[ 25.131]
X.Org X Server 1.12.4
Release Date: 2012-08-27
[ 25.131] X Protocol Version 11, Revision 0
[ 25.131] Build Operating System: Linux 3.10-3-amd64 x86_64 Debian
[ 25.131] Current Operating System: Linux eustachy 3.2.0-4-amd64 #1 SMP Debian 3.2.51-1 x86_64
[ 25.131] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-amd64 root=UUID=874486bb-b320-427e-a0ad-d7a1d449074b ro quiet
[ 25.131] Build Date: 21 October 2013 04:49:48PM
[ 25.131] xorg-server 2:1.12.4-6+deb7u1 (Moritz Muehlenhoff <jmm@debian.org>)
[ 25.131] Current version of pixman: 0.30.2
[ 25.131] Before reporting problems, check http://wiki.x.org
[ 25.131] Markers: (--) probed, (**) from config file, (==) default setting,
[ 25.132] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Nov 11 16:25:43 2013
[ 25.176] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 25.312] (==) No Layout section. Using the first Screen section.
[ 25.312] (==) No screen section available. Using defaults.
[ 25.312] (**) |-->Screen "Default Screen Section" (0)
[ 25.312] (**) | |-->Monitor "<default monitor>"
[ 25.313] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 25.313] (==) Automatically adding devices
[ 25.313] (==) Automatically enabling devices
[ 25.372] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 25.372] Entry deleted from font path.
[ 25.387] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 25.387] Entry deleted from font path.
[ 25.387] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 25.387] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 25.387] (II) The server relies on udev to provide the list of input devices.
[ 25.387] (II) Loader magic: 0x7fc9041a3ae0
[ 25.387] (II) Module ABI versions:
[ 25.387] X.Org ANSI C Emulation: 0.4
[ 25.387] X.Org Video Driver: 12.1
[ 25.387] X.Org XInput driver : 16.0
[ 25.387] X.Org Server Extension : 6.0
[ 25.388] (--) PCI:*(0:0:2:0) 8086:0126:17aa:21d0 rev 9, Mem @ 0xf1400000/4194304, 0xe0000000/268435456, I/O @ 0x00006000/64
[ 25.389] (--) PCI: (0:1:0:0) 10de:1057:17aa:21d0 rev 161, Mem @ 0xf0000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x????????/524288
[ 25.389] (II) Open ACPI successful (/var/run/acpid.socket)
[ 25.389] (II) LoadModule: "extmod"
[ 25.615] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 25.697] (II) Module extmod: vendor="X.Org Foundation"
[ 25.697] compiled for 1.12.4, module version = 1.0.0
[ 25.697] Module class: X.Org Server Extension
[ 25.697] ABI class: X.Org Server Extension, version 6.0
[ 25.697] (II) Loading extension SELinux
[ 25.697] (II) Loading extension MIT-SCREEN-SAVER
[ 25.697] (II) Loading extension XFree86-VidModeExtension
[ 25.697] (II) Loading extension XFree86-DGA
[ 25.697] (II) Loading extension DPMS
[ 25.697] (II) Loading extension XVideo
[ 25.697] (II) Loading extension XVideo-MotionCompensation
[ 25.697] (II) Loading extension X-Resource
[ 25.697] (II) LoadModule: "dbe"
[ 25.697] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 25.708] (II) Module dbe: vendor="X.Org Foundation"
[ 25.708] compiled for 1.12.4, module version = 1.0.0
[ 25.708] Module class: X.Org Server Extension
[ 25.708] ABI class: X.Org Server Extension, version 6.0
[ 25.708] (II) Loading extension DOUBLE-BUFFER
[ 25.708] (II) LoadModule: "glx"
[ 25.708] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[ 26.476] (II) Module glx: vendor="NVIDIA Corporation"
[ 26.476] compiled for 4.0.2, module version = 1.0.0
[ 26.476] Module class: X.Org Server Extension
[ 26.476] (II) NVIDIA GLX Module 319.60 Wed Sep 25 14:24:11 PDT 2013
[ 26.499] (II) Loading extension GLX
[ 26.499] (II) LoadModule: "record"
[ 26.499] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 26.526] (II) Module record: vendor="X.Org Foundation"
[ 26.526] compiled for 1.12.4, module version = 1.13.0
[ 26.526] Module class: X.Org Server Extension
[ 26.526] ABI class: X.Org Server Extension, version 6.0
[ 26.526] (II) Loading extension RECORD
