Po zainstalowaniu pakietu
[color=#333333][font=monospace]aptitudeinstall firmware-linux-nonfree[/font][/color]Niestety zaczęły się pokazywać nowe błędy w logach. Przy okazji sprawdzania komend z terminala (spisywałem je żeby na przyszłość wiedzieć co robiłem) odpaliłem jedną, żeby zobaczyć co robi:
[ 0.000000] Initializing cgroup subsys cpuset[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.2.0-4-amd64 (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.51-1
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-amd64 root=UUID=e574c626-76e4-4d03-b3ce-f2372d90bddd ro quiet
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000cff80000 (usable)
[ 0.000000] BIOS-e820: 00000000cff80000 - 00000000cff8e000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cff8e000 - 00000000cffe0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cffe0000 - 00000000d0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 0000000130000000 (usable)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: System manufacturer P5K PRO/P5K PRO, BIOS 1303 12/16/2008
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] No AGP bridge found
[ 0.000000] last_pfn = 0x130000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-DFFFF write-protect
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0D0000000 mask FF0000000 uncachable
[ 0.000000] 1 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 2 base 000000000 mask F00000000 write-back
[ 0.000000] 3 base 100000000 mask FE0000000 write-back
[ 0.000000] 4 base 120000000 mask FF0000000 write-back
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000d0000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0xcff80 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [ffff8800000ff780] ff780
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] Base memory trampoline at [ffff88000009a000] 9a000 size 20480
[ 0.000000] init_memory_mapping: 0000000000000000-00000000cff80000
[ 0.000000] 0000000000 - 00cfe00000 page 2M
[ 0.000000] 00cfe00000 - 00cff80000 page 4k
[ 0.000000] kernel direct mapping tables up to cff80000 @ 1fffa000-20000000
[ 0.000000] init_memory_mapping: 0000000100000000-0000000130000000
[ 0.000000] 0100000000 - 0130000000 page 2M
[ 0.000000] kernel direct mapping tables up to 130000000 @ cff7e000-cff80000
[ 0.000000] RAMDISK: 36b64000 - 375aa000
[ 0.000000] ACPI: RSDP 00000000000fbc10 00014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 00000000cff80000 0003C (v01 A_M_I_ OEMRSDT 12000816 MSFT 00000097)
[ 0.000000] ACPI: FACP 00000000cff80200 00084 (v02 A_M_I_ OEMFACP 12000816 MSFT 00000097)
[ 0.000000] ACPI: DSDT 00000000cff80440 08B31 (v01 A0916 A0916041 00000041 INTL 20060113)
[ 0.000000] ACPI: FACS 00000000cff8e000 00040
[ 0.000000] ACPI: APIC 00000000cff80390 0006C (v01 A_M_I_ OEMAPIC 12000816 MSFT 00000097)
[ 0.000000] ACPI: MCFG 00000000cff80400 0003C (v01 A_M_I_ OEMMCFG 12000816 MSFT 00000097)
[ 0.000000] ACPI: OEMB 00000000cff8e040 00081 (v01 A_M_I_ AMI_OEM 12000816 MSFT 00000097)
[ 0.000000] ACPI: HPET 00000000cff88f80 00038 (v01 A_M_I_ OEMHPET 12000816 MSFT 00000097)
[ 0.000000] ACPI: OSFR 00000000cff88fc0 000B0 (v01 A_M_I_ OEMOSFR 12000816 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-0000000130000000
[ 0.000000] Initmem setup node 0 0000000000000000-0000000130000000
[ 0.000000] NODE_DATA [000000012fffb000 - 000000012fffffff]
[ 0.000000] [ffffea0000000000-ffffea00043fffff] PMD -> [ffff88012b600000-ffff88012effffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal 0x00100000 -> 0x00130000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x000cff80
[ 0.000000] 0: 0x00100000 -> 0x00130000
[ 0.000000] On node 0 totalpages: 1048335
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 5 pages reserved
[ 0.000000] DMA zone: 3922 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14280 pages used for memmap
[ 0.000000] DMA32 zone: 833464 pages, LIFO batch:31
[ 0.000000] Normal zone: 2688 pages used for memmap
[ 0.000000] Normal zone: 193920 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 00000000cff80000 - 00000000cff8e000
[ 0.000000] PM: Registered nosave memory: 00000000cff8e000 - 00000000cffe0000
[ 0.000000] PM: Registered nosave memory: 00000000cffe0000 - 00000000d0000000
[ 0.000000] PM: Registered nosave memory: 00000000d0000000 - 00000000fee00000
[ 0.000000] PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000
[ 0.000000] PM: Registered nosave memory: 00000000fee01000 - 00000000fff00000
[ 0.000000] PM: Registered nosave memory: 00000000fff00000 - 0000000100000000
[ 0.000000] Allocating PCI resources starting at d0000000 (gap: d0000000:2ee00000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 28 pages/cpu @ffff88012fc00000 s82944 r8192 d23552 u524288
[ 0.000000] pcpu-alloc: s82944 r8192 d23552 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 1031306
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-amd64 root=UUID=e574c626-76e4-4d03-b3ce-f2372d90bddd ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Checking aperture...
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 4048396k/4980736k available (3426k kernel code, 787396k absent, 144944k reserved, 3312k data, 576k init)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:33024 nr_irqs:712 16
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2405.471 MHz processor.
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4810.94 BogoMIPS (lpj=9621884)
[ 0.004008] pid_max: default: 32768 minimum: 301
[ 0.004050] Security Framework initialized
[ 0.004056] AppArmor: AppArmor disabled by boot time parameter
[ 0.004371] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.008376] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.009431] Mount-cache hash table entries: 256
[ 0.009577] Initializing cgroup subsys cpuacct
[ 0.009582] Initializing cgroup subsys memory
[ 0.009596] Initializing cgroup subsys devices
[ 0.009599] Initializing cgroup subsys freezer
[ 0.009601] Initializing cgroup subsys net_cls
[ 0.009603] Initializing cgroup subsys blkio
[ 0.009611] Initializing cgroup subsys perf_event
[ 0.009643] CPU: Physical Processor ID: 0
[ 0.009645] CPU: Processor Core ID: 0
[ 0.009647] mce: CPU supports 6 MCE banks
[ 0.009656] CPU0: Thermal monitoring enabled (TM2)
[ 0.009660] using mwait in idle threads.
[ 0.010084] ACPI: Core revision 20110623
[ 0.016420] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.056536] CPU0: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz stepping 0b
[ 0.060003] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
[ 0.060003] PEBS disabled due to CPU errata.
[ 0.060003] ... version: 2
[ 0.060003] ... bit width: 40
[ 0.060003] ... generic registers: 2
[ 0.060003] ... value mask: 000000ffffffffff
[ 0.060003] ... max period: 000000007fffffff
[ 0.060003] ... fixed-purpose events: 3
[ 0.060003] ... event mask: 0000000700000003
[ 0.060003] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.060003] Booting Node 0, Processors #1
[ 0.060003] smpboot cpu 1: start_ip = 9a000
[ 0.148040] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.148188] #2
[ 0.148190] smpboot cpu 2: start_ip = 9a000
[ 0.240032] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.240145] #3 Ok.
[ 0.240147] smpboot cpu 3: start_ip = 9a000
[ 0.332039] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.332062] Brought up 4 CPUs
[ 0.332065] Total of 4 processors activated (19243.64 BogoMIPS).
[ 0.335630] devtmpfs: initialized
[ 0.338721] PM: Registering ACPI NVS region at cff8e000 (335872 bytes)
[ 0.338721] print_constraints: dummy:
[ 0.338721] NET: Registered protocol family 16
[ 0.338721] ACPI: bus type pci registered
[ 0.338721] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.338721] PCI: not using MMCONFIG
[ 0.338721] PCI: Using configuration type 1 for base access
[ 0.340121] bio: create slab <bio-0> at 0
[ 0.340213] ACPI: Added _OSI(Module Device)
[ 0.340213] ACPI: Added _OSI(Processor Device)
[ 0.340213] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.340213] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.341118] ACPI: EC: Look up EC in DSDT
[ 0.342175] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.348300] ACPI: SSDT 00000000cff8e0d0 001D2 (v01 AMI CPU1PM 00000001 INTL 20060113)
[ 0.348553] ACPI: Dynamic OEM Table Load:
[ 0.348556] ACPI: SSDT (null) 001D2 (v01 AMI CPU1PM 00000001 INTL 20060113)
[ 0.348742] ACPI: SSDT 00000000cff8e2b0 00143 (v01 AMI CPU2PM 00000001 INTL 20060113)
[ 0.348989] ACPI: Dynamic OEM Table Load:
[ 0.348992] ACPI: SSDT (null) 00143 (v01 AMI CPU2PM 00000001 INTL 20060113)
[ 0.349177] ACPI: SSDT 00000000cff8e400 00143 (v01 AMI CPU3PM 00000001 INTL 20060113)
[ 0.349424] ACPI: Dynamic OEM Table Load:
[ 0.349427] ACPI: SSDT (null) 00143 (v01 AMI CPU3PM 00000001 INTL 20060113)
[ 0.349611] ACPI: SSDT 00000000cff8e550 00143 (v01 AMI CPU4PM 00000001 INTL 20060113)
[ 0.349860] ACPI: Dynamic OEM Table Load:
[ 0.349862] ACPI: SSDT (null) 00143 (v01 AMI CPU4PM 00000001 INTL 20060113)
[ 0.350024] ACPI: Interpreter enabled
[ 0.350029] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.350053] ACPI: Using IOAPIC for interrupt routing
[ 0.350074] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.350614] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.379738] ACPI: No dock devices found.
