Jak ustawic xorg.conf dla dwoch monitorow (extended desktop). Ten sam obraz wyswietla mi sie na dwoch monitorach leczy gdy chce to zmienic w ustawieniach systemowych>Displays odznaczam "mirror displays" i wywala mi blad. Wywnioskowalem, ze musze zmienic max virtual screen tylko nie wiem jak to zmienic i gdzie.
Przepraszam za brak Polskich znakow. To moje poczatki z Linuxem (drugie podejscie) i zainstalowalem wersje angielsko jezyczna aby cwiczyc jezyk
Ponizej log :
fglrxinfo
display: :0 screen: 0OpenGL vendor string: Advanced Micro Devices, Inc.
OpenGL renderer string: ATI Radeon HD 5450
OpenGL version string: 4.2.11762 Compatibility Profile ContextKod: Zaznacz cały
Section "ServerLayout" Identifier "X.org Configured"
Screen 0 "aticonfig-Screen[0]-0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "built-ins"
EndSection
Section "Module"
Load "record"
Load "dri2"
Load "glx"
Load "dri"
Load "extmod"
Load "dbe"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Monitor"
Identifier "Monitor1"
EndSection
Section "Monitor"
Identifier "Monitor2"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-0"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
### <percent>: "<f>%"
### [arg]: arg optional
#Option "NoAccel" # [<bool>]
#Option "SWcursor" # [<bool>]
#Option "Dac6Bit" # [<bool>]
#Option "Dac8Bit" # [<bool>]
#Option "BusType" # [<str>]
#Option "CPPIOMode" # [<bool>]
#Option "CPusecTimeout" # <i>
#Option "AGPMode" # <i>
#Option "AGPFastWrite" # [<bool>]
#Option "AGPSize" # <i>
#Option "GARTSize" # <i>
#Option "RingSize" # <i>
#Option "BufferSize" # <i>
#Option "EnableDepthMoves" # [<bool>]
#Option "EnablePageFlip" # [<bool>]
#Option "NoBackBuffer" # [<bool>]
#Option "DMAForXv" # [<bool>]
#Option "FBTexPercent" # <i>
#Option "DepthBits" # <i>
#Option "PCIAPERSize" # <i>
#Option "AccelDFS" # [<bool>]
#Option "IgnoreEDID" # [<bool>]
#Option "CustomEDID" # [<str>]
#Option "DisplayPriority" # [<str>]
#Option "PanelSize" # [<str>]
#Option "ForceMinDotClock" # <freq>
#Option "ColorTiling" # [<bool>]
#Option "VideoKey" # <i>
#Option "RageTheatreCrystal" # <i>
#Option "RageTheatreTunerPort" # <i>
#Option "RageTheatreCompositePort" # <i>
#Option "RageTheatreSVideoPort" # <i>
#Option "TunerType" # <i>
#Option "RageTheatreMicrocPath" # <str>
#Option "RageTheatreMicrocType" # <str>
#Option "ScalerWidth" # <i>
#Option "RenderAccel" # [<bool>]
#Option "SubPixelOrder" # [<str>]
#Option "ClockGating" # [<bool>]
#Option "VGAAccess" # [<bool>]
#Option "ReverseDDC" # [<bool>]
#Option "LVDSProbePLL" # [<bool>]
#Option "AccelMethod" # <str>
#Option "DRI" # [<bool>]
#Option "ConnectorTable" # <str>
#Option "DefaultConnectorTable" # [<bool>]
#Option "DefaultTMDSPLL" # [<bool>]
#Option "TVDACLoadDetect" # [<bool>]
#Option "ForceTVOut" # [<bool>]
#Option "TVStandard" # <str>
#Option "IgnoreLidStatus" # [<bool>]
#Option "DefaultTVDACAdj" # [<bool>]
#Option "Int10" # [<bool>]
#Option "EXAVSync" # [<bool>]
#Option "ATOMTVOut" # [<bool>]
#Option "R4xxATOM" # [<bool>]
#Option "ForceLowPowerMode" # [<bool>]
#Option "DynamicPM" # [<bool>]
#Option "NewPLL" # [<bool>]
#Option "ZaphodHeads" # <str>
Identifier "Card0"
Driver "radeon"
BusID "PCI:7:0:0"
EndSection
Section "Device"
#Option "ShadowFB" # [<bool>]
#Option "Rotate" # <str>
#Option "fbdev" # <str>
#Option "debug" # [<bool>]
Identifier "Card1"
Driver "fbdev"
BusID "PCI:7:0:0"
EndSection
Section "Device"
#Option "DefaultRefresh" # [<bool>]
#Option "ModeSetClearScreen" # [<bool>]
Identifier "Card2"
Driver "vesa"
BusID "PCI:7:0:0"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
BusID "PCI:7:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Card1"
Monitor "Monitor1"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen2"
Device "Card2"
Monitor "Monitor2"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Screen 0: minimum 320 x 200, current 1280 x 1024, maximum 1920 x 1920DFP1 disconnected (normal left inverted right x axis y axis)
DFP2 disconnected (normal left inverted right x axis y axis)
CRT1 connected 1280x1024+0+0 (normal left inverted right x axis y axis) 338mm x 270mm
1280x1024 60.0*+ 75.0
1280x960 75.0 60.0
1152x864 75.0 60.0
1280x768 75.0 60.0
1280x720 75.0 60.0
1024x768 75.0 60.0
800x600 75.0 60.3
640x480 75.0 59.9
CRT2 connected 1280x1024+0+0 (normal left inverted right x axis y axis) 509mm x 286mm
1920x1080 60.0 +
1680x1050 60.0
1400x1050 60.0
1600x900 60.0
1280x1024 60.0*
1440x900 59.9
1280x960 60.0
1280x800 59.8
1152x864 60.0 75.0
1280x768 59.8
1280x720 59.8
1024x768 70.1 60.0
800x600 60.3 56.2
640x480 67.0 59.9 Kod: Zaznacz cały
[ 13.675] X.Org X Server 1.12.4
Release Date: 2012-08-27
[ 13.675] X Protocol Version 11, Revision 0
[ 13.675] Build Operating System: Linux 3.11-2-amd64 x86_64 Debian
[ 13.675] Current Operating System: Linux debian 3.2.0-4-amd64 #1 SMP Debian 3.2.51-1 x86_64
[ 13.675] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-amd64 root=UUID=5dd3ae90-76f3-455a-8742-6ec4f02db53a ro quiet
[ 13.675] Build Date: 17 December 2013 07:37:58PM
[ 13.675] xorg-server 2:1.12.4-6+deb7u2 (Julien Cristau <jcristau@debian.org>)
[ 13.676] Current version of pixman: 0.26.0
[ 13.676] Before reporting problems, check http://wiki.x.org
[ 13.676] Markers: (--) probed, (**) from config file, (==) default setting,
[ 13.676] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Feb 11 22:55:53 2014
[ 13.682] (==) Using config file: "/etc/X11/xorg.conf"
[ 13.682] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 13.684] (==) ServerLayout "X.org Configured"
[ 13.684] (**) |-->Screen "aticonfig-Screen[0]-0" (0)
[ 13.684] (**) | |-->Monitor "aticonfig-Monitor[0]-0"
[ 13.685] (**) | |-->Device "aticonfig-Device[0]-0"
[ 13.685] (**) |-->Input Device "Mouse0"
[ 13.685] (**) |-->Input Device "Keyboard0"
[ 13.685] (==) Automatically adding devices
[ 13.685] (==) Automatically enabling devices
[ 13.687] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 13.687] Entry deleted from font path.
