Dzień dobry.
No wygląda że coś wyłapuje, dobrze by było jeszcze dokonfigurować pod siebie.
Druga sprawa jest taka że sama instalacja demona i konfiguracja nie załatwi ci sprawy musisz mieć jeszcze uruchomione tcp-wrappers.
Oto mój konfig denychosta, tcp-wrappers znajedziesz w google:
############ THESE SETTINGS ARE REQUIRED ############
# SECURE_LOG: the log file that contains sshd logging info
# if you are not sure, grep "sshd:" /var/log/*
# The file to process can be overridden with the --file command line
# argument
# Redhat or Fedora Core:
#SECURE_LOG = /var/log/secure
# Mandrake, FreeBSD or OpenBSD:
#SECURE_LOG = /var/log/auth.log
# SuSE:
#SECURE_LOG = /var/log/messages
# Mac OS X (v10.4 or greater -
# also refer to: http://www.denyhosts.net/faq.html#macos
#SECURE_LOG = /private/var/log/asl.log
# Mac OS X (v10.3 or earlier):
#SECURE_LOG=/private/var/log/system.log
# Debian:
# HOSTS_DENY: the file which contains restricted host access information
# Most operating systems:
HOSTS_DENY = /etc/hosts.deny
# Some BSD (FreeBSD) Unixes:
#HOSTS_DENY = /etc/hosts.allow
# Another possibility (also see the next option):
#HOSTS_DENY = /etc/hosts.evil
# PURGE_DENY: removed HOSTS_DENY entries that are older than this time
# when DenyHosts is invoked with the --purge flag
# format is: i[dhwmy]
# Where 'i' is an integer (eg. 7)
# 'm' = minutes
# 'h' = hours
# 'd' = days
# 'w' = weeks
# 'y' = years
# never purge:
PURGE_DENY =
# purge entries older than 1 week
#PURGE_DENY = 1w
# purge entries older than 5 days
#PURGE_DENY = 5d
# PURGE_THRESHOLD: defines the maximum times a host will be purged.
# Once this value has been exceeded then this host will not be purged.
# Setting this parameter to 0 (the default) disables this feature.
# default: a denied host can be purged/re-added indefinitely
#PURGE_THRESHOLD = 0
# a denied host will be purged at most 2 times.
#PURGE_THRESHOLD = 2
# BLOCK_SERVICE: the service name that should be blocked in HOSTS_DENY
# man 5 hosts_access for details
# eg. sshd: 127.0.0.1 # will block sshd logins from 127.0.0.1
# To block all services for the offending host:
#BLOCK_SERVICE = ALL
# To block only sshd:
#BLOCK_SERVICE = sshd
# To only record the offending host and nothing else (if using
# an auxilary file to list the hosts). Refer to:
# http://denyhosts.sourceforge.net/faq.html#aux
BLOCK_SERVICE = ALL
# DENY_THRESHOLD_INVALID: block each host after the number of failed login
# attempts has exceeded this value. This value applies to invalid
# user login attempts (eg. non-existent user accounts)
DENY_THRESHOLD_INVALID = 2
# DENY_THRESHOLD_VALID: block each host after the number of failed
# login attempts has exceeded this value. This value applies to valid
# user login attempts (eg. user accounts that exist in /etc/passwd) except
# for the "root" user
DENY_THRESHOLD_VALID = 6
# DENY_THRESHOLD_ROOT: block each host after the number of failed
# "root" user login attempts only.
DENY_THRESHOLD_ROOT = 1
# DENY_THRESHOLD_RESTRICTED: block each host after the number of failed
# usernames that appear in the WORK_DIR/restricted-usernames file only.
DENY_THRESHOLD_RESTRICTED = 1
# WORK_DIR: the path that DenyHosts will use for writing data to
# (it will be created if it does not already exist).
# Note: it is recommended that you use an absolute pathname
# for this value (eg. /home/foo/denyhosts/data)
WORK_DIR = /var/lib/denyhosts
#WORK_DIR = /home/denyhosts
# SUSPICIOUS_LOGIN_REPORT_ALLOWED_HOSTS
# SUSPICIOUS_LOGIN_REPORT_ALLOWED_HOSTS=YES|NO
# If set to YES, if a suspicious login attempt results from an allowed-host
# then it is considered suspicious. If this is NO, then suspicious logins
# from allowed-hosts will not be reported. All suspicious logins from
# ip addresses that are not in allowed-hosts will always be reported.
# HOSTNAME_LOOKUP
# HOSTNAME_LOOKUP=YES|NO
# If set to YES, for each IP address that is reported by Denyhosts,
# the corresponding hostname will be looked up and reported as well
# (if available).
HOSTNAME_LOOKUP=NO
# LOCK_FILE
# LOCK_FILE=/path/denyhosts
# If this file exists when DenyHosts is run, then DenyHosts will exit
# immediately. Otherwise, this file will be created upon invocation
# and deleted upon exit. This ensures that only one instance is
# running at a time.
# Redhat/Fedora:
#LOCK_FILE = /var/lock/subsys/denyhosts
# Debian
LOCK_FILE = /home/denyhosts/denyhosts.pid
# Misc
#LOCK_FILE = /tmp/denyhosts.lock
