11:22:06 euklides kernel: [   10.733530] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
Feb 22 11:22:06 euklides kernel: [   10.733532] [drm] Driver supports precise vblank timestamp query.
Feb 22 11:22:06 euklides kernel: [   10.733570] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem :o wns=io+mem
Feb 22 11:22:06 euklides kernel: [   11.098204] cfg80211: World regulatory domain updated:
Feb 22 11:22:06 euklides kernel: [   11.098208] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Feb 22 11:22:06 euklides kernel: [   11.098211] cfg80211:     (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Feb 22 11:22:06 euklides kernel: [   11.098214] cfg80211:     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Feb 22 11:22:06 euklides kernel: [   11.098217] cfg80211:     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Feb 22 11:22:06 euklides kernel: [   11.098220] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Feb 22 11:22:06 euklides kernel: [   11.098222] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Feb 22 11:22:06 euklides kernel: [   11.234538] fbcon: inteldrmfb (fb0) is primary device
Feb 22 11:22:06 euklides kernel: [   11.456309] Console: switching to colour frame buffer device 170x48
Feb 22 11:22:06 euklides kernel: [   11.460384] fb0: inteldrmfb frame buffer device
Feb 22 11:22:06 euklides kernel: [   11.460386] drm: registered panic notifier
Feb 22 11:22:06 euklides kernel: [   11.461873] acpi device:03: registered as cooling_device3
Feb 22 11:22:06 euklides kernel: [   11.462005] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8
Feb 22 11:22:06 euklides kernel: [   11.462057] ACPI: Video Device [OVGA] (multi-head: yes  rom: no  post: no)
Feb 22 11:22:06 euklides kernel: [   11.462087] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
Feb 22 11:22:06 euklides kernel: [   11.674153] Linux media interface: v0.10
Feb 22 11:22:06 euklides kernel: [   11.714012] Initializing USB Mass Storage driver...
Feb 22 11:22:06 euklides kernel: [   11.714098] usbcore: registered new interface driver usb-storage
Feb 22 11:22:06 euklides kernel: [   11.714100] USB Mass Storage support registered.
Feb 22 11:22:06 euklides kernel: [   11.761117] input: Genius 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:1d.0/usb4/4-1/4-1:1.0/input/input9
Feb 22 11:22:06 euklides kernel: [   11.761248] generic-usb 0003:0458:00F7.0001: input,hidraw0: USB HID v1.00 Mouse [Genius 2.4G Wireless Mouse] on usb-0000:00:1d.0-1/input0
Feb 22 11:22:06 euklides kernel: [   11.761273] usbcore: registered new interface driver usbhid
Feb 22 11:22:06 euklides kernel: [   11.761275] usbhid: USB HID core driver
Feb 22 11:22:06 euklides kernel: [   11.765782] usb 1-3: USB disconnect, device number 3
Feb 22 11:22:06 euklides kernel: [   11.768695] scsi4 : usb-storage 1-3:1.0
Feb 22 11:22:06 euklides kernel: [   11.768804] usbcore: registered new interface driver ums-realtek
Feb 22 11:22:06 euklides kernel: [   11.917125] Linux video capture interface: v2.00
Feb 22 11:22:06 euklides kernel: [   11.993534] uvcvideo: Found UVC 1.00 device USB Camera (10f1:1a2a)
Feb 22 11:22:06 euklides kernel: [   12.010538] input: USB Camera as /devices/pci0000:00/0000:00:1a.7/usb1/1-2/1-2:1.0/input/input10
Feb 22 11:22:06 euklides kernel: [   12.010642] usbcore: registered new interface driver uvcvideo
Feb 22 11:22:06 euklides kernel: [   12.010644] USB Video Class driver (1.1.1)
Feb 22 11:22:06 euklides kernel: [   14.846722] Adding 2096716k swap on /dev/sda5.  Priority:-1 extents:1 across:2096716k
Feb 22 11:22:06 euklides kernel: [   14.871913] EXT4-fs (sda6): re-mounted. Opts: (null)
Feb 22 11:22:06 euklides kernel: [   15.142238] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 22 11:22:06 euklides kernel: [   15.329358] loop: module loaded
Feb 22 11:22:06 euklides kernel: [   16.882290] RPC: Registered named UNIX socket transport module.