[ 0.379740] HEST: Table not found.
[ 0.379744] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.379816] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.379959] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.379961] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.379964] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.379966] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff]
[ 0.379969] pci_root PNP0A08:00: host bridge window [mem 0xd0000000-0xffffffff]
[ 0.379981] pci 0000:00:00.0: [8086:29c0] type 0 class 0x000600
[ 0.380034] pci 0000:00:01.0: [8086:29c1] type 1 class 0x000604
[ 0.380070] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.380107] pci 0000:00:1a.0: [8086:2937] type 0 class 0x000c03
[ 0.380145] pci 0000:00:1a.0: reg 20: [io 0xa800-0xa81f]
[ 0.380193] pci 0000:00:1a.1: [8086:2938] type 0 class 0x000c03
[ 0.380232] pci 0000:00:1a.1: reg 20: [io 0xa880-0xa89f]
[ 0.380279] pci 0000:00:1a.2: [8086:2939] type 0 class 0x000c03
[ 0.380317] pci 0000:00:1a.2: reg 20: [io 0xac00-0xac1f]
[ 0.380372] pci 0000:00:1a.7: [8086:293c] type 0 class 0x000c03
[ 0.380392] pci 0000:00:1a.7: reg 10: [mem 0xfe7ffc00-0xfe7fffff]
[ 0.380474] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.380498] pci 0000:00:1b.0: [8086:293e] type 0 class 0x000403
[ 0.380512] pci 0000:00:1b.0: reg 10: [mem 0xfe7f8000-0xfe7fbfff 64bit]
[ 0.380572] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.380593] pci 0000:00:1c.0: [8086:2940] type 1 class 0x000604
[ 0.380665] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.380694] pci 0000:00:1c.4: [8086:2948] type 1 class 0x000604
[ 0.380761] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.380783] pci 0000:00:1c.5: [8086:294a] type 1 class 0x000604
[ 0.380844] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.380868] pci 0000:00:1d.0: [8086:2934] type 0 class 0x000c03
[ 0.380906] pci 0000:00:1d.0: reg 20: [io 0xa080-0xa09f]
[ 0.380954] pci 0000:00:1d.1: [8086:2935] type 0 class 0x000c03
[ 0.380992] pci 0000:00:1d.1: reg 20: [io 0xa400-0xa41f]
[ 0.381039] pci 0000:00:1d.2: [8086:2936] type 0 class 0x000c03
[ 0.381077] pci 0000:00:1d.2: reg 20: [io 0xa480-0xa49f]
[ 0.381133] pci 0000:00:1d.7: [8086:293a] type 0 class 0x000c03
[ 0.381152] pci 0000:00:1d.7: reg 10: [mem 0xfe7ff800-0xfe7ffbff]
[ 0.381234] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.381255] pci 0000:00:1e.0: [8086:244e] type 1 class 0x000604
[ 0.381312] pci 0000:00:1f.0: [8086:2916] type 0 class 0x000601
[ 0.381387] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0294 (mask 0003)
[ 0.381432] pci 0000:00:1f.2: [8086:2920] type 0 class 0x000101
[ 0.381446] pci 0000:00:1f.2: reg 10: [io 0x9000-0x9007]
[ 0.381453] pci 0000:00:1f.2: reg 14: [io 0x8c00-0x8c03]
[ 0.381460] pci 0000:00:1f.2: reg 18: [io 0x8880-0x8887]
[ 0.381468] pci 0000:00:1f.2: reg 1c: [io 0x8800-0x8803]
[ 0.381475] pci 0000:00:1f.2: reg 20: [io 0x8480-0x848f]
[ 0.381482] pci 0000:00:1f.2: reg 24: [io 0x8400-0x840f]
[ 0.381525] pci 0000:00:1f.3: [8086:2930] type 0 class 0x000c05
[ 0.381539] pci 0000:00:1f.3: reg 10: [mem 0xfe7ff400-0xfe7ff4ff 64bit]
[ 0.381558] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f]
[ 0.381589] pci 0000:00:1f.5: [8086:2926] type 0 class 0x000101
[ 0.381603] pci 0000:00:1f.5: reg 10: [io 0xa000-0xa007]
[ 0.381611] pci 0000:00:1f.5: reg 14: [io 0x9c00-0x9c03]
[ 0.381618] pci 0000:00:1f.5: reg 18: [io 0x9880-0x9887]
[ 0.381625] pci 0000:00:1f.5: reg 1c: [io 0x9800-0x9803]
[ 0.381633] pci 0000:00:1f.5: reg 20: [io 0x9480-0x948f]
[ 0.381640] pci 0000:00:1f.5: reg 24: [io 0x9400-0x940f]
[ 0.381709] pci 0000:01:00.0: [1002:9442] type 0 class 0x000300
[ 0.381722] pci 0000:01:00.0: reg 10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.381732] pci 0000:01:00.0: reg 18: [mem 0xfe8e0000-0xfe8effff 64bit]
[ 0.381739] pci 0000:01:00.0: reg 20: [io 0xb000-0xb0ff]
[ 0.381751] pci 0000:01:00.0: reg 30: [mem 0xfe8c0000-0xfe8dffff pref]
[ 0.381780] pci 0000:01:00.0: supports D1 D2
[ 0.381799] pci 0000:01:00.1: [1002:aa30] type 0 class 0x000403
[ 0.381812] pci 0000:01:00.1: reg 10: [mem 0xfe8fc000-0xfe8fffff 64bit]
[ 0.381865] pci 0000:01:00.1: supports D1 D2
[ 0.381893] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.381896] pci 0000:00:01.0: bridge window [io 0xb000-0xbfff]
[ 0.381899] pci 0000:00:01.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.381903] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.381938] pci 0000:00:1c.0: PCI bridge to [bus 04-04]
[ 0.381947] pci 0000:00:1c.0: bridge window [mem 0xfdf00000-0xfdffffff 64bit pref]
[ 0.382000] pci 0000:03:00.0: [11ab:6101] type 0 class 0x000101
[ 0.382015] pci 0000:03:00.0: reg 10: [io 0xdc00-0xdc07]
[ 0.382026] pci 0000:03:00.0: reg 14: [io 0xd880-0xd883]
[ 0.382038] pci 0000:03:00.0: reg 18: [io 0xd800-0xd807]
[ 0.382049] pci 0000:03:00.0: reg 1c: [io 0xd480-0xd483]
[ 0.382060] pci 0000:03:00.0: reg 20: [io 0xd400-0xd40f]
[ 0.382072] pci 0000:03:00.0: reg 24: [mem 0xfeaffc00-0xfeaffdff]
[ 0.382133] pci 0000:03:00.0: supports D1
[ 0.382135] pci 0000:03:00.0: PME# supported from D0 D1 D3hot
[ 0.382154] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.382163] pci 0000:00:1c.4: PCI bridge to [bus 03-03]
[ 0.382166] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff]
[ 0.382170] pci 0000:00:1c.4: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.382229] pci 0000:02:00.0: [11ab:4364] type 0 class 0x000200
[ 0.382251] pci 0000:02:00.0: reg 10: [mem 0xfe9fc000-0xfe9fffff 64bit]
[ 0.382262] pci 0000:02:00.0: reg 18: [io 0xc800-0xc8ff]
[ 0.382303] pci 0000:02:00.0: reg 30: [mem 0xfe9c0000-0xfe9dffff pref]
[ 0.382366] pci 0000:02:00.0: supports D1 D2
[ 0.382368] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.388041] pci 0000:00:1c.5: PCI bridge to [bus 02-02]
[ 0.388047] pci 0000:00:1c.5: bridge window [io 0xc000-0xcfff]
[ 0.388052] pci 0000:00:1c.5: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.388098] pci 0000:05:03.0: [1106:3044] type 0 class 0x000c00
[ 0.388118] pci 0000:05:03.0: reg 10: [mem 0xfebff800-0xfebfffff]
[ 0.388129] pci 0000:05:03.0: reg 14: [io 0xec00-0xec7f]
[ 0.388204] pci 0000:05:03.0: supports D2
[ 0.388206] pci 0000:05:03.0: PME# supported from D2 D3hot D3cold
[ 0.388246] pci 0000:00:1e.0: PCI bridge to [bus 05-05] (subtractive decode)
[ 0.388250] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.388253] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.388259] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.388262] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.388264] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.388267] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode)
[ 0.388269] pci 0000:00:1e.0: bridge window [mem 0xd0000000-0xffffffff] (subtractive decode)
[ 0.388289] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.388425] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P2._PRT]
[ 0.388464] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.388550] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P8._PRT]
[ 0.388587] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT]
[ 0.388648] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT]
