em w system ->preferencje-> wybór systemów multimediów, a tak to nigdzie indziej nie ma.
ylko szumi jak w regulacji głośności włączę mic boost na full.
A ma być zero czy o bo zero wywala brak komendy.
[ 0.261174] pnp: PnP ACPI init
[ 0.261183] ACPI: bus type pnp registered
[ 0.265476] pnp: PnP ACPI: found 14 devices
[ 0.265478] ACPI: ACPI bus type pnp unregistered
[ 0.265491] system 00:01: ioport range 0x400-0x47f has been reserved
[ 0.265494] system 00:01: ioport range 0x500-0x50f has been reserved
[ 0.265499] system 00:02: ioport range 0x4d0-0x4d1 has been reserved
[ 0.265501] system 00:02: ioport range 0x290-0x29f has been reserved
[ 0.265504] system 00:02: ioport range 0x800-0x805 has been reserved
[ 0.265506] system 00:02: ioport range 0x880-0x88f has been reserved
[ 0.265513] system 00:0a: iomem range 0x10000000-0x10000fff could not be reserved
[ 0.265518] system 00:0b: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.265523] system 00:0d: iomem range 0xcf000-0xcffff has been reserved
[ 0.265526] system 00:0d: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.265528] system 00:0d: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.265531] system 00:0d: iomem range 0xfc000-0xfffff could not be reserved
[ 0.265533] system 00:0d: iomem range 0xfe800000-0xfe8000ff has been reserved
[ 0.265536] system 00:0d: iomem range 0x3fee0000-0x3fefffff could not be reserved
[ 0.265539] system 00:0d: iomem range 0xffff0000-0xffffffff has been reserved
[ 0.265541] system 00:0d: iomem range 0x0-0x9ffff could not be reserved
[ 0.265544] system 00:0d: iomem range 0x100000-0x3fedffff could not be reserved
[ 0.265547] system 00:0d: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.265550] system 00:0d: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.265552] system 00:0d: iomem range 0xfff80000-0xfffeffff has been reserved
[ 0.270252] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.270254] pci 0000:00:01.0: IO window: disabled
[ 0.270258] pci 0000:00:01.0: MEM window: disabled
[ 0.270262] pci 0000:00:01.0: PREFETCH window: disabled
[ 0.270268] pci 0000:00:02.0: PCI bridge, secondary bus 0000:02
[ 0.270271] pci 0000:00:02.0: IO window: 0xc000-0xcfff
[ 0.270277] pci 0000:00:02.0: MEM window: 0xdfe00000-0xdfefffff
[ 0.270281] pci 0000:00:02.0: PREFETCH window: 0x000000c0000000-0x000000cfffffff
[ 0.270288] pci 0000:00:13.1: PCI bridge, secondary bus 0000:04
[ 0.270291] pci 0000:00:13.1: IO window: 0xb000-0xbfff
[ 0.270296] pci 0000:00:13.1: MEM window: 0xdfd00000-0xdfdfffff
[ 0.270300] pci 0000:00:13.1: PREFETCH window: 0x40000000-0x400fffff
[ 0.270318] pci 0000:00:01.0: setting latency timer to 64
[ 0.270327] alloc irq_desc for 27 on node -1
[ 0.270329] alloc kstat_irqs on node -1
[ 0.270335] pci 0000:00:02.0: PCI INT A -> GSI 27 (level, low) -> IRQ 27
[ 0.270339] pci 0000:00:02.0: setting latency timer to 64
[ 0.270346] pci 0000:00:13.1: setting latency timer to 64
[ 0.270350] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.270352] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
[ 0.270354] pci_bus 0000:02: resource 0 io: [0xc000-0xcfff]
[ 0.270356] pci_bus 0000:02: resource 1 mem: [0xdfe00000-0xdfefffff]
[ 0.270358] pci_bus 0000:02: resource 2 pref mem [0xc0000000-0xcfffffff]
[ 0.270361] pci_bus 0000:04: resource 0 io: [0xb000-0xbfff]
[ 0.270362] pci_bus 0000:04: resource 1 mem: [0xdfd00000-0xdfdfffff]
[ 0.270365] pci_bus 0000:04: resource 2 pref mem [0x40000000-0x400fffff]