[ 13.693] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 13.693] Entry deleted from font path.
[ 13.693] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 13.693] (**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins,
built-ins
[ 13.693] (**) ModulePath set to "/usr/lib/xorg/modules"
[ 13.693] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 13.693] (WW) Disabling Mouse0
[ 13.693] (WW) Disabling Keyboard0
[ 13.693] (II) Loader magic: 0x7fe81f660ae0
[ 13.693] (II) Module ABI versions:
[ 13.693] X.Org ANSI C Emulation: 0.4
[ 13.693] X.Org Video Driver: 12.1
[ 13.693] X.Org XInput driver : 16.0
[ 13.693] X.Org Server Extension : 6.0
[ 13.695] (--) PCI:*(0:7:0:0) 1002:68f9:1682:304a rev 0, Mem @ 0xc0000000/268435456, 0xfe620000/131072, I/O @ 0x0000b000/256, BIOS @ 0x????????/131072
[ 13.695] (II) Open ACPI successful (/var/run/acpid.socket)
[ 13.695] (II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
[ 13.695] (II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
[ 13.695] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[ 13.695] (II) "record" will be loaded. This was enabled by default and also specified in the config file.
[ 13.695] (II) "dri" will be loaded. This was enabled by default and also specified in the config file.
[ 13.695] (II) "dri2" will be loaded. This was enabled by default and also specified in the config file.
[ 13.695] (II) LoadModule: "record"
[ 13.709] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 13.710] (II) Module record: vendor="X.Org Foundation"
[ 13.710] compiled for 1.12.4, module version = 1.13.0
[ 13.710] Module class: X.Org Server Extension
[ 13.710] ABI class: X.Org Server Extension, version 6.0
[ 13.710] (II) Loading extension RECORD
[ 13.710] (II) LoadModule: "dri2"
[ 13.711] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 13.713] (II) Module dri2: vendor="X.Org Foundation"
[ 13.713] compiled for 1.12.4, module version = 1.2.0
[ 13.713] ABI class: X.Org Server Extension, version 6.0
[ 13.713] (II) Loading extension DRI2
[ 13.713] (II) LoadModule: "glx"
[ 13.713] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[ 13.718] (II) Module glx: vendor="Advanced Micro Devices, Inc."
[ 13.718] compiled for 6.9.0, module version = 1.0.0
[ 13.718] (II) Loading extension GLX
[ 13.718] (II) LoadModule: "dri"
[ 13.719] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 13.720] (II) Module dri: vendor="X.Org Foundation"
[ 13.720] compiled for 1.12.4, module version = 1.0.0
[ 13.720] ABI class: X.Org Server Extension, version 6.0
[ 13.720] (II) Loading extension XFree86-DRI
[ 13.720] (II) LoadModule: "extmod"
[ 13.720] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 13.722] (II) Module extmod: vendor="X.Org Foundation"
[ 13.722] compiled for 1.12.4, module version = 1.0.0
[ 13.722] Module class: X.Org Server Extension
[ 13.722] ABI class: X.Org Server Extension, version 6.0
[ 13.722] (II) Loading extension SELinux
[ 13.722] (II) Loading extension MIT-SCREEN-SAVER
[ 13.722] (II) Loading extension XFree86-VidModeExtension
[ 13.722] (II) Loading extension XFree86-DGA
[ 13.722] (II) Loading extension DPMS
[ 13.722] (II) Loading extension XVideo
[ 13.722] (II) Loading extension XVideo-MotionCompensation
[ 13.722] (II) Loading extension X-Resource
[ 13.722] (II) LoadModule: "dbe"
[ 13.723] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 13.724] (II) Module dbe: vendor="X.Org Foundation"
[ 13.724] compiled for 1.12.4, module version = 1.0.0
[ 13.724] Module class: X.Org Server Extension
[ 13.724] ABI class: X.Org Server Extension, version 6.0
[ 13.724] (II) Loading extension DOUBLE-BUFFER
[ 13.724] (II) LoadModule: "fglrx"
[ 13.724] (II) Loading /usr/lib/xorg/modules/drivers/fglrx_drv.so
[ 13.806] (II) Module fglrx: vendor="FireGL - AMD Technologies Inc."
[ 13.806] compiled for 1.4.99.906, module version = 8.98.2
[ 13.806] Module class: X.Org Video Driver
[ 13.807] (II) Loading sub module "fglrxdrm"
[ 13.807] (II) LoadModule: "fglrxdrm"
[ 13.807] (II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
[ 13.812] (II) Module fglrxdrm: vendor="FireGL - AMD Technologies Inc."
[ 13.812] compiled for 1.4.99.906, module version = 8.98.2
[ 13.812] (II) AMD Proprietary Linux Driver Version Identifier:8.98.2
[ 13.812] (II) AMD Proprietary Linux Driver Release Identifier: 8.982.13
[ 13.812] (II) AMD Proprietary Linux Driver Build Date: Jul 19 2012 20:59:44
[ 13.812] (++) using VT number 7
[ 13.821] (WW) Falling back to old probe method for fglrx
[ 13.833] (II) Loading PCS database from /etc/ati/amdpcsdb
[ 13.836] (--) Chipset Supported AMD Graphics Processor (0x68F9) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:0:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:2:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:4:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:5:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:6:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:7:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:17:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:18:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:18:2) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:2) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:2) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:3) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:4) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:5) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:21:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:22:0) found
[ 13.837] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:22:2) found
[ 13.838] (WW) fglrx: No matching Device section for instance (BusID PCI:0@7:0:1) found
[ 13.840] (II) AMD Video driver is running on a device belonging to a group targeted for this release
[ 13.840] (II) AMD Video driver is signed
[ 13.841] (II) fglrx(0): pEnt->device->identifier=0x7fe81fd77a60
[ 13.841] (II) fglrx(0): === [xdl_xs112_atiddxPreInit] === begin
[ 13.841] (II) Loading sub module "vgahw"
[ 13.841] (II) LoadModule: "vgahw"
[ 13.843] (II) Loading /usr/lib/xorg/modules/libvgahw.so
[ 13.844] (II) Module vgahw: vendor="X.Org Foundation"
[ 13.844] compiled for 1.12.4, module version = 0.1.0
[ 13.844] ABI class: X.Org Video Driver, version 12.1
[ 13.844] (**) fglrx(0): Depth 24, (--) framebuffer bpp 32
[ 13.844] (II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 13.844] (==) fglrx(0): Default visual is TrueColor
[ 13.844] (**) fglrx(0): Option "DPMS" "true"
[ 13.844] (==) fglrx(0): RGB weight 888
[ 13.844] (II) fglrx(0): Using 8 bits per RGB
[ 13.844] (==) fglrx(0): Buffer Tiling is ON
[ 13.845] (II) Loading sub module "fglrxdrm"
[ 13.845] (II) LoadModule: "fglrxdrm"
[ 13.845] (II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
[ 13.845] (II) Module fglrxdrm: vendor="FireGL - AMD Technologies Inc."
