!!ALSA Information Script v 0.4.62
!!Script ran on: Thu May 30 23:03:13 UTC 2013
!!Linux Distribution
ID_LIKE=debian
!!DMI Information
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: 945GCM-S2L
Product Version:
Firmware Version: F8b
!!Kernel Information
Kernel release: 3.7-trunk-686-pae
Operating System: GNU/Linux
Architecture: i686
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k3.7-trunk-686-pae
Library version: 1.0.25
Utilities version: 1.0.25
!!Loaded ALSA modules
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
ESound Daemon:
Installed - Yes (/usr/bin/esd)
Running - No
!!Soundcards recognised by ALSA
0 [Intel ]: HDA-Intel - HDA Intel
HDA Intel at 0xd11c0000 irq 43
!!PCI Soundcards installed in the system
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
!!Advanced information - PCI Vendor/Device/Subsystem ID's
00:1b.0 0403: 8086:27d8 (rev 01)
Subsystem: 1458:a002
!!Modprobe options (Sound related)
snd_pcsp: index=-2
snd_usb_audio: index=-2
snd_atiixp_modem: index=-2
snd_intel8x0m: index=-2
snd_via82xx_modem: index=-2
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : 1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : N
snoop : Y
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC662 rev1
Address: 2
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0662
Subsystem Id: 0x1458a002
Revision Id: 0x100101
No Modem Function Group found
Default PCM:
rates [0x160]: 44100 48000 96000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x1d: Stereo Amp-Out
Control: name="Front Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Device: name="ALC662 rev1 Analog", type="Audio", device=0
Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
Amp-Out vals: [0x40 0x40]
Converter: stream=8, channel=0
PCM:
formats [0x1]: PCM
Node 0x03 [Audio Output] wcaps 0x1d: Stereo Amp-Out
Control: name="Surround Playback Volume", index=0, device=0
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x1d: Stereo Amp-Out
Control: name="Center Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="LFE Playback Volume", index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
PCM:
formats [0x1]: PCM
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x211: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
Device: name="ALC662 rev1 Digital", type="SPDIF", device=1
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
bits [0x1e]: 16 20 24 32
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10011b: Stereo Amp-In
Control: name="Capture Switch", index=0, device=0
Control: name="Capture Volume", index=0, device=0
Amp-In caps: ofs=0x09, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x1f 0x1f]
Converter: stream=4, channel=0
SDI-Select: 0
PCM:
bits [0x6]: 16 20
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10011b: Stereo Amp-In
Control: name="Capture Switch", index=1, device=0
Control: name="Capture Volume", index=1, device=0
Device: name="ALC662 rev1 Analog", type="Audio", device=2
Amp-In vals: [0x80 0x80]
Converter: stream=0, channel=0
SDI-Select: 0
PCM:
bits [0x6]: 16 20
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Rear Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Rear Mic Playback Switch", index=0, device=0
Control: name="Front Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name="Front Mic Playback Switch", index=0, device=0
Control: name="Line Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Line Playback Switch", index=0, device=0
Control: name="Beep Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=5, ofs=0
Control: name="Beep Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x9f 0x9f] [0x9f 0x9f] [0x9f 0x9f] [0x80 0x80] [0x80 0x80] [0x9f 0x9f] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 9
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x00 0x00]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x04 0x0b
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40018d: Stereo Amp-Out
Control: name="Front Playback Switch", index=0, device=0
Control: name="Line Out Jack", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0001003c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=02, enabled=1
Connection: 1
0x0c
Node 0x15 [Pin Complex] wcaps 0x40018d: Stereo Amp-Out
Amp-Out vals: [0x80 0x80]
Pincap 0x00010034: IN OUT EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Unsolicited: tag=00, enabled=0
Connection: 1
0x0d
Node 0x16 [Pin Complex] wcaps 0x40018d: Stereo Amp-Out
Pincap 0x00000034: IN OUT Detect
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 1
0x0e
Node 0x17 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x18 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name="Center Playback Switch", index=0, device=0
Control: name="LFE Playback Switch", index=0, device=0
Control: name="Rear Mic Boost Volume", index=0, device=0
Control: name="Rear Mic Jack", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-In vals: [0x03 0x03]
Pincap 0x00001734: IN OUT Detect
Vref caps: HIZ 50 GRD 80
Pin Default 0x01a19830: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0x40: OUT VREF_HIZ
Unsolicited: tag=03, enabled=1
Connection: 1
0x0e
Node 0x19 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name="Front Mic Boost Volume", index=0, device=0
Control: name="Front Mic Jack", index=0, device=0
Pincap 0x0000173c: IN OUT HP Detect
Pin Default 0x02a19c31: [Jack] Mic at Ext Front
DefAssociation = 0x3, Sequence = 0x1
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=04, enabled=1
Connection: 2
0x0c* 0x0e