[ 0.270367] pci_bus 0000:04: resource 3 io: [0x00-0xffff]
[ 0.270369] pci_bus 0000:04: resource 4 mem: [0x000000-0xffffffffffffffff]
[ 0.270371] pci_bus 0000:80: resource 0 io: [0x00-0xffff]
[ 0.270373] pci_bus 0000:80: resource 1 mem: [0x000000-0xffffffffffffffff]
[ 0.270403] NET: Registered protocol family 2
[ 0.270502] IP route cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.270979] TCP established hash table entries: 131072 (order: 9, 2097152 bytes)
[ 0.272290] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.273163] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.273166] TCP reno registered
[ 0.273319] NET: Registered protocol family 1
[ 0.273339] pci 0000:00:00.0: MSI quirk detected; MSI disabled
[ 0.273353] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.273384] alloc irq_desc for 20 on node -1
[ 0.273387] alloc kstat_irqs on node -1
[ 0.273398] pci 0000:00:10.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 0.273420] pci 0000:00:10.0: PCI INT A disabled
[ 0.273431] alloc irq_desc for 22 on node -1
[ 0.273432] alloc kstat_irqs on node -1
[ 0.273435] pci 0000:00:10.1: PCI INT B -> GSI 22 (level, low) -> IRQ 22
[ 0.273456] pci 0000:00:10.1: PCI INT B disabled
[ 0.273466] alloc irq_desc for 21 on node -1
[ 0.273468] alloc kstat_irqs on node -1
[ 0.273471] pci 0000:00:10.2: PCI INT C -> GSI 21 (level, low) -> IRQ 21
[ 0.273492] pci 0000:00:10.2: PCI INT C disabled
[ 0.273502] alloc irq_desc for 23 on node -1
[ 0.273503] alloc kstat_irqs on node -1
[ 0.273506] pci 0000:00:10.3: PCI INT D -> GSI 23 (level, low) -> IRQ 23
[ 0.273527] pci 0000:00:10.3: PCI INT D disabled
[ 0.273537] pci 0000:00:10.4: PCI INT C -> GSI 21 (level, low) -> IRQ 21
[ 0.273565] pci 0000:00:10.4: PCI INT C disabled
[ 0.273576] pci 0000:02:00.0: Boot video device
[ 0.273650] Unpacking initramfs...
[ 0.468954] Freeing initrd memory: 9111k freed
[ 0.474330] audit: initializing netlink socket (disabled)
[ 0.474351] type=2000 audit(1362364206.471:1): initialized
[ 0.477156] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.478406] VFS: Disk quotas dquot_6.5.2
[ 0.478457] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.478538] msgmni has been set to 2001
[ 0.478728] alg: No test for stdrng (krng)
[ 0.478775] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.478778] io scheduler noop registered
[ 0.478780] io scheduler anticipatory registered
[ 0.478781] io scheduler deadline registered
[ 0.478836] io scheduler cfq registered (default)
[ 0.478976] pcieport 0000:00:02.0: setting latency timer to 64
[ 0.480387] Linux agpgart interface v0.103
[ 0.480424] agpgart: Detected VIA P4M900 chipset
[ 0.486660] agpgart-via 0000:00:00.0: AGP aperture is 128M @ 0xd0000000
[ 0.486692] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.487051] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 0.487113] PNP: PS/2 Controller [PNP0f13:PS2M] at 0x60,0x64 irq 12
[ 0.487114] PNP: PS/2 controller doesn't have KBD irq; using default 1
[ 0.490700] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.490706] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.490768] mice: PS/2 mouse device common for all mice
[ 0.490804] rtc_cmos 00:05: RTC can wake from S4
[ 0.490837] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.490885] rtc0: alarms up to one year, y3k, 242 bytes nvram, hpet irqs
[ 0.490895] cpuidle: using governor ladder
[ 0.490897] cpuidle: using governor menu
[ 0.490901] No iBFT detected.