[ 13.845] compiled for 1.4.99.906, module version = 8.98.2
[ 13.848] ukiDynamicMajor: found major device number 250
[ 13.848] ukiOpenByBusid: Searching for BusID PCI:7:0:0
[ 13.848] ukiOpenDevice: node name is /dev/ati/card0
[ 13.848] ukiOpenDevice: open result is 12, (OK)
[ 13.848] ukiOpenByBusid: ukiOpenMinor returns 12
[ 13.848] ukiOpenByBusid: ukiGetBusid reports PCI:7:0:0
[ 13.849] (**) fglrx(0): NoAccel = NO
[ 13.849] (**) fglrx(0): AMD 2D Acceleration Architecture enabled
[ 13.849] (--) fglrx(0): Chipset: "ATI Radeon HD 5450" (Chipset = 0x68f9)
[ 13.849] (--) fglrx(0): (PciSubVendor = 0x1682, PciSubDevice = 0x304a)
[ 13.849] (==) fglrx(0): board vendor info: third party graphics adapter - NOT original AMD
[ 13.849] (--) fglrx(0): Linear framebuffer (phys) at 0xc0000000
[ 13.849] (--) fglrx(0): MMIO registers at 0xfe620000
[ 13.849] (--) fglrx(0): I/O port at 0x0000b000
[ 13.849] (==) fglrx(0): ROM-BIOS at 0x000c0000
[ 13.851] (II) fglrx(0): AC Adapter is used
[ 13.866] (II) fglrx(0): Primary V_BIOS segment is: 0xc000
[ 14.029] (II) Loading sub module "vbe"
[ 14.029] (II) LoadModule: "vbe"
[ 14.030] (II) Loading /usr/lib/xorg/modules/libvbe.so
[ 14.031] (II) Module vbe: vendor="X.Org Foundation"
[ 14.031] compiled for 1.12.4, module version = 1.1.0
[ 14.031] ABI class: X.Org Video Driver, version 12.1
[ 14.032] (II) fglrx(0): VESA BIOS detected
[ 14.032] (II) fglrx(0): VESA VBE Version 3.0
[ 14.032] (II) fglrx(0): VESA VBE Total Mem: 16384 kB
[ 14.032] (II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
[ 14.032] (II) fglrx(0): VESA VBE OEM Software Rev: 12.20
[ 14.032] (II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
[ 14.032] (II) fglrx(0): VESA VBE OEM Product: CEDAR
[ 14.032] (II) fglrx(0): VESA VBE OEM Product Rev: 01.00
[ 14.066] (II) fglrx(0): AMD Video BIOS revision 9 or later detected
[ 14.066] (--) fglrx(0): Video RAM: 1048576 kByte, Type: DDR3
[ 14.066] (II) fglrx(0): PCIE card detected
[ 14.066] (--) fglrx(0): Using per-process page tables (PPPT) as GART.
[ 14.066] (WW) fglrx(0): board is an unknown third party board, chipset is supported
[ 14.069] (II) fglrx(0): Using adapter: 7:0.0.
[ 14.094] (II) fglrx(0): [FB] MC range(MCFBBase = 0xf00000000, MCFBSize = 0x40000000)
[ 14.226] (II) fglrx(0): Interrupt handler installed at IRQ 89.
[ 14.226] (II) fglrx(0): RandR 1.2 support is enabled!
[ 14.226] (II) fglrx(0): RandR 1.2 rotation support is enabled!
[ 14.226] (==) fglrx(0): Center Mode is disabled
[ 14.226] (II) Loading sub module "fb"
[ 14.226] (II) LoadModule: "fb"
[ 14.227] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 14.229] (II) Module fb: vendor="X.Org Foundation"
[ 14.229] compiled for 1.12.4, module version = 1.0.0
[ 14.229] ABI class: X.Org ANSI C Emulation, version 0.4
[ 14.229] (II) Loading sub module "ddc"
[ 14.229] (II) LoadModule: "ddc"
[ 14.229] (II) Module "ddc" already built-in
[ 14.358] (II) fglrx(0): Finished Initialize PPLIB!
[ 14.360] (II) fglrx(0): Output DFP1 using monitor section aticonfig-Monitor[0]-0
[ 14.360] (II) fglrx(0): Output DFP2 has no monitor section
[ 14.360] (II) fglrx(0): Output CRT1 has no monitor section
[ 14.360] (II) fglrx(0): Output CRT2 has no monitor section
[ 14.360] (II) Loading sub module "ddc"
[ 14.360] (II) LoadModule: "ddc"
[ 14.360] (II) Module "ddc" already built-in
[ 14.360] (II) fglrx(0): Connected Display0: CRT1
[ 14.360] (II) fglrx(0): Display0 EDID data ---------------------------
[ 14.360] (II) fglrx(0): Manufacturer: DEL Model: a015 Serial#: 825576012
[ 14.360] (II) fglrx(0): Year: 2006 Week: 16
[ 14.360] (II) fglrx(0): EDID Version: 1.3
[ 14.360] (II) fglrx(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 14.360] (II) fglrx(0): Sync: Separate
[ 14.360] (II) fglrx(0): Max Image Size [cm]: horiz.: 34 vert.: 27
[ 14.360] (II) fglrx(0): Gamma: 2.20
[ 14.360] (II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 14.360] (II) fglrx(0): Default color space is primary color space
[ 14.360] (II) fglrx(0): First detailed timing is preferred mode
[ 14.360] (II) fglrx(0): redX: 0.640 redY: 0.340 greenX: 0.279 greenY: 0.619
[ 14.360] (II) fglrx(0): blueX: 0.140 blueY: 0.069 whiteX: 0.310 whiteY: 0.330
[ 14.361] (II) fglrx(0): Supported established timings:
[ 14.361] (II) fglrx(0): 720x400@70Hz
[ 14.361] (II) fglrx(0): 640x480@60Hz
[ 14.361] (II) fglrx(0): 640x480@75Hz
[ 14.361] (II) fglrx(0): 800x600@60Hz
[ 14.361] (II) fglrx(0): 800x600@75Hz
[ 14.361] (II) fglrx(0): 1024x768@60Hz
[ 14.361] (II) fglrx(0): 1024x768@75Hz
[ 14.361] (II) fglrx(0): 1280x1024@75Hz
[ 14.361] (II) fglrx(0): Manufacturer's mask: 0
[ 14.361] (II) fglrx(0): Supported standard timings:
[ 14.361] (II) fglrx(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 14.361] (II) fglrx(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 14.361] (II) fglrx(0): Supported detailed timing:
[ 14.361] (II) fglrx(0): clock: 108.0 MHz Image Size: 338 x 270 mm
[ 14.361] (II) fglrx(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
[ 14.361] (II) fglrx(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
[ 14.361] (II) fglrx(0): Ranges: V min: 56 V max: 75 Hz, H min: 31 H max: 80 kHz, PixClock max 145 MHz
[ 14.361] (II) fglrx(0): Serial No: FC99864K15JL
[ 14.361] (II) fglrx(0): Monitor name: DELL E196FP
[ 14.361] (II) fglrx(0): EDID (in hex):
[ 14.361] (II) fglrx(0): 00ffffffffffff0010ac15a04c4a3531
[ 14.361] (II) fglrx(0): 1010010368221b78eecaf6a357479e23
[ 14.361] (II) fglrx(0): 114f54a54b00714f8180010101010101
[ 14.361] (II) fglrx(0): 010101010101302a009851002a403070
[ 14.361] (II) fglrx(0): 1300520e1100001e000000fd00384b1f
[ 14.361] (II) fglrx(0): 500e000a202020202020000000ff0046
[ 14.361] (II) fglrx(0): 4339393836344b31354a4c0a000000fc
[ 14.361] (II) fglrx(0): 0044454c4c204531393646500a2000b2
[ 14.361] (II) fglrx(0): End of Display0 EDID data --------------------