[ 26.526] (II) LoadModule: "dri"
[ 26.527] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 26.586] (II) Module dri: vendor="X.Org Foundation"
[ 26.586] compiled for 1.12.4, module version = 1.0.0
[ 26.586] ABI class: X.Org Server Extension, version 6.0
[ 26.586] (II) Loading extension XFree86-DRI
[ 26.586] (II) LoadModule: "dri2"
[ 26.587] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 26.588] (II) Module dri2: vendor="X.Org Foundation"
[ 26.588] compiled for 1.12.4, module version = 1.2.0
[ 26.588] ABI class: X.Org Server Extension, version 6.0
[ 26.588] (II) Loading extension DRI2
[ 26.588] (==) Matched intel as autoconfigured driver 0
[ 26.588] (==) Matched vesa as autoconfigured driver 1
[ 26.588] (==) Matched fbdev as autoconfigured driver 2
[ 26.588] (==) Assigned the driver to the xf86ConfigLayout
[ 26.588] (II) LoadModule: "intel"
[ 26.588] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 26.641] (II) Module intel: vendor="X.Org Foundation"
[ 26.641] compiled for 1.12.3.902, module version = 2.19.0
[ 26.641] Module class: X.Org Video Driver
[ 26.641] ABI class: X.Org Video Driver, version 12.1
[ 26.641] (II) LoadModule: "vesa"
[ 26.641] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 26.667] (II) Module vesa: vendor="X.Org Foundation"
[ 26.667] compiled for 1.12.1, module version = 2.3.1
[ 26.667] Module class: X.Org Video Driver
[ 26.667] ABI class: X.Org Video Driver, version 12.0
[ 26.667] (II) LoadModule: "fbdev"
[ 26.667] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 26.696] (II) Module fbdev: vendor="X.Org Foundation"
[ 26.696] compiled for 1.12.1, module version = 0.4.2
[ 26.696] ABI class: X.Org Video Driver, version 12.0
[ 26.696] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge Desktop (GT1), Sandybridge Desktop (GT2),
Sandybridge Desktop (GT2+), Sandybridge Mobile (GT1),
Sandybridge Mobile (GT2), Sandybridge Mobile (GT2+),
Sandybridge Server, Ivybridge Mobile (GT1), Ivybridge Mobile (GT2),
Ivybridge Desktop (GT1), Ivybridge Desktop (GT2), Ivybridge Server,
Ivybridge Server (GT2)
[ 26.696] (II) VESA: driver for VESA chipsets: vesa
[ 26.696] (II) FBDEV: driver for framebuffer: fbdev
[ 26.696] (++) using VT number 7
[ 26.717] (WW) Falling back to old probe method for vesa
[ 26.717] (WW) Falling back to old probe method for fbdev
[ 26.717] (II) Loading sub module "fbdevhw"
[ 26.717] (II) LoadModule: "fbdevhw"
[ 26.717] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 26.739] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 26.739] compiled for 1.12.4, module version = 0.0.2
[ 26.739] ABI class: X.Org Video Driver, version 12.1
[ 26.739] drmOpenDevice: node name is /dev/dri/card0
[ 26.739] drmOpenDevice: open result is 9, (OK)
[ 26.740] drmOpenByBusid: Searching for BusID pci:0000:00:02.0
[ 26.740] drmOpenDevice: node name is /dev/dri/card0
[ 26.740] drmOpenDevice: open result is 9, (OK)
[ 26.740] drmOpenByBusid: drmOpenMinor returns 9
[ 26.740] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[ 26.740] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 26.740] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 26.740] (==) intel(0): RGB weight 888
[ 26.740] (==) intel(0): Default visual is TrueColor
[ 26.740] (II) intel(0): Integrated Graphics Chipset: Intel(R) Sandybridge Mobile (GT2+)
[ 26.740] (--) intel(0): Chipset: "Sandybridge Mobile (GT2+)"
[ 26.740] (**) intel(0): Relaxed fencing enabled
[ 26.740] (**) intel(0): Wait on SwapBuffers? enabled
[ 26.740] (**) intel(0): Triple buffering? enabled
[ 26.740] (**) intel(0): Framebuffer tiled
[ 26.740] (**) intel(0): Pixmaps tiled
[ 26.740] (**) intel(0): 3D buffers tiled
[ 26.740] (**) intel(0): SwapBuffers wait enabled
[ 26.740] (==) intel(0): video overlay key set to 0x101fe
[ 26.740] (II) intel(0): Output LVDS1 has no monitor section
[ 26.741] (II) intel(0): found backlight control interface /sys/class/backlight/acpi_video1