Node 0x1a [Pin Complex] wcaps 0x40018d: Stereo Amp-Out
Control: name="Surround Playback Switch", index=0, device=0
Control: name="Line Jack", index=0, device=0
Pin Default 0x0181303f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x3, Sequence = 0xf
Pin-ctls: 0x40: OUT
Unsolicited: tag=05, enabled=1
Connection: 1
0x0d
Node 0x1b [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Control: name="Front Headphone Jack", index=0, device=0
Pin Default 0x02214c1f: [Jack] HP Out at Ext Front
DefAssociation = 0x1, Sequence = 0xf
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Unsolicited: tag=01, enabled=1
Connection: 2
0x0c* 0x0e
Node 0x1c [Pin Complex] wcaps 0x400001: Stereo
Pincap 0x00000020: IN
Pin Default 0x593301f0: [N/A] CD at Int ATAPI
Conn = ATAPI, Color = Unknown
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400000: Mono
Pin Default 0x4005c603: [N/A] Line Out at Ext N/A
Conn = Optical, Color = UNKNOWN
DefAssociation = 0x0, Sequence = 0x3
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400300: Mono Digital
Control: name="SPDIF Phantom Jack", index=0, device=0
Pincap 0x00000010: OUT
Pin Default 0x014b6120: [Jack] SPDIF Out at Ext Rear
Conn = Comb, Color = Orange
DefAssociation = 0x2, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=12
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Input Source", index=1, device=0
Amp-In vals: [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Input Source", index=0, device=0
Connection: 10
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x26 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
crw-rw---T 1 root audio 116, 7 May 30 16:22 /dev/snd/controlC0
crw-rw---T 1 root audio 116, 6 May 30 16:22 /dev/snd/hwC0D2
crw-rw---T 1 root audio 116, 5 May 30 21:01 /dev/snd/pcmC0D0c
crw-rw---T 1 root audio 116, 4 May 30 21:01 /dev/snd/pcmC0D0p
crw-rw---T 1 root audio 116, 3 May 30 21:01 /dev/snd/pcmC0D1p
crw-rw---T 1 root audio 116, 2 May 30 16:22 /dev/snd/pcmC0D2c
crw-rw---T 1 root audio 116, 1 May 30 18:22 /dev/snd/seq
crw-rw---T 1 root audio 116, 33 May 30 18:22 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 May 30 16:22 .
drwxr-xr-x 3 root root 220 May 30 16:22 ..
lrwxrwxrwx 1 root root 12 May 30 16:22 pci-0000:00:1b.0 -> ../controlC0
!!Aplay/Arecord output
APLAY
[/etc/pulse/client.conf:2] Missing '='.
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC662 rev1 Analog [ALC662 rev1 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: ALC662 rev1 Digital [ALC662 rev1 Digital]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 0: Intel [HDA Intel], device 2: ALC662 rev1 Analog [ALC662 rev1 Analog]
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card 0 [Intel]
Card hw:0 'Intel'/'HDA Intel at 0xd11c0000 irq 43'
Mixer name : 'Realtek ALC662 rev1'
Components : 'HDA:10ec0662,1458a002,00100101'
Controls : 46
Simple ctrls : 22
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
Playback channels: Mono
Limits: Playback 0 - 64
Mono: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pswitch penum
Playback channels: Front Left - Front Right
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control 'PCM',0
Capabilities: pvolume penum
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Capabilities: pvolume pswitch penum
Mono:
Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 31 [100%] [12.00dB] [off]
Front Right: Playback 31 [100%] [12.00dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume penum
Capture channels: Front Left - Front Right
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
Mono:
Simple mixer control 'Center',0
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
Mono:
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined penum
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Beep',0
Mono:
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch penum
Limits: Capture 0 - 31
Front Left: Capture 31 [100%] [33.00dB] [on]
Front Right: Capture 31 [100%] [33.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-13.50dB] [off]
Front Right: Capture 0 [0%] [-13.50dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Channel Mode',0
Capabilities: enum
Items: '2ch' '4ch' '6ch'
Item0: '6ch'
Simple mixer control 'Digital',0
Capabilities: cvolume penum
Limits: Capture 0 - 120
Front Left: Capture 60 [50%] [0.00dB]
Front Right: Capture 60 [50%] [0.00dB]
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Rear Mic' 'Front Mic' 'Line'
Item0: 'Rear Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Rear Mic'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
Front Left: 3 [100%] [30.00dB]
Front Right: 3 [100%] [30.00dB]
!!Alsactl output
--startcollapse--
state.Intel {
control.1 {
iface MIXER
name 'Channel Mode'
value '6ch'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '2ch'
item.1 '4ch'
item.2 '6ch'
control.2 {
iface MIXER
name 'Front Playback Volume'
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.3 {
iface MIXER
name 'Front Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.4 {
iface MIXER
name 'Surround Playback Volume'
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.5 {
iface MIXER
name 'Surround Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.6 {
iface MIXER
name 'Center Playback Volume'
value 64
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
control.7 {
iface MIXER
name 'LFE Playback Volume'
value 64
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
control.8 {
iface MIXER
name 'Center Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