[ 0.388683] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.388686] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[ 0.388688] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.398583] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.398633] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.398682] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.398729] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[ 0.398779] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.398827] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.398875] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[ 0.398922] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.399020] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.399020] vgaarb: loaded
[ 0.399020] vgaarb: bridge control possible 0000:01:00.0
[ 0.399020] PCI: Using ACPI for IRQ routing
[ 0.404500] PCI: pci_cache_line_size set to 64 bytes
[ 0.404580] reserve RAM buffer: 000000000009f800 - 000000000009ffff
[ 0.404583] reserve RAM buffer: 00000000cff80000 - 00000000cfffffff
[ 0.404690] HPET: 4 timers in total, 0 timers will be used for per-cpu timer
[ 0.404695] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.404700] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.412749] Switching to clocksource hpet
[ 0.413997] pnp: PnP ACPI init
[ 0.414012] ACPI: bus type pnp registered
[ 0.414090] pnp 00:00: [bus 00-ff]
[ 0.414093] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.414095] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.414098] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.414100] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.414102] pnp 00:00: [mem 0x000d0000-0x000dffff window]
[ 0.414104] pnp 00:00: [mem 0xd0000000-0xffffffff window]
[ 0.414161] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.414171] pnp 00:01: [mem 0xfed14000-0xfed19fff]
[ 0.414221] system 00:01: [mem 0xfed14000-0xfed19fff] has been reserved
[ 0.414224] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.414257] pnp 00:02: [dma 4]
[ 0.414259] pnp 00:02: [io 0x0000-0x000f]
[ 0.414261] pnp 00:02: [io 0x0081-0x0083]
[ 0.414263] pnp 00:02: [io 0x0087]
[ 0.414265] pnp 00:02: [io 0x0089-0x008b]
[ 0.414267] pnp 00:02: [io 0x008f]
[ 0.414268] pnp 00:02: [io 0x00c0-0x00df]
[ 0.414295] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.414307] pnp 00:03: [io 0x0070-0x0071]
[ 0.414316] pnp 00:03: [irq 8]
[ 0.414343] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.414354] pnp 00:04: [io 0x0061]
[ 0.414380] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.414390] pnp 00:05: [io 0x00f0-0x00ff]
[ 0.414395] pnp 00:05: [irq 13]
[ 0.414423] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.414743] pnp 00:06: [irq 6]
[ 0.414746] pnp 00:06: [dma 2]
[ 0.414748] pnp 00:06: [io 0x03f0-0x03f5]
[ 0.414750] pnp 00:06: [io 0x03f7]
[ 0.414807] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.414840] pnp 00:07: [io 0x0000-0xffffffffffffffff disabled]
[ 0.414842] pnp 00:07: [io 0x0000-0xffffffffffffffff disabled]
[ 0.414845] pnp 00:07: [io 0x0290-0x0297]
[ 0.414893] system 00:07: [io 0x0290-0x0297] has been reserved
[ 0.414896] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.415000] pnp 00:08: [io 0x0010-0x001f]
[ 0.415003] pnp 00:08: [io 0x0022-0x003f]
[ 0.415005] pnp 00:08: [io 0x0044-0x004d]
[ 0.415006] pnp 00:08: [io 0x0050-0x005f]
[ 0.415008] pnp 00:08: [io 0x0062-0x0063]
[ 0.415010] pnp 00:08: [io 0x0065-0x006f]
[ 0.415012] pnp 00:08: [io 0x0072-0x007f]
[ 0.415014] pnp 00:08: [io 0x0080]
[ 0.415016] pnp 00:08: [io 0x0084-0x0086]
[ 0.415017] pnp 00:08: [io 0x0088]
[ 0.415019] pnp 00:08: [io 0x008c-0x008e]
[ 0.415021] pnp 00:08: [io 0x0090-0x009f]
[ 0.415023] pnp 00:08: [io 0x00a2-0x00bf]
[ 0.415025] pnp 00:08: [io 0x00e0-0x00ef]
[ 0.415027] pnp 00:08: [io 0x04d0-0x04d1]
[ 0.415029] pnp 00:08: [io 0x0800-0x087f]
[ 0.415031] pnp 00:08: [io 0x0400-0x03ff disabled]
[ 0.415033] pnp 00:08: [io 0x0480-0x04bf]
[ 0.415035] pnp 00:08: [mem 0xfed1c000-0xfed1ffff]
[ 0.415038] pnp 00:08: [mem 0xfed20000-0xfed3ffff]
[ 0.415040] pnp 00:08: [mem 0xfed50000-0xfed8ffff]
[ 0.415042] pnp 00:08: [mem 0xffa00000-0xffafffff]
[ 0.415044] pnp 00:08: [mem 0xffb00000-0xffbfffff]
[ 0.415046] pnp 00:08: [mem 0xffe00000-0xffefffff]
[ 0.415048] pnp 00:08: [mem 0xfff00000-0xfffffffe]
[ 0.415123] system 00:08: [io 0x04d0-0x04d1] has been reserved
[ 0.415126] system 00:08: [io 0x0800-0x087f] has been reserved
[ 0.415129] system 00:08: [io 0x0480-0x04bf] has been reserved
[ 0.415132] system 00:08: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.415135] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.415138] system 00:08: [mem 0xfed50000-0xfed8ffff] has been reserved
[ 0.415141] system 00:08: [mem 0xffa00000-0xffafffff] has been reserved
[ 0.415144] system 00:08: [mem 0xffb00000-0xffbfffff] has been reserved
[ 0.415147] system 00:08: [mem 0xffe00000-0xffefffff] has been reserved
[ 0.415149] system 00:08: [mem 0xfff00000-0xfffffffe] has been reserved
[ 0.415152] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.415221] pnp 00:09: [mem 0xfed00000-0xfed003ff]
[ 0.415251] pnp 00:09: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.415512] pnp 00:0a: [irq 4]
[ 0.415515] pnp 00:0a: [dma 0 disabled]
[ 0.415517] pnp 00:0a: [io 0x03f8-0x03ff]
[ 0.415591] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.415640] pnp 00:0b: [mem 0xfec00000-0xfec00fff]
[ 0.415643] pnp 00:0b: [mem 0xfee00000-0xfee00fff]
[ 0.415691] system 00:0b: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.415695] system 00:0b: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.415698] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.415728] pnp 00:0c: [io 0x0060]
[ 0.415730] pnp 00:0c: [io 0x0064]
[ 0.415735] pnp 00:0c: [irq 1]
[ 0.415773] pnp 00:0c: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.415822] pnp 00:0d: [irq 12]
[ 0.415858] pnp 00:0d: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
[ 0.415893] pnp 00:0e: [mem 0xe0000000-0xefffffff]
[ 0.415942] system 00:0e: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.415946] system 00:0e: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.416117] pnp 00:0f: [mem 0x00000000-0x0009ffff]
[ 0.416119] pnp 00:0f: [mem 0x000c0000-0x000cffff]
[ 0.416121] pnp 00:0f: [mem 0x000e0000-0x000fffff]
[ 0.416123] pnp 00:0f: [mem 0x00100000-0xcfffffff]
[ 0.416125] pnp 00:0f: [mem 0x00000000-0xffffffffffffffff disabled]
[ 0.416186] system 00:0f: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.416189] system 00:0f: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.416192] system 00:0f: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.416195] system 00:0f: [mem 0x00100000-0xcfffffff] could not be reserved
[ 0.416198] system 00:0f: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.416331] pnp: PnP ACPI: found 16 devices
[ 0.416332] ACPI: ACPI bus type pnp unregistered
[ 0.424583] PCI: max bus depth: 1 pci_try_num: 2
[ 0.424618] pci 0000:00:1c.5: BAR 15: assigned [mem 0xf0000000-0xf01fffff 64bit pref]
[ 0.424622] pci 0000:00:1c.4: BAR 15: assigned [mem 0xf0200000-0xf03fffff 64bit pref]
[ 0.424625] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf0400000-0xf07fffff]
