[+] D
poker98face
[+] Długie uruchamianie systemu - Jessie
Post autor: poker98face »
Przy każdym uruchamianiu systemu pokazuje się mnóstwo błędów, trwa to kilka minut po czym system się uruchamia. Zignorowałbym to, jednak według mnie, to poważne błędy systemowe i system zamiast uruchamiać się 20 sekund, uruchamia się w 5 minut.
Debian Jessie aktualizacja z Debian Wheezy
Linux msi 3.9-1-686-pae #1 SMP Debian 3.9.6-1 i686 GNU/Linux
lspci -k
00:00.0 Host bridge: Silicon Integrated Systems [SiS] 671MX
    Subsystem: Micro-Star International Co., Ltd. Device 104c
00:01.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge
00:02.0 ISA bridge: Silicon Integrated Systems [SiS] SiS968 [MuTIOL Media IO] (rev 01)
00:03.0 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
    Kernel driver in use: ohci_hcd
00:03.1 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
00:03.3 USB controller: Silicon Integrated Systems [SiS] USB 2.0 Controller
00:04.0 Ethernet controller: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter (rev 02)
    Kernel driver in use: sis190
00:05.0 IDE interface: Silicon Integrated Systems [SiS] SATA Controller / IDE mode (rev 03)
    Kernel driver in use: sata_sis
00:06.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge
00:07.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge
00:0f.0 Audio device: Silicon Integrated Systems [SiS] Azalia Audio Controller
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Park [Mobility Radeon HD 5430/5450/5470]
    Kernel driver in use: radeon
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Cedar HDMI Audio [Radeon HD 5400/6300 Series]
02:00.0 Network controller: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) (rev 01)
    Subsystem: AzureWave AW-NE785 / AW-NE785H 802.11bgn Wireless Full or Half-size Mini PCIe Card
    Kernel driver in use: ath9k
Fragment:
Jul  2 20:56:05 msi udevd[388]: timeout: killing '/sbin/modprobe -b acpi:PNP0C0A:' [498]
Jul  2 20:56:05 msi acpid: starting up with netlink and the input layer
Jul  2 20:56:05 msi acpid: 44 rules loaded
Jul  2 20:56:05 msi acpid: waiting for events: event logging is off
Jul  2 20:56:06 msi udevd[388]: timeout: killing '/sbin/modprobe -b acpi:PNP0C0A:' [498]
Jul  2 20:56:07 msi avahi-daemon[3500]: Found user 'avahi' (UID 106) and group 'avahi' (GID 116).
Jul  2 20:56:07 msi avahi-daemon[3500]: Successfully dropped root privileges.
Jul  2 20:56:07 msi avahi-daemon[3500]: avahi-daemon 0.6.31 starting up.
Jul  2 20:56:07 msi avahi-daemon[3500]: Successfully called chroot().
Jul  2 20:56:07 msi avahi-daemon[3500]: Successfully dropped remaining capabilities.
Jul  2 20:56:07 msi avahi-daemon[3500]: Loading service file /services/udisks.service.
Jul  2 20:56:07 msi avahi-daemon[3500]: Network interface enumeration completed.
Jul  2 20:56:07 msi avahi-daemon[3500]: Registering HINFO record with values 'I686'/'LINUX'.
Jul  2 20:56:07 msi avahi-daemon[3500]: Server startup complete. Host name is msi.local. Local service cookie is 3261296576.
Jul  2 20:56:07 msi avahi-daemon[3500]: Service "msi" (/services/udisks.service) successfully established.
Całość:
http://pastebin.com/GUufGcFZ
A jak Debiana Jessie instalowałeś?
Zdaje się, że problem rozwiązany/obejście: http://forums.debian.net/viewtopic.php?f=10&t=105460
poker98face
Tak problem rozwiązany, pomyśleć że to przez głupi czytnik kart :)