name 'LFE Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.10 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
name 'Rear Mic Playback Volume'
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 1200
dbvalue.1 1200
control.12 {
iface MIXER
name 'Rear Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.13 {
iface MIXER
name 'Front Mic Playback Volume'
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 1200
dbvalue.1 1200
control.14 {
iface MIXER
name 'Front Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.15 {
iface MIXER
name 'Line Playback Volume'
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 1200
dbvalue.1 1200
control.16 {
iface MIXER
name 'Line Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.17 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.18 {
iface MIXER
name 'Rear Mic Boost Volume'
value.0 3
value.1 3
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 3000
dbvalue.1 3000
control.19 {
iface MIXER
name 'Front Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.20 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.21 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.22 {
iface MIXER
name 'Capture Volume'
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1350
dbmax 3300
dbvalue.0 3300
dbvalue.1 3300
control.23 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1350
dbmax 3300
dbvalue.0 -1350
dbvalue.1 -1350
control.24 {
iface MIXER
name 'Input Source'
value 'Rear Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Rear Mic'
item.1 'Front Mic'
item.2 Line
control.25 {
iface MIXER
name 'Input Source'
index 1
value 'Rear Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Rear Mic'
item.1 'Front Mic'
item.2 Line
control.26 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface MIXER
name 'IEC958 Default PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.31 {
iface MIXER
name 'Beep Playback Volume'
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 1200
dbvalue.1 1200
control.32 {
iface MIXER
name 'Beep Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.33 {
iface MIXER
name 'Master Playback Volume'
value 64
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
control.34 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.35 {
iface CARD
name 'Line Out Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.36 {
iface CARD
name 'Front Headphone Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.37 {
iface CARD
name 'Rear Mic Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.38 {
iface CARD
name 'Front Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.39 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.40 {
iface CARD
name 'SPDIF Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.41 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
comment {
access read
type INTEGER
count 6
range '0 - 27'
control.42 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 27'
control.43 {
iface PCM
device 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 27'
control.44 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 27'
control.45 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.46 {
iface MIXER
name 'Digital Capture Volume'
value.0 60
value.1 60
comment {
type INTEGER
count 2
range '0 - 120'
tlv '0000000100000008fffff44800000032'
dbmin -3000
dbmax 3000
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
Module
ppp_deflate
zlib_deflate
bsd_comp
ppp_async
crc_ccitt
ppp_generic
slhc
nls_utf8
isofs
binfmt_misc
loop
dm_crypt
cdc_ncm
usbnet
option
usb_wwan
usbserial
snd_hda_codec_realtek
iTCO_wdt
iTCO_vendor_support
snd_hda_intel
snd_hda_codec
snd_hwdep
snd_pcm
evdev
parport_pc
i915
video
drm_kms_helper
drm
lpc_ich
i2c_algo_bit
parport
mfd_core
coretemp
snd_page_alloc
snd_seq
snd_seq_device
snd_timer
snd
i2c_i801
i2c_core
acpi_cpufreq
rng_core
mperf
soundcore
processor
thermal_sys
button
hid_generic
ext4
crc16
jbd2
mbcache
usbhid
hid
dm_mod
usb_storage
sg
sd_mod
sr_mod
cdrom
crc_t10dif
ata_generic
floppy
uhci_hcd
microcode
ata_piix
r8169
mii
ehci_hcd
libata
scsi_mod
usbcore
usb_common
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x14 0x01014010
0x15 0x411111f0
0x16 0x411111f0
0x18 0x01a19830
0x19 0x02a19c31
0x1a 0x0181303f
0x1b 0x02214c1f
0x1c 0x593301f0
0x1d 0x4005c603
0x1e 0x014b6120
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[ 5.576262] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 5.576684] snd_hda_intel 0000:00:1b.0: irq 43 for MSI/MSI-X
[ 5.673787] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input4
[ 5.679654] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 5.679761] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 5.679846] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 5.679930] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 5.680097] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 5.721304] usbcore: registered new interface driver usbserial
[ 7782.689441] PK-Backend[8736]: segfault at ffffffff ip b520164c sp be750bc0 error 4 in libapt-pkg.so.4.12.0[b51b1000 127000]
[16769.254126] hda-intel: IRQ timing workaround is activated for card #0. Suggest a bigger bdl_pos_adj.
Zrobiłem tak jak mówiłeś, do tego ustawiłem w programie AVL strumień wyjścia audio na alsę. Nic to nie dało.
Jest jeszcze alternatywa z tym front panelem. Nie mam stu procentowej pewności, czy ostatnim razem przy wyjmowaniu płyty głównej podłączyłem dobrze to małe piny. Wygląda to jak kabel z ośmioma końcami i nie wiadomo w jakie miejsca podpiąć który z nich.