[ 0.424628] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.424631] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.424634] pci 0000:00:01.0: bridge window [io 0xb000-0xbfff]
[ 0.424638] pci 0000:00:01.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.424641] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.424645] pci 0000:00:1c.0: PCI bridge to [bus 04-04]
[ 0.424648] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.424652] pci 0000:00:1c.0: bridge window [mem 0xf0400000-0xf07fffff]
[ 0.424656] pci 0000:00:1c.0: bridge window [mem 0xfdf00000-0xfdffffff 64bit pref]
[ 0.424662] pci 0000:00:1c.4: PCI bridge to [bus 03-03]
[ 0.424665] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff]
[ 0.424669] pci 0000:00:1c.4: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.424673] pci 0000:00:1c.4: bridge window [mem 0xf0200000-0xf03fffff 64bit pref]
[ 0.424678] pci 0000:00:1c.5: PCI bridge to [bus 02-02]
[ 0.424681] pci 0000:00:1c.5: bridge window [io 0xc000-0xcfff]
[ 0.424686] pci 0000:00:1c.5: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.424689] pci 0000:00:1c.5: bridge window [mem 0xf0000000-0xf01fffff 64bit pref]
[ 0.424695] pci 0000:00:1e.0: PCI bridge to [bus 05-05]
[ 0.424698] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.424702] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.424720] pci 0000:00:01.0: setting latency timer to 64
[ 0.424725] pci 0000:00:1c.0: enabling device (0106 -> 0107)
[ 0.424733] pci 0000:00:1c.0: setting latency timer to 64
[ 0.424740] pci 0000:00:1c.4: setting latency timer to 64
[ 0.424746] pci 0000:00:1c.5: setting latency timer to 64
[ 0.424752] pci 0000:00:1e.0: setting latency timer to 64
[ 0.424755] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.424757] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.424760] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.424762] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.424764] pci_bus 0000:00: resource 8 [mem 0xd0000000-0xffffffff]
[ 0.424767] pci_bus 0000:01: resource 0 [io 0xb000-0xbfff]
[ 0.424769] pci_bus 0000:01: resource 1 [mem 0xfe800000-0xfe8fffff]
[ 0.424771] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.424774] pci_bus 0000:04: resource 0 [io 0x1000-0x1fff]
[ 0.424776] pci_bus 0000:04: resource 1 [mem 0xf0400000-0xf07fffff]
[ 0.424778] pci_bus 0000:04: resource 2 [mem 0xfdf00000-0xfdffffff 64bit pref]
[ 0.424781] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.424783] pci_bus 0000:03: resource 1 [mem 0xfea00000-0xfeafffff]
[ 0.424785] pci_bus 0000:03: resource 2 [mem 0xf0200000-0xf03fffff 64bit pref]
[ 0.424788] pci_bus 0000:02: resource 0 [io 0xc000-0xcfff]
[ 0.424790] pci_bus 0000:02: resource 1 [mem 0xfe900000-0xfe9fffff]
[ 0.424792] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf01fffff 64bit pref]
[ 0.424795] pci_bus 0000:05: resource 0 [io 0xe000-0xefff]
[ 0.424797] pci_bus 0000:05: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 0.424799] pci_bus 0000:05: resource 4 [io 0x0000-0x0cf7]
[ 0.424801] pci_bus 0000:05: resource 5 [io 0x0d00-0xffff]
[ 0.424803] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.424805] pci_bus 0000:05: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.424808] pci_bus 0000:05: resource 8 [mem 0xd0000000-0xffffffff]
[ 0.424915] NET: Registered protocol family 2
[ 0.425084] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.426163] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.429963] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.430493] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.430495] TCP reno registered
[ 0.430506] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.430547] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.430758] NET: Registered protocol family 1
[ 0.431004] pci 0000:01:00.0: Boot video device
[ 0.431017] PCI: CLS 32 bytes, default 64
[ 0.431073] Unpacking initramfs...
[ 0.653527] Freeing initrd memory: 10520k freed
[ 0.657266] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.657273] Placing 64MB software IO TLB between ffff8800cbf7e000 - ffff8800cff7e000
[ 0.657275] software IO TLB at phys 0xcbf7e000 - 0xcff7e000
[ 0.658002] audit: initializing netlink socket (disabled)
[ 0.658018] type=2000 audit(1387654527.652:1): initialized
[ 0.670612] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.671564] VFS: Disk quotas dquot_6.5.2
[ 0.671609] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.671698] msgmni has been set to 7927
[ 0.671940] alg: No test for stdrng (krng)
[ 0.671996] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.672000] io scheduler noop registered
[ 0.672002] io scheduler deadline registered
[ 0.672036] io scheduler cfq registered (default)
[ 0.672161] pcieport 0000:00:01.0: setting latency timer to 64
[ 0.672192] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
[ 0.672240] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.672272] pcieport 0000:00:1c.0: irq 41 for MSI/MSI-X
[ 0.672326] pcieport 0000:00:1c.4: setting latency timer to 64
[ 0.672360] pcieport 0000:00:1c.4: irq 42 for MSI/MSI-X
[ 0.672417] pcieport 0000:00:1c.5: setting latency timer to 64
[ 0.672450] pcieport 0000:00:1c.5: irq 43 for MSI/MSI-X
[ 0.672532] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.672554] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.672556] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.672848] intel_idle: does not run on family 6 model 15
[ 0.672875] ERST: Table is not found!
[ 0.672877] GHES: HEST is not enabled!
[ 0.672960] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.693292] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.844707] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.845072] Linux agpgart interface v0.103
[ 0.845334] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 0.848037] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.848044] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.848208] mousedev: PS/2 mouse device common for all mice
[ 0.848265] rtc_cmos 00:03: RTC can wake from S4
[ 0.848368] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 0.848390] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.848406] cpuidle: using governor ladder
[ 0.848408] cpuidle: using governor menu
[ 0.848631] TCP cubic registered
[ 0.848703] NET: Registered protocol family 10
[ 0.849159] Mobile IPv6
[ 0.849162] NET: Registered protocol family 17
[ 0.849165] Registering the dns_resolver key type
[ 0.849291] PM: Hibernation image not present or could not be loaded.
[ 0.849304] registered taskstats version 1
[ 0.849979] rtc_cmos 00:03: setting system clock to 2013-12-21 19:35:28 UTC (1387654528)
[ 0.850017] Initializing network drop monitor service
[ 0.851250] Freeing unused kernel memory: 576k freed
[ 0.851363] Write protecting the kernel read-only data: 6144k
[ 0.853805] Freeing unused kernel memory: 652k freed
[ 0.856436] Freeing unused kernel memory: 688k freed
[ 0.868272] udevd[59]: starting version 175
[ 0.882993] usbcore: registered new interface driver usbfs
[ 0.883017] usbcore: registered new interface driver hub
[ 0.886360] SCSI subsystem initialized
[ 0.898535] usbcore: registered new device driver usb
[ 0.898961] libata version 3.00 loaded.