[ 14.361] (II) fglrx(0): Connected Display1: CRT2
[ 14.361] (II) fglrx(0): Display1 EDID data ---------------------------
[ 14.361] (II) fglrx(0): Manufacturer: PKB Model: c1 Serial#: 4275988
[ 14.361] (II) fglrx(0): Year: 2010 Week: 4
[ 14.361] (II) fglrx(0): EDID Version: 1.3
[ 14.361] (II) fglrx(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 14.361] (II) fglrx(0): Sync: Separate
[ 14.361] (II) fglrx(0): Max Image Size [cm]: horiz.: 51 vert.: 28
[ 14.361] (II) fglrx(0): Gamma: 2.20
[ 14.361] (II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 14.361] (II) fglrx(0): First detailed timing is preferred mode
[ 14.361] (II) fglrx(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 14.362] (II) fglrx(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 14.362] (II) fglrx(0): Supported established timings:
[ 14.362] (II) fglrx(0): 720x400@70Hz
[ 14.362] (II) fglrx(0): 640x480@60Hz
[ 14.362] (II) fglrx(0): 640x480@67Hz
[ 14.362] (II) fglrx(0): 800x600@56Hz
[ 14.362] (II) fglrx(0): 800x600@60Hz
[ 14.362] (II) fglrx(0): 1024x768@60Hz
[ 14.362] (II) fglrx(0): 1024x768@70Hz
[ 14.362] (II) fglrx(0): Manufacturer's mask: 0
[ 14.362] (II) fglrx(0): Supported standard timings:
[ 14.362] (II) fglrx(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 14.362] (II) fglrx(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 14.362] (II) fglrx(0): #2: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 14.362] (II) fglrx(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 14.362] (II) fglrx(0): #4: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 14.362] (II) fglrx(0): Supported detailed timing:
[ 14.362] (II) fglrx(0): clock: 148.5 MHz Image Size: 509 x 286 mm
[ 14.362] (II) fglrx(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 14.362] (II) fglrx(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 14.362] (II) fglrx(0): Monitor name: Viseo 230Ws
[ 14.362] (II) fglrx(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 83 kHz, PixClock max 205 MHz
[ 14.362] (II) fglrx(0): Serial No: D150C0054002
[ 14.362] (II) fglrx(0): EDID (in hex):
[ 14.362] (II) fglrx(0): 00ffffffffffff004162c100143f4100
[ 14.362] (II) fglrx(0): 0414010368331c78eaee95a3544c9926
[ 14.362] (II) fglrx(0): 0f5054b30c00714f818081009500d1c0
[ 14.362] (II) fglrx(0): 010101010101023a801871382d40582c
[ 14.362] (II) fglrx(0): 4500fd1e1100001e000000fc00566973
[ 14.362] (II) fglrx(0): 656f2032333057730a20000000fd0038
[ 14.362] (II) fglrx(0): 4c1f5314000a202020202020000000ff
[ 14.362] (II) fglrx(0): 004431353043303035343030320a007a
[ 14.362] (II) fglrx(0): End of Display1 EDID data --------------------
[ 14.364] (II) fglrx(0): EDID for output DFP1
[ 14.364] (II) fglrx(0): EDID for output DFP2
[ 14.364] (II) fglrx(0): EDID for output CRT1
[ 14.364] (II) fglrx(0): Manufacturer: DEL Model: a015 Serial#: 825576012
[ 14.364] (II) fglrx(0): Year: 2006 Week: 16
[ 14.364] (II) fglrx(0): EDID Version: 1.3
[ 14.364] (II) fglrx(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 14.364] (II) fglrx(0): Sync: Separate
[ 14.364] (II) fglrx(0): Max Image Size [cm]: horiz.: 34 vert.: 27
[ 14.364] (II) fglrx(0): Gamma: 2.20
[ 14.364] (II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 14.364] (II) fglrx(0): Default color space is primary color space
[ 14.364] (II) fglrx(0): First detailed timing is preferred mode
[ 14.364] (II) fglrx(0): redX: 0.640 redY: 0.340 greenX: 0.279 greenY: 0.619
[ 14.364] (II) fglrx(0): blueX: 0.140 blueY: 0.069 whiteX: 0.310 whiteY: 0.330
[ 14.364] (II) fglrx(0): Supported established timings:
[ 14.364] (II) fglrx(0): 720x400@70Hz
[ 14.364] (II) fglrx(0): 640x480@60Hz
[ 14.364] (II) fglrx(0): 640x480@75Hz
[ 14.364] (II) fglrx(0): 800x600@60Hz
[ 14.364] (II) fglrx(0): 800x600@75Hz
[ 14.364] (II) fglrx(0): 1024x768@60Hz
[ 14.364] (II) fglrx(0): 1024x768@75Hz
[ 14.364] (II) fglrx(0): 1280x1024@75Hz
[ 14.364] (II) fglrx(0): Manufacturer's mask: 0
[ 14.365] (II) fglrx(0): Supported standard timings:
[ 14.365] (II) fglrx(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 14.365] (II) fglrx(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 14.365] (II) fglrx(0): Supported detailed timing:
[ 14.365] (II) fglrx(0): clock: 108.0 MHz Image Size: 338 x 270 mm
[ 14.365] (II) fglrx(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
[ 14.365] (II) fglrx(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
[ 14.365] (II) fglrx(0): Ranges: V min: 56 V max: 75 Hz, H min: 31 H max: 80 kHz, PixClock max 145 MHz
[ 14.365] (II) fglrx(0): Serial No: FC99864K15JL
[ 14.365] (II) fglrx(0): Monitor name: DELL E196FP
[ 14.365] (II) fglrx(0): EDID (in hex):
[ 14.365] (II) fglrx(0): 00ffffffffffff0010ac15a04c4a3531
[ 14.365] (II) fglrx(0): 1010010368221b78eecaf6a357479e23
[ 14.365] (II) fglrx(0): 114f54a54b00714f8180010101010101
[ 14.365] (II) fglrx(0): 010101010101302a009851002a403070
[ 14.365] (II) fglrx(0): 1300520e1100001e000000fd00384b1f
[ 14.365] (II) fglrx(0): 500e000a202020202020000000ff0046
[ 14.365] (II) fglrx(0): 4339393836344b31354a4c0a000000fc
[ 14.365] (II) fglrx(0): 0044454c4c204531393646500a2000b2
[ 14.365] (II) fglrx(0): Printing probed modes for output CRT1
[ 14.365] (II) fglrx(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 14.365] (II) fglrx(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 14.365] (II) fglrx(0): Modeline "1280x960"x75.0 135.00 1280 1296 1440 1688 960 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 14.365] (II) fglrx(0): Modeline "1280x960"x60.0 108.00 1280 1328 1440 1688 960 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 14.365] (II) fglrx(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