############ THESE SETTINGS ARE OPTIONAL ############
# ADMIN_EMAIL: if you would like to receive emails regarding newly
# restricted hosts and suspicious logins, set this address to
# match your email address. If you do not want to receive these reports
# leave this field blank (or run with the --noemail option)
# Multiple email addresses can be delimited by a comma, eg:
# ADMIN_EMAIL = foo@bar.com, bar@foo.com, etc@foobar.com
ADMIN_EMAIL =
# SMTP_HOST and SMTP_PORT: if DenyHosts is configured to email
# reports (see ADMIN_EMAIL) then these settings specify the
# email server address (SMTP_HOST) and the server port (SMTP_PORT)
SMTP_HOST = localhost
SMTP_PORT = 25
# SMTP_USERNAME and SMTP_PASSWORD: set these parameters if your
# smtp email server requires authentication
#SMTP_USERNAME=foo
#SMTP_PASSWORD=bar
# SMTP_FROM: you can specify the "From:" address in messages sent
# from DenyHosts when it reports thwarted abuse attempts
SMTP_FROM = DenyHosts <nobody@localhost>
# SMTP_SUBJECT: you can specify the "Subject:" of messages sent
# by DenyHosts when it reports thwarted abuse attempts
SMTP_SUBJECT = DenyHosts Report
# SMTP_DATE_FORMAT: specifies the format used for the "Date:" header
# when sending email messages.
# for possible values for this parameter refer to: man strftime
# the default:
#SMTP_DATE_FORMAT = %a, %d %b %Y %H:%M:%S %z
# SYSLOG_REPORT
# SYSLOG_REPORT=YES|NO
# If set to yes, when denied hosts are recorded the report data
# will be sent to syslog (syslog must be present on your system).
# The default is: NO
#SYSLOG_REPORT=NO
#SYSLOG_REPORT=YES
# ALLOWED_HOSTS_HOSTNAME_LOOKUP
# ALLOWED_HOSTS_HOSTNAME_LOOKUP=YES|NO
# If set to YES, for each entry in the WORK_DIR/allowed-hosts file,
# the hostname will be looked up. If your versions of tcp_wrappers
# and sshd sometimes log hostnames in addition to ip addresses
# then you may wish to specify this option.
#ALLOWED_HOSTS_HOSTNAME_LOOKUP=NO
# AGE_RESET_VALID: Specifies the period of time between failed login
# attempts that, when exceeded will result in the failed count for
# this host to be reset to 0. This value applies to login attempts
# to all valid users (those within /etc/passwd) with the
# exception of root. If not defined, this count will never
# be reset.
# See the comments in the PURGE_DENY section (above)
# for details on specifying this value or for complete details
# refer to: http://denyhosts.sourceforge.net/faq.html#timespec
AGE_RESET_VALID=1d
# AGE_RESET_ROOT: Specifies the period of time between failed login
# this host to be reset to 0. This value applies to all login
# attempts to the "root" user account. If not defined,
# this count will never be reset.
#AGE_RESET_ROOT=25d
# AGE_RESET_RESTRICTED: Specifies the period of time between failed login
# attempts to entries found in the WORK_DIR/restricted-usernames file.
# If not defined, the count will never be reset.
AGE_RESET_RESTRICTED=25d
# AGE_RESET_INVALID: Specifies the period of time between failed login
# made to any invalid username (those that do not appear
# in /etc/passwd). If not defined, count will never be reset.
AGE_RESET_INVALID=10d
# RESET_ON_SUCCESS: If this parameter is set to "yes" then the
# failed count for the respective ip address will be reset to 0
# if the login is successful.
# The default is RESET_ON_SUCCESS = no
RESET_ON_SUCCESS = yes
# PLUGIN_DENY: If set, this value should point to an executable
# program that will be invoked when a host is added to the
# HOSTS_DENY file. This executable will be passed the host
# that will be added as its only argument.
#PLUGIN_DENY=/usr/bin/true
# PLUGIN_PURGE: If set, this value should point to an executable
# program that will be invoked when a host is removed from the
# that is to be purged as its only argument.
#PLUGIN_PURGE=/usr/bin/true
# USERDEF_FAILED_ENTRY_REGEX: if set, this value should contain
# a regular expression that can be used to identify additional
# hackers for your particular ssh configuration. This functionality
# extends the built-in regular expressions that DenyHosts uses.
# This parameter can be specified multiple times.
# See this faq entry for more details:
# http://denyhosts.sf.net/faq.html#userdef_regex
#USERDEF_FAILED_ENTRY_REGEX=
######### THESE SETTINGS ARE SPECIFIC TO DAEMON MODE ##########
# DAEMON_LOG: when DenyHosts is run in daemon mode (--daemon flag)
# this is the logfile that DenyHosts uses to report its status.
# To disable logging, leave blank. (default is: /var/log/denyhosts)
DAEMON_LOG = /var/log/denyhosts
