jak miec direct rendering, chciałem dociagnac do tego compiz-fusiona ale nie moge sobie poradzić z direct renderingiem na intelowską grafike.
driver i810
2.6.21-2-686
gnome
/var/log/Xorg.0.log
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Debian
Current Operating System: Linux debian 2.6.21-2-686 #1 SMP Wed Jul 11 03:53:02 UTC 2007 i686
Build Date: 14 July 2007
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Jul 17 08:23:47 2007
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Generic Monitor"
(**) | |-->Device "Intel Corporation 82852/855GM Integrated Graphics Device"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "Synaptics Touchpad"
Entry deleted from font path.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to "/etc/X11/rgb"
(**) Extension "Composite" is enabled
(**) Extension "RENDER" is enabled
(II) Loader magic: 0x81e50c0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.2
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
compiled for 1.3.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: 00:00:0: chip 8086,3580 card 1043,1897 rev 02 class 06,00,00 hdr 80
(II) PCI: 00:00:1: chip 8086,3584 card 1043,1897 rev 02 class 08,80,00 hdr 00
(II) PCI: 00:00:3: chip 8086,3585 card 1043,1897 rev 02 class 08,80,00 hdr 80
(II) PCI: 00:02:0: chip 8086,3582 card 1043,1712 rev 02 class 03,00,00 hdr 80
(II) PCI: 00:02:1: chip 8086,3582 card 1043,1712 rev 02 class 03,80,00 hdr 80
(II) PCI: 00:1d:0: chip 8086,24c2 card 1043,1897 rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,24c4 card 1043,1897 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,24c7 card 1043,1897 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,24cd card 1043,1897 rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev 83 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,24cc card 0000,0000 rev 03 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,24ca card 1043,1897 rev 03 class 01,01,8a hdr 00
(II) PCI: 00:1f:5: chip 8086,24c5 card 1043,1893 rev 03 class 04,01,00 hdr 00
(II) PCI: 00:1f:6: chip 8086,24c6 card 1043,1826 rev 03 class 07,03,00 hdr 00
(II) PCI: 01:00:0: chip 10ec,8139 card 1043,1045 rev 10 class 02,00,00 hdr 00
(II) PCI: 01:04:0: chip 8086,4220 card 8086,2701 rev 05 class 02,80,00 hdr 00
(II) PCI: 01:05:0: chip 1180,0476 card c000,0000 rev ac class 06,07,00 hdr 82
(II) PCI: 01:05:1: chip 1180,0476 card cc00,0000 rev ac class 06,07,00 hdr 82
(II) PCI: 01:05:2: chip 1180,0552 card 1043,1897 rev 04 class 0c,00,10 hdr 80
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,6), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:30:0), (0,1,9), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 1 I/O range:
[0] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[1] -1 0 0x0000c400 - 0x0000c4ff (0x100) IX[B]
[2] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[3] -1 0 0x0000cc00 - 0x0000ccff (0x100) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xfe800000 - 0xfe8fffff (0x100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xde600000 - 0xde6fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-CardBus bridge:
(II) Bus 2: bridge is at (1:5:0), (1,2,5), BCTRL: 0x0580 (VGA_EN is cleared)
(II) Bus 2 I/O range:
(II) Bus 6: bridge is at (1:5:1), (1,6,9), BCTRL: 0x0580 (VGA_EN is cleared)
(II) Bus 6 I/O range:
[0] -1 0 0x0000cc00 - 0x0000ccff (0x100) IX[B]
(--) PCI:*(0:2:0) Intel Corporation 82852/855GM Integrated Graphics Device rev 2, Mem @ 0xf0000000/27, 0xfeb80000/19, I/O @ 0xdc00/3
(--) PCI: (0:2:1) Intel Corporation 82852/855GM Integrated Graphics Device rev 2, Mem @ 0xe8000000/27, 0xfea80000/19
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xfe8ff800 - 0xfe8fffff (0x800) MX[B]
[1] -1 0 0xfe8fe000 - 0xfe8fefff (0x1000) MX[B]
[2] -1 0 0xfe8ff400 - 0xfe8ff4ff (0x100) MX[B]
[3] -1 0 0x30000600 - 0x300006ff (0x100) MX[B]
[4] -1 0 0x30000400 - 0x300005ff (0x200) MX[B]
[5] -1 0 0x30000000 - 0x300003ff (0x400) MX[B]
[6] -1 0 0xfeb7fc00 - 0xfeb7ffff (0x400) MX[B]
[7] -1 0 0xfea80000 - 0xfeafffff (0x80000) MX[B](B)
[8] -1 0 0xe8000000 - 0xefffffff (0x8000000) MX[B](B)
[9] -1 0 0xfeb80000 - 0xfebfffff (0x80000) MX[B](B)
[10] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
[11] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[12] -1 0 0x0000e300 - 0x0000e37f (0x80) IX[B]
[13] -1 0 0x0000e200 - 0x0000e2ff (0x100) IX[B]
[14] -1 0 0x0000e100 - 0x0000e13f (0x40) IX[B]