[ 14.365] (II) fglrx(0): Modeline "1152x864"x60.0 108.00 1152 1328 1440 1688 864 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 14.365] (II) fglrx(0): Modeline "1280x768"x75.0 135.00 1280 1296 1440 1688 768 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 14.365] (II) fglrx(0): Modeline "1280x768"x60.0 108.00 1280 1328 1440 1688 768 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 14.365] (II) fglrx(0): Modeline "1280x720"x75.0 135.00 1280 1296 1440 1688 720 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 14.365] (II) fglrx(0): Modeline "1280x720"x60.0 108.00 1280 1328 1440 1688 720 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 14.365] (II) fglrx(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 14.365] (II) fglrx(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 14.365] (II) fglrx(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 14.365] (II) fglrx(0): Modeline "800x600"x60.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 14.365] (II) fglrx(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 14.365] (II) fglrx(0): Modeline "640x480"x60.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 14.365] (II) fglrx(0): EDID for output CRT2
[ 14.366] (II) fglrx(0): Manufacturer: PKB Model: c1 Serial#: 4275988
[ 14.366] (II) fglrx(0): Year: 2010 Week: 4
[ 14.366] (II) fglrx(0): EDID Version: 1.3
[ 14.366] (II) fglrx(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 14.366] (II) fglrx(0): Sync: Separate
[ 14.366] (II) fglrx(0): Max Image Size [cm]: horiz.: 51 vert.: 28
[ 14.366] (II) fglrx(0): Gamma: 2.20
[ 14.366] (II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 14.366] (II) fglrx(0): First detailed timing is preferred mode
[ 14.366] (II) fglrx(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 14.366] (II) fglrx(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 14.366] (II) fglrx(0): Supported established timings:
[ 14.366] (II) fglrx(0): 720x400@70Hz
[ 14.366] (II) fglrx(0): 640x480@60Hz
[ 14.366] (II) fglrx(0): 640x480@67Hz
[ 14.366] (II) fglrx(0): 800x600@56Hz
[ 14.366] (II) fglrx(0): 800x600@60Hz
[ 14.366] (II) fglrx(0): 1024x768@60Hz
[ 14.366] (II) fglrx(0): 1024x768@70Hz
[ 14.366] (II) fglrx(0): Manufacturer's mask: 0
[ 14.366] (II) fglrx(0): Supported standard timings:
[ 14.366] (II) fglrx(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 14.366] (II) fglrx(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 14.366] (II) fglrx(0): #2: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 14.366] (II) fglrx(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 14.366] (II) fglrx(0): #4: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 14.366] (II) fglrx(0): Supported detailed timing:
[ 14.366] (II) fglrx(0): clock: 148.5 MHz Image Size: 509 x 286 mm
[ 14.366] (II) fglrx(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 14.366] (II) fglrx(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 14.366] (II) fglrx(0): Monitor name: Viseo 230Ws
[ 14.366] (II) fglrx(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 83 kHz, PixClock max 205 MHz
[ 14.366] (II) fglrx(0): Serial No: D150C0054002
[ 14.366] (II) fglrx(0): EDID (in hex):
[ 14.366] (II) fglrx(0): 00ffffffffffff004162c100143f4100
[ 14.366] (II) fglrx(0): 0414010368331c78eaee95a3544c9926
[ 14.366] (II) fglrx(0): 0f5054b30c00714f818081009500d1c0
[ 14.366] (II) fglrx(0): 010101010101023a801871382d40582c
[ 14.366] (II) fglrx(0): 4500fd1e1100001e000000fc00566973
[ 14.366] (II) fglrx(0): 656f2032333057730a20000000fd0038
[ 14.366] (II) fglrx(0): 4c1f5314000a202020202020000000ff
[ 14.366] (II) fglrx(0): 004431353043303035343030320a007a
[ 14.367] (II) fglrx(0): Printing probed modes for output CRT2
[ 14.367] (II) fglrx(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz)
[ 14.367] (II) fglrx(0): Modeline "1680x1050"x60.0 148.50 1680 2008 2052 2200 1050 1084 1089 1125 +hsync +vsync (67.5 kHz)
[ 14.367] (II) fglrx(0): Modeline "1400x1050"x60.0 148.50 1400 2008 2052 2200 1050 1084 1089 1125 +hsync +vsync (67.5 kHz)
[ 14.367] (II) fglrx(0): Modeline "1600x900"x60.0 148.50 1600 2008 2052 2200 900 1084 1089 1125 +hsync +vsync (67.5 kHz)
[ 14.367] (II) fglrx(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 14.367] (II) fglrx(0): Modeline "1440x900"x60.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz)
[ 14.367] (II) fglrx(0): Modeline "1280x960"x60.0 108.00 1280 1328 1440 1688 960 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 14.367] (II) fglrx(0): Modeline "1280x800"x60.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz)
[ 14.367] (II) fglrx(0): Modeline "1152x864"x60.0 148.50 1152 2008 2052 2200 864 1084 1089 1125 +hsync +vsync (67.5 kHz)
[ 14.367] (II) fglrx(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
[ 14.367] (II) fglrx(0): Modeline "1280x768"x60.0 83.50 1280 1352 1480 1680 768 803 809 831 -hsync +vsync (49.7 kHz)
[ 14.367] (II) fglrx(0): Modeline "1280x720"x60.0 83.50 1280 1352 1480 1680 720 803 809 831 -hsync +vsync (49.7 kHz)
[ 14.367] (II) fglrx(0): Modeline "1024x768"x70.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 14.367] (II) fglrx(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 14.367] (II) fglrx(0): Modeline "800x600"x60.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 14.367] (II) fglrx(0): Modeline "800x600"x56.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 14.367] (II) fglrx(0): Modeline "640x480"x67.0 27.28 640 664 728 816 480 481 484 499 -hsync +vsync (33.4 kHz)
[ 14.367] (II) fglrx(0): Modeline "640x480"x60.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 14.367] (II) fglrx(0): Output DFP1 disconnected
[ 14.367] (II) fglrx(0): Output DFP2 disconnected
[ 14.367] (II) fglrx(0): Output CRT1 connected
[ 14.367] (II) fglrx(0): Output CRT2 connected
[ 14.367] (II) fglrx(0): Using exact sizes for initial modes
[ 14.367] (II) fglrx(0): Output CRT1 using initial mode 1280x1024
[ 14.367] (II) fglrx(0): Output CRT2 using initial mode 1280x1024
[ 14.367] (II) fglrx(0): DPI set to (96, 96)
[ 14.367] (II) fglrx(0): Eyefinity capable adapter detected.