Feb 22 11:22:06 euklides kernel: [   16.882293] RPC: Registered udp transport module.
Feb 22 11:22:06 euklides kernel: [   16.882295] RPC: Registered tcp transport module.
Feb 22 11:22:06 euklides kernel: [   16.882297] RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb 22 11:22:06 euklides kernel: [   16.953475] FS-Cache: Loaded
Feb 22 11:22:06 euklides kernel: [   17.013605] FS-Cache: Netfs 'nfs' registered for caching
Feb 22 11:22:06 euklides kernel: [   17.026839] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Feb 22 11:22:07 euklides kernel: [   18.944974] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input11
Feb 22 11:22:09 euklides kernel: [   21.553885] Bluetooth: Core ver 2.16
Feb 22 11:22:09 euklides kernel: [   21.553912] NET: Registered protocol family 31
Feb 22 11:22:09 euklides kernel: [   21.553914] Bluetooth: HCI device and connection manager initialized
Feb 22 11:22:09 euklides kernel: [   21.553917] Bluetooth: HCI socket layer initialized
Feb 22 11:22:09 euklides kernel: [   21.553919] Bluetooth: L2CAP socket layer initialized
Feb 22 11:22:09 euklides kernel: [   21.553925] Bluetooth: SCO socket layer initialized
Feb 22 11:22:09 euklides kernel: [   21.589570] Bluetooth: RFCOMM TTY layer initialized
Feb 22 11:22:09 euklides kernel: [   21.589576] Bluetooth: RFCOMM socket layer initialized
Feb 22 11:22:09 euklides kernel: [   21.589578] Bluetooth: RFCOMM ver 1.11
Feb 22 11:22:10 euklides kernel: [   21.695037] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Feb 22 11:22:10 euklides kernel: [   21.695040] Bluetooth: BNEP filters: protocol multicast
Feb 22 11:22:14 euklides kernel: [   25.075680] atl1c 0000:02:00.0: irq 45 for MSI/MSI-X
Feb 22 11:22:15 euklides kernel: [   26.689992] ADDRCONF(NETDEV_UP): eth0: link is not ready
Feb 22 11:22:15 euklides kernel: [   26.743234] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Feb 22 11:22:16 euklides kernel: [   27.707854] lp: driver loaded but no devices found
Feb 22 11:22:16 euklides kernel: [   27.760968] ppdev: user-space parallel port driver
Feb 22 11:22:17 euklides kernel: [   29.346779] wlan0: authenticate with d8:5d:4c:f5:5b:f4 (try 1)
Feb 22 11:22:17 euklides kernel: [   29.348723] wlan0: authenticated
Feb 22 11:22:17 euklides kernel: [   29.378308] wlan0: associate with d8:5d:4c:f5:5b:f4 (try 1)
Feb 22 11:22:17 euklides kernel: [   29.380866] wlan0: RX AssocResp from d8:5d:4c:f5:5b:f4 (capab=0x431 status=0 aid=1)
Feb 22 11:22:17 euklides kernel: [   29.380869] wlan0: associated
Feb 22 11:22:17 euklides kernel: [   29.381251] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Feb 22 11:22:28 euklides kernel: [   40.160030] wlan0: no IPv6 routers presentnot be reserved
Co tu robić, aby Debian startował normalnie? Miałem jeszcze problem AHCI -> IDE w BIOS. Poprzez AHCI nie startował Debian.
A mógłbyś powyciągać z tego te błędy, albo je pogrubić, bo nie chce mi się tego analizować linijka po linijce i dochodzić co jest błędem, a co normalnym komunikatem.