[ 0.491190] TCP cubic registered
[ 0.491289] NET: Registered protocol family 10
[ 0.491923] Mobile IPv6
[ 0.491926] NET: Registered protocol family 17
[ 0.491998] PM: Resume from disk failed.
[ 0.492009] registered taskstats version 1
[ 0.492428] rtc_cmos 00:05: setting system clock to 2013-03-04 02:30:06 UTC (1362364206)
[ 0.492465] Initalizing network drop monitor service
[ 0.492487] Freeing unused kernel memory: 592k freed
[ 0.492649] Write protecting the kernel read-only data: 4252k
[ 0.505461] udev[56]: starting version 164
[ 0.601995] usbcore: registered new interface driver usbfs
[ 0.602136] usbcore: registered new interface driver hub
[ 0.602266] usbcore: registered new device driver usb
[ 0.612992] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.613035] ehci_hcd 0000:00:10.4: PCI INT C -> GSI 21 (level, low) -> IRQ 21
[ 0.613059] ehci_hcd 0000:00:10.4: EHCI Host Controller
[ 0.613085] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 1
[ 0.613151] ehci_hcd 0000:00:10.4: irq 21, io mem 0xdffff000
[ 0.613637] SCSI subsystem initialized
[ 0.625638] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00
[ 0.625667] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.625670] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.625672] usb usb1: Product: EHCI Host Controller
[ 0.625674] usb usb1: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 0.625675] usb usb1: SerialNumber: 0000:00:10.4
[ 0.625767] usb usb1: configuration #1 chosen from 1 choice
[ 0.625795] hub 1-0:1.0: USB hub found
[ 0.625803] hub 1-0:1.0: 8 ports detected
[ 0.628302] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.628342] r8169 0000:04:07.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 0.628356] r8169 0000:04:07.0: PCI: Disallowing DAC for device
[ 0.628372] r8169 0000:04:07.0: (unregistered net_device): no PCI Express capability
[ 0.629068] r8169 0000:04:07.0: eth0: RTL8169sc/8110sc at 0xffffc900001fe000, 00:1d:60:dc:29:14, XID 18000000 IRQ 20
[ 0.629922] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.630211] uhci_hcd 0000:00:10.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 0.630223] uhci_hcd 0000:00:10.0: UHCI Host Controller
[ 0.630408] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[ 0.630464] uhci_hcd 0000:00:10.0: irq 20, io base 0x0000e000
[ 0.630508] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.630510] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.630512] usb usb2: Product: UHCI Host Controller
[ 0.630514] usb usb2: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd
[ 0.630515] usb usb2: SerialNumber: 0000:00:10.0
[ 0.630637] usb usb2: configuration #1 chosen from 1 choice
[ 0.630691] hub 2-0:1.0: USB hub found
[ 0.630699] hub 2-0:1.0: 2 ports detected
[ 0.630752] uhci_hcd 0000:00:10.1: PCI INT B -> GSI 22 (level, low) -> IRQ 22
[ 0.630781] uhci_hcd 0000:00:10.1: UHCI Host Controller
[ 0.630790] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3
[ 0.631010] libata version 3.00 loaded.