[ 0.899069] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.899131] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 0.899135] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 0.899159] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 0.899193] ehci_hcd 0000:00:1a.7: debug port 1
[ 0.900673] sky2: driver version 1.30
[ 0.900725] sky2 0000:02:00.0: setting latency timer to 64
[ 0.900753] sky2 0000:02:00.0: Yukon-2 EC Ultra chip revision 3
[ 0.900852] sky2 0000:02:00.0: irq 44 for MSI/MSI-X
[ 0.902363] sky2 0000:02:00.0: eth0: addr 00:1f:c6:37:66:83
[ 0.903091] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported
[ 0.903249] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xfe7ffc00
[ 0.912549] Floppy drive(s): fd0 is 1.44M
[ 0.916029] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 0.916064] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.916067] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.916069] usb usb1: Product: EHCI Host Controller
[ 0.916071] usb usb1: Manufacturer: Linux 3.2.0-4-amd64 ehci_hcd
[ 0.916073] usb usb1: SerialNumber: 0000:00:1a.7
[ 0.916313] hub 1-0:1.0: USB hub found
[ 0.916318] hub 1-0:1.0: 6 ports detected
[ 0.916464] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 0.916468] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 0.916478] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 0.916514] ehci_hcd 0000:00:1d.7: debug port 1
[ 0.920398] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 0.920418] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfe7ff800
[ 0.924595] pata_marvell 0000:03:00.0: setting latency timer to 64
[ 0.924619] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.924893] scsi0 : pata_marvell
[ 0.924989] scsi1 : pata_marvell
[ 0.925052] ata1: PATA max UDMA/100 cmd 0xdc00 ctl 0xd880 bmdma 0xd400 irq 16
[ 0.925054] ata2: DUMMY
[ 0.931717] FDC 0 is a post-1991 82077
[ 0.936046] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.936081] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.936085] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.936088] usb usb2: Product: EHCI Host Controller
[ 0.936091] usb usb2: Manufacturer: Linux 3.2.0-4-amd64 ehci_hcd
[ 0.936094] usb usb2: SerialNumber: 0000:00:1d.7
[ 0.936256] hub 2-0:1.0: USB hub found
[ 0.936261] hub 2-0:1.0: 6 ports detected
[ 0.936343] ata_piix 0000:00:1f.2: version 2.13
[ 0.936365] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 0.936411] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 0.936764] scsi2 : ata_piix
[ 0.936833] scsi3 : ata_piix
[ 0.938156] ata3: SATA max UDMA/133 cmd 0x9000 ctl 0x8c00 bmdma 0x8480 irq 22
[ 0.938161] ata4: SATA max UDMA/133 cmd 0x8880 ctl 0x8800 bmdma 0x8488 irq 22
[ 0.938183] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 0.938238] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 0.938524] scsi4 : ata_piix
[ 0.938605] scsi5 : ata_piix
[ 0.939756] ata5: SATA max UDMA/133 cmd 0xa000 ctl 0x9c00 bmdma 0x9480 irq 22
[ 0.939760] ata6: SATA max UDMA/133 cmd 0x9880 ctl 0x9800 bmdma 0x9488 irq 22
[ 0.939792] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 0.939796] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 0.939806] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 0.939834] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000a800
[ 0.939868] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.939870] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.939873] usb usb3: Product: UHCI Host Controller
[ 0.939875] usb usb3: Manufacturer: Linux 3.2.0-4-amd64 uhci_hcd
[ 0.939876] usb usb3: SerialNumber: 0000:00:1a.0
[ 0.939993] hub 3-0:1.0: USB hub found
[ 0.939997] hub 3-0:1.0: 2 ports detected
[ 0.940097] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 0.940100] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 0.940113] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 0.940142] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000a880
[ 0.940176] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.940178] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.940181] usb usb4: Product: UHCI Host Controller
[ 0.940182] usb usb4: Manufacturer: Linux 3.2.0-4-amd64 uhci_hcd
[ 0.940185] usb usb4: SerialNumber: 0000:00:1a.1
[ 0.940292] hub 4-0:1.0: USB hub found
[ 0.940296] hub 4-0:1.0: 2 ports detected
[ 0.940380] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[ 0.940383] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 0.940390] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[ 0.940412] uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000ac00
[ 0.940442] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.940445] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.940447] usb usb5: Product: UHCI Host Controller
[ 0.940449] usb usb5: Manufacturer: Linux 3.2.0-4-amd64 uhci_hcd
[ 0.940451] usb usb5: SerialNumber: 0000:00:1a.2
[ 0.940552] hub 5-0:1.0: USB hub found
[ 0.940556] hub 5-0:1.0: 2 ports detected
[ 0.940639] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.940642] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.940648] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[ 0.940669] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000a080
[ 0.940699] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.940702] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.940704] usb usb6: Product: UHCI Host Controller
[ 0.940706] usb usb6: Manufacturer: Linux 3.2.0-4-amd64 uhci_hcd
[ 0.940708] usb usb6: SerialNumber: 0000:00:1d.0
[ 0.940812] hub 6-0:1.0: USB hub found
[ 0.940821] hub 6-0:1.0: 2 ports detected
[ 0.940902] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.940905] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.940912] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[ 0.940943] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000a400
[ 0.940973] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.940975] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.940977] usb usb7: Product: UHCI Host Controller
[ 0.940979] usb usb7: Manufacturer: Linux 3.2.0-4-amd64 uhci_hcd
[ 0.940981] usb usb7: SerialNumber: 0000:00:1d.1
[ 0.941087] hub 7-0:1.0: USB hub found
[ 0.941095] hub 7-0:1.0: 2 ports detected
[ 0.941180] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.941183] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.941190] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[ 0.941210] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000a480
[ 0.941241] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.941244] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.941246] usb usb8: Product: UHCI Host Controller
[ 0.941248] usb usb8: Manufacturer: Linux 3.2.0-4-amd64 uhci_hcd
[ 0.941250] usb usb8: SerialNumber: 0000:00:1d.2
[ 0.941355] hub 8-0:1.0: USB hub found
[ 0.941364] hub 8-0:1.0: 2 ports detected
[ 0.980076] firewire_ohci: Added fw-ohci device 0000:05:03.0, OHCI v1.10, 4 IR + 8 IT contexts, quirks 0x11
[ 1.270674] ata5: SATA link down (SStatus 0 SControl 300)
[ 1.416058] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.424253] ata6.00: ATA-7: SAMSUNG HD322HJ, 1AC01109, max UDMA7
[ 1.424259] ata6.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.432252] ata6.00: configured for UDMA/133
[ 1.480137] firewire_core: created device fw0: GUID 001e8c0001227e8f, S400
[ 1.632023] usb 3-2: new full-speed USB device number 2 using uhci_hcd
[ 1.656024] Refined TSC clocksource calibration: 2405.454 MHz.
[ 1.656029] Switching to clocksource tsc
[ 1.732066] ata3.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.732080] ata3.01: SATA link down (SStatus 0 SControl 300)
[ 1.732092] ata3.01: link offline, clearing class 3 to NONE
[ 1.736068] ata4.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.736080] ata4.01: SATA link down (SStatus 0 SControl 300)
[ 1.740127] ata3.00: ATAPI: PIONEER DVD-RW DVR-215, 1.19, max UDMA/66
[ 1.744238] ata4.00: ATA-7: SAMSUNG HD322HJ, 1AC01113, max UDMA7
[ 1.744243] ata4.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.752243] ata4.00: configured for UDMA/133
[ 1.756152] ata3.00: configured for UDMA/66
[ 1.780229] scsi 2:0:0:0: CD-ROM PIONEER DVD-RW DVR-215 1.19 PQ: 0 ANSI: 5
[ 1.780527] scsi 3:0:0:0: Direct-Access ATA SAMSUNG HD322HJ 1AC0 PQ: 0 ANSI: 5
[ 1.780764] scsi 5:0:0:0: Direct-Access ATA SAMSUNG HD322HJ 1AC0 PQ: 0 ANSI: 5
[ 1.798247] sr0: scsi3-mmc drive: 12x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.798252] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.798426] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 1.798612] sd 3:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 1.798680] sd 3:0:0:0: [sda] Write Protect is off
[ 1.798683] sd 3:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.798707] sd 3:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.798737] sd 5:0:0:0: [sdb] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 1.798802] sd 5:0:0:0: [sdb] Write Protect is off
[ 1.798805] sd 5:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.798833] sd 5:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.800465] sr 2:0:0:0: Attached scsi generic sg0 type 5
[ 1.800504] sd 3:0:0:0: Attached scsi generic sg1 type 0
[ 1.800541] sd 5:0:0:0: Attached scsi generic sg2 type 0
[ 1.805671] sdb: sdb1 sdb2
[ 1.805993] sd 5:0:0:0: [sdb] Attached SCSI disk
[ 1.826305] sda: sda1 sda2 < sda5 sda6 >
[ 1.826695] sd 3:0:0:0: [sda] Attached SCSI disk
[ 1.836894] usb 3-2: New USB device found, idVendor=093a, idProduct=2600
[ 1.836897] usb 3-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.084051] usb 5-1: new low-speed USB device number 2 using uhci_hcd
[ 2.263452] usb 5-1: New USB device found, idVendor=046d, idProduct=c312
[ 2.263456] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.263460] usb 5-1: Product: USB Multimedia Keyboard
[ 2.263463] usb 5-1: Manufacturer: LITEON Technology
[ 2.319711] input: LITEON Technology USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.0/input/input0
[ 2.319794] generic-usb 0003:046D:C312.0001: input,hidraw0: USB HID v1.10 Keyboard [LITEON Technology USB Multimedia Keyboard] on usb-0000:00:1a.2-1/input0
[ 2.319816] usbcore: registered new interface driver usbhid
[ 2.319818] usbhid: USB HID core driver
[ 2.504026] usb 5-2: new low-speed USB device number 3 using uhci_hcd
[ 2.673722] PM: Starting manual resume from disk
[ 2.673725] PM: Hibernation image partition 8:5 present
[ 2.673727] PM: Looking for hibernation image.