[ 26.741] (II) intel(0): Output VGA1 has no monitor section
[ 26.741] (II) intel(0): EDID for output LVDS1
[ 26.741] (II) intel(0): Manufacturer: LGD Model: 2e2 Serial#: 0
[ 26.741] (II) intel(0): Year: 2010 Week: 0
[ 26.741] (II) intel(0): EDID Version: 1.3
[ 26.741] (II) intel(0): Digital Display Input
[ 26.741] (II) intel(0): Max Image Size [cm]: horiz.: 31 vert.: 17
[ 26.741] (II) intel(0): Gamma: 2.20
[ 26.741] (II) intel(0): No DPMS capabilities specified
[ 26.741] (II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 26.741] (II) intel(0): First detailed timing is preferred mode
[ 26.741] (II) intel(0): redX: 0.591 redY: 0.348 greenX: 0.340 greenY: 0.558
[ 26.741] (II) intel(0): blueX: 0.157 blueY: 0.129 whiteX: 0.313 whiteY: 0.329
[ 26.741] (II) intel(0): Manufacturer's mask: 0
[ 26.741] (II) intel(0): Supported detailed timing:
[ 26.741] (II) intel(0): clock: 96.0 MHz Image Size: 310 x 174 mm
[ 26.741] (II) intel(0): h_active: 1600 h_sync: 1648 h_sync_end 1680 h_blank_end 1728 h_border: 0
[ 26.741] (II) intel(0): v_active: 900 v_sync: 903 v_sync_end 908 v_blanking: 926 v_border: 0
[ 26.741] (II) intel(0): LG Display
[ 26.741] (II) intel(0): LP140WD2-TLB1
[ 26.741] (II) intel(0): EDID (in hex):
[ 26.741] (II) intel(0): 00ffffffffffff0030e4e20200000000
[ 26.741] (II) intel(0): 00140103801f11780a43459759578e28
[ 26.741] (II) intel(0): 21505400000001010101010101010101
[ 26.741] (II) intel(0): 0101010101018025408060841a303020
[ 26.741] (II) intel(0): 350036ae100000190000000000000000
[ 26.741] (II) intel(0): 00000000000000000000000000fe004c
[ 26.741] (II) intel(0): 4720446973706c61790a2020000000fe
[ 26.741] (II) intel(0): 004c503134305744322d544c42310038
[ 26.741] (II) intel(0): EDID vendor "LGD", prod id 738
[ 26.741] (II) intel(0): Printing DDC gathered Modelines:
[ 26.741] (II) intel(0): Modeline "1600x900"x0.0 96.00 1600 1648 1680 1728 900 903 908 926 -hsync -vsync (55.6 kHz eP)
[ 26.742] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "576x432" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "680x384" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "720x450" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "800x512" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "840x525" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "960x540" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "960x600" (doublescan mode not supported)
[ 26.742] (II) intel(0): Not using default mode "1024x768" (doublescan mode not supported)
[ 26.742] (II) intel(0): Printing probed modes for output LVDS1
[ 26.742] (II) intel(0): Modeline "1600x900"x60.0 96.00 1600 1648 1680 1728 900 903 908 926 -hsync -vsync (55.6 kHz eP)
[ 26.742] (II) intel(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz d)
[ 26.742] (II) intel(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 26.742] (II) intel(0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 26.742] (II) intel(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz d)
[ 26.742] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 26.742] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 26.742] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 26.742] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 26.742] (II) intel(0): EDID for output VGA1
[ 26.742] (II) intel(0): Output LVDS1 connected
[ 26.742] (II) intel(0): Output VGA1 disconnected
[ 26.742] (II) intel(0): Using exact sizes for initial modes
[ 26.742] (II) intel(0): Output LVDS1 using initial mode 1600x900
[ 26.742] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 26.742] (II) intel(0): Kernel page flipping support detected, enabling
[ 26.742] (**) intel(0): Display dimensions: (310, 170) mm
[ 26.742] (**) intel(0): DPI set to (131, 134)
[ 26.742] (II) Loading sub module "fb"
[ 26.742] (II) LoadModule: "fb"
[ 26.742] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 26.775] (II) Module fb: vendor="X.Org Foundation"
[ 26.775] compiled for 1.12.4, module version = 1.0.0
