[+] Baza MySQL nie chce si
mpm1122
[+] Baza MySQL nie chce się włączyć
Post autor: mpm1122 »
Przy próbie instalacji bazy danych MySQL (po wpisaniu haseł) dostaję taką informację:
[ ok ] Stopping MySQL database server: mysqld.130804 11:45:29 [Note] Plugin 'FEDERATED' is disabled.
130804 11:45:29 InnoDB: The InnoDB memory heap is disabled
130804 11:45:29 InnoDB: Mutexes and rw_locks use GCC atomic builtins
130804 11:45:29 InnoDB: Compressed tables use zlib 1.2.7
130804 11:45:29 InnoDB: Using Linux native AIO
130804 11:45:29  InnoDB: Warning: io_setup() failed with EAGAIN. Will make 5 attempts before giving up.
InnoDB: Warning: io_setup() attempt 1 failed.
InnoDB: Warning: io_setup() attempt 2 failed.
InnoDB: Warning: io_setup() attempt 3 failed.
InnoDB: Warning: io_setup() attempt 4 failed.
InnoDB: Warning: io_setup() attempt 5 failed.
130804 11:45:32  InnoDB: Error: io_setup() failed with EAGAIN after 5 attempts.
InnoDB: You can disable Linux Native AIO by setting innodb_use_native_aio = 0 in my.cnf
130804 11:45:32 InnoDB: Fatal error: cannot initialize AIO sub-system
130804 11:45:32 [ERROR] Plugin 'InnoDB' init function returned error.
130804 11:45:32 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
130804 11:45:32 [ERROR] Unknown/unsupported storage engine: InnoDB
130804 11:45:32 [ERROR] Aborting
130804 11:45:32 [Note] /usr/sbin/mysqld: Shutdown complete
A kilkanaście sekund później taką:
 Unable to set password for the MySQL "root" user        An error occurred while setting the password for the MySQL administrative user. This may have happened because the account already has a password, or because of a communication problem with the MySQL server.        You should check the account's password after the package installation.
Please read the /usr/share/doc/mysql-server-5.5/README.Debian file for more information.
Próbowałem takowych rozwiązań:
  • Kod: Zaznacz cały
    apt-get -f install
  • Kod: Zaznacz cały
    mysql_secure_installation (ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2))
  • Kod: Zaznacz cały
    innodb_use_native_aio=0 w my.cnf
Lista repozytoriów:
deb [URL]http://ftp.de.debian.org/debian/[/URL] wheezy main contrib non-free
deb-src [URL]http://ftp.de.debian.org/debian/[/URL] wheezy main contrib non-free
deb [URL]http://security.debian.org/[/URL] wheezy/updates main contrib non-free
deb-src [URL]http://security.debian.org/[/URL] wheezy/updates main contrib non-free
deb [URL]http://ftp.de.debian.org/debian/[/URL] wheezy-updates main contrib non-free
deb-src [URL]http://ftp.de.debian.org/debian/[/URL] wheezy-updates main contrib non-free
System na VPS-ie to Debian 7, zainstalowany na openvz. Zakupiony w ultimahost.pl (pakiet ovz.4096MB). Niestety, ale po reinstalacji systemu problem powrócił.
Proszę o pomoc.
Zresetuj hasło roota do bazy mysql.
mpm1122
Niestety, ale nie mogę zmienić hasła bo serwer nawet nie uruchamia się. Próbowałem przez:
mysqladmin -u root password
Dostaję w wyniku coś takiego:
mysqladmin -u root password testhaslo
mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)'
Check that mysqld is running and that the socket: '/var/run/mysqld/mysqld.sock' exists!
dhapollo
Post autor: dhapollo »
A może w ten sposób:
dpkg-reconfigure mysql-server-5.5
mpm1122
/usr/sbin/dpkg-reconfigure: mysql-server-5.5 is broken or not fully installed.
ps -ef | grep mysql
root     15714  1546  0 15:57 pts/0    00:00:00 grep mysql
[B]telnet 127.0.0.1 3306[/B]
Trying 127.0.0.1...
telnet: Unable to connect to remote host: Connection refused
[B]mysql_upgrade[/B]
Looking for 'mysql' as: mysql
Looking for 'mysqlcheck' as: mysqlcheck
Running 'mysqlcheck' with connection arguments: '--port=3306' '--socket=/var/run/mysqld/mysqld.sock'
mysqlcheck: Got error: 2002: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) when trying to connect
FATAL ERROR: Upgrade failed
dpkg --configure mysql-server-5.5
Setting up mysql-server-5.5 (5.5.31+dfsg-0+wheezy1) ...
130804 16:03:57 [Note] Plugin 'FEDERATED' is disabled.
130804 16:03:57 InnoDB: The InnoDB memory heap is disabled
130804 16:03:57 InnoDB: Mutexes and rw_locks use GCC atomic builtins
130804 16:03:57 InnoDB: Compressed tables use zlib 1.2.7
130804 16:03:57 InnoDB: Using Linux native AIO
130804 16:03:57  InnoDB: Warning: io_setup() failed with EAGAIN. Will make 5 attempts before giving up.
130804 16:04:00  InnoDB: Error: io_setup() failed with EAGAIN after 5 attempts.
130804 16:04:00 InnoDB: Fatal error: cannot initialize AIO sub-system
130804 16:04:00 [ERROR] Plugin 'InnoDB' init function returned error.
130804 16:04:00 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
130804 16:04:00 [ERROR] Unknown/unsupported storage engine: InnoDB
130804 16:04:00 [ERROR] Aborting
130804 16:04:00 [Note] /usr/sbin/mysqld: Shutdown complete
Jakieś pomysły?
mpm1122 pisze:
Jako root wpisujesz:
mysqladmin -u root password twoje_hasło
dhapollo
Problem rozwiązany, baza mysql uruchomiła się.
echo " innodb_use_native_aio=0" >> /etc/mysql/my.cnf
service mysql start
[ ok ] Starting MySQL database server: mysqld . . ..
ps -A | grep mysql
 7334 pts/1    00:00:00 mysqld_safe
 7705 pts/1    00:00:00 mysqld