[ 14.367] (II) fglrx(0): Adapter ATI Radeon HD 5450 has 3 configurable heads and 2 displays connected.
[ 14.367] (==) fglrx(0): PseudoColor visuals disabled
[ 14.367] (II) Loading sub module "ramdac"
[ 14.367] (II) LoadModule: "ramdac"
[ 14.367] (II) Module "ramdac" already built-in
[ 14.368] (==) fglrx(0): NoDRI = NO
[ 14.368] (==) fglrx(0): Capabilities: 0x00000000
[ 14.368] (==) fglrx(0): CapabilitiesEx: 0x00000000
[ 14.368] (==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
[ 14.368] (==) fglrx(0): UseFastTLS=0
[ 14.368] (--) Depth 24 pixmap format is 32 bpp
[ 14.368] (II) Loading extension ATIFGLRXDRI
[ 14.368] (II) fglrx(0): doing swlDriScreenInit
[ 14.368] (II) fglrx(0): swlDriScreenInit for fglrx driver
[ 14.368] ukiDynamicMajor: found major device number 250
[ 14.368] ukiOpenByBusid: Searching for BusID PCI:7:0:0
[ 14.368] ukiOpenDevice: node name is /dev/ati/card0
[ 14.368] ukiOpenDevice: open result is 13, (OK)
[ 14.368] ukiOpenByBusid: ukiOpenMinor returns 13
[ 14.368] ukiOpenByBusid: ukiGetBusid reports PCI:7:0:0
[ 14.368] (II) fglrx(0): [uki] DRM interface version 1.0
[ 14.368] (II) fglrx(0): [uki] created "fglrx" driver at busid "PCI:7:0:0"
[ 14.368] (II) fglrx(0): [uki] added 8192 byte SAREA at 0x2000
[ 14.368] (II) fglrx(0): [uki] mapped SAREA 0x2000 to 0x7fe81f090000
[ 14.368] (II) fglrx(0): [uki] framebuffer handle = 0x3000
[ 14.369] (II) fglrx(0): [uki] added 1 reserved context for kernel
[ 14.369] (II) fglrx(0): swlDriScreenInit done
[ 14.369] (II) fglrx(0): Kernel Module Version Information:
[ 14.369] (II) fglrx(0): Name: fglrx
[ 14.369] (II) fglrx(0): Version: 8.98.2
[ 14.369] (II) fglrx(0): Date: Jul 19 2012
[ 14.369] (II) fglrx(0): Desc: AMD FireGL DRM kernel module
[ 14.369] (II) fglrx(0): Kernel Module version matches driver.
[ 14.369] (II) fglrx(0): Kernel Module Build Time Information:
[ 14.369] (II) fglrx(0): Build-Kernel UTS_RELEASE: 3.2.0-4-amd64
[ 14.369] (II) fglrx(0): Build-Kernel MODVERSIONS: no
[ 14.369] (II) fglrx(0): Build-Kernel __SMP__: no
[ 14.369] (II) fglrx(0): Build-Kernel PAGE_SIZE: 0x1000
[ 14.369] (II) fglrx(0): [uki] register handle = 0x00004000
[ 14.396] (II) fglrx(0): DRI initialization successfull
[ 14.397] (II) fglrx(0): FBADPhys: 0xf00000000 FBMappedSize: 0x01068000
[ 14.401] (==) fglrx(0): Backing store disabled
[ 14.401] (II) Loading extension FGLRXEXTENSION
[ 14.401] (**) fglrx(0): DPMS enabled
[ 14.401] (II) fglrx(0): Initialized in-driver Xinerama extension
[ 14.401] (**) fglrx(0): Textured Video is enabled.
[ 14.401] (II) LoadModule: "glesx"
[ 14.402] (II) Loading /usr/lib/xorg/modules/glesx.so
[ 14.442] (II) Module glesx: vendor="X.Org Foundation"
[ 14.442] compiled for 1.4.99.906, module version = 1.0.0
[ 14.442] (II) Loading extension GLESX
[ 14.442] (II) fglrx(0): GLESX enableFlags = 592
[ 14.444] (II) fglrx(0): GLESX is enabled
[ 14.444] (II) LoadModule: "amdxmm"
[ 14.444] (II) Loading /usr/lib/xorg/modules/amdxmm.so
[ 14.448] (II) Module amdxmm: vendor="X.Org Foundation"
[ 14.448] compiled for 1.4.99.906, module version = 2.0.0
[ 14.461] (II) Loading extension AMDXVOPL
[ 14.461] (II) Loading extension AMDXVBA
[ 14.464] (II) fglrx(0): UVD feature is enabled(II) fglrx(0):
[ 14.465] (II) fglrx(0): Enable composite support successfully
[ 14.465] (WW) fglrx(0): Option "VendorName" is not used
[ 14.465] (WW) fglrx(0): Option "ModelName" is not used
[ 14.465] (II) fglrx(0): X context handle = 0x1
[ 14.465] (II) fglrx(0): [DRI] installation complete
[ 14.466] (==) fglrx(0): Silken mouse enabled
[ 14.466] (==) fglrx(0): Using HW cursor of display infrastructure!
[ 14.466] (II) fglrx(0): Disabling in-server RandR and enabling in-driver RandR 1.2.
