Domowy serwer ftp
jacekj11
Domowy serwer ftp
Post autor: jacekj11 »
Zrobiłem sobie serwer ftp na prywatnym adresie 192.168.0.111. Mogę się na niego logować z konta użytkownika i z tego konta mam dostęp jedynie do folderu tego użytkownika ale nie mogę się zalogować na serwer z konta roota. Proszę, napiszcie co mam zrobić żeby mieć dostęp do serwera jako root do każdego pliku, oto moja konfiguracja pliku /etc/proftpd/proftpd.conf
# # /etc/proftpd/proftpd.conf -- This is a basic ProFTPD configuration file.
 # To really apply changes, reload proftpd after modifications, if
 # it runs in daemon mode. It is not required in inetd/xinetd mode.
 #   # Includes DSO modules Include /etc/proftpd/modules.conf
  # Set off to disable IPv6 support which is annoying on IPv4 only boxes.
 UseIPv6                 off
 # If set on you can experience a longer connection delay in many cases.
 IdentLookups            off
  ServerName            "Debian"
 ServerType            standalone
 DeferWelcome            off
  MultilineRFC2228        on
 DefaultServer            on
 ShowSymlinks            on
  TimeoutNoTransfer        600
 TimeoutStalled            600
 TimeoutIdle            1200
  DisplayLogin                    welcome.msg
 DisplayChdir                   .message true
 ListOptions                    "-l"
  DenyFilter            \*.*/
  # Use this to jail all users in their homes
  # DefaultRoot            ~
  # Users require a valid shell listed in /etc/shells to login.
 # Use this directive to release that constrain.
 # RequireValidShell        off
  # Port 21 is the standard FTP port.
 Port                21
  # In some cases you have to specify passive ports range to by-pass
 # firewall limitations. Ephemeral ports can be used for that, but
 # feel free to use a more narrow range.
 # PassivePorts                  49152 65534
  # If your host was NATted, this option is useful in order to
 # allow passive tranfers to work. You have to use your public
 # address and opening the passive ports used on your firewall as well.
 # MasqueradeAddress        1.2.3.4
  # This is useful for masquerading address with dynamic IPs:
 # refresh any configured MasqueradeAddress directives every 8 hours <IfModule mod_dynmasq.c>
 # DynMasqRefresh 28800 </IfModule>
  # To prevent DoS attacks, set the maximum number of child processes
 # to 30.  If you need to allow more than 30 concurrent connections
 # at once, simply increase this value.  Note that this ONLY works
 # in standalone mode, in inetd mode you should use an inetd server
 # that allows you to limit maximum number of processes per service
 # (such as xinetd) MaxInstances            30
  # Set the user and group that the server normally runs at.
 User                proftpd
 Group                nogroup
  # Umask 022 is a good standard umask to prevent new files and dirs
 # (second parm) from being group and world writable.
 Umask                022  022
 # Normally, we want files to be overwriteable.
 AllowOverwrite            on
  # Uncomment this if you are using NIS or LDAP via NSS to retrieve passwords:
 # PersistentPasswd        off
  # This is required to use both PAM-based authentication and local passwords
 # AuthOrder            mod_auth_pam.c* mod_auth_unix.c
  # Be warned: use of this directive impacts CPU average load!
 # Uncomment this if you like to see progress and transfer rate with ftpwho
 # in downloads. That is not needed for uploads rates.
 # # UseSendFile            off
  TransferLog /var/log/proftpd/xferlog SystemLog   /var/log/proftpd/proftpd.log
  # Logging onto /var/log/lastlog is enabled but set to off by default #UseLastlog on
  # In order to keep log file dates consistent after chroot, use timezone info
 # from /etc/localtime.  If this is not set, and proftpd is configured to
 # chroot (e.g. DefaultRoot or <Anonymous>), it will use the non-daylight
 # savings timezone regardless of whether DST is in effect.
 #SetEnv TZ :/etc/localtime  <IfModule mod_quotatab.c> QuotaEngine off </IfModule>
