SDL video target is 'x11'
This system supports the OpenGL extension GL_EXT_framebuffer_object.
This system supports the OpenGL extension GL_EXT_framebuffer_blit.
This system supports the OpenGL extension GL_EXT_framebuffer_multisample.
This system DOES NOT support the OpenGL extension GL_APPLE_fence.
This system DOES NOT support the OpenGL extension GL_NV_fence.
This system supports the OpenGL extension GL_ARB_sync.
This system DOES NOT support the OpenGL extension GL_EXT_draw_buffers2.
Could not find required OpenGL entry point 'glColorMaskIndexedEXT'! Either your video card is unsupported, or your OpenGL driver needs to be updated.
Game removed: AppID 440 "Team Fortress 2", ProcID 4988
Shutting down. . .
unlinked 2 orphaned pipes
CAsyncIOManager: 0 threads terminating. 0 reads, 0 writes, 0 deferrals.
CAsyncIOManager: 12449 single object sleeps, 0 multi object sleeps
CAsyncIOManager: 0 single object alertable sleeps, 2 multi object alertable sleeps
[2013-11-02 10:23:58] Shutdown
Nie mam radeona. Lecz na nvidi w amd64 zawsze są problemy (multiarch)z wersją x32. A to sterowniki instalują się w błędnym katalogu, a to coś podobnego.
Masz multiarch, czy czyste amd64?
