Mam problem z zaimportowaniem bazy danych przez phpmyadmina, generalnie nie potrafi poprawnie za importować triggerów . Poniżej kod błędu. Dziękuje za pomoc.
[B]Błąd[/B]
     [B]Zapytanie SQL:[/B]
               USE  `xxxxxxx` $$ [url=http://192.168.1.12/phpmyadmin/url.php?url=http%3A%2F%2Fdev.mysql.com%2Fdoc%2Frefman%2F5.5%2Fang.%2Fdrop-trigger.html&token=142073d7e18abef9ddeeaa10112fc0c8]DROP TRIGGER IF  EXISTS  `xxxx`.`ComponentDefinitionUpTrig` $$ [/URL][url=http://192.168.1.12/phpmyadmin/url.php?url=http%3A%2F%2Fdev.mysql.com%2Fdoc%2Frefman%2F5.5%2Fang.%2Fshow.html&token=142073d7e18abef9ddeeaa10112fc0c8]SHOW[/URL] WARNINGS$$ USE  `xxxxx` $$ CREATE trigger ComponentDefinitionUpTrig AFTER  [url=http://192.168.1.12/phpmyadmin/url.php?url=http%3A%2F%2Fdev.mysql.com%2Fdoc%2Frefman%2F5.5%2Fang.%2Fupdate.html&token=142073d7e18abef9ddeeaa10112fc0c8]UPDATE[/URL]  ON ComponentDefinition FOR each ROW  BEGIN  [url=http://192.168.1.12/phpmyadmin/url.php?url=http%3A%2F%2Fdev.mysql.com%2Fdoc%2Frefman%2F5.5%2Fang.%2Fdelete.html&token=142073d7e18abef9ddeeaa10112fc0c8]DELETE[/URL]  FROM ComponentDefinitionTree WHERE ancestor_id = new.id OR descendant_id = new.id;
      [B]MySQL zwrócił komunikat: [/B][url=http://192.168.1.12/phpmyadmin/url.php?url=http%3A%2F%2Fdev.mysql.com%2Fdoc%2Frefman%2F5.5%2Fang.%2Ferror-messages-server.html&token=142073d7e18abef9ddeeaa10112fc0c8][IMG]http://192.168.1.12/phpmyadmin/themes/pmahomme/img/b_help.png[/IMG][/URL]
  #1064 - You have an error in your SQL syntax; check the manual that  corresponds to your MySQL server version for the right syntax to use  near '$$
DROP TRIGGER IF EXISTS `xxxxx`.`ComponentDefinitionUpTrig` $$
SHOW WAR' at line 1