[ 14.550] (--) RandR disabled
[ 14.550] (II) Initializing built-in extension Generic Event Extension
[ 14.550] (II) Initializing built-in extension SHAPE
[ 14.550] (II) Initializing built-in extension MIT-SHM
[ 14.550] (II) Initializing built-in extension XInputExtension
[ 14.550] (II) Initializing built-in extension XTEST
[ 14.550] (II) Initializing built-in extension BIG-REQUESTS
[ 14.550] (II) Initializing built-in extension SYNC
[ 14.550] (II) Initializing built-in extension XKEYBOARD
[ 14.550] (II) Initializing built-in extension XC-MISC
[ 14.550] (II) Initializing built-in extension SECURITY
[ 14.550] (II) Initializing built-in extension XINERAMA
[ 14.550] (II) Initializing built-in extension XFIXES
[ 14.550] (II) Initializing built-in extension RENDER
[ 14.550] (II) Initializing built-in extension RANDR
[ 14.550] (II) Initializing built-in extension COMPOSITE
[ 14.550] (II) Initializing built-in extension DAMAGE
[ 14.551] (II) SELinux: Disabled on system
[ 14.609] ukiDynamicMajor: found major device number 250
[ 14.609] ukiOpenByBusid: Searching for BusID PCI:7:0:0
[ 14.609] ukiOpenDevice: node name is /dev/ati/card0
[ 14.609] ukiOpenDevice: open result is 15, (OK)
[ 14.609] ukiOpenByBusid: ukiOpenMinor returns 15
[ 14.609] ukiOpenByBusid: ukiGetBusid reports PCI:7:0:0
[ 14.858] (II) AIGLX: Loaded and initialized OpenGL driver(II) GLX: Initialized DRI GL provider for screen 0
[ 14.858] (II) fglrx(0): Enable the clock gating!
[ 14.858] (II) fglrx(0): Setting screen physical size to 338 x 270
[ 14.953] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 14.953] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 14.953] (II) LoadModule: "evdev"
[ 14.953] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 14.955] (II) Module evdev: vendor="X.Org Foundation"
[ 14.955] compiled for 1.12.1, module version = 2.7.0
[ 14.955] Module class: X.Org XInput Driver
[ 14.955] ABI class: X.Org XInput driver, version 16.0
[ 14.955] (II) Using input driver 'evdev' for 'Power Button'
[ 14.955] (**) Power Button: always reports core events
[ 14.955] (**) evdev: Power Button: Device: "/dev/input/event3"
[ 14.955] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 14.955] (--) evdev: Power Button: Found keys
[ 14.955] (II) evdev: Power Button: Configuring as keyboard
[ 14.955] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 14.955] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 14.955] (**) Option "xkb_rules" "evdev"
[ 14.955] (**) Option "xkb_model" "pc105"
[ 14.955] (**) Option "xkb_layout" "gb"
[ 15.012] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 15.012] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 15.012] (II) Using input driver 'evdev' for 'Power Button'
[ 15.012] (**) Power Button: always reports core events
[ 15.012] (**) evdev: Power Button: Device: "/dev/input/event2"
[ 15.012] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 15.012] (--) evdev: Power Button: Found keys
[ 15.012] (II) evdev: Power Button: Configuring as keyboard
[ 15.012] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[ 15.012] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 15.012] (**) Option "xkb_rules" "evdev"
[ 15.012] (**) Option "xkb_model" "pc105"
[ 15.012] (**) Option "xkb_layout" "gb"
[ 15.013] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event0)
[ 15.013] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 15.013] (II) Using input driver 'evdev' for 'Logitech USB Receiver'
[ 15.013] (**) Logitech USB Receiver: always reports core events
[ 15.013] (**) evdev: Logitech USB Receiver: Device: "/dev/input/event0"
[ 15.013] (--) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc52e
[ 15.013] (--) evdev: Logitech USB Receiver: Found keys
[ 15.013] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[ 15.013] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb5/5-1/5-1:1.0/input/input0/event0"
[ 15.013] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 8)
[ 15.013] (**) Option "xkb_rules" "evdev"
[ 15.013] (**) Option "xkb_model" "pc105"
[ 15.013] (**) Option "xkb_layout" "gb"
[ 15.014] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event1)
[ 15.014] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 15.014] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 15.014] (II) Using input driver 'evdev' for 'Logitech USB Receiver'
[ 15.014] (**) Logitech USB Receiver: always reports core events
[ 15.015] (**) evdev: Logitech USB Receiver: Device: "/dev/input/event1"
[ 15.015] (--) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc52e
[ 15.015] (--) evdev: Logitech USB Receiver: Found 20 mouse buttons
[ 15.015] (--) evdev: Logitech USB Receiver: Found scroll wheel(s)
[ 15.015] (--) evdev: Logitech USB Receiver: Found relative axes
[ 15.015] (--) evdev: Logitech USB Receiver: Found x and y relative axes
[ 15.015] (--) evdev: Logitech USB Receiver: Found absolute axes
[ 15.015] (II) evdev: Logitech USB Receiver: Forcing absolute x/y axes to exist.
[ 15.015] (--) evdev: Logitech USB Receiver: Found keys
[ 15.015] (II) evdev: Logitech USB Receiver: Configuring as mouse
[ 15.015] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[ 15.015] (II) evdev: Logitech USB Receiver: Adding scrollwheel support
[ 15.015] (**) evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[ 15.015] (**) evdev: Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 15.015] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb5/5-1/5-1:1.1/input/input1/event1"
[ 15.015] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 9)
[ 15.015] (**) Option "xkb_rules" "evdev"
[ 15.015] (**) Option "xkb_model" "pc105"
[ 15.015] (**) Option "xkb_layout" "gb"
[ 15.015] (II) evdev: Logitech USB Receiver: initialized for relative axes.
[ 15.015] (WW) evdev: Logitech USB Receiver: ignoring absolute axes.
[ 15.016] (**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
[ 15.016] (**) Logitech USB Receiver: (accel) acceleration profile 0
[ 15.016] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 15.016] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 15.016] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[ 15.016] (II) No input driver specified, ignoring this device.
[ 15.016] (II) This device may have been added with another device file.
[ 15.017] (II) config/udev: Adding input device UVC Camera (046d:09a4) (/dev/input/event7)
[ 15.017] (**) UVC Camera (046d:09a4): Applying InputClass "evdev keyboard catchall"
[ 15.017] (II) Using input driver 'evdev' for 'UVC Camera (046d:09a4)'
[ 15.017] (**) UVC Camera (046d:09a4): always reports core events
[ 15.017] (**) evdev: UVC Camera (046d:09a4): Device: "/dev/input/event7"
[ 15.017] (--) evdev: UVC Camera (046d:09a4): Vendor 0x46d Product 0x9a4
[ 15.017] (--) evdev: UVC Camera (046d:09a4): Found keys
[ 15.017] (II) evdev: UVC Camera (046d:09a4): Configuring as keyboard
[ 15.017] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.2/usb2/2-3/2-3:1.0/input/input7/event7"
[ 15.017] (II) XINPUT: Adding extended input device "UVC Camera (046d:09a4)" (type: KEYBOARD, id 10)
[ 15.017] (**) Option "xkb_rules" "evdev"
[ 15.017] (**) Option "xkb_model" "pc105"
[ 15.017] (**) Option "xkb_layout" "gb"
[ 15.018] (II) config/udev: Adding input device HDA ATI SB Headphone (/dev/input/event6)
[ 15.018] (II) No input driver specified, ignoring this device.