[ 26.775] ABI class: X.Org ANSI C Emulation, version 0.4
[ 26.775] (II) Loading sub module "dri2"
[ 26.775] (II) LoadModule: "dri2"
[ 26.775] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 26.775] (II) Module dri2: vendor="X.Org Foundation"
[ 26.775] compiled for 1.12.4, module version = 1.2.0
[ 26.775] ABI class: X.Org Server Extension, version 6.0
[ 26.776] (II) UnloadModule: "vesa"
[ 26.776] (II) Unloading vesa
[ 26.776] (II) UnloadModule: "fbdev"
[ 26.776] (II) Unloading fbdev
[ 26.776] (II) UnloadSubModule: "fbdevhw"
[ 26.776] (II) Unloading fbdevhw
[ 26.776] (==) Depth 24 pixmap format is 32 bpp
[ 26.776] (II) intel(0): [DRI2] Setup complete
[ 26.776] (II) intel(0): [DRI2] DRI driver: i965
[ 26.776] (II) intel(0): Allocated new frame buffer 1600x900 stride 6656, tiled
[ 26.814] (II) UXA(0): Driver registered support for the following operations:
[ 26.815] (II) solid
[ 26.815] (II) copy
[ 26.815] (II) composite (RENDER acceleration)
[ 26.815] (II) put_image
[ 26.815] (II) get_image
[ 26.815] (==) intel(0): Backing store disabled
[ 26.815] (==) intel(0): Silken mouse enabled
[ 26.815] (II) intel(0): Initializing HW Cursor
[ 26.815] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 26.817] (==) intel(0): DPMS enabled
[ 26.817] (==) intel(0): Intel XvMC decoder enabled
[ 26.817] (II) intel(0): Set up textured video
[ 26.817] (II) intel(0): [XvMC] xvmc_vld driver initialized.
[ 26.817] (II) intel(0): direct rendering: DRI2 Enabled
[ 26.817] (==) intel(0): hotplug detection: "enabled"
[ 26.876] (--) RandR disabled
[ 26.876] (II) Initializing built-in extension Generic Event Extension
[ 26.876] (II) Initializing built-in extension SHAPE
[ 26.876] (II) Initializing built-in extension MIT-SHM
[ 26.876] (II) Initializing built-in extension XInputExtension
[ 26.876] (II) Initializing built-in extension XTEST
[ 26.876] (II) Initializing built-in extension BIG-REQUESTS
[ 26.876] (II) Initializing built-in extension SYNC
[ 26.876] (II) Initializing built-in extension XKEYBOARD
[ 26.876] (II) Initializing built-in extension XC-MISC
[ 26.876] (II) Initializing built-in extension SECURITY
[ 26.876] (II) Initializing built-in extension XINERAMA
[ 26.876] (II) Initializing built-in extension XFIXES
[ 26.876] (II) Initializing built-in extension RENDER
[ 26.876] (II) Initializing built-in extension RANDR
[ 26.876] (II) Initializing built-in extension COMPOSITE
[ 26.876] (II) Initializing built-in extension DAMAGE
[ 26.876] (II) SELinux: Disabled on system
[ 26.898] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[ 26.908] (II) intel(0): Setting screen physical size to 423 x 238
[ 27.337] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[ 27.337] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 27.337] (II) LoadModule: "evdev"
[ 27.337] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 27.351] (II) Module evdev: vendor="X.Org Foundation"
[ 27.351] compiled for 1.12.1, module version = 2.7.0
[ 27.351] Module class: X.Org XInput Driver
[ 27.351] ABI class: X.Org XInput driver, version 16.0
[ 27.351] (II) Using input driver 'evdev' for 'Power Button'
[ 27.351] (**) Power Button: always reports core events
[ 27.351] (**) evdev: Power Button: Device: "/dev/input/event4"
[ 27.351] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 27.351] (--) evdev: Power Button: Found keys
[ 27.351] (II) evdev: Power Button: Configuring as keyboard
[ 27.351] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event4"
[ 27.351] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 27.351] (**) Option "xkb_rules" "evdev"
[ 27.351] (**) Option "xkb_model" "pc105"
[ 27.351] (**) Option "xkb_layout" "pl"
[ 27.391] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[ 27.391] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 27.391] (II) Using input driver 'evdev' for 'Video Bus'
[ 27.391] (**) Video Bus: always reports core events
