Instalacja sterowników do karty graficznej
mmati
Post autor: mmati »
Witam, na wstępie powiem, iż jestem zielony w temacie Debiana. Zainstalowałem go z racji ćwiczeń w pracowni szkolnej.
Proszę o pomoc jak zainstalować kartę graficzną Radeon HD5500.
Zawartość pliku /var/log/Xorg.0.log
  GNU nano 2.2.6                                           Plik: /var/log/Xorg.0.log
[    17.293]
X.Org X Server 1.12.4
Release Date: 2012-08-27
[    17.294] X Protocol Version 11, Revision 0
[    17.294] Build Operating System: Linux 2.6.32-5-686-bigmem i686 Debian
[    17.294] Current Operating System: Linux debian 3.2.0-4-686-pae #1 SMP Debian 3.2.41-2 i686
[    17.294] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-686-pae root=UUID=92248a01-b581-4297-a2e5-e3765649245a ro initrd=/install/initrd.gz quiet
[    17.294] Build Date: 17 April 2013  11:13:16AM
[    17.294] xorg-server 2:1.12.4-6 (Julien Cristau <jcristau@debian.org>)
[    17.294] Current version of pixman: 0.26.0
[    17.294]    Before reporting problems, check http://wiki.x.org
[    17.294] Markers: (--) probed, (**) from config file, (==) default setting,
[    17.294] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Oct 19 13:27:48 2013
[    17.296] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    17.301] (==) No Layout section.  Using the first Screen section.
[    17.302] (==) No screen section available. Using defaults.
[    17.302] (**) |-->Screen "Default Screen Section" (0)
[    17.302] (**) |   |-->Monitor "<default monitor>"
[    17.303] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[    17.303] (==) Automatically adding devices
[    17.303] (==) Automatically enabling devices
[    17.334] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    17.334]    Entry deleted from font path.
[    17.341] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[    17.341]    Entry deleted from font path.
[    17.341] (==) FontPath set to:
        /usr/share/fonts/X11/misc,
        /usr/share/fonts/X11/Type1,
        /usr/share/fonts/X11/100dpi,
        /usr/share/fonts/X11/75dpi,
        built-ins
[    17.341] (==) ModulePath set to "/usr/lib/xorg/modules"
[    17.341] (II) The server relies on udev to provide the list of input devices.
[    17.341] (II) Loader magic: 0xb773c5a0
[    17.341] (II) Module ABI versions:
[    17.341]    X.Org ANSI C Emulation: 0.4
[    17.341]    X.Org Video Driver: 12.1
[    17.342]    X.Org XInput driver : 16.0
[    17.342]    X.Org Server Extension : 6.0
[    17.343] (--) PCI:*(0:2:0:0) 1002:675f:1458:254b rev 0, Mem @ 0xe0000000/268435456, 0xfbfe0000/131072, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[    17.343] (II) Open ACPI successful (/var/run/acpid.socket)
[    17.343] (II) LoadModule: "extmod"
[    17.345] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[    17.501] (II) Module extmod: vendor="X.Org Foundation"
[    17.501]    compiled for 1.12.4, module version = 1.0.0
[    17.501]    Module class: X.Org Server Extension
[    17.501]    ABI class: X.Org Server Extension, version 6.0
[    17.501] (II) Loading extension SELinux
[    17.501] (II) Loading extension MIT-SCREEN-SAVER
[    17.501] (II) Loading extension XFree86-VidModeExtension
[    17.501] (II) Loading extension XFree86-DGA
[    17.501] (II) Loading extension DPMS
[    17.501] (II) Loading extension XVideo
[    17.501] (II) Loading extension XVideo-MotionCompensation
[    17.501] (II) Loading extension X-Resource
[    17.501] (II) LoadModule: "dbe"
[    17.502] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[    17.564] (II) Module dbe: vendor="X.Org Foundation"
[    17.564]    compiled for 1.12.4, module version = 1.0.0
^G Pomoc                      ^O Zapisz                     ^R Wczyt.plik                 ^Y Poprz.str.                 ^K Wytnij                     ^C Bież.poz.
^X Wyjdź                      ^J Wyjustuj                   ^W Wyszukaj                   ^V Nast.str.                  ^U Wklej                      ^T Pisownia
To nie jest chyba cały log. Jak sytuacja wygląda teraz? Xorg działa? Może wystarczy ci pozostanie na sterownikach otwartych? Zainstaluj pakiet:
[B]f[/B]irmware-linux-nonfree
Edycja: poprawiłem literówkę, dzięki marcin1982.
Oczywiście chodzi o pakiet:
firmware-linux-nonfree