[15] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[16] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[17] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[18] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[19] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[20] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[21] -1 0 0x0000d880 - 0x0000d89f (0x20) IX[B]
[22] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[23] -1 0 0x0000d480 - 0x0000d49f (0x20) IX[B]
[24] -1 0 0x0000dc00 - 0x0000dc07 (0x8) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
[0] -1 0 0x00100000 - 0x2fffffff (0x2ff00000) MX[B]E(B)
(II) All system resource ranges:
[4] -1 0 0xfe8ff800 - 0xfe8fffff (0x800) MX[B]
[5] -1 0 0xfe8fe000 - 0xfe8fefff (0x1000) MX[B]
[6] -1 0 0xfe8ff400 - 0xfe8ff4ff (0x100) MX[B]
[7] -1 0 0x30000600 - 0x300006ff (0x100) MX[B]
[8] -1 0 0x30000400 - 0x300005ff (0x200) MX[B]
[9] -1 0 0x30000000 - 0x300003ff (0x400) MX[B]
[10] -1 0 0xfeb7fc00 - 0xfeb7ffff (0x400) MX[B]
[11] -1 0 0xfea80000 - 0xfeafffff (0x80000) MX[B](B)
[12] -1 0 0xe8000000 - 0xefffffff (0x8000000) MX[B](B)
[13] -1 0 0xfeb80000 - 0xfebfffff (0x80000) MX[B](B)
[14] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[18] -1 0 0x0000e300 - 0x0000e37f (0x80) IX[B]
[19] -1 0 0x0000e200 - 0x0000e2ff (0x100) IX[B]
[20] -1 0 0x0000e100 - 0x0000e13f (0x40) IX[B]
[21] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[22] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[23] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[24] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[25] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[26] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[27] -1 0 0x0000d880 - 0x0000d89f (0x20) IX[B]
[28] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[29] -1 0 0x0000d480 - 0x0000d49f (0x20) IX[B]
[30] -1 0 0x0000dc00 - 0x0000dc07 (0x8) IX[B](B)
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "ddc"(II) Module already built-in
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
compiled for 1.3.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
compiled for 1.3.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "i810"
(II) Loading /usr/lib/xorg/modules/drivers//i810_drv.so
(II) Module i810: vendor="X.Org Foundation"
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
compiled for 1.3.0, module version = 1.2.1
ABI class: X.Org XInput driver, version 0.7
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input//synaptics_drv.so
(II) Module synaptics: vendor="X.Org Foundation"
compiled for 4.3.99.902, module version = 1.0.0
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, 965G, 965G, 965Q, 946GZ,
965GM, 965GME/GLE, G33, Q35, Q33
(II) Primary Device is: PCI 00:02:0
(--) Chipset 852GM/855GM found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[15] 1 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[16] 1 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[17] 1 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[20] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[21] -1 0 0x0000e300 - 0x0000e37f (0x80) IX[B]
[22] -1 0 0x0000e200 - 0x0000e2ff (0x100) IX[B]
[23] -1 0 0x0000e100 - 0x0000e13f (0x40) IX[B]
[24] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[25] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[26] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[27] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[28] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[29] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[30] -1 0 0x0000d880 - 0x0000d89f (0x20) IX[B]
[31] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[32] -1 0 0x0000d480 - 0x0000d49f (0x20) IX[B]
[33] -1 0 0x0000dc00 - 0x0000dc07 (0x8) IX[B](B)
[34] 1 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[35] 1 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.1.0
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 0.1.0
(II) intel(0): Creating default Display subsection in Screen section
"Default Screen" for depth/fbbpp 24/32
(**) intel(0): Depth 24, (--) framebuffer bpp 32
(==) intel(0): RGB weight 888
(==) intel(0): Default visual is TrueColor
(II) intel(0): Integrated Graphics Chipset: Intel(R) 855GM
(--) intel(0): Chipset: "852GM/855GM"
(--) intel(0): Linear framebuffer at 0xF0000000
(--) intel(0): IO registers at addr 0xFEB80000
(II) intel(0): 2 display pipes available.
