Próbuję kompilować jądro do wersji 3.9.2. Niby wszystko poszło bez błędów, ale nie mogę wystartować gnome. Po wpisaniu:
startx
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
cat /var/log/Xorg.0.log | grep intel
[ 41.036] (II) LoadModule: "intel"
[ 41.036] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 41.066] (II) Module intel: vendor="X.Org Foundation"
[ 41.066] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
[ 41.074] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 41.074] (==) intel(0): RGB weight 888
[ 41.074] (==) intel(0): Default visual is TrueColor
[ 41.074] (II) intel(0): Integrated Graphics Chipset: Intel(R) Ivybridge Mobile (GT2)
[ 41.074] (--) intel(0): Chipset: "Ivybridge Mobile (GT2)"
[ 41.074] (**) intel(0): Relaxed fencing enabled
[ 41.074] (**) intel(0): Wait on SwapBuffers? enabled
[ 41.074] (**) intel(0): Triple buffering? enabled
[ 41.074] (**) intel(0): Framebuffer tiled
[ 41.074] (**) intel(0): Pixmaps tiled
[ 41.074] (**) intel(0): 3D buffers tiled
[ 41.075] (**) intel(0): SwapBuffers wait enabled
[ 41.075] (==) intel(0): video overlay key set to 0x101fe
[ 41.075] (II) intel(0): Output LVDS1 using monitor section Monitor0
[ 41.075] (II) intel(0): found backlight control interface /sys/class/backlight/acpi_video0
[ 41.075] (II) intel(0): Output VGA1 has no monitor section
[ 41.076] (II) intel(0): Output HDMI1 has no monitor section
[ 41.124] (II) intel(0): Output DP1 has no monitor section
[ 41.124] (II) intel(0): EDID for output LVDS1
[ 41.124] (II) intel(0): Manufacturer: LGD Model: 33a Serial#: 0
[ 41.124] (II) intel(0): Year: 2011 Week: 0
[ 41.124] (II) intel(0): EDID Version: 1.3
[ 41.124] (II) intel(0): Digital Display Input
[ 41.124] (II) intel(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 41.124] (II) intel(0): Gamma: 2.20
[ 41.124] (II) intel(0): No DPMS capabilities specified
[ 41.124] (II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 41.124] (II) intel(0): First detailed timing is preferred mode
[ 41.124] (II) intel(0): redX: 0.618 redY: 0.369 greenX: 0.355 greenY: 0.603
[ 41.124] (II) intel(0): blueX: 0.151 blueY: 0.103 whiteX: 0.313 whiteY: 0.329
[ 41.124] (II) intel(0): Manufacturer's mask: 0
[ 41.124] (II) intel(0): Supported detailed timing:
[ 41.124] (II) intel(0): clock: 70.0 MHz Image Size: 344 x 194 mm
[ 41.124] (II) intel(0): h_active: 1366 h_sync: 1402 h_sync_end 1450 h_blank_end 1492 h_border: 0
[ 41.124] (II) intel(0): v_active: 768 v_sync: 771 v_sync_end 776 v_blanking: 782 v_border: 0
[ 41.124] (II) intel(0): LG Display
[ 41.124] (II) intel(0): LP156WH4-TLN1
[ 41.124] (II) intel(0): EDID (in hex):
[ 41.124] (II) intel(0): 00ffffffffffff0030e43a0300000000
[ 41.124] (II) intel(0): 00150103802213780a61d59e5e5b9a26
[ 41.124] (II) intel(0): 1a505400000001010101010101010101
[ 41.124] (II) intel(0): 010101010101581b567e50000e302430
[ 41.125] (II) intel(0): 350058c2100000190000000000000000
[ 41.125] (II) intel(0): 00000000000000000000000000fe004c
[ 41.125] (II) intel(0): 4720446973706c61790a2020000000fe
[ 41.125] (II) intel(0): 004c503135365748342d544c4e310083
[ 41.125] (II) intel(0): EDID vendor "LGD", prod id 826
[ 41.125] (II) intel(0): Printing DDC gathered Modelines:
[ 41.125] (II) intel(0): Modeline "1366x768"x0.0 70.00 1366 1402 1450 1492 768 771 776 782 -hsync -vsync (46.9 kHz eP)
[ 41.125] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "576x432" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "680x384" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "720x450" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "800x512" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "840x525" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "960x540" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "960x600" (doublescan mode not supported)
