Apache2 i przekierowywania
Witam. Odkad probowalem zainstalowac serwer poczty (nie pamietam jaki to byl program) zawsze gdy wejde na strone przez http://www.exelana.pl/ to przekierowywuje mnie na http://www.exelana.pl/mail. Dodam jeszcze do tego ze jesli wpisze http://www.exelana.pl/index.php To normalnie ta strona ktora chce mi sie otwiera. Prosze o szybka pomoc!!
Config Apache2:
/sites-enabled/000-default:# This is the main Apache server configuration file. It contains the
# configuration directives that give the server its instructions.
# See http://httpd.apache.org/docs/2.2/ for detailed information about
# the directives and /usr/share/doc/apache2-common/README.Debian.gz about
# Debian specific hints.
# Summary of how the Apache 2 configuration works in Debian:
# The Apache 2 web server configuration in Debian is quite different to
# upstream's suggested way to configure the web server. This is because Debian's
# default Apache2 installation attempts to make adding and removing modules,
# virtual hosts, and extra configuration directives as flexible as possible, in
# order to make automating the changes and administering the server as easy as
# possible.
# It is split into several files forming the configuration hierarchy outlined
# below, all located in the /etc/apache2/ directory:
# /etc/apache2/
# |-- apache2.conf
# | `-- ports.conf
# |-- mods-enabled
# | |-- *.load
# | `-- *.conf
# |-- conf.d
# `-- sites-enabled
# * apache2.conf is the main configuration file (this file). It puts the pieces
# together by including all remaining configuration files when starting up the
# web server.
# In order to avoid conflicts with backup files, the Include directive is
# adapted to ignore files that:
# - do not begin with a letter or number
# - contain a character that is neither letter nor number nor _-:.
# - contain .dpkg
# Yet we strongly suggest that all configuration files either end with a
# .conf or .load suffix in the file name. The next Debian release will
# ignore files not ending with .conf (or .load for mods-enabled).
# * ports.conf is always included from the main configuration file. It is
# supposed to determine listening ports for incoming connections, and which
# of these ports are used for name based virtual hosts.
# * Configuration files in the mods-enabled/ and sites-enabled/ directories
# contain particular configuration snippets which manage modules or virtual
# host configurations, respectively.
# They are activated by symlinking available configuration files from their
# respective *-available/ counterparts. These should be managed by using our
# helpers a2enmod/a2dismod, a2ensite/a2dissite. See
# their respective man pages for detailed information.
# * Configuration files in the conf.d directory are either provided by other
# packages or may be added by the local administrator. Local additions
# should start with local- or end with .local.conf to avoid name clashes. All
# files in conf.d are considered (excluding the exceptions noted above) by
# the Apache 2 web server.
# * The binary is called apache2. Due to the use of environment variables, in
# the default configuration, apache2 needs to be started/stopped with
# /etc/init.d/apache2 or apache2ctl. Calling /usr/bin/apache2 directly will not
# work with the default configuration.
# Global configuration
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the LockFile documentation (available
