[+] Postfix - 5.1.1 Recipient rejected gmail.com (opendkim, gmail, spf)
lukixx3
Post autor: lukixx3 »
Robię wszystko według instrukcji:
http://sealedabstract.com/code/nsa-proo ... n-2-hours/ (pomijam szyfrowanie).
I dostaję błąd przy wysyłaniu:
5.1.1 Recipient rejected.
Wiadomości też nie dochodzą.
xxx2.pl = moja domena
Oct 30 19:35:36 sunrise postfix/master[15409]: daemon started -- version 2.9.6, configuration /etc/postfix
Oct 30 19:35:36 sunrise postfix/qmgr[15419]: 1ADA733C11BB: from=<xxx@gmail.com>, size=1828, nrcpt=1 (queue active)
Oct 30 19:35:36 sunrise postfix/lmtp[15431]: 1ADA733C11BB: to=<a@xxx2.pl>, relay=none, delay=4358, delays=4358/0.01/0/0, dsn=4.4.1, status=deferre
d (connect to xxx2.pl[private/dovecot-lmtp]: No such file or directory)
Oct 30 19:35:51 sunrise postfix/smtpd[15433]: connect from unknown[x.59.104.236]
Oct 30 19:35:51 sunrise postfix/smtpd[15433]: NOQUEUE: reject: RCPT from unknown[x.59.104.236]: 550 5.1.1 <xxx3@gmail.com>: Recipient address rej
ected: gmail.com; from=<a@xxx2.pl> to=<xxx3@gmail.com> proto=ESMTP helo=<[192.168.0.100]>
Oct 30 19:35:51 sunrise postfix/smtpd[15433]: disconnect from unknown[x.59.104.236]
Oct 30 19:39:01 sunrise /USR/SBIN/CRON[15442]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mind
epth 1 -maxdepth 1 -type f -ignore[I]readdir[/I]race -cmin +$(/usr/lib/php5/maxlifetime) ! -execdir fuser -s {} 2>/dev/null \; -delete)
Oct 30 19:39:01 sunrise postfix/pickup[15418]: AB33833C118B: uid=0 from=<root>
Oct 30 19:39:01 sunrise postfix/cleanup[15450]: AB33833C118B: message-id=<20131030193901.AB33833C118B@xxx2.pl>
Oct 30 19:39:01 sunrise opendkim[14541]: AB33833C118B: no signing table match for 'root@xxxx.serverloft.eu'
Oct 30 19:39:01 sunrise opendkim[14541]: AB33833C118B: no signature data
Oct 30 19:39:01 sunrise postfix/qmgr[15419]: AB33833C118B: from=<root@xxxx.serverloft.eu>, size=861, nrcpt=1 (queue active)
Oct 30 19:39:01 sunrise postfix/error[15454]: AB33833C118B: to=<root@xxxx.serverloft.eu>, orig_to=<root>, relay=none, delay=0.21, delays=0.15/0.01/0/
0.05, dsn=5.0.0, status=bounced (xxxx.serverloft.eu)
Oct 30 19:39:01 sunrise postfix/cleanup[15450]: D26D333C1199: message-id=<20131030193901.D26D333C1199@xxx2.pl>
Oct 30 19:39:01 sunrise postfix/bounce[15455]: AB33833C118B: sender non-delivery notification: D26D333C1199
Oct 30 19:39:01 sunrise postfix/qmgr[15419]: D26D333C1199: from=<>, size=2650, nrcpt=1 (queue active)
Oct 30 19:39:01 sunrise postfix/qmgr[15419]: AB33833C118B: removed
Oct 30 19:39:01 sunrise postfix/error[15454]: D26D333C1199: to=<root@xxxx.serverloft.eu>, relay=none, delay=0.1, delays=0.05/0/0/0.05, dsn=5.0.0, sta
Oct 30 19:39:01 sunrise postfix/qmgr[15419]: D26D333C1199: removed
A PTR dla swojej maszyny ustawiłeś?
lukixx3
Nie wiem co to PTR? DNS i RevDNS są poprawnie ustawione.
Dodatkowo są rekordy TXT:
v=DKIM1; h=rsa-sha256; k=rsa; p=klucz
oraz
v=spf1 include:_spf.google.com ~all
Test:
[TABLE="class: table table-striped table-bordered table-condensed tool-result-table, width: 727"]
[TR]
[TD="bgcolor: #F9F9F9"]SMTP Reverse Banner Check[/TD]
[TD="bgcolor: #F9F9F9"]OK - ip resolves to xxx.pl[/TD]
[/TR]
[TR]
[TD]Obrazek[/TD]
[TD]SMTP Reverse DNS Mismatch[/TD]
[TD]OK - Reverse DNS matches SMTP Banner[/TD]
[/TR]
[TR]
[TD="bgcolor: #F9F9F9"]Obrazek[/TD]
[TD="bgcolor: #F9F9F9"]SMTP TLS[/TD]
[TD="bgcolor: #F9F9F9"]OK - Supports TLS.[/TD]
[/TR]
[TR]
[TD]Obrazek[/TD]
[TD]SMTP Connection Time[/TD]
[TD]1.872 seconds - Good on Connection time[/TD]
[/TR]
[TR]
[TD="bgcolor: #F9F9F9"]SMTP Open Relay[/TD]
[TD="bgcolor: #F9F9F9"]OK - Not an open relay.[/TD]
[/TR]
[TR]
[TD]Obrazek[/TD]
[TD]SMTP Transaction Time[/TD]
[TD]4.415 seconds - Good on Transaction Time[/TD]
[/TR]
[/TABLE]
Wszystko już działa, sam zrobiłem.