(==) intel(0): Using XAA for acceleration
(--) intel(0): Will try to allocate texture pool for old Mesa 3D driver.
(II) intel(0): Will try to reserve 32768 kiB of AGP aperture space
for the DRM memory manager.
(II) Loading sub module "ddc"
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"(II) Module already built-in
(II) intel(0): Output VGA using monitor section Generic Monitor
(II) intel(0): I2C bus "CRTDDC_A" initialized.
(II) intel(0): Output LVDS has no monitor section
(II) intel(0): I2C bus "LVDSDDC_C" initialized.
(II) intel(0): I2C device "LVDSDDC_C:ddc2" registered at address 0xA0.
(II) intel(0): I2C device "LVDSDDC_C:ddc2" removed.
(II) intel(0): EDID for output LVDS
(II) Reloading /usr/lib/xorg/modules//libint10.so
(II) intel(0): initializing int10
(WW) intel(0): Bad V_BIOS checksum
(II) intel(0): Primary V_BIOS segment is: 0xc000
(II) intel(0): VESA BIOS detected
(II) intel(0): VESA VBE Version 3.0
(II) intel(0): VESA VBE Total Mem: 8000 kB
(II) intel(0): VESA VBE OEM: Intel(r)852GM/852GME/855GM/855GME Graphics Chip Accelerated VGA BIOS
(II) intel(0): VESA VBE OEM Software Rev: 1.0
(II) intel(0): VESA VBE OEM Vendor: Intel Corporation
(II) intel(0): VESA VBE OEM Product: Intel(r)852GM/852GME/855GM/855GME Graphics Controller
(II) intel(0): VESA VBE OEM Product Rev: Hardware Version 0.0
(II) intel(0): I2C bus "DVODDC_D" initialized.
(II) Loading sub module "sil164"
(II) LoadModule: "sil164"
(II) Loading /usr/lib/xorg/modules/drivers//sil164.so
(II) Module sil164: vendor="X.Org Foundation"
(II) intel(0): I2C bus "DVOI2C_E" initialized.
(EE) intel(0): detecting sil164
(EE) intel(0): Unable to read from DVOI2C_E Slave 112.
(II) Loading sub module "ch7xxx"
(II) LoadModule: "ch7xxx"
(II) Loading /usr/lib/xorg/modules/drivers//ch7xxx.so
(II) Module ch7xxx: vendor="X.Org Foundation"
(II) intel(0): I2C bus "DVOI2C_E" removed.
(EE) intel(0): Unable to read from DVOI2C_E Slave 236.
(II) Loading sub module "ivch"
(II) LoadModule: "ivch"
(II) Loading /usr/lib/xorg/modules/drivers//ivch.so
(II) Module ivch: vendor="X.Org Foundation"
(II) intel(0): I2C bus "DVOI2C_B" initialized.
(EE) intel(0): ivch: Unable to read register 0x00 from DVOI2C_B:04.
(II) Loading sub module "tfp410"
(II) LoadModule: "tfp410"
(II) Loading /usr/lib/xorg/modules/drivers//tfp410.so
(II) Module tfp410: vendor="X.Org Foundation"
(II) intel(0): I2C bus "DVOI2C_B" removed.
(II) intel(0): detecting tfp410
(EE) intel(0): tfp410 not detected got VID FFFFFFFF: from DVOI2C_E Slave 112.