[ 2.673914] PM: Image not found (code -22)
[ 2.673918] PM: Hibernation image not present or could not be loaded.
[ 2.677459] usb 5-2: New USB device found, idVendor=13ee, idProduct=0003
[ 2.677463] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.677465] usb 5-2: Product: Optical Mouse
[ 2.677467] usb 5-2: Manufacturer: MosArt
[ 2.693695] input: MosArt Optical Mouse as /devices/pci0000:00/0000:00:1a.2/usb5/5-2/5-2:1.0/input/input1
[ 2.693787] generic-usb 0003:13EE:0003.0002: input,hidraw1: USB HID v1.10 Mouse [MosArt Optical Mouse] on usb-0000:00:1a.2-2/input0
[ 2.705362] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.937850] udevd[373]: starting version 175
[ 4.410414] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 4.410421] ACPI: Power Button [PWRB]
[ 4.410482] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 4.410486] ACPI: Power Button [PWRF]
[ 4.604374] coretemp coretemp.0: Using relative temperature scale!
[ 4.604394] coretemp coretemp.0: Using relative temperature scale!
[ 4.604413] coretemp coretemp.0: Using relative temperature scale!
[ 4.604440] coretemp coretemp.0: Using relative temperature scale!
[ 4.713561] ACPI: Requesting acpi_cpufreq
[ 4.736764] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 4.758825] iTCO_vendor_support: vendor-support=0
[ 4.770177] ACPI: resource 0000:00:1f.3 [io 0x0400-0x041f] conflicts with ACPI region SMRG [io 0x400-0x40f]
[ 4.770180] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 4.800639] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 4.800748] iTCO_wdt: Found a ICH9R TCO device (Version=2, TCOBASE=0x0860)
[ 4.800814] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 4.913460] [drm] Initialized drm 1.1.0 20060810
[ 4.939505] snd_hda_intel 0000:00:1b.0: irq 45 for MSI/MSI-X
[ 4.939530] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 4.985403] [drm] radeon kernel modesetting enabled.
[ 5.005540] radeon 0000:01:00.0: setting latency timer to 64
[ 5.005552] [drm] initializing kernel modesetting (RV770 0x1002:0x9442 0x1043:0x036E).
[ 5.005579] [drm] register mmio base: 0xFE8E0000
[ 5.005582] [drm] register mmio size: 65536
[ 5.005806] ATOM BIOS: 9442.11.13.0.2.AS06
[ 5.005828] radeon 0000:01:00.0: VRAM: 1024M 0x0000000000000000 - 0x000000003FFFFFFF (1024M used)
[ 5.005832] radeon 0000:01:00.0: GTT: 512M 0x0000000040000000 - 0x000000005FFFFFFF
[ 5.005840] mtrr: type mismatch for d0000000,10000000 old: write-back new: write-combining
[ 5.005843] [drm] Detected VRAM RAM=1024M, BAR=256M
[ 5.005846] [drm] RAM width 256bits DDR
[ 5.005900] [TTM] Zone kernel: Available graphics memory: 2030416 kiB
[ 5.005902] [TTM] Initializing pool allocator
[ 5.005910] [TTM] Initializing DMA pool allocator
[ 5.005934] [drm] radeon: 1024M of VRAM memory ready
[ 5.005937] [drm] radeon: 512M of GTT memory ready.
[ 5.005957] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 5.006741] [drm] radeon: ib pool ready.
[ 5.006865] [drm] Loading RV770 Microcode
[ 5.161688] hda_codec: ALC883: BIOS auto-probing.
[ 5.164294] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input5
[ 5.170590] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 5.171805] platform radeon_cp.0: firmware: agent loaded radeon/RV770_pfp.bin into memory
[ 5.219228] platform radeon_cp.0: firmware: agent loaded radeon/RV770_me.bin into memory
[ 5.271883] platform radeon_cp.0: firmware: agent loaded radeon/R700_rlc.bin into memory
[ 5.273632] [drm] PCIE GART of 512M enabled (table at 0x0000000000040000).
[ 5.273683] radeon 0000:01:00.0: WB enabled
[ 5.273686] [drm] fence driver on ring 0 use gpu addr 0x40000c00 and cpu addr 0xffff8801294f7c00
[ 5.273690] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 5.273691] [drm] Driver supports precise vblank timestamp query.
[ 5.273729] radeon 0000:01:00.0: irq 46 for MSI/MSI-X
[ 5.273734] radeon 0000:01:00.0: radeon: using MSI.
[ 5.273762] [drm] radeon: irq initialized.
[ 5.319899] [drm] ring test on 0 succeeded in 1 usecs
[ 5.320286] [drm] ib test on ring 0 succeeded in 0 usecs
[ 5.320560] [drm] Radeon Display Connectors
[ 5.320562] [drm] Connector 0:
[ 5.320563] [drm] HDMI-A
[ 5.320565] [drm] HPD1
[ 5.320567] [drm] DDC: 0x7e60 0x7e60 0x7e64 0x7e64 0x7e68 0x7e68 0x7e6c 0x7e6c
[ 5.320568] [drm] Encoders:
[ 5.320570] [drm] DFP1: INTERNAL_UNIPHY
[ 5.320571] [drm] Connector 1:
[ 5.320573] [drm] VGA
[ 5.320575] [drm] DDC: 0x7e60 0x7e60 0x7e64 0x7e64 0x7e68 0x7e68 0x7e6c 0x7e6c
[ 5.320577] [drm] Encoders:
[ 5.320578] [drm] CRT2: INTERNAL_KLDSCP_DAC2
[ 5.320580] [drm] Connector 2:
[ 5.320581] [drm] DVI-I
[ 5.320582] [drm] HPD2
[ 5.320584] [drm] DDC: 0x7e20 0x7e20 0x7e24 0x7e24 0x7e28 0x7e28 0x7e2c 0x7e2c
[ 5.320585] [drm] Encoders:
[ 5.320587] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 5.320588] [drm] DFP2: INTERNAL_KLDSCP_LVTMA
[ 5.320613] [drm] Internal thermal controller with fan control
[ 5.320676] [drm] radeon: power management initialized
[ 5.470922] [drm] fb mappable at 0xD0142000
[ 5.470925] [drm] vram apper at 0xD0000000
[ 5.470926] [drm] size 8294400
[ 5.470928] [drm] fb depth is 24
[ 5.470929] [drm] pitch is 7680
[ 5.471042] fbcon: radeondrmfb (fb0) is primary device
[ 5.772505] Linux media interface: v0.10
[ 5.796358] Linux video capture interface: v2.00
[ 5.808357] gspca_main: v2.14.0 registered
[ 5.834326] gspca_main: pac7311-2.14.0 probing 093a:2600
[ 5.844973] input: pac7311 as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/input/input7
[ 5.845132] usbcore: registered new interface driver pac7311
[ 5.910675] Console: switching to colour frame buffer device 160x60
[ 5.917085] fb0: radeondrmfb frame buffer device
[ 5.917088] drm: registered panic notifier
[ 5.917103] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:00.0 on minor 0
[ 5.917258] snd_hda_intel 0000:01:00.1: irq 47 for MSI/MSI-X
[ 5.917292] snd_hda_intel 0000:01:00.1: setting latency timer to 64
[ 5.951239] HDMI status: Codec=0 Pin=3 Presence_Detect=0 ELD_Valid=0
[ 5.951349] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
[ 7.332598] Adding 5859324k swap on /dev/sda5. Priority:-1 extents:1 across:5859324k
[ 7.349795] EXT4-fs (sdb1): re-mounted. Opts: (null)
[ 7.508630] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro
[ 7.586762] loop: module loaded
[ 8.120098] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 8.814631] RPC: Registered named UNIX socket transport module.
[ 8.814635] RPC: Registered udp transport module.
[ 8.814637] RPC: Registered tcp transport module.