  <IfModule mod_ratio.c> Ratios off </IfModule>
   # Delay engine reduces impact of the so-called Timing Attack described in
 # http://www.securityfocus.com/bid/11430/discuss
 # It is on by default.
  <IfModule mod_delay.c> DelayEngine on </IfModule>
  <IfModule mod_ctrls.c>
 ControlsEngine        off
 ControlsMaxClients    2
 ControlsLog           /var/log/proftpd/controls.log
 ControlsInterval      5
 ControlsSocket        /var/run/proftpd/proftpd.sock
 </IfModule>
  <IfModule mod_ctrls_admin.c> AdminControlsEngine off </IfModule>
  # # Alternative authentication frameworks
 # #Include /etc/proftpd/ldap.conf
 #Include /etc/proftpd/sql.conf
  # # This is used for FTPS connections
 # #Include /etc/proftpd/tls.conf
  # # Useful to keep VirtualHost/VirtualRoot directives separated
 # #Include /etc/proftpd/virtuals.conf
  # A basic anonymous configuration, no upload directories.
  # <Anonymous ~ftp>
 #   User                ftp
 #   Group                nogroup
 #   # We want clients to be able to login with "anonymous" as well as "ftp"
 #   UserAlias            anonymous ftp
 #   # Cosmetic changes, all files belongs to ftp user
 #   DirFakeUser    on ftp
 #   DirFakeGroup on ftp
 #  #   RequireValidShell        off
 #  #   # Limit the maximum number of anonymous logins
 #   MaxClients            10
 #  #   # We want 'welcome.msg' displayed at login, and '.message' displayed
 #   # in each newly chdired directory.
 #   DisplayLogin            welcome.msg
 #   DisplayChdir        .message
 #  #   # Limit WRITE everywhere in the anonymous chroot
 #   <Directory *>
 #     <Limit WRITE>
 #       DenyAll
 #     </Limit>
 #   </Directory>
 #  #   # Uncomment this if you're brave.
 #   # <Directory incoming>
 #   #   # Umask 022 is a good standard umask to prevent new files and dirs
 #   #   # (second parm) from being group and world writable.
 #   #   Umask                022  022
 #   #            <Limit READ WRITE>
 #   #            DenyAll
 #   #            </Limit>
 #   #            <Limit STOR>
 #   #            AllowAll
 #   #            </Limit>
 #   # </Directory>
 #  # </Anonymous>
  # Include other custom configuration files Include /etc/proftpd/conf.d/
 <Global>     RequireValidShell off </Global>
  DefaultRoot ~ grupaftp
  <Limit LOGIN>     DenyGroup !grupaftp </Limit>
 RootLogin On
OBROŃCA
Post autor: OBROŃCA »
Moja propozycja utwórz sobie grupę roboczą przykładowo:
# <Anonymous ~ftp> #   User                ftp #   Group                luzak
A następnie dodaj do niej oprócz użytkownika również roota i powinno działać jak tralala, tylko po władowaniu roota zmień mu jeszcze uprawnienia z samego odczytu, na odczyt i zapis.
jacekj11
Ok opanowałem loguję się do FTP jako root, jeszcze chciał bym wiedzieć co w pliku /etc/proftpd/proftpd.conf dodać żeby root miał możliwość dostępu do każdej lokalizacji nie tylko do swojego katalogu.
OBROŃCA
Proces na gniazdach
Nie wiem czy pomoże, ale proponuję wywołać proces na gniazdach:
do/*Wykonuje pętle, do czasu nawiązania połączenia z serwerem*/
result = connect (clientFd, serverSocketAddrPtr, serverLen):
if (result == -1) sleep (1); /* Odczekuj chwilę i spróbuj ponownie*/
while (result == -1)
Odczyt i zapis dla kont przez gniazda:
write (fd, line1, strlen (line1) + 1): /*Zapis pierwszego wiersza*/
write (fd, line2, strlen (line2) + 1): /*Zapis drugiego wiersza*/
Czytanie wierszy przez klientów:
readLine (fd, str)
int fd;
char* str
int n:
n = read (fd,str, 1):
while (n > 0 && *str++ != 0):
return (n > 0):
Taaa.
Czy wiesz że login i hasło do deamona FTP idzie czystym TXT ? Wystarczy że ktoś podsłucha hasło i komputer/serwer masz przejęty :P
O ile w domu takie praktyki są dopuszczalne o tyle poza domem jest wpadka.
A należy uczyć się poprawnego postępowania
Nie bardzo widzę po co chcesz się logować do maszyny jako root za pomocą FTP, to jest nic innego jak proszenie się o kłopoty.
Do tego za pomocą FTP? Nie wiem czy mogłeś wybrać bardziej niewygodną metodę :)
Stanowczo odradzam takie praktyki!
No napisz lepiej co chcesz dokładnie osiągnąć tym "trafionym" pomysłem.
Może da się to osiągnąć innym sposobem niż tym wyżej zaprezentowanym...
jacekj11
Yampress pisze:Taaa.
Bardzo ważna uwaga. Dziękuję. a co do logowania się na FTP jako root chodziło mi o to żeby wrzucać tam pliki z innego kompa ale w tej sytuacji to chyba będzie lepiej ja będę to robił z jakiegoś przenośnego napędu. A serwer ten mam po to bo chcę się trochę podszkolić w lunuxie co prawda na tą chwilę jest mi ta wiedza nie potrzebna ale lepiej umieć zrobić coś niż nie umieć.
pone13
Post autor: pone13 »
jacek spod jakiego klienta chcesz to kopiować? spod linuxa czy spod windowsa na ten serwer linuxowy..
