Zatrzymałem się na konfiguracji w podłączenia Debiana do domeny AD i odczytywaniu grup,
użytkowników przez:
wbinfo -uKod: Zaznacz cały
wbinfo -g
failed to call wbcListGroups: WBC_ERR_INVALID_RESPONSE
Error looking up domain groupsKod: Zaznacz cały
net rpc testjoin
Unable to find a suitable server for domain My-Domain
Join to domain "MyDomain" is not valid: NT_STATUS_UNSUCCESSFUL
net rpc getsid
Unable to find a suitable server for domain My-DomainKod: Zaznacz cały
net rpc testjoin -S bwdc
Join to "My-Domain" is OKKod: Zaznacz cały
net ads join -S bwdc.my-domain.net -U [EMAIL="Administrator@my-domain.net"]Administrator@my-domain.net[/EMAIL]
Using short domain name -- MY-DOMAIN
Joined "DEBPROXY" to realm "my-domain"
net rpc join -S bwdc.my-domain.net -U [EMAIL="Administrator@my-domain.net"]Administrator@my-domain.net[/EMAIL]
Joined domain MY-DOMAIN .
rebootKod: Zaznacz cały
wbinfo -u
echo "piotr allowinternet" | /usr/lib/squid/wbinfo_group.pl -d
getent group
net ads group -U Administrator
wbinfo --group-info=allowinternet
wbinfo --user-groups=piotr
net ads testjoin
Join is OKKod: Zaznacz cały
uname -a
linux debian 3.2.0.-4-amd64 #1 SMP Debian 3.2.46-1+deb7u1 x86_64 GNU/Linux
smbd -V
Version 3.6.6
winbindd -V
Version 3.6.6Kod: Zaznacz cały
[global]
workgroup = MY-DOMAIN
map to guest = Bad User
logon path = [url=file://\\%L\profiles\.msprofile]\\%L\profiles\.msprofile[/URL]
logon home = [url=file://\\%L\%U\.9xprofile]\\%L\%U\.9xprofile[/URL]
logon drive = P:
usershare allow guests = No
idmap uid = 10000-20000
idmap gid = 10000-20000
realm = my-domain.net
security = ads
template homedir = /home/%D/%U
template shell = /bin/bash
winbind offline logon = yes
winbind refresh tickets = yes
winbind enum groups = yes
winbind enum users = yes
winbind nested groups = yes
winbind use default domain = yes
encrypt passwords = true
socket options = TCP_NODELAY SO_RCVBUF=16384 SO_SNDBUF=16384
log level = 3 passdb:5 winbind:3
[homes]
comment = Home Directories
valid users = %s, %D%W%S]
browseable = no
read only = no
inherit acls = yes]Kod: Zaznacz cały
127.0.0.1 localhost.my-domain.net localhost
192.168.30.100 debproxy.my-domain.net debproxy
192.168.31.100 debproxy.my-domain.net debproxy
192.168.21.2 bwdc.my-domain.net bwdc
192.168.21.2 my-domain.nKod: Zaznacz cały
domain my-domain.net
search my-domain.net
nameserver 192.168.21.2
nameserver 192.168.21.1Kod: Zaznacz cały
[libdefaults]
default_realm = MY-DOMAIN.NET
krb4_config = /etc/krb.conf
krb4_realms = /etc/krb.realms
kdc_timesync = 1
ccache_type = 4
forwardable = true
proxiable = true
v4_instance_resolve = false
v4_name_convert = {
host = {
rcmd = host
ftp = ftp
plain = {
something = something-else
fcc-mit-ticketflags = true
[realms]
3CITY.LOCAL = {
kdc = bwdc.my-domain.net:88
admin_server = bwdc.my-domain.net
default_domain = my-domain.net
[domain_realm]
.my-domain.net = MY-DOMAIN.NET
[login]
krb4_convert = true
krb4_get_tickets = falseKod: Zaznacz cały
PATH=/sbin:/bin:/usr/sbin:/usr/bin
[ -r /etc/default/winbind ] && . /etc/default/winbind
DAEMON=/usr/sbin/winbindd
PIDDIR=/var/run/samba
WINBINDPID=$PIDDIR/winbindd.pid
unset TMPDIR
test -x $DAEMON || exit 0
. /lib/lsb/init-functions
case "$1" in
start)
log_daemon_msg "Starting the Winbind daemon" "winbind"
mkdir -p /var/run/samba/winbindd_privileged || return 1
chgrp proxy $PIDDIR/winbindd_privileged/ || return 1
chmod 0750 $PIDDIR/winbindd_privileged/ || return 1
start-stop-daemon --start --quiet --oknodo --exec $DAEMON -- $WINBINDD_OPTS
log_end_msg $?
stop)
log_daemon_msg "Stopping the Winbind daemon" "winbind"
start-stop-daemon --stop --quiet --oknodo --exec $DAEMON
log_end_msg $?
restart|force-reload)
$0 stop && sleep 2 && $0 start
status)
status_of_proc -p $WINBINDPID $DAEMON winbind && exit 0 || exit $?
echo "Usage: /etc/init.d/winbind {start|stop|restart|force-reload|status}"
exit 1
esacProszę Was o pomoc, co z tym rpc jest nie tak że przez wbinfo nie można odczytać grup z AD.
Cały weekend w plecy, parę miesięcy temu robiłem to, brakuje mi jakieś dodatkowego polecenia,
które wykonywałem podczas dodawania do domeny konta, mój błąd nie zapisałem jej.
Piotr