[ 8.814640] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 8.853652] FS-Cache: Loaded
[ 8.903997] FS-Cache: Netfs 'nfs' registered for caching
[ 8.918538] Installing knfsd (copyright (C) 1996 [EMAIL="okir@monad.swb.de"]okir@monad.swb.de[/EMAIL]).
[ 11.573716] Bluetooth: Core ver 2.16
[ 11.573740] NET: Registered protocol family 31
[ 11.573743] Bluetooth: HCI device and connection manager initialized
[ 11.573746] Bluetooth: HCI socket layer initialized
[ 11.573749] Bluetooth: L2CAP socket layer initialized
[ 11.573756] Bluetooth: SCO socket layer initialized
[ 11.600498] Bluetooth: RFCOMM TTY layer initialized
[ 11.600504] Bluetooth: RFCOMM socket layer initialized
[ 11.600506] Bluetooth: RFCOMM ver 1.11
[ 11.683786] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.683789] Bluetooth: BNEP filters: protocol multicast
[ 12.374609] sky2 0000:02:00.0: eth0: enabling interface
[ 12.375136] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.065804] sky2 0000:02:00.0: eth0: Link is up at 1000 Mbps, full duplex, flow control both
[ 15.066504] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 18.118227] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 18.445380] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 25.968009] eth0: no IPv6 routers present
[ 1472.127246] sky2 0000:02:00.0: eth0: disabling interface
[ 1474.480855] PM: Marking nosave pages: 000000000009f000 - 0000000000100000
[ 1474.480860] PM: Marking nosave pages: 00000000cff80000 - 0000000100000000
[ 1474.481766] PM: Basic memory bitmaps created
[ 1474.481767] PM: Syncing filesystems ... done.
[ 1474.586018] Freezing user space processes ... (elapsed 0.01 seconds) done.
[ 1474.600096] PM: Preallocating image memory... done (allocated 180296 pages)
[ 1474.739253] PM: Allocated 721184 kbytes in 0.13 seconds (5547.56 MB/s)
[ 1474.739256] Freezing remaining freezable tasks ... (elapsed 0.01 seconds) done.
[ 1474.752333] Suspending console(s) (use no_console_suspend to debug)
[ 1474.752550] sd 5:0:0:0: [sdb] Synchronizing SCSI cache
[ 1474.752680] sd 3:0:0:0: [sda] Synchronizing SCSI cache
[ 1474.752697] i8042 aux 00:0d: wake-up capability disabled by ACPI
[ 1474.752703] i8042 kbd 00:0c: wake-up capability enabled by ACPI
[ 1474.753160] serial 00:0a: disabled
[ 1474.753165] serial 00:0a: wake-up capability disabled by ACPI
[ 1474.760054] ACPI handle has no context!
[ 1474.856099] ACPI handle has no context!
[ 1474.856139] ACPI handle has no context!
[ 1475.184440] PM: freeze of devices complete after 432.098 msecs
[ 1475.184932] PM: late freeze of devices complete after 0.489 msecs
[ 1475.185267] ACPI: Preparing to enter system sleep state S4
[ 1475.185503] PM: Saving platform NVS memory
[ 1475.186087] Disabling non-boot CPUs ...
[ 1475.288029] CPU 1 is now offline
[ 1475.392014] CPU 2 is now offline
[ 1475.496017] CPU 3 is now offline
[ 1475.496450] PM: Creating hibernation image:
[ 1475.500012] PM: Need to copy 189609 pages
[ 1475.500012] PM: Normal pages needed: 189609 + 1024, available pages: 858647
[ 1475.500012] PM: Restoring platform NVS memory
[ 1475.500012] Enabling non-boot CPUs ...
[ 1475.500012] Booting Node 0 Processor 1 APIC 0x1
[ 1475.500012] smpboot cpu 1: start_ip = 9a000
[ 1475.187665] Calibrating delay loop (skipped) already calibrated this CPU
[ 1475.527947] NMI watchdog enabled, takes one hw-pmu counter.
[ 1475.532044] CPU1 is up
[ 1475.532245] Booting Node 0 Processor 2 APIC 0x2
[ 1475.532246] smpboot cpu 2: start_ip = 9a000
[ 1475.289981] Calibrating delay loop (skipped) already calibrated this CPU
[ 1475.563655] NMI watchdog enabled, takes one hw-pmu counter.
[ 1475.564130] CPU2 is up
[ 1475.564347] Booting Node 0 Processor 3 APIC 0x3
[ 1475.564349] smpboot cpu 3: start_ip = 9a000
[ 1475.393708] Calibrating delay loop (skipped) already calibrated this CPU
[ 1475.595849] NMI watchdog enabled, takes one hw-pmu counter.
[ 1475.600062] CPU3 is up
[ 1475.603733] ACPI: Waking up from system sleep state S4
[ 1475.620209] PM: early restore of devices complete after 16.254 msecs
[ 1475.668726] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1475.668741] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 1475.668762] usb usb3: root hub lost power or was reset
[ 1475.668767] usb usb4: root hub lost power or was reset
[ 1475.668778] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[ 1475.668788] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 1475.668801] usb usb5: root hub lost power or was reset
[ 1475.668842] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 1475.668848] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1475.668853] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1475.668883] usb usb6: root hub lost power or was reset
[ 1475.668887] usb usb7: root hub lost power or was reset
[ 1475.668900] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1475.668909] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1475.668929] usb usb8: root hub lost power or was reset
[ 1475.668931] snd_hda_intel 0000:00:1b.0: irq 45 for MSI/MSI-X
[ 1475.668954] pci 0000:00:1e.0: setting latency timer to 64
[ 1475.668969] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1475.668975] radeon 0000:01:00.0: setting latency timer to 64
[ 1475.668978] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 1475.668996] snd_hda_intel 0000:01:00.1: setting latency timer to 64
[ 1475.669016] pata_marvell 0000:03:00.0: setting latency timer to 64
[ 1475.669068] snd_hda_intel 0000:01:00.1: irq 47 for MSI/MSI-X
[ 1475.669119] usb usb1: root hub lost power or was reset
[ 1475.670717] usb usb2: root hub lost power or was reset
[ 1475.672528] sd 3:0:0:0: [sda] Starting disk
[ 1475.672584] sd 5:0:0:0: [sdb] Starting disk
[ 1475.672996] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported
[ 1475.674612] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 1475.674924] serial 00:0a: activated
[ 1475.674939] i8042 kbd 00:0c: wake-up capability disabled by ACPI
[ 1475.707126] [drm] PCIE GART of 512M enabled (table at 0x0000000000933000).
[ 1475.707191] radeon 0000:01:00.0: WB enabled
[ 1475.707194] [drm] fence driver on ring 0 use gpu addr 0x40000c00 and cpu addr 0xffff8801294f7c00
[ 1475.736091] firewire_core: skipped bus generations, destroying all nodes
[ 1475.752984] [drm] ring test on 0 succeeded in 1 usecs
[ 1475.753004] [drm] ib test on ring 0 succeeded in 0 usecs
[ 1476.006616] ata5: SATA link down (SStatus 0 SControl 300)
[ 1476.140023] usb 3-2: reset full-speed USB device number 2 using uhci_hcd
[ 1476.148348] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1476.156140] ata6.00: ACPI cmd ef/03:45:00:00:00:a0 (SET FEATURES) filtered out
[ 1476.156144] ata6.00: ACPI cmd ef/03:0c:00:00:00:a0 (SET FEATURES) filtered out
[ 1476.156258] ata6.00: ACPI cmd c6/00:10:00:00:00:a0 (SET MULTIPLE MODE) succeeded
[ 1476.156264] ata6.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1476.172257] ata6.00: configured for UDMA/133
[ 1476.236063] firewire_core: rediscovered device fw0
[ 1476.344143] pac7311 3-2:1.0: no reset_resume for driver pac7311?
[ 1476.464070] ata4.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1476.464082] ata4.01: SATA link down (SStatus 0 SControl 300)
[ 1476.468068] ata3.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1476.468081] ata3.01: SATA link down (SStatus 0 SControl 300)
[ 1476.468092] ata3.01: link offline, clearing class 3 to NONE
[ 1476.472135] ata4.00: ACPI cmd ef/03:45:00:00:00:a0 (SET FEATURES) filtered out
[ 1476.472140] ata4.00: ACPI cmd ef/03:0c:00:00:00:a0 (SET FEATURES) filtered out
[ 1476.472249] ata4.00: ACPI cmd c6/00:10:00:00:00:a0 (SET MULTIPLE MODE) succeeded
[ 1476.472254] ata4.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1476.476130] ata3.00: ACPI cmd ef/03:44:00:00:00:a0 (SET FEATURES) filtered out
[ 1476.476134] ata3.00: ACPI cmd ef/03:0c:00:00:00:a0 (SET FEATURES) filtered out
[ 1476.476139] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1476.488250] ata4.00: configured for UDMA/133
[ 1476.492133] ata3.00: configured for UDMA/66
[ 1476.536032] usb 5-1: reset low-speed USB device number 2 using uhci_hcd
[ 1477.084028] usb 5-2: reset low-speed USB device number 3 using uhci_hcd
[ 1477.391431] PM: restore of devices complete after 1722.764 msecs
[ 1477.391476] gspca_main: pac7311-2.14.0 probing 093a:2600
[ 1477.402219] input: pac7311 as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/input/input9
[ 1477.402515] PM: Image restored successfully.