# at <URL:http://httpd.apache.org/docs/2.2/mod/mp ... l#lockfile>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
#ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
LockFile ${APACHE_LOCK_DIR}/accept.lock
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 5
## Server-Pool Size Regulation (MPM specific)
# prefork MPM
# StartServers: number of server processes to start
# MinSpareServers: minimum number of server processes which are kept spare
# MaxSpareServers: maximum number of server processes which are kept spare
# MaxClients: maximum number of server processes allowed to start
# MaxRequestsPerChild: maximum number of requests a server process serves
<IfModule mpm_prefork_module>
StartServers 5
MinSpareServers 5
MaxSpareServers 10
MaxClients 150
MaxRequestsPerChild 0
</IfModule>
# worker MPM
# StartServers: initial number of server processes to start
# MinSpareThreads: minimum number of worker threads which are kept spare
# MaxSpareThreads: maximum number of worker threads which are kept spare
# ThreadLimit: ThreadsPerChild can be changed to this maximum value during a
# graceful restart. ThreadLimit can only be changed by stopping
# and starting Apache.
# ThreadsPerChild: constant number of worker threads in each server process
# MaxClients: maximum number of simultaneous client connections
<IfModule mpm_worker_module>
StartServers 2
MinSpareThreads 25
MaxSpareThreads 75
ThreadLimit 64
ThreadsPerChild 25
MaxClients 150
</IfModule>
# event MPM
<IfModule mpm_event_module>
StartServers 2
MinSpareThreads 25
MaxSpareThreads 75
ThreadLimit 64
ThreadsPerChild 25
MaxClients 150
</IfModule>
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives. See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ~ "^\.ht">
Order allow,deny
Deny from all
Satisfy all
</Files>
# DefaultType is the default MIME type the server will use for a document
# if it cannot otherwise determine one, such as from filename extensions.
# If your server contains mostly text or HTML documents, "text/plain" is
# a good value. If most of your content is binary, such as applications
# or images, you may want to use "application/octet-stream" instead to
# keep browsers from trying to display binary files as though they are
# text.
# It is also possible to omit any default MIME type and let the
# client's browser guess an appropriate action instead. Typically the
# browser will decide based on the file's extension then. In cases
# where no good assumption can be made, letting the default MIME type
# unset is suggested instead of forcing the browser to accept
# incorrect metadata.
DefaultType None
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., http://www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog ${APACHE_LOG_DIR}/error.log
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
# Include module configuration:
Include mods-enabled/*.load
Include mods-enabled/*.conf
# Include list of ports to listen on and which to use for name based vhosts
Include ports.conf
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
# If you are behind a reverse proxy, you might want to change %h into %{X-Forwarded-For}i
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Include of directories ignores editors' and dpkg's backup files,
# see the comments above for details.
# Include generic snippets of statements
Include conf.d/
# Include the virtual host configurations:
Include sites-enabled/
<VirtualHost *:80>
ServerAdmin webmaster@localhost
DocumentRoot /var/www
<Directory />
Options FollowSymLinks
AllowOverride All
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride All
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/access.log combined
</VirtualHost>
Moze to zabrzmi dla cb idiotycznie ale nie wiem za bardzo co mam zmienic zeby to zaczelo dzialac
@EDIT
Z tego co zauwazylem to przekierowywuje sie nawet wtedy jak apache jest wylaczone... Nie mam bladego pojecia o co z tym chodzi...
@ref
@edit
Z tego co jeszcze znalazlem w plikach to ten syf zrobil albo amavis albo roundcube.. Moze ta wiadomosc cos wam pomoze..
@EDIT
@ref
@edit
O jacie.. To bylo jeszcze cos innego.. Roundcube.. http://www.piotrdyduch.pl/debian-ubuntu ... roundcube/
A tu co masz /etc/apache2/conf.d
chodzi o aliasy
chodzi o aliasy
Access webmail and other web applications
After installation successfully completed, you can access web-based programs if you choose to install them. Replace 'your_server' below by your actual server name or IP address.
Component URL
Webmail [url]https://your_server/mail/[/url]
iRedAdmin (admin panel) [url]httpS://your_server/iredadmin/[/url]
phpMyAdmin [url]httpS://your_server/phpmyadmin/[/url]
phpLDAPadmin [url]httpS://your_server/phpldapadmin/[/url]
Awstats [url]httpS://your_server/awstats/awstats.pl?config=web[/url] (or ?config=smtp)
Powiedz mi konkretnie o jaki pliczek ci chodzi bo ja w zadnym czegos takiego nie widze ;/
@edit
Chyba ze Tobie chodzi o ten pliczek.. /etc/apache2/mods-enabled/alias.conf
@edit
<IfModule alias_module>
# Aliases: Add here as many aliases as you need (with no limit). The format is
# Alias fakename realname
# Note that if you include a trailing / on fakename then the server will
# require it to be present in the URL. So "/icons" isn't aliased in this
# example, only "/icons/". If the fakename is slash-terminated, then the
# realname must also be slash terminated, and if the fakename omits the
# trailing slash, the realname must also omit it.
# We include the /icons/ alias for FancyIndexed directory listings. If
# you do not use FancyIndexing, you may comment this out.
Alias /icons/ "/usr/share/apache2/icons/"
<Directory "/usr/share/apache2/icons">
Options FollowSymlinks
AllowOverride None
Order allow,deny
Allow from all
</Directory>
</IfModule>