(II) intel(0): I2C bus "DVODDC_D" removed.
(II) intel(0): Output VGA disconnected
(II) intel(0): EDID for output VGA
(II) intel(0): Output LVDS connected
(II) intel(0): Not using default mode "1152x864" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1280x960" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1280x1024" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1600x1200" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1792x1344" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1856x1392" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1920x1440" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1280x768" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1280x800" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1152x768" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1400x1050" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1440x900" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1600x1024" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1680x1050" (exceeds panel dimensions)
(II) intel(0): Not using default mode "1920x1200" (exceeds panel dimensions)
(II) intel(0): Not using default mode "2048x1536" (exceeds panel dimensions)
(II) intel(0): Printing probed modes for output LVDS
(II) intel(0): Modeline "1024x768"x60.1 65.14 1024 1048 1184 1344 768 771 777 806 (48.5 kHz)
(II) intel(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz)
(II) intel(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(II) intel(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) intel(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(II) intel(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
(II) intel(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) intel(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) intel(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
(II) intel(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(II) intel(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) intel(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz)
(II) intel(0): Output LVDS using initial mode 1024x768
(II) intel(0): Monitoring connected displays enabled
(II) intel(0): detected 128 kB GTT.
(II) intel(0): detected 8060 kB stolen memory.
(==) intel(0): video overlay key set to 0x101fe
(==) intel(0): Will not try to enable page flipping
(==) intel(0): Triple buffering disabled
(==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
(++) intel(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.2.0
(II) LoadModule: "ramdac"(II) Module already built-in
(II) intel(0): Comparing regs from server start up to After PreInit
(==) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 1 0 0xfeb80000 - 0xfebfffff (0x80000) MS[B]
[1] 1 0 0xf0000000 - 0xf7ffffff (0x8000000) MS[B]
[2] -1 0 0x00100000 - 0x2fffffff (0x2ff00000) MX[B]E(B)
[3] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[4] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[5] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[6] -1 0 0xfe8ff800 - 0xfe8fffff (0x800) MX[B]
[7] -1 0 0xfe8fe000 - 0xfe8fefff (0x1000) MX[B]
[8] -1 0 0xfe8ff400 - 0xfe8ff4ff (0x100) MX[B]
[9] -1 0 0x30000600 - 0x300006ff (0x100) MX[B]
[10] -1 0 0x30000400 - 0x300005ff (0x200) MX[B]
[11] -1 0 0x30000000 - 0x300003ff (0x400) MX[B]
[12] -1 0 0xfeb7fc00 - 0xfeb7ffff (0x400) MX[B]
[13] -1 0 0xfea80000 - 0xfeafffff (0x80000) MX[B](B)
[14] -1 0 0xe8000000 - 0xefffffff (0x8000000) MX[B](B)
[15] -1 0 0xfeb80000 - 0xfebfffff (0x80000) MX[B](B)
[16] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
[17] 1 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[18] 1 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[19] 1 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[20] 1 0 0x0000dc00 - 0x0000dc07 (0x8) IS[B]
[21] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[22] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[23] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[24] -1 0 0x0000e300 - 0x0000e37f (0x80) IX[B]
[25] -1 0 0x0000e200 - 0x0000e2ff (0x100) IX[B]
[26] -1 0 0x0000e100 - 0x0000e13f (0x40) IX[B]
[27] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[28] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[29] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[30] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[31] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[32] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[33] -1 0 0x0000d880 - 0x0000d89f (0x20) IX[B]
[34] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[35] -1 0 0x0000d480 - 0x0000d49f (0x20) IX[B]
[36] -1 0 0x0000dc00 - 0x0000dc07 (0x8) IX[B](B)
[37] 1 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[38] 1 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) intel(0): Kernel reported 174592 total, 1 used
(II) intel(0): I830CheckAvailableMemory: 698364 kB available
(==) intel(0): VideoRam: 131072 KB
(II) intel(0): Attempting memory allocation with tiled buffers and
large DRI memory manager reservation:
(WW) intel(0): xf86AllocateGARTMemory: allocation of 10 pages failed
(Cannot allocate memory)
(II) intel(0): Allocating 5112 scanlines for pixmap cache
(II) intel(0): Success.