[ 0.631142] uhci_hcd 0000:00:10.1: irq 22, io base 0x0000dc00
[ 0.631184] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.631186] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.631188] usb usb3: Product: UHCI Host Controller
[ 0.631190] usb usb3: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd
[ 0.631191] usb usb3: SerialNumber: 0000:00:10.1
[ 0.631265] usb usb3: configuration #1 chosen from 1 choice
[ 0.631294] hub 3-0:1.0: USB hub found
[ 0.631300] hub 3-0:1.0: 2 ports detected
[ 0.631345] uhci_hcd 0000:00:10.2: PCI INT C -> GSI 21 (level, low) -> IRQ 21
[ 0.631353] uhci_hcd 0000:00:10.2: UHCI Host Controller
[ 0.631363] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4
[ 0.631383] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000d800
[ 0.631413] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.631415] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.631417] usb usb4: Product: UHCI Host Controller
[ 0.631418] usb usb4: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd
[ 0.631420] usb usb4: SerialNumber: 0000:00:10.2
[ 0.631478] usb usb4: configuration #1 chosen from 1 choice
[ 0.631501] hub 4-0:1.0: USB hub found
[ 0.631507] hub 4-0:1.0: 2 ports detected
[ 0.631548] uhci_hcd 0000:00:10.3: PCI INT D -> GSI 23 (level, low) -> IRQ 23
[ 0.631555] uhci_hcd 0000:00:10.3: UHCI Host Controller
[ 0.631561] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 5
[ 0.631602] uhci_hcd 0000:00:10.3: irq 23, io base 0x0000d400
[ 0.631631] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.631634] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.631635] usb usb5: Product: UHCI Host Controller
[ 0.631637] usb usb5: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd
[ 0.631639] usb usb5: SerialNumber: 0000:00:10.3
[ 0.631695] usb usb5: configuration #1 chosen from 1 choice
[ 0.631717] hub 5-0:1.0: USB hub found
[ 0.631723] hub 5-0:1.0: 2 ports detected
[ 0.632572] sata_via 0000:00:0f.0: version 2.4
[ 0.632588] sata_via 0000:00:0f.0: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 0.632623] sata_via 0000:00:0f.0: routed to hard irq line 11
[ 0.634733] scsi0 : sata_via
[ 0.634955] thermal LNXTHERM:01: registered as thermal_zone0
[ 0.634963] ACPI: Thermal Zone [THRM] (40 C)
[ 0.636486] scsi1 : sata_via
[ 0.637193] fan PNP0C0B:00: registered as cooling_device0
[ 0.637199] ACPI: Fan [FAN] (on)
[ 0.638155] ata1: SATA max UDMA/133 cmd 0xfc00 ctl 0xf800 bmdma 0xec00 irq 21
[ 0.638158] ata2: SATA max UDMA/133 cmd 0xf400 ctl 0xf000 bmdma 0xec08 irq 21
[ 0.733686] pata_via 0000:00:0f.1: version 0.3.4
[ 0.733893] scsi2 : pata_via
[ 0.733957] scsi3 : pata_via
[ 0.735652] ata3: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xe400 irq 14
[ 0.735655] ata4: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xe408 irq 15
[ 0.840477] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.013028] ata3.00: ATA-7: SAMSUNG SP2014N, VC100-41, max UDMA/100
[ 1.013033] ata3.00: 390721968 sectors, multi 16: LBA48
[ 1.013093] ata3.01: ATAPI: LITE-ON DVDRW SOHW-1673S, JS01, max UDMA/66
[ 1.020356] ata1.00: ATAPI: LITE-ON DVDRW LH-20A1S, 9L09, max UDMA/100
[ 1.044405] ata3.00: configured for UDMA/100
[ 1.052331] ata1.00: configured for UDMA/100
[ 1.060269] ata3.01: configured for UDMA/66
[ 1.062199] scsi 0:0:0:0: CD-ROM LITE-ON DVDRW LH-20A1S 9L09 PQ: 0 ANSI: 5
[ 1.104041] usb 1-3: new high speed USB device using ehci_hcd and address 4
[ 1.239890] usb 1-3: New USB device found, idVendor=0930, idProduct=6545
[ 1.239894] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.239898] usb 1-3: Product: USB Flash Memory
[ 1.239901] usb 1-3: Manufacturer:
[ 1.239904] usb 1-3: SerialNumber: 001D60B166DFEC1066AA002F
[ 1.240017] usb 1-3: configuration #1 chosen from 1 choice
[ 1.245577] Initializing USB Mass Storage driver...