[ 27.391] (**) evdev: Video Bus: Device: "/dev/input/event8"
[ 27.391] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 27.391] (--) evdev: Video Bus: Found keys
[ 27.391] (II) evdev: Video Bus: Configuring as keyboard
[ 27.391] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8/event8"
[ 27.391] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 27.391] (**) Option "xkb_rules" "evdev"
[ 27.391] (**) Option "xkb_model" "pc105"
[ 27.391] (**) Option "xkb_layout" "pl"
[ 27.392] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[ 27.392] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 27.392] (II) Using input driver 'evdev' for 'Video Bus'
[ 27.392] (**) Video Bus: always reports core events
[ 27.392] (**) evdev: Video Bus: Device: "/dev/input/event9"
[ 27.393] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 27.393] (--) evdev: Video Bus: Found keys
[ 27.393] (II) evdev: Video Bus: Configuring as keyboard
[ 27.393] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/LNXVIDEO:01/input/input9/event9"
[ 27.393] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 27.393] (**) Option "xkb_rules" "evdev"
[ 27.393] (**) Option "xkb_model" "pc105"
[ 27.393] (**) Option "xkb_layout" "pl"
[ 27.394] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[ 27.394] (II) No input driver specified, ignoring this device.
[ 27.394] (II) This device may have been added with another device file.
[ 27.394] (II) config/udev: Adding input device Sleep Button (/dev/input/event3)
[ 27.394] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 27.395] (II) Using input driver 'evdev' for 'Sleep Button'
[ 27.395] (**) Sleep Button: always reports core events
[ 27.395] (**) evdev: Sleep Button: Device: "/dev/input/event3"
[ 27.395] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 27.395] (--) evdev: Sleep Button: Found keys
[ 27.395] (II) evdev: Sleep Button: Configuring as keyboard
[ 27.395] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3/event3"
[ 27.395] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 27.395] (**) Option "xkb_rules" "evdev"
[ 27.395] (**) Option "xkb_model" "pc105"
[ 27.395] (**) Option "xkb_layout" "pl"
[ 27.396] (II) config/udev: Adding input device PIXART USB OPTICAL MOUSE (/dev/input/event1)
[ 27.396] (**) PIXART USB OPTICAL MOUSE: Applying InputClass "evdev pointer catchall"
[ 27.396] (II) Using input driver 'evdev' for 'PIXART USB OPTICAL MOUSE'
[ 27.396] (**) PIXART USB OPTICAL MOUSE: always reports core events
[ 27.396] (**) evdev: PIXART USB OPTICAL MOUSE: Device: "/dev/input/event1"
[ 27.396] (--) evdev: PIXART USB OPTICAL MOUSE: Vendor 0x93a Product 0x2510
[ 27.396] (--) evdev: PIXART USB OPTICAL MOUSE: Found 3 mouse buttons
[ 27.396] (--) evdev: PIXART USB OPTICAL MOUSE: Found scroll wheel(s)
[ 27.396] (--) evdev: PIXART USB OPTICAL MOUSE: Found relative axes
[ 27.396] (--) evdev: PIXART USB OPTICAL MOUSE: Found x and y relative axes
[ 27.396] (II) evdev: PIXART USB OPTICAL MOUSE: Configuring as mouse
[ 27.396] (II) evdev: PIXART USB OPTICAL MOUSE: Adding scrollwheel support
[ 27.396] (**) evdev: PIXART USB OPTICAL MOUSE: YAxisMapping: buttons 4 and 5
[ 27.396] (**) evdev: PIXART USB OPTICAL MOUSE: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 27.397] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input1/event1"
[ 27.397] (II) XINPUT: Adding extended input device "PIXART USB OPTICAL MOUSE" (type: MOUSE, id 10)
[ 27.397] (II) evdev: PIXART USB OPTICAL MOUSE: initialized for relative axes.
[ 27.397] (**) PIXART USB OPTICAL MOUSE: (accel) keeping acceleration scheme 1
[ 27.397] (**) PIXART USB OPTICAL MOUSE: (accel) acceleration profile 0
[ 27.397] (**) PIXART USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[ 27.397] (**) PIXART USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[ 27.398] (II) config/udev: Adding input device PIXART USB OPTICAL MOUSE (/dev/input/mouse0)
[ 27.398] (II) No input driver specified, ignoring this device.