[ 41.125] (II) intel(0): Not using default mode "1024x768" (doublescan mode not supported)
[ 41.126] (II) intel(0): Printing probed modes for output LVDS1
[ 41.126] (II) intel(0): Modeline "1366x768"x60.0 70.00 1366 1402 1450 1492 768 771 776 782 -hsync -vsync (46.9 kHz eP)
[ 41.126] (II) intel(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 41.126] (II) intel(0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 41.126] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 41.126] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 41.126] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 41.126] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 41.126] (II) intel(0): EDID for output VGA1
[ 41.126] (II) intel(0): EDID for output HDMI1
[ 41.176] (II) intel(0): EDID for output DP1
[ 41.176] (II) intel(0): Output LVDS1 connected
[ 41.176] (II) intel(0): Output VGA1 disconnected
[ 41.176] (II) intel(0): Output HDMI1 disconnected
[ 41.176] (II) intel(0): Output DP1 disconnected
[ 41.176] (II) intel(0): Using exact sizes for initial modes
[ 41.176] (II) intel(0): Output LVDS1 using initial mode 1366x768
[ 41.176] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 41.176] (II) intel(0): Kernel page flipping support detected, enabling
[ 41.176] (**) intel(0): Display dimensions: (340, 190) mm
[ 41.176] (**) intel(0): DPI set to (102, 102)
[ 41.202] (II) intel(0): [DRI2] Setup complete
[ 41.202] (II) intel(0): [DRI2] DRI driver: i965
[ 41.202] (II) intel(0): Allocated new frame buffer 1408x768 stride 5632, tiled
[ 41.205] (==) intel(0): Backing store disabled
[ 41.205] (==) intel(0): Silken mouse enabled
[ 41.205] (II) intel(0): Initializing HW Cursor
[ 41.205] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 41.207] (==) intel(0): DPMS enabled
[ 41.207] (==) intel(0): Intel XvMC decoder enabled
[ 41.207] (II) intel(0): Set up textured video
[ 41.207] (II) intel(0): [XvMC] xvmc_vld driver initialized.
[ 41.207] (II) intel(0): direct rendering: DRI2 Enabled
[ 41.207] (==) intel(0): hotplug detection: "enabled"
[ 41.422] (II) intel(0): Setting screen physical size to 361 x 203
[ 41.985] (II) intel(0): EDID vendor "LGD", prod id 826
[ 41.985] (II) intel(0): Printing DDC gathered Modelines:
[ 41.985] (II) intel(0): Modeline "1366x768"x0.0 70.00 1366 1402 1450 1492 768 771 776 782 -hsync -vsync (46.9 kHz eP)
[ 45.361] (II) intel(0): EDID vendor "LGD", prod id 826
[ 45.362] (II) intel(0): Printing DDC gathered Modelines:
[ 45.362] (II) intel(0): Modeline "1366x768"x0.0 70.00 1366 1402 1450 1492 768 771 776 782 -hsync -vsync (46.9 kHz eP)
[ 58.770] (II) intel(0): EDID vendor "LGD", prod id 826
[ 58.770] (II) intel(0): Printing DDC gathered Modelines:
[ 58.770] (II) intel(0): Modeline "1366x768"x0.0 70.00 1366 1402 1450 1492 768 771 776 782 -hsync -vsync (46.9 kHz eP)
[ 60.385] (II) intel(0): EDID vendor "LGD", prod id 826
[ 60.385] (II) intel(0): Printing DDC gathered Modelines:
[ 60.385] (II) intel(0): Modeline "1366x768"x0.0 70.00 1366 1402 1450 1492 768 771 776 782 -hsync -vsync (46.9 kHz eP)
[ 61.997] (II) intel(0): EDID vendor "LGD", prod id 826
[ 61.997] (II) intel(0): Printing DDC gathered Modelines:
[ 61.997] (II) intel(0): Modeline "1366x768"x0.0 70.00 1366 1402 1450 1492 768 771 776 782 -hsync -vsync (46.9 kHz eP)
Zaznaczenie opcji:
[*]Enable modesetting on intel by default
nomodeset[/I] lub [I]i915.modeset=0
Ma ktoś jakieś pomysły gdzie jest problem? Dlaczego nie uruchamia się gnome? Na standardowym jądrze wszystko działa poprawnie.