(II) intel(0): Memory allocation layout:
(II) intel(0): 0x00000000-0x0001ffff: ring buffer (128 kB)
(II) intel(0): 0x00020000-0x00027fff: logical 3D context (32 kB)
(II) intel(0): 0x00028000-0x00037fff: xaa scratch (64 kB)
(II) intel(0): 0x007df000: end of stolen memory
(II) intel(0): 0x007df000-0x007dffff: Core cursor (4 kB, 0x2c3ba000 physical)
(II) intel(0): 0x007e0000-0x007e3fff: ARGB cursor (16 kB, 0x2be20000 physical)
(II) intel(0): 0x007e4000-0x007e4fff: Core cursor (4 kB, 0x2d130000 physical)
(II) intel(0): 0x007e5000-0x007e8fff: ARGB cursor (16 kB, 0x2be24000 physical)
(II) intel(0): 0x007e9000-0x007e9fff: overlay registers (4 kB, 0x2c3a6000 physical)
(II) intel(0): 0x007f0000-0x01fe7fff: front buffer (24544 kB)
(II) intel(0): 0x02000000-0x023fffff: back buffer (4096 kB)
(II) intel(0): 0x02400000-0x027fffff: depth buffer (4096 kB)
(II) intel(0): 0x02800000-0x047fffff: DRI memory manager (32768 kB)
(II) intel(0): 0x04800000-0x067fffff: textures (32768 kB)
(II) intel(0): 0x08000000: end of aperture
(II) intel(0): front buffer is not tiled
(II) intel(0): back buffer is tiled
(II) intel(0): depth buffer is tiled
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device or address)
drmOpenDevice: Open failed
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenDevice: open result is 8, (OK)
drmOpenByBusid: drmOpenMinor returns 8
drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
(II) intel(0): [drm] loaded kernel module for "i915" driver
(II) intel(0): [drm] DRM interface version 1.3
(II) intel(0): [drm] created "i915" driver at busid "pci:0000:00:02.0"
(II) intel(0): [drm] added 8192 byte SAREA at 0xf041a000
(II) intel(0): [drm] mapped SAREA 0xf041a000 to 0xb7b7e000
(II) intel(0): [drm] framebuffer handle = 0xf07f0000
(II) intel(0): [drm] added 1 reserved context for kernel
(II) intel(0): Unable to use TTM-based memory manager with DRM version 1.6
(II) intel(0): [drm] Registers = 0xfeb80000
(II) intel(0): [drm] ring buffer = 0xf0000000
(II) intel(0): [drm] init sarea width,height = 1024 x 1024 (pitch 1024)
(II) intel(0): [drm] Mapping front buffer
(II) intel(0): [drm] Front Buffer = 0x2e0fe000
(II) intel(0): [drm] Back Buffer = 0xf2000000
(II) intel(0): [drm] Depth Buffer = 0xf2400000
(II) intel(0): [drm] textures = 0xf4800000
(II) intel(0): [drm] Initialized kernel agp heap manager, 33554432
(II) intel(0): [dri] visual configs initialized
(II) intel(0): Page Flipping disabled
(==) intel(0): Write-combining range (0xf0000000,0x8000000)
(II) intel(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(**) intel(0): Option "XaaNoOffscreenPixmaps" "true"
(II) intel(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Horizontal and Vertical Lines
Setting up tile and stipple cache:
32 128x128 slots
26 256x256 slots
11 512x512 slots
(==) intel(0): Backing store disabled
(==) intel(0): Silken mouse enabled
(II) intel(0): Initializing HW Cursor
(II) intel(0): xf86BindGARTMemory: bind key 0 at 0x007df000 (pgoffset 2015)
(II) intel(0): xf86BindGARTMemory: bind key 1 at 0x007e0000 (pgoffset 2016)
(II) intel(0): xf86BindGARTMemory: bind key 2 at 0x007e4000 (pgoffset 2020)
(II) intel(0): xf86BindGARTMemory: bind key 3 at 0x007e5000 (pgoffset 2021)
(II) intel(0): xf86BindGARTMemory: bind key 4 at 0x007e9000 (pgoffset 2025)
(II) intel(0): xf86BindGARTMemory: bind key 5 at 0x007f0000 (pgoffset 2032)
(II) intel(0): xf86BindGARTMemory: bind key 6 at 0x02000000 (pgoffset 8192)
(II) intel(0): xf86BindGARTMemory: bind key 7 at 0x02400000 (pgoffset 9216)
(II) intel(0): xf86BindGARTMemory: bind key 8 at 0x04800000 (pgoffset 18432)
(II) intel(0): Output configuration:
(II) intel(0): Pipe A is off
(II) intel(0): Display plane A is now disabled and connected to pipe A.