# disable logging:
#DAEMON_LOG =
# DAEMON_LOG_TIME_FORMAT: when DenyHosts is run in daemon mode
# (--daemon flag) this specifies the timestamp format of
# the DAEMON_LOG messages (default is the ISO8061 format:
# ie. 2005-07-22 10:38:01,745)
# Jan 1 13:05:59
#DAEMON_LOG_TIME_FORMAT = %b %d %H:%M:%S
# Jan 1 01:05:59
#DAEMON_LOG_TIME_FORMAT = %b %d %I:%M:%S
# DAEMON_LOG_MESSAGE_FORMAT: when DenyHosts is run in daemon mode
# (--daemon flag) this specifies the message format of each logged
# entry. By default the following format is used:
# %(asctime)s - %(name)-12s: %(levelname)-8s %(message)s
# Where the "%(asctime)s" portion is expanded to the format
# defined by DAEMON_LOG_TIME_FORMAT
# This string is passed to python's logging.Formatter contstuctor.
# For details on the possible format types please refer to:
# http://docs.python.org/lib/node357.html
# This is the default:
#DAEMON_LOG_MESSAGE_FORMAT = %(asctime)s - %(name)-12s: %(levelname)-8s %(message)s
# DAEMON_SLEEP: when DenyHosts is run in daemon mode (--daemon flag)
# this is the amount of time DenyHosts will sleep between polling
# the SECURE_LOG. See the comments in the PURGE_DENY section (above)
DAEMON_SLEEP = 30s
# DAEMON_PURGE: How often should DenyHosts, when run in daemon mode,
# run the purge mechanism to expire old entries in HOSTS_DENY
# This has no effect if PURGE_DENY is blank.
DAEMON_PURGE = 1h
######### THESE SETTINGS ARE SPECIFIC TO ##########
######### DAEMON SYNCHRONIZATION ##########
# Synchronization mode allows the DenyHosts daemon the ability
# to periodically send and receive denied host data such that
# DenyHosts daemons worldwide can automatically inform one
# another regarding banned hosts. This mode is disabled by
# default, you must uncomment SYNC_SERVER to enable this mode.
# for more information, please refer to:
# http:/denyhosts.sourceforge.net/faq.html#sync
# SYNC_SERVER: The central server that communicates with DenyHost
# daemons. Currently, denyhosts.net is the only available server
# however, in the future, it may be possible for organizations to
# install their own server for internal network synchronization
# To disable synchronization (the default), do nothing.
# To enable synchronization, you must uncomment the following line:
#SYNC_SERVER = http://xmlrpc.denyhosts.net:9911
# SYNC_INTERVAL: the interval of time to perform synchronizations if
# SYNC_SERVER has been uncommented. The default is 1 hour.
#SYNC_INTERVAL = 1h
# SYNC_UPLOAD: allow your DenyHosts daemon to transmit hosts that have
# been denied? This option only applies if SYNC_SERVER has
# been uncommented.
# The default is SYNC_UPLOAD = yes
#SYNC_UPLOAD = no
#SYNC_UPLOAD = yes
# SYNC_DOWNLOAD: allow your DenyHosts daemon to receive hosts that have
# been denied by others? This option only applies if SYNC_SERVER has
# been uncommented.
# The default is SYNC_DOWNLOAD = yes
#SYNC_DOWNLOAD = no
#SYNC_DOWNLOAD = yes
# SYNC_DOWNLOAD_THRESHOLD: If SYNC_DOWNLOAD is enabled this parameter
# filters the returned hosts to those that have been blocked this many
# times by others. That is, if set to 1, then if a single DenyHosts
# server has denied an ip address then you will receive the denied host.
# See also SYNC_DOWNLOAD_RESILIENCY
#SYNC_DOWNLOAD_THRESHOLD = 10
# The default is SYNC_DOWNLOAD_THRESHOLD = 3
#SYNC_DOWNLOAD_THRESHOLD = 3
# SYNC_DOWNLOAD_RESILIENCY: If SYNC_DOWNLOAD is enabled then the
# value specified for this option limits the downloaded data
# to this resiliency period or greater.
# Resiliency is defined as the timespan between a hackers first known
# attack and its most recent attack. Example:
# If the centralized denyhosts.net server records an attack at 2 PM
# and then again at 5 PM, specifying a SYNC_DOWNLOAD_RESILIENCY = 4h
# will not download this ip address.
# However, if the attacker is recorded again at 6:15 PM then the
# ip address will be downloaded by your DenyHosts instance.
# This value is used in conjunction with the SYNC_DOWNLOAD_THRESHOLD
# and only hosts that satisfy both values will be downloaded.
# This value has no effect if SYNC_DOWNLOAD_THRESHOLD = 1
# The default is SYNC_DOWNLOAD_RESILIENCY = 5h (5 hours)
# Only obtain hackers that have been at it for 2 days or more:
#SYNC_DOWNLOAD_RESILIENCY = 2d
# Only obtain hackers that have been at it for 5 hours or more:
#SYNC_DOWNLOAD_RESILIENCY = 5h
