Jestem na etapie iż wysyła emaile, ale nie dochodząmail.err
Jul 21 18:03:36 mail postfix/smtpd[7642]: fatal: need service transport:endpoint instead of "permit"
Jul 21 18:04:37 mail postfix/smtpd[7738]: fatal: need service transport:endpoint instead of "permit"
Jul 21 18:05:38 mail postfix/smtpd[8123]: fatal: need service transport:endpoint instead of "permit"
Jul 21 18:06:36 mail postfix/master[7617]: terminating on signal 15
Jul 21 18:06:37 mail postfix/master[8360]: daemon started -- version 2.9.6, configuration /etc/postfix
Jul 21 18:06:38 mail dovecot: auth-worker(4657): Warning: mysql: Query failed, retrying: MySQL server has gone away (idled for 38 secs)
Jul 21 18:06:38 mail dovecot: auth-worker(4657): mysql(127.0.0.1): Connected to database virtual_email
Jul 21 18:06:38 mail dovecot: imap-login: Login: user=<admin@dom.pl>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=8380, secured, session=<hK2Mvgfi+AB/AAAB>
Jul 21 18:06:38 mail dovecot: imap(admin@dom.pl): Disconnected: Logged out in=90 out=794
Jul 21 18:06:46 mail postfix/smtpd[8382]: fatal: need service transport:endpoint instead of "permit"
Jul 21 18:06:47 mail postfix/master[8360]: warning: process /usr/lib/postfix/smtpd pid 8382 exit status 1
Jul 21 18:06:47 mail postfix/master[8360]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
Jul 21 18:07:00 mail dovecot: imap-login: Login: user=<admin@dom2.pl>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=8386, secured, session=<8qXivwfirwB/AAAB>
Jul 21 18:07:00 mail dovecot: imap(admin@po-land.pl): Disconnected: Logged out in=90 out=794
root@mail:~# cat /etc/postfix/main.cf
# The first text sent to a connecting process.
smtpd_banner = $myhostname ESMTP $mail_name
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
readme_directory = no
# SASL parameters
# Use Dovecot to authenticate.
smtpd_sasl_type = dovecot
# Referring to /var/spool/postfix/private/auth
smtpd_sasl_auth_enable = yes
smtpd_sasl_security_options = noanonymous
smtpd_sasl_local_domain =
smtpd_sasl_authenticated_header = yes
# TLS parameters
# Replace this with your SSL certificate path if you are using one.
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
# The snakeoil self-signed certificate has no need for a CA file. But
# if you are using your own SSL certificate, then you probably have
# a CA certificate bundle from your provider. The path to that goes
# here.
#smtpd_tls_CAfile=/path/to/ca/file
smtpd_use_tls=yes
smtp_tls_security_level = may
smtpd_tls_security_level = may
#smtpd_tls_auth_only = no
smtp_tls_note_starttls_offer = yes
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
tls_random_source = dev:/dev/urandom
#smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
#smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
# SMTPD parameters
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
# will it be a permanent error or temporary
unknown_local_recipient_reject_code = 450
# how long to keep message on queue before return as failed.
# some have 3 days, I have 16 days as I am backup server for some people
# whom go on holiday with their server switched off.
maximal_queue_lifetime = 7d
# max and min time in seconds between retries if connection failed
minimal_backoff_time = 1000s
maximal_backoff_time = 8000s
# how long to wait when servers connect before receiving rest of data
smtp_helo_timeout = 60s
# how many address can be used in one message.
# effective stopper to mass spammers, accidental copy in whole address list
# but may restrict intentional mail shots.
smtpd_recipient_limit = 16
# how many error before back off.
smtpd_soft_error_limit = 3
# how many max errors before blocking it.
smtpd_hard_error_limit = 12
# This next set are important for determining who can send mail and relay mail
# to other servers. It is very important to get this right - accidentally producing
# an open relay that allows unauthenticated sending of mail is a Very Bad Thing.
# You are encouraged to read up on what exactly each of these options accomplish.
# Requirements for the HELO statement
smtpd_helo_restrictions = permit_mynetworks, warn_if_reject reject_non_fqdn_hostname, reject_invalid_hostname, permit
# Requirements for the sender details
smtpd_sender_restrictions = permit_sasl_authenticated, permit_mynetworks, warn_if_reject reject_non_fqdn_sender, reject_unknown_sender_domain, reject_unauth_pipelining, permit
# Requirements for the connecting server
smtpd_client_restrictions = reject_rbl_client sbl.spamhaus.org, reject_rbl_client blackholes.easynet.nl, reject_rbl_client dnsbl.njabl.org
# Requirement for the recipient address. Note that the entry for
# "check_policy_service inet:127.0.0.1:10023" enables Postgrey.
smtpd_recipient_restrictions = reject_unauth_pipelining, permit_mynetworks, permit_sasl_authenticated, reject_non_fqdn_recipient, reject_unknown_recipient_domain, reject_unauth_destination, check_policy_service, permit
smtpd_data_restrictions = reject_unauth_pipelining
# require proper helo at connections
smtpd_helo_required = yes
# waste spammers time before rejecting them
smtpd_delay_reject = yes
disable_vrfy_command = yes
# General host and delivery info
myhostname = mail.dom.pl
myorigin = /etc/hostname
# Some people see issues when setting mydestination explicitly to the server
# subdomain, while leaving it empty generally doesn't hurt. So it is left empty here.
# mydestination = mail.example.com, localhost
mydestination =
# If you have a separate web server that sends outgoing mail through this
# mailserver, you may want to add its IP address to the space-delimited list in
# mynetworks, e.g. as 111.222.333.444/32.
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
mynetworks_style = host
# This specifies where the virtual mailbox folders will be located.
virtual_mailbox_base = /var/vmail
# This is for the mailbox location for each user. The domainaliases
# map allows us to make use of Postfix Admin's domain alias feature.
virtual_mailbox_maps = mysql:/etc/postfix/mysql_virtual_mailbox_maps.cf, mysql:/etc/postfix/mysql_virtual_mailbox_domainaliases_maps.cf
# and their user id
virtual_uid_maps = static:150
# and group id
virtual_gid_maps = static:8
# This is for aliases. The domainaliases map allows us to make
# use of Postfix Admin's domain alias feature.
virtual_alias_maps = mysql:/etc/postfix/mysql_virtual_alias_maps.cf, mysql:/etc/postfix/mysql_virtual_alias_domainaliases_maps.cf
# This is for domain lookups.
virtual_mailbox_domains = mysql:/etc/postfix/mysql_virtual_domains_maps.cf
# Integration with other packages
# Tell postfix to hand off mail to the definition for dovecot in master.cf
virtual_transport = dovecot
#dovecot_destination_recipient_limit = 1
# Use amavis for virus and spam scanning
#content_filter = amavis:[127.0.0.1]:10024
# Header manipulation
# Getting rid of unwanted headers. See: https://posluns.com/guides/header-removal/
#header_checks = regexp:/etc/postfix/header_checks
# getting rid of x-original-to
enable_original_recipient = no
[font=Helvetica Neue][color=#282828][font=arial]
[/font][/color][/font]
Jakieś pomysły jak to naprawic?