[ 1.245691] scsi4 : SCSI emulation for USB Mass Storage devices
[ 1.245773] usbcore: registered new interface driver usb-storage
[ 1.245775] USB Mass Storage support registered.
[ 1.245780] usb-storage: device found at 4
[ 1.245781] usb-storage: waiting for device to settle before scanning
[ 1.264037] ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
[ 1.274862] scsi 2:0:0:0: Direct-Access ATA SAMSUNG SP2014N VC10 PQ: 0 ANSI: 5
[ 1.275756] scsi 2:0:1:0: CD-ROM LITE-ON DVDRW SOHW-1673S JS01 PQ: 0 ANSI: 5
[ 1.439381] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.439387] Uniform CD-ROM driver Revision: 3.20
[ 1.439532] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 1.441243] sd 2:0:0:0: [sda] 390721968 512-byte logical blocks: (200 GB/186 GiB)
[ 1.443244] sr1: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
[ 1.443300] sd 2:0:0:0: [sda] Write Protect is off
[ 1.443305] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.443346] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.443464] sr 2:0:1:0: Attached scsi CD-ROM sr1
[ 1.443607] sda: sda1 sda2 sda3 sda4 < sda5 sda6
[ 1.480042] usb 2-1: new low speed USB device using uhci_hcd and address 2
[ 1.490927] sda7 >
[ 1.506656] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.510405] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 1.510521] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 1.510610] sr 2:0:1:0: Attached scsi generic sg2 type 5
[ 1.736743] usb 2-1: New USB device found, idVendor=09da, idProduct=0260
[ 1.736749] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.736753] usb 2-1: Product: USB Keyboard
[ 1.736756] usb 2-1: Manufacturer:
[ 1.736899] usb 2-1: configuration #1 chosen from 1 choice
[ 1.751078] usbcore: registered new interface driver hiddev
[ 1.795039] input: USB Keyboard as /devices/pci0000:00/0000:00:10.0/usb2/2-1/2-1:1.0/input/input1
[ 1.795103] generic-usb 0003:09DA:0260.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-0000:00:10.0-1/input0
[ 1.888216] input: USB Keyboard as /devices/pci0000:00/0000:00:10.0/usb2/2-1/2-1:1.1/input/input2
[ 1.888275] generic-usb 0003:09DA:0260.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-0000:00:10.0-1/input1
[ 1.888301] usbcore: registered new interface driver usbhid
[ 1.888304] usbhid: v2.6:USB HID core driver
[ 1.980016] usb 2-2: new full speed USB device using uhci_hcd and address 3
[ 1.986389] PM: Starting manual resume from disk
[ 1.986392] PM: Resume from partition 8:3
[ 1.986393] PM: Checking hibernation image.
[ 1.986626] PM: Error -22 checking image file
[ 1.986629] PM: Resume from disk failed.