(II) intel(0): Pipe B is on
(II) intel(0): Display plane B is now enabled and connected to pipe B.
(II) intel(0): Output VGA is connected to pipe none
(II) intel(0): Output LVDS is connected to pipe B
(**) Option "dpms"
(**) intel(0): DPMS enabled
(II) intel(0): Set up overlay video
(II) intel(0): X context handle = 0x1
(II) intel(0): [drm] installed DRM signal handler
(II) intel(0): [DRI] installation complete
(II) intel(0): [drm] dma control initialized, using IRQ 17
(II) intel(0): direct rendering: Enabled
(II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(--) RandR disabled
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension XEVIE
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: drmOpenMinor returns 9
(EE) AIGLX error: dlopen of /usr/lib/dri/i915_dri.so failed (/usr/lib/dri/i915_dri.so: cannot open shared object file: No such file or directory)
(EE) AIGLX: reverting to software rendering
(II) Loading local sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/lib/xorg/modules/extensions//libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) GLX: Initialized MESA-PROXY GL provider for screen 0
(II) intel(0): Setting screen physical size to 270 x 203
(**) Option "CoreKeyboard"
(**) Generic Keyboard: Core Keyboard
(**) Option "Protocol" "standard"
(**) Generic Keyboard: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Generic Keyboard: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Generic Keyboard: XkbModel: "pc105"
(**) Option "XkbLayout" "pl"
(**) Generic Keyboard: XkbLayout: "pl"
(**) Option "CustomKeycodes" "off"
(**) Generic Keyboard: CustomKeycodes disabled
(**) Option "Protocol" "ImPS/2"
(**) Configured Mouse: Device: "/dev/input/mice"
(**) Configured Mouse: Protocol: "ImPS/2"
(**) Option "CorePointer"
(**) Configured Mouse: Core Pointer
(**) Option "Device" "/dev/input/mice"
(**) Option "Emulate3Buttons" "true"
(**) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
(**) Configured Mouse: ZAxisMapping: buttons 4 and 5
(**) Configured Mouse: Buttons: 9
(**) Configured Mouse: Sensitivity: 1
(II) Synaptics touchpad driver version 0.14.6 (1406)
(--) Synaptics Touchpad auto-dev sets device to /dev/input/event3
(**) Option "Device" "/dev/input/event3"
(**) Option "HorizScrollDelta" "0"
(--) Synaptics Touchpad touchpad found
(**) Option "SendCoreEvents" "true"
(**) Synaptics Touchpad: always reports core events
(II) XINPUT: Adding extended input device "Synaptics Touchpad" (type: MOUSE)
(II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
(II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
Synaptics DeviceInit called
SynapticsCtrl called.
(II) Configured Mouse: ps2EnableDataReporting: succeeded
Synaptics DeviceOn called
ProcXCloseDevice to close or not ?