[ 27.398] (II) This device may have been added with another device file.
[ 27.398] (II) config/udev: Adding input device Integrated Camera (/dev/input/event11)
[ 27.398] (**) Integrated Camera: Applying InputClass "evdev keyboard catchall"
[ 27.398] (II) Using input driver 'evdev' for 'Integrated Camera'
[ 27.398] (**) Integrated Camera: always reports core events
[ 27.398] (**) evdev: Integrated Camera: Device: "/dev/input/event11"
[ 27.399] (--) evdev: Integrated Camera: Vendor 0x4f2 Product 0xb221
[ 27.399] (--) evdev: Integrated Camera: Found keys
[ 27.399] (II) evdev: Integrated Camera: Configuring as keyboard
[ 27.399] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.0/input/input11/event11"
[ 27.399] (II) XINPUT: Adding extended input device "Integrated Camera" (type: KEYBOARD, id 11)
[ 27.399] (**) Option "xkb_rules" "evdev"
[ 27.399] (**) Option "xkb_model" "pc105"
[ 27.399] (**) Option "xkb_layout" "pl"
[ 27.400] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event10)
[ 27.400] (II) No input driver specified, ignoring this device.
[ 27.400] (II) This device may have been added with another device file.
[ 27.400] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 27.400] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 27.400] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 27.400] (**) AT Translated Set 2 keyboard: always reports core events
[ 27.400] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[ 27.400] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 27.400] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 27.400] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 27.400] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 27.400] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[ 27.400] (**) Option "xkb_rules" "evdev"
[ 27.400] (**) Option "xkb_model" "pc105"
[ 27.400] (**) Option "xkb_layout" "pl"
[ 27.400] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event7)
[ 27.400] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 27.400] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[ 27.400] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
[ 27.400] (II) LoadModule: "synaptics"
[ 27.401] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 27.465] (II) Module synaptics: vendor="X.Org Foundation"
[ 27.465] compiled for 1.12.4, module version = 1.6.2
[ 27.465] Module class: X.Org XInput Driver
[ 27.465] ABI class: X.Org XInput driver, version 16.0
[ 27.465] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
[ 27.465] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 27.465] (**) Option "Device" "/dev/input/event7"
[ 27.568] (II) synaptics: SynPS/2 Synaptics TouchPad: ignoring touch events for semi-multitouch device
[ 27.568] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5470
[ 27.568] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4498
[ 27.568] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[ 27.568] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[ 27.568] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right double triple
[ 27.568] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[ 27.568] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 27.568] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 27.572] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event7"
[ 27.572] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 13)
[ 27.572] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[ 27.572] (**) synaptics: SynPS/2 Synaptics TouchPad: MaxSpeed is now 1.75
[ 27.572] (**) synaptics: SynPS/2 Synaptics TouchPad: AccelFactor is now 0.040
[ 27.573] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 27.573] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[ 27.573] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 27.573] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 27.573] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 27.573] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[ 27.574] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
[ 27.574] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/event12)
[ 27.574] (**) TPPS/2 IBM TrackPoint: Applying InputClass "evdev pointer catchall"
[ 27.574] (II) Using input driver 'evdev' for 'TPPS/2 IBM TrackPoint'
[ 27.574] (**) TPPS/2 IBM TrackPoint: always reports core events
[ 27.574] (**) evdev: TPPS/2 IBM TrackPoint: Device: "/dev/input/event12"
[ 27.574] (--) evdev: TPPS/2 IBM TrackPoint: Vendor 0x2 Product 0xa
[ 27.574] (--) evdev: TPPS/2 IBM TrackPoint: Found 3 mouse buttons
[ 27.574] (--) evdev: TPPS/2 IBM TrackPoint: Found relative axes
[ 27.574] (--) evdev: TPPS/2 IBM TrackPoint: Found x and y relative axes
[ 27.574] (II) evdev: TPPS/2 IBM TrackPoint: Configuring as mouse
[ 27.574] (**) evdev: TPPS/2 IBM TrackPoint: YAxisMapping: buttons 4 and 5
[ 27.574] (**) evdev: TPPS/2 IBM TrackPoint: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 27.574] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/serio2/input/input12/event12"
[ 27.574] (II) XINPUT: Adding extended input device "TPPS/2 IBM TrackPoint" (type: MOUSE, id 14)
[ 27.575] (II) evdev: TPPS/2 IBM TrackPoint: initialized for relative axes.