taxiarz
Proszę wyłuskałem errory:
root@euklides:/home/rafal# cat /var/log/kern.log | grep error
Feb 21 20:17:23 euklides kernel: [   14.770197] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 21 20:19:03 euklides kernel: [   14.943930] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 21 22:52:40 euklides kernel: [ 9235.016066] usb 2-3: device not accepting address 15, error -71
Feb 21 22:52:40 euklides kernel: [ 9235.656049] usb 2-3: device not accepting address 16, error -71
Feb 21 23:36:28 euklides kernel: [11862.679617] colord-sane[8665]: segfault at 4 ip b4df4472 sp b5614fb8 error 6 in libdbus-1.so.3.7.2[b4dc9000+49000]
Feb 21 23:37:11 euklides kernel: [   14.875646] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 21 23:38:27 euklides kernel: [   15.344566] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 21 23:50:30 euklides kernel: [   14.583581] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 22 07:10:19 euklides kernel: [   14.659517] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 22 08:19:36 euklides kernel: [ 4175.355690] option: option_instat_callback: error -108
Feb 22 09:07:39 euklides kernel: [   14.613221] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 22 09:08:48 euklides kernel: [   14.823871] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 22 11:20:45 euklides kernel: [   14.827031] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 22 11:41:34 euklides kernel: [ 1185.897041] colord-sane[3319]: segfault at 34 ip b5dff472 sp b4e13fb8 error 6 in libdbus-1.so.3.7.2[b5dd4000+49000]
Feb 22 11:43:57 euklides kernel: [   14.546901] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 22 11:47:33 euklides kernel: [   15.046379] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 22 12:04:07 euklides kernel: [   14.719749] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
Feb 22 12:07:06 euklides kernel: [  197.557577] colord-sane[3385]: segfault at 7c ip b6153472 sp b4ea6fb8 error 6 in libdbus-1.so.3.7.2[b6128000+49000]
Feb 22 16:21:19 euklides kernel: [   14.552049] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
cat /etc/fstab
root@euklides:/home/rafal# cat /etc/fstab
UUID=9f4bce15-1fd8-43ea-bae9-56acf7072d6c /               ext4    errors=remount-ro 0       1
UUID=c476fa17-26c4-4e82-8589-907a775df130 none            swap    sw              0       0
/dev/sr0        /media/cdrom0   udf,iso9660 user,noauto     0       0
root@euklides:/home/rafal# fsck -n /dev/sda6
fsck z pakietu util-linux 2.20.1
e2fsck 1.42.5 (29-Jul-2012)
Warning!  /dev/sda6 is mounted.
Uwaga: pominięto odtwarzanie z kroniki z powodu sprawdzania w trybie tylko
do odczytu.
/dev/sda6: czysty, 168566/12132352 plików, 2047295/48510720 bloków
root@euklides:/home/rafal# uname -a
Linux euklides 3.2.0-4-686-pae #1 SMP Debian 3.2.54-2 i686 GNU/Linux
root@euklides:/home/rafal# tail -n 30 /var/log/kern.log
Feb 23 23:42:58 euklides kernel: [   15.887012] RPC: Registered tcp transport module.
Feb 23 23:42:58 euklides kernel: [   15.887014] RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb 23 23:42:58 euklides kernel: [   15.951684] FS-Cache: Loaded
Feb 23 23:42:58 euklides kernel: [   16.001029] FS-Cache: Netfs 'nfs' registered for caching
Feb 23 23:42:58 euklides kernel: [   16.009691] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Feb 23 23:42:59 euklides kernel: [   18.112230] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input11
Feb 23 23:43:06 euklides kernel: [   23.698234] atl1c 0000:02:00.0: irq 45 for MSI/MSI-X
Feb 23 23:43:06 euklides kernel: [   24.975118] sched: RT throttling activated
Feb 23 23:43:06 euklides kernel: [   25.058123] ADDRCONF(NETDEV_UP): eth0: link is not ready
Feb 23 23:43:06 euklides kernel: [   25.109770] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Feb 23 23:43:06 euklides kernel: [   25.570557] lp: driver loaded but no devices found
Feb 23 23:43:07 euklides kernel: [   25.715285] Bluetooth: Core ver 2.16