[ 1477.402517] Restarting tasks ... done.
[ 1477.404406] PM: Basic memory bitmaps freed
[ 1477.717017] sky2 0000:02:00.0: eth0: enabling interface
[ 1477.717776] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 1480.182242] sky2 0000:02:00.0: eth0: Link is up at 1000 Mbps, full duplex, flow control both
[ 1480.182941] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 1490.680007] eth0: no IPv6 routers present
[ 9538.805020] Inbound IN=eth0 OUT= MAC=00:1f:c6:37:66:83:fc:94:e3:a2:98:f8:08:00 SRC=206.190.36.51 DST=192.168.0.11 LEN=257 TOS=0x00 PREC=0x40 TTL=36 ID=5606 DF PROTO=TCP SPT=80 DPT=41234 WINDOW=5840 RES=0x00 ACK PSH URGP=0
[ 9674.320337] CPU1: Core temperature above threshold, cpu clock throttled (total events = 1)
[ 9674.320817] CPU1: Core temperature/speed normal
[ 9680.227602] CPU2: Core temperature above threshold, cpu clock throttled (total events = 1)
[ 9680.228088] CPU2: Core temperature/speed normal
[ 9875.780017] [Hardware Error]: Machine check events logged
[ 9974.320982] CPU1: Core temperature/speed normal
[ 9974.973959] CPU0: Core temperature/speed normal
[ 9983.438188] CPU2: Core temperature above threshold, cpu clock throttled (total events = 51883)
[ 9983.438671] CPU2: Core temperature/speed normal
[10025.780076] [Hardware Error]: Machine check events logged
[10283.472764] CPU2: Core temperature above threshold, cpu clock throttled (total events = 131205)
[10283.473249] CPU2: Core temperature/speed normal
[10475.792020] [Hardware Error]: Machine check events logged
[10575.362593] CPU0: Core temperature above threshold, cpu clock throttled (total events = 223919)
[10575.363078] CPU0: Core temperature/speed normal
[10583.481682] CPU2: Core temperature above threshold, cpu clock throttled (total events = 194129)
[10583.482166] CPU2: Core temperature/speed normal
[10625.792019] [Hardware Error]: Machine check events logged
[10875.360909] CPU0: Core temperature/speed normal
[11065.926856] Inbound IN=eth0 OUT= MAC=00:1f:c6:37:66:83:fc:94:e3:a2:98:f8:08:00 SRC=206.190.36.51 DST=192.168.0.11 LEN=257 TOS=0x00 PREC=0x40 TTL=36 ID=39502 DF PROTO=TCP SPT=80 DPT=41444 WINDOW=5840 RES=0x00 ACK PSH URGP=0
[11075.804016] [Hardware Error]: Machine check events logged
[11175.360460] CPU0: Core temperature above threshold, cpu clock throttled (total events = 414613)
[11175.360483] CPU0: Core temperature/speed normal
[11175.405585] CPU1: Core temperature above threshold, cpu clock throttled (total events = 411999)
[11183.512640] CPU2: Core temperature/speed normal
[11225.807919] [Hardware Error]: Machine check events logged
[11475.540564] CPU1: Core temperature above threshold, cpu clock throttled (total events = 515306)
[11475.541045] CPU1: Core temperature/speed normal
[11485.239807] CPU2: Core temperature above threshold, cpu clock throttled (total events = 482772)
[11485.240297] CPU2: Core temperature/speed normal
[11699.816033] [Hardware Error]: Machine check events logged
[11775.540314] CPU1: Core temperature/speed normal
[11775.588619] CPU0: Core temperature above threshold, cpu clock throttled (total events = 594219)
[11775.589104] CPU0: Core temperature/speed normal
[11788.609584] CPU2: Core temperature above threshold, cpu clock throttled (total events = 578483)
[11788.610070] CPU2: Core temperature/speed normal
[11849.816016] [Hardware Error]: Machine check events logged
[12088.956986] CPU2: Core temperature above threshold, cpu clock throttled (total events = 654561)
[12088.957470] CPU2: Core temperature/speed normal
[12350.780031] [Hardware Error]: Machine check events logged
[12375.548387] CPU1: Core temperature above threshold, cpu clock throttled (total events = 743758)
[12375.640809] CPU0: Core temperature/speed normal
[12389.029098] CPU2: Core temperature above threshold, cpu clock throttled (total events = 727528)
[12389.029582] CPU2: Core temperature/speed normal
[12500.780036] [Hardware Error]: Machine check events logged
[12675.651480] CPU0: Core temperature above threshold, cpu clock throttled (total events = 886229)
[12689.037608] CPU2: Core temperature above threshold, cpu clock throttled (total events = 782709)
[12689.038092] CPU2: Core temperature/speed normal
[12975.908032] CPU0: Core temperature above threshold, cpu clock throttled (total events = 992826)
[12975.908512] CPU0: Core temperature/speed normal
[12989.361034] CPU2: Core temperature above threshold, cpu clock throttled (total events = 838221)
[12989.361523] CPU2: Core temperature/speed normal
[13036.810798] Inbound IN=eth0 OUT= MAC=00:1f:c6:37:66:83:fc:94:e3:a2:98:f8:08:00 SRC=206.190.36.51 DST=192.168.0.11 LEN=257 TOS=0x00 PREC=0x40 TTL=36 ID=30751 DF PROTO=TCP SPT=80 DPT=41631 WINDOW=5840 RES=0x00 ACK PSH URGP=0
[13276.290563] CPU0: Core temperature above threshold, cpu clock throttled (total events = 1101818)
[13276.291048] CPU0: Core temperature/speed normal
[13289.705659] CPU2: Core temperature above threshold, cpu clock throttled (total events = 900844)
[13289.706144] CPU2: Core temperature/speed normal
[14964.365408] CPU2: Core temperature above threshold, cpu clock throttled (total events = 929211)
[14964.365892] CPU2: Core temperature/speed normal
[14974.830576] CPU0: Core temperature above threshold, cpu clock throttled (total events = 1137778)
[14974.831061] CPU0: Core temperature/speed normal
[15264.376100] CPU2: Core temperature above threshold, cpu clock throttled (total events = 970902)
[15264.376584] CPU2: Core temperature/speed normal
[15274.832691] CPU0: Core temperature above threshold, cpu clock throttled (total events = 1211593)
[15274.908013] CPU1: Core temperature above threshold, cpu clock throttled (total events = 1079832)
[15274.908499] CPU1: Core temperature/speed normal
[15564.481847] CPU2: Core temperature above threshold, cpu clock throttled (total events = 1050345)
[15564.482330] CPU2: Core temperature/speed normal
[15574.838017] CPU0: Core temperature above threshold, cpu clock throttled (total events = 1315693)
[15574.855685] CPU0: Core temperature/speed normal
[15864.860852] CPU2: Core temperature above threshold, cpu clock throttled (total events = 1168810)
[15864.861335] CPU2: Core temperature/speed normal
[15874.852353] CPU0: Core temperature above threshold, cpu clock throttled (total events = 1463481)
[16118.376051] Inbound IN=eth0 OUT= MAC=00:1f:c6:37:66:83:fc:94:e3:a2:98:f8:08:00 SRC=206.190.36.51 DST=192.168.0.11 LEN=257 TOS=0x00 PREC=0x20 TTL=47 ID=44237 DF PROTO=TCP SPT=80 DPT=42314 WINDOW=5840 RES=0x00 ACK PSH URGP=0 Pytanie: czy to może być wina braku lub złych sterowników ACPI, czy na 100% faktycznie mam problem z chłodzeniem i trzeb zajrzeć w bebechy?
Domyślam się, że grafika się mocniej może grzać skoro mam włączoną akcelerację sprzętową, ale czy na gierce we flashu mogłoby ją aż tak obciążać?