[ 15.018] (II) This device may have been added with another device file.
[ 15.019] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event8)
[ 15.019] (II) No input driver specified, ignoring this device.
[ 15.019] (II) This device may have been added with another device file.
[ 15.019] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event5)
[ 15.019] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 15.019] (II) Using input driver 'evdev' for 'Eee PC WMI hotkeys'
[ 15.019] (**) Eee PC WMI hotkeys: always reports core events
[ 15.019] (**) evdev: Eee PC WMI hotkeys: Device: "/dev/input/event5"
[ 15.019] (--) evdev: Eee PC WMI hotkeys: Vendor 0 Product 0
[ 15.019] (--) evdev: Eee PC WMI hotkeys: Found keys
[ 15.019] (II) evdev: Eee PC WMI hotkeys: Configuring as keyboard
[ 15.019] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input5/event5"
[ 15.019] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 11)
[ 15.019] (**) Option "xkb_rules" "evdev"
[ 15.019] (**) Option "xkb_model" "pc105"
[ 15.019] (**) Option "xkb_layout" "gb"
[ 15.020] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 15.020] (II) No input driver specified, ignoring this device.
[ 15.020] (II) This device may have been added with another device file.
[ 15.027] (II) fglrx(0): Restoring Recent Mode via PCS is not supported in RANDR 1.2 capable environments
[ 15.036] (II) fglrx(0): EDID vendor "DEL", prod id 40981
[ 15.036] (II) fglrx(0): Using EDID range info for horizontal sync
[ 15.036] (II) fglrx(0): Using EDID range info for vertical refresh
[ 15.036] (II) fglrx(0): Printing DDC gathered Modelines:
[ 15.036] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 15.036] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 15.036] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 15.036] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 15.036] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 15.036] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 15.036] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 15.036] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 15.036] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 15.036] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 15.570] (II) fglrx(0): EDID vendor "DEL", prod id 40981
[ 15.570] (II) fglrx(0): Using hsync ranges from config file
[ 15.570] (II) fglrx(0): Using vrefresh ranges from config file
[ 15.570] (II) fglrx(0): Printing DDC gathered Modelines:
[ 15.570] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 15.571] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 15.571] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 15.571] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 15.571] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 15.571] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 15.571] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 15.571] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 15.571] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 15.571] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 26.433] (II) fglrx(0): EDID vendor "DEL", prod id 40981
[ 26.433] (II) fglrx(0): Using hsync ranges from config file
[ 26.433] (II) fglrx(0): Using vrefresh ranges from config file
[ 26.433] (II) fglrx(0): Printing DDC gathered Modelines:
[ 26.433] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 26.433] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 26.433] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 26.433] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 26.433] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 26.433] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 26.433] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 26.434] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 26.434] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 26.434] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 27.234] (II) fglrx(0): EDID vendor "DEL", prod id 40981
[ 27.234] (II) fglrx(0): Using hsync ranges from config file
[ 27.234] (II) fglrx(0): Using vrefresh ranges from config file
[ 27.234] (II) fglrx(0): Printing DDC gathered Modelines:
[ 27.234] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 27.234] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 27.234] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 27.234] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 27.234] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 27.234] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 27.234] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 27.234] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 27.234] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 27.234] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 27.982] (II) fglrx(0): EDID vendor "DEL", prod id 40981
[ 27.982] (II) fglrx(0): Using hsync ranges from config file
[ 27.982] (II) fglrx(0): Using vrefresh ranges from config file
[ 27.982] (II) fglrx(0): Printing DDC gathered Modelines:
[ 27.982] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 27.982] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 27.982] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 27.982] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 27.982] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 27.982] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 27.982] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 27.982] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 27.982] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 27.982] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 47.016] (II) fglrx(0): EDID vendor "DEL", prod id 40981
[ 47.016] (II) fglrx(0): Using hsync ranges from config file
[ 47.016] (II) fglrx(0): Using vrefresh ranges from config file
[ 47.016] (II) fglrx(0): Printing DDC gathered Modelines:
[ 47.016] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 47.016] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 47.016] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 47.016] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 47.016] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 47.016] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 47.016] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 47.016] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 47.016] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 47.016] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 481.202] (II) fglrx(0): EDID vendor "DEL", prod id 40981
[ 481.202] (II) fglrx(0): Using hsync ranges from config file
[ 481.202] (II) fglrx(0): Using vrefresh ranges from config file
[ 481.202] (II) fglrx(0): Printing DDC gathered Modelines:
[ 481.202] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 481.202] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 481.202] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 481.202] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 481.202] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 481.202] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 481.202] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 481.202] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 481.202] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 481.202] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 1518.962] (II) fglrx(0): EDID vendor "DEL", prod id 40981
[ 1518.962] (II) fglrx(0): Using hsync ranges from config file
[ 1518.962] (II) fglrx(0): Using vrefresh ranges from config file
[ 1518.962] (II) fglrx(0): Printing DDC gathered Modelines:
[ 1518.962] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 1518.962] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 1518.962] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 1518.962] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1518.962] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 1518.962] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 1518.962] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 1518.962] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 1518.962] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 1518.962] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 1554.935] (II) fglrx(0): EDID vendor "DEL", prod id 40981
[ 1554.935] (II) fglrx(0): Using hsync ranges from config file
[ 1554.935] (II) fglrx(0): Using vrefresh ranges from config file
[ 1554.935] (II) fglrx(0): Printing DDC gathered Modelines:
[ 1554.935] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 1554.935] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 1554.935] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 1554.935] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1554.935] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 1554.935] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 1554.935] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 1554.935] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 1554.935] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 1554.935] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 1703.399] (II) fglrx(0): EDID vendor "DEL", prod id 40981
[ 1703.399] (II) fglrx(0): Using hsync ranges from config file
[ 1703.399] (II) fglrx(0): Using vrefresh ranges from config file
[ 1703.399] (II) fglrx(0): Printing DDC gathered Modelines:
[ 1703.399] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 1703.399] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 1703.399] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 1703.399] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1703.399] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 1703.399] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 1703.399] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 1703.399] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 1703.399] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 1703.399] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 1892.268] (II) fglrx(0): EDID vendor "DEL", prod id 40981
[ 1892.268] (II) fglrx(0): Using hsync ranges from config file
[ 1892.268] (II) fglrx(0): Using vrefresh ranges from config file
[ 1892.268] (II) fglrx(0): Printing DDC gathered Modelines:
[ 1892.268] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 1892.268] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 1892.268] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 1892.268] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1892.268] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 1892.268] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 1892.268] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 1892.268] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 1892.268] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 1892.268] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