[ 2.030437] EXT4-fs (sda2): mounted filesystem with ordered data mode
[ 2.149837] usb 2-2: New USB device found, idVendor=0a05, idProduct=7211
[ 2.149842] usb 2-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.149847] usb 2-2: Product: USB2.0 HUB
[ 2.150004] usb 2-2: configuration #1 chosen from 1 choice
[ 2.152872] hub 2-2:1.0: USB hub found
[ 2.154830] hub 2-2:1.0: 4 ports detected
[ 3.402973] udev[407]: starting version 164
[ 3.742604] ACPI: SSDT 000000003feeaec0 001F9 (v01 AWARD ASUSACPI 42302E31 AWRD 00000000)
[ 3.743333] processor LNXCPU:00: registered as cooling_device1
[ 3.743541] ACPI: SSDT 000000003feeb2d0 000CE (v01 AWARD ASUSACPI 42302E31 AWRD 00000000)
[ 3.743762] processor LNXCPU:01: registered as cooling_device2
[ 3.756243] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 3.756251] ACPI: Power Button [PWRB]
[ 3.756301] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4
[ 3.756311] ACPI: Sleep Button [SLPB]
[ 3.756372] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 3.756375] ACPI: Power Button [PWRF]
[ 4.015419] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 4.017722] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 4.131722] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ 4.234854] parport_pc 00:08: reported by Plug and Play ACPI
[ 4.234948] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 4.247068] alloc irq_desc for 25 on node -1
[ 4.247071] alloc kstat_irqs on node -1
[ 4.247079] HDA Intel 0000:02:00.1: PCI INT B -> GSI 25 (level, low) -> IRQ 25
[ 4.247118] HDA Intel 0000:02:00.1: setting latency timer to 64
[ 4.247126] HDA Intel 0000:02:00.1: PCI: Disallowing DAC for device
[ 4.323136] [drm] Initialized drm 1.1.0 20060810
[ 4.544245] alloc irq_desc for 17 on node -1
[ 4.544248] alloc kstat_irqs on node -1
[ 4.544256] HDA Intel 0000:80:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 4.544307] HDA Intel 0000:80:01.0: setting latency timer to 64
[ 4.544311] HDA Intel 0000:80:01.0: PCI: Disallowing DAC for device
[ 4.751090] cfg80211: Using static regulatory domain info
[ 4.751093] cfg80211: Regulatory domain: US
[ 4.751095] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 4.751097] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 4.751100] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 4.751102] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 4.751104] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 4.751106] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 4.751109] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 4.751118] cfg80211: Calling CRDA for country: US
[ 4.869998] alloc irq_desc for 18 on node -1
[ 4.870001] alloc kstat_irqs on node -1
[ 4.870010] ath5k 0000:04:04.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 4.870064] ath5k 0000:04:04.0: registered as 'phy0'
[ 4.902139] [drm] radeon kernel modesetting enabled.
[ 4.902211] alloc irq_desc for 24 on node -1
[ 4.902213] alloc kstat_irqs on node -1
[ 4.902222] radeon 0000:02:00.0: PCI INT A -> GSI 24 (level, low) -> IRQ 24
[ 4.902228] radeon 0000:02:00.0: setting latency timer to 64
[ 4.905342] [drm] radeon: Initializing kernel modesetting.
[ 4.905433] radeon 0000:02:00.0: PCI: Disallowing DAC for device
[ 4.905435] radeon: No suitable DMA available.
[ 4.905480] [drm] register mmio base: 0xDFEE0000
[ 4.905481] [drm] register mmio size: 65536
[ 4.905663] ATOM BIOS: RV710
[ 4.905690] [drm] Clocks initialized !
[ 4.906644] [drm] Detected VRAM RAM=256M, BAR=256M
[ 4.906647] [drm] RAM width 64bits DDR
[ 4.906731] [TTM] Zone kernel: Available graphics memory: 512704 kiB.
[ 4.906749] [drm] radeon: 256M of VRAM memory ready
[ 4.906751] [drm] radeon: 512M of GTT memory ready.
[ 4.906823] [drm] radeon: irq initialized.
[ 4.906826] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 4.907383] [drm] Loading RV710 Microcode
[ 4.907389] platform radeon_cp.0: firmware: requesting radeon/RV710_pfp.bin
[ 4.921470] input: HDA Digital PCBeep as /devices/pci0000:80/0000:80:01.0/input/input7
[ 5.044802] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input8
[ 5.457908] ath: EEPROM regdomain: 0x30
[ 5.457911] ath: EEPROM indicates we should expect a direct regpair map
[ 5.457914] ath: Country alpha2 being used: AM
[ 5.457915] ath: Regpair used: 0x30
[ 5.546905] r600_cp: Failed to load firmware "radeon/RV710_pfp.bin"
[ 5.546954] [drm:rv770_startup] *ERROR* Failed to load firmware!
