Kdenlive-Problem z filmem
TDK8GB
Post autor: TDK8GB »
Witam!
Ostatnio ustawiłem renederowanie w Kdenlive z następującymi parametrami:
f=mov acodec=pcm_s16le ar=48000 ac=2 vcodec=libx264 s=1280x720 b=19700k trellis=1 minrate=0 g=250 b_strategy=1 subcmp=2 cmp=2 coder=1 flags=+loop flags2=dct8x8 qmax=51 subq=7 qmin=10 qcomp=0.6 qdiff=4 trellis=1 aspect=%dar pass=%passes pix_fmt=yuv420p
Na Linuxie wszystko jest ok. Na windowsie nie działa dźwięk. Jak to narpawić żeby dźwięk PCM działał?
Dodatkowo podam informacje z mediainfo:
GeneralCount                                    : 284
Count of stream of this kind             : 1
Kind of stream                           : General
Stream identifier                        : 0
Inform                                   : MPEG-4 (QuickTime): 1.22 GiB, 8mn 8s
Count of video streams                   : 1
Count of audio streams                   : 1
Video_Format_List                        : AVC
Video_Format_WithHint_List               : AVC
Codecs Video                             : AVC
Video_Language_List                      : English
Audio_Format_List                        : PCM
Audio_Format_WithHint_List               : PCM
Audio codecs                             : PCM
Audio_Language_List                      : English
Complete name                            : /media/kamil/ADATA/film.mov
Folder name                              : /media/kamil/ADATA
File name                                : film
File extension                           : mov
Format                                   : MPEG-4
Format                                   : MPEG-4
Format/Extensions usually used           : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
Commercial name                          : MPEG-4
Format profile                           : QuickTime
Internet media type                      : video/mp4
Codec ID                                 : qt
Codec ID/Url                             : http://www.apple.com/quicktime/download/standalone.html
Codec                                    : MPEG-4
Codec                                    : MPEG-4
Codec/Extensions usually used            : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
File size                                : 1315044920
File size                                : 1.22 GiB
File size                                : 1 GiB
File size                                : 1.2 GiB
File size                                : 1.225 GiB
Duration                                 : 488320
Duration                                 : 8mn 8s
Duration                                 : 8mn 8s 320ms
Duration                                 : 8mn 8s
Duration                                 : 00:08:08.320
Overall bit rate                         : 21543986
Overall bit rate                         : 21.5 Mbps
Stream size                              : 175604
Stream size                              : 171 KiB (0%)
Stream size                              : 171.5 KiB
Proportion of this stream                : 0.00013
HeaderSize                               : 28
DataSize                                 : 1314869324
FooterSize                               : 175568
IsStreamable                             : No
File last modification date              : UTC 2014-02-16 19:01:51
File last modification date (local)      : 2014-02-16 20:01:51
Writing application                      : Lavf54.20.3
Video
Count                                    : 272
Kind of stream                           : Video
StreamOrder                              : 0
Inform                                   : English, 20.0 Mbps, 1280*720 (16:9), at 23.976 fps, AVC (High@L4.1) (CABAC / 4 Ref Frames)
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format/Url                               : http://developers.videolan.org/x264.html
Commercial name                          : AVC
Format profile                           : High@L4.1
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4
Format settings, ReFrames                : 4 frames
Internet media type                      : video/H264
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Codec                                    : AVC
Codec                                    : AVC
Codec/Family                             : AVC
Codec/Info                               : Advanced Video Codec
Codec/Url                                : http://developers.videolan.org/x264.html
Codec/CC                                 : avc1
Codec profile                            : High@L4.1
Codec settings                           : CABAC / 4 Ref Frames
Codec settings, CABAC                    : Yes
Codec_Settings_RefFrames                 : 4
Duration                                 : 488113
Duration                                 : 8mn 8s
Duration                                 : 8mn 8s 113ms
Duration                                 : 8mn 8s
Duration                                 : 00:08:08.113
Bit rate                                 : 20000000
Bit rate                                 : 20.0 Mbps
Width                                    : 1280
Width                                    : 1 280 pixels
Height                                   : 720
Height                                   : 720 pixels
Pixel aspect ratio                       : 1.000
Display aspect ratio                     : 1.778
Display aspect ratio                     : 16:9
Rotation                                 : 0.000
Frame rate mode                          : CFR
Frame rate mode                          : Constant
FrameRate_Mode_Original                  : VFR
Frame rate                               : 23.976
Frame rate                               : 23.976 fps
Frame count                              : 11703
Resolution                               : 8
Resolution                               : 8 bits
Colorimetry                              : 4:2:0
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8
Bit depth                                : 8 bits
Scan type                                : Progressive
Interlacement                            : PPF
Interlacement                            : Progressive
Bits/(Pixel*Frame)                       : 0.905
Stream size                              : 1221111876
Stream size                              : 1.14 GiB (93%)
Stream size                              : 1 GiB
Stream size                              : 1.1 GiB
Stream size                              : 1.137 GiB
Proportion of this stream                : 0.92857
Writing library                          : x264 - core 133 r2339 585324f
Writing library                          : x264 core 133 r2339 585324f
Writing library/Name                     : x264
Writing library/Version                  : core 133 r2339 585324f
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=2 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=20000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.25 / aq=1:1.00
Language                                 : en
Language                                 : English
Language                                 : English
Language                                 : en
Language                                 : eng
Language                                 : en
Audio
Count                                    : 222
Kind of stream                           : Audio
StreamOrder                              : 1
Inform                                   : English, 1 536 Kbps, 48.0 KHz, 16 bits, 2 channels, PCM (Little / Signed)
Format                                   : PCM
Commercial name                          : PCM
Format settings                          : Little / Signed
Format settings, Endianness              : Little
Format settings, Sign                    : Signed
Codec ID                                 : lpcm
Codec                                    : PCM
Codec                                    : PCM
Codec/Family                             : PCM
Codec/CC                                 : lpcm
Codec settings                           : Little / Signed
Codec settings, Endianness               : Little
Codec settings, Sign                     : Signed
Duration                                 : 488320
Duration                                 : 8mn 8s
Duration                                 : 8mn 8s
Bit rate mode                            : CBR
Bit rate mode                            : Constant
Bit rate                                 : 1536000
Bit rate                                 : 1 536 Kbps
Channel(s)                               : 2
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
ChannelLayout                            : L R
Sampling rate                            : 48000
Sampling rate                            : 48.0 KHz
Samples count                            : 23439360
Resolution                               : 16
Resolution                               : 16 bits
Bit depth                                : 16
Bit depth                                : 16 bits
Stream size                              : 93757440
Stream size                              : 89.4 MiB (7%)
Stream size                              : 89 MiB
Stream size                              : 89.41 MiB
Proportion of this stream                : 0.07130
Language                                 : en
Language                                 : English
Language                                 : English
Language                                 : en
Language                                 : eng
Language                                 : en
PS: Pozdrowienia dla ilina :D