Feb 23 23:43:07 euklides kernel: [   25.715311] NET: Registered protocol family 31
Feb 23 23:43:07 euklides kernel: [   25.715313] Bluetooth: HCI device and connection manager initialized
Feb 23 23:43:07 euklides kernel: [   25.715316] Bluetooth: HCI socket layer initialized
Feb 23 23:43:07 euklides kernel: [   25.715318] Bluetooth: L2CAP socket layer initialized
Feb 23 23:43:07 euklides kernel: [   25.715325] Bluetooth: SCO socket layer initialized
Feb 23 23:43:07 euklides kernel: [   25.764230] Bluetooth: RFCOMM TTY layer initialized
Feb 23 23:43:07 euklides kernel: [   25.764235] Bluetooth: RFCOMM socket layer initialized
Feb 23 23:43:07 euklides kernel: [   25.764237] Bluetooth: RFCOMM ver 1.11
Feb 23 23:43:07 euklides kernel: [   25.835340] ppdev: user-space parallel port driver
Feb 23 23:43:07 euklides kernel: [   26.041224] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Feb 23 23:43:07 euklides kernel: [   26.041228] Bluetooth: BNEP filters: protocol multicast
Feb 23 23:43:09 euklides kernel: [   28.118138] wlan0: authenticate with d8:5d:4c:f5:5b:f4 (try 1)
Feb 23 23:43:09 euklides kernel: [   28.119982] wlan0: authenticated
Feb 23 23:43:09 euklides kernel: [   28.139615] wlan0: associate with d8:5d:4c:f5:5b:f4 (try 1)
Feb 23 23:43:09 euklides kernel: [   28.142168] wlan0: RX AssocResp from d8:5d:4c:f5:5b:f4 (capab=0x431 status=0 aid=1)
Feb 23 23:43:09 euklides kernel: [   28.142172] wlan0: associated
Feb 23 23:43:09 euklides kernel: [   28.142550] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Feb 23 23:43:20 euklides kernel: [   39.520018] wlan0: no IPv6 routers present
root@euklides:/home/rafal# apt-get remove colord-sane
Budowanie drzewa zależności
E: Nie udało się odnaleźć pakietu colord-sane
Odmontuj jako root tą partycje, zamontuj ją w trybie rw (read write) i dopiero zrób fsck.
Albo uruchom live-cd linux i zrób spod niego sprawdzanie
taxiarz
Właśnie uruchomiłem SystemRescueCd i wykonałem fsck. Daje clean, czy 0. Po windowsem dałem Ashampoo HDD Control 96% zdrowia dysku.
No ale po co ze zródeł robiłeś hplip? Przepakietywałeś czy jak to robiłeś? Widocznie to jakoś ostro namieszało.
A skąd pobrałeś żródła hplip?
Wesz Ci sami ludzie siędzą na DUG i DPL :)
taxiarz
Ze źródel instalowałem, bo to z Debiana pisało, że kabel USB uszkodzony. Leciałem wg. tego http://hplipopensource.com/hplip-web/in ... ebian.html
Teraz wg tej instrukcji drukarka działa. Ten pakiet z Debiana nie działał. Zrobiłem fsck na live cd. Wyniki:
root@sysresccd / % fsck -c /dev/sda6
fsck from util-linux 2.22.2
e2fsck 1.42.8 (20-Jun-2013)
Checking for bad blocks (read-only test):   0.00% done, 0:00 elapsed. (0/0/0 errdone
/dev/sda6: Updating bad block inode.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/sda6: ***** FILE SYSTEM WAS MODIFIED *****
/dev/sda6: 165731/12132352 files (0.2% non-contiguous), 2018257/48510720 blocks
root@sysresccd / %
Hplip nie miało nic do rzeczy, wcześniej też errory występowały po instalacji czytego systemu z netinstalla.
Już z 4 raz instaluje Debiana. Problematyczny jest x64, więc dałem x32 obraz.
Tak radził kolega od Slackware. Ubuntu 13.10 x64 działało mi bez problemów, ale kolega powiedział, że na Ubuntu
tylko naucze się klikać, jak na Windowsie. Więc postanowiłem Debiana zainstalować, bo ze Slackware sobie kompletnie
bym nie poradził.
Myślałem, że DUG, a forum debiana, to dwa różne fora, a nie odpowiadali mi na jednym i drugim, więc także napisałem na forum
ubuntu, to mnie wyganiali stamtąd.
Tak to dwa fora, ale wielu tych samych pisze i tu i tu jak ja. A dlaczego? Bo debian jest jeden, a że fora 2 to już nie mój problem. To ludzie twotrzą podziały.
Ja mam wiedzę i chce ją używać tzn pomagać innym. Więc nie ograniczam się do 1 forum i mnie podziały nie interesują.
taxiarz
fsck gruntowne nic nie pomogło, dalej system raz wstaje, raz nie. Podaje logi z /var/log/message
http://pastebin.com/BCh4gdvE
A jak wygląda to od sprzętowej strony? Nie siada płyta główna, dysk, zasilacz?