[ 27.575] (**) TPPS/2 IBM TrackPoint: (accel) keeping acceleration scheme 1
[ 27.575] (**) TPPS/2 IBM TrackPoint: (accel) acceleration profile 0
[ 27.575] (**) TPPS/2 IBM TrackPoint: (accel) acceleration factor: 2.000
[ 27.575] (**) TPPS/2 IBM TrackPoint: (accel) acceleration threshold: 4
[ 27.575] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/mouse2)
[ 27.576] (II) No input driver specified, ignoring this device.
[ 27.576] (II) This device may have been added with another device file.
[ 27.576] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 27.577] (II) config/udev: Adding input device ThinkPad Extra Buttons (/dev/input/event6)
[ 27.577] (**) ThinkPad Extra Buttons: Applying InputClass "evdev keyboard catchall"
[ 27.577] (II) Using input driver 'evdev' for 'ThinkPad Extra Buttons'
[ 27.577] (**) ThinkPad Extra Buttons: always reports core events
[ 27.577] (**) evdev: ThinkPad Extra Buttons: Device: "/dev/input/event6"
[ 27.577] (--) evdev: ThinkPad Extra Buttons: Vendor 0x17aa Product 0x5054
[ 27.577] (--) evdev: ThinkPad Extra Buttons: Found keys
[ 27.577] (II) evdev: ThinkPad Extra Buttons: Configuring as keyboard
[ 27.578] (**) Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input6/event6"
[ 27.578] (II) XINPUT: Adding extended input device "ThinkPad Extra Buttons" (type: KEYBOARD, id 15)
[ 27.578] (**) Option "xkb_rules" "evdev"
[ 27.578] (**) Option "xkb_model" "pc105"
[ 27.578] (**) Option "xkb_layout" "pl"
[ 27.579] (II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event13)
[ 27.579] (**) ACPI Virtual Keyboard Device: Applying InputClass "evdev keyboard catchall"
[ 27.579] (II) Using input driver 'evdev' for 'ACPI Virtual Keyboard Device'
[ 27.579] (**) ACPI Virtual Keyboard Device: always reports core events
[ 27.579] (**) evdev: ACPI Virtual Keyboard Device: Device: "/dev/input/event13"
[ 27.579] (--) evdev: ACPI Virtual Keyboard Device: Vendor 0 Product 0
[ 27.579] (--) evdev: ACPI Virtual Keyboard Device: Found keys
[ 27.579] (II) evdev: ACPI Virtual Keyboard Device: Configuring as keyboard
[ 27.579] (**) Option "config_info" "udev:/sys/devices/virtual/input/input13/event13"
[ 27.579] (II) XINPUT: Adding extended input device "ACPI Virtual Keyboard Device" (type: KEYBOARD, id 16)
[ 27.579] (**) Option "xkb_rules" "evdev"
[ 27.579] (**) Option "xkb_model" "pc105"
[ 27.579] (**) Option "xkb_layout" "pl"
[ 47.658] (II) intel(0): EDID vendor "LGD", prod id 738
[ 47.658] (II) intel(0): Printing DDC gathered Modelines:
[ 47.658] (II) intel(0): Modeline "1600x900"x0.0 96.00 1600 1648 1680 1728 900 903 908 926 -hsync -vsync (55.6 kHz eP)
[ 51.176] (II) intel(0): EDID vendor "LGD", prod id 738
[ 51.176] (II) intel(0): Printing DDC gathered Modelines:
[ 51.176] (II) intel(0): Modeline "1600x900"x0.0 96.00 1600 1648 1680 1728 900 903 908 926 -hsync -vsync (55.6 kHz eP)
[ 54.230] (II) intel(0): EDID vendor "LGD", prod id 738
[ 54.230] (II) intel(0): Printing DDC gathered Modelines:
[ 54.230] (II) intel(0): Modeline "1600x900"x0.0 96.00 1600 1648 1680 1728 900 903 908 926 -hsync -vsync (55.6 kHz eP)
do Wheezy i dalej Gnome się nie włącza poprawnie. Nie wiem, czy to istotne, ale poniższe komendy nie dają żadnego rezultatu (nic się nie dzieje):