SetGrabKeysState - disabled
SetGrabKeysState - enabled
Module Size Used by
arc4 2016 2
ecb 3392 2
blkcipher 5956 1 ecb
ieee80211_crypt_wep 5056 1
ipv6 236256 8
i915 21280 1
drm 73908 2 i915
rfcomm 35480 0
l2cap 22208 5 rfcomm
bluetooth 48676 4 rfcomm,l2cap
ppdev 8580 0
lp 10884 0
button 7952 0
ac 5220 0
battery 10020 0
acpi_cpufreq 8680 1
cpufreq_userspace 4128 0
cpufreq_stats 5120 0
cpufreq_ondemand 7884 1
freq_table 4512 3 acpi_cpufreq,cpufreq_stats,cpufreq_ondemand
cpufreq_powersave 1792 0
cpufreq_conservative 6888 0
dm_snapshot 16420 0
dm_mirror 20116 0
dm_mod 52556 2 dm_snapshot,dm_mirror
sbp2 21188 0
loop 15880 0
pcmcia 35276 0
irtty_sir 8064 0
sir_dev 15300 1 irtty_sir
joydev 9152 0
ipw2200 130628 0
irda 172668 2 irtty_sir,sir_dev
ieee80211 30984 1 ipw2200
ieee80211_crypt 5792 2 ieee80211_crypt_wep,ieee80211
sd_mod 19904 0
crc_ccitt 2144 1 irda
firmware_class 9408 2 pcmcia,ipw2200
parport_pc 32740 1
parport 33672 3 ppdev,lp,parport_pc
yenta_socket 24876 2
rsrc_nonstatic 11968 1 yenta_socket
pcmcia_core 36884 3 pcmcia,yenta_socket,rsrc_nonstatic
pcspkr 3136 0
snd_intel8x0m 16716 0
snd_pcm_oss 39168 0
snd_mixer_oss 15328 1 snd_pcm_oss
rtc 12760 0
snd_intel8x0 32060 1
snd_ac97_codec 92356 2 snd_intel8x0m,snd_intel8x0
psmouse 34952 0
ac97_bus 2272 1 snd_ac97_codec
iTCO_wdt 9956 0
serio_raw 6564 0
snd_pcm 71940 4 snd_intel8x0m,snd_pcm_oss,snd_intel8x0,snd_ac97_codec
snd_timer 20868 1 snd_pcm
snd 48132 9 snd_intel8x0m,snd_pcm_oss,snd_mixer_oss,snd_intel8x0,snd_ac97_codec,snd_pcm,snd_timer
soundcore 7424 1 snd
snd_page_alloc 9512 3 snd_intel8x0m,snd_intel8x0,snd_pcm
shpchp 30996 0
pci_hotplug 29088 1 shpchp
intel_agp 23004 1
agpgart 32168 3 drm,intel_agp
eth1394 18276 0
tsdev 7520 0
evdev 9216 5
ext3 120904 2
jbd 55208 1 ext3
mbcache 8164 1 ext3
ide_cd 36512 0
cdrom 32768 1 ide_cd
ide_disk 15584 4
ata_generic 8100 0
libata 109172 1 ata_generic
usbhid 23488 0
hid 23680 1 usbhid
usb_storage 76384 0
scsi_mod 133740 4 sbp2,sd_mod,libata,usb_storage
piix 9508 0 [permanent]
8139cp 22336 0
ohci1394 32432 0
ieee1394 89560 3 sbp2,eth1394,ohci1394
generic 4804 0 [permanent]
ide_core 115016 5 ide_cd,ide_disk,usb_storage,piix,generic
8139too 25536 0
mii 5280 2 8139cp,8139too
ehci_hcd 30796 0
uhci_hcd 22608 0
usbcore 123272 5 usbhid,usb_storage,ehci_hcd,uhci_hcd
thermal 14120 0
processor 30888 2 acpi_cpufreq,thermal
fan 4868 0
~$ cat /etc/X11/xorg.conf
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
EndSection
Section "Device"
Identifier "Intel Corporation 82852/855GM Integrated Graphics Device"
Driver "i810"
BusID "PCI:0:2:0"
Option "XAANoOffscreenPixmaps" "true"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
HorizSync 30-70
VertRefresh 50-160
EndSection
Section "Module"
#Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
#Load "extmod"
#Load "freetype"
Load "glx"
#Load "int10"
#Load "record"
#Load "type1"
#Load "v4l"
#Load "vbe"
EndSection
Section "DRI"
Group 0
Mode 0666
EndSection
Section "Screen"
Identifier "Default Screen"
DefaultDepth 24
EndSection
Section "ServerLayout"
Identifier "Default Layout"
InputDevice "Synaptics Touchpad"
EndSection
Section "Extensions"
Option "Composite" "Enable"
Option "RENDER" "Enable"
EndSection