[ 5.546998] radeon 0000:02:00.0: disabling GPU acceleration
[ 5.562054] radeon 0000:02:00.0: ffff88003ec65e00 unpin not necessary
[ 5.562059] radeon 0000:02:00.0: ffff88003ec65e00 unpin not necessary
[ 5.562993] [drm] Radeon Display Connectors
[ 5.562995] [drm] Connector 0:
[ 5.562997] [drm] VGA
[ 5.562999] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c
[ 5.563000] [drm] Encoders:
[ 5.563002] [drm] CRT2: INTERNAL_KLDSCP_DAC2
[ 5.563004] [drm] Connector 1:
[ 5.563005] [drm] HDMI-A
[ 5.563007] [drm] HPD1
[ 5.563009] [drm] DDC: 0x7e50 0x7e50 0x7e54 0x7e54 0x7e58 0x7e58 0x7e5c 0x7e5c
[ 5.563010] [drm] Encoders:
[ 5.563011] [drm] DFP1: INTERNAL_UNIPHY
[ 5.563013] [drm] Connector 2:
[ 5.563014] [drm] DVI-I
[ 5.563015] [drm] HPD4
[ 5.563017] [drm] DDC: 0x7f10 0x7f10 0x7f14 0x7f14 0x7f18 0x7f18 0x7f1c 0x7f1c
[ 5.563018] [drm] Encoders:
[ 5.563020] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 5.563021] [drm] DFP2: INTERNAL_UNIPHY2
[ 5.699979] [drm] fb mappable at 0xC0040000
[ 5.699982] [drm] vram apper at 0xC0000000
[ 5.699984] [drm] size 11059200
[ 5.699985] [drm] fb depth is 24
[ 5.699986] [drm] pitch is 7680
[ 5.715153] Console: switching to colour frame buffer device 240x90
[ 5.721981] fb0: radeondrmfb frame buffer device
[ 5.721983] registered panic notifier
[ 5.721989] [drm] Initialized radeon 2.0.0 20080528 for 0000:02:00.0 on minor 0
[ 5.732204] phy0: Selected rate control algorithm 'minstrel'
[ 5.732809] ath5k phy0: Atheros AR2414 chip found (MAC: 0x79, PHY: 0x45)
[ 5.732948] cfg80211: Calling CRDA for country: AM
[ 6.244680] usb-storage: device scan complete
[ 6.246294] scsi 4:0:0:0: Direct-Access USB Flash Memory PMAP PQ: 0 ANSI: 0 CCS
[ 6.246727] sd 4:0:0:0: Attached scsi generic sg3 type 0
[ 6.248776] sd 4:0:0:0: [sdb] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[ 6.249271] sd 4:0:0:0: [sdb] Write Protect is off
[ 6.249276] sd 4:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 6.249280] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 6.252018] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 6.252073] sdb: sdb1
[ 6.254893] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 6.254934] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 6.893083] Adding 2343928k swap on /dev/sda3. Priority:-1 extents:1 across:2343928k
[ 7.279768] loop: module loaded
[ 7.686252] EXT4-fs (sda5): mounted filesystem with ordered data mode
[ 9.096909] fuse init (API version 7.13)
[ 11.811408] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.826436] r8169 0000:04:07.0: eth0: link down
[ 11.826570] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.505325] Bluetooth: Core ver 2.15
[ 13.505387] NET: Registered protocol family 31
[ 13.505389] Bluetooth: HCI device and connection manager initialized
[ 13.505392] Bluetooth: HCI socket layer initialized
[ 13.536901] Bluetooth: L2CAP ver 2.14
[ 13.536903] Bluetooth: L2CAP socket layer initialized
[ 13.655594] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.655598] Bluetooth: BNEP filters: protocol multicast
[ 13.670538] Bluetooth: RFCOMM TTY layer initialized
[ 13.670545] Bluetooth: RFCOMM socket layer initialized
[ 13.670548] Bluetooth: RFCOMM ver 1.11
[ 13.698408] Bridge firewalling registered
[ 13.843879] Bluetooth: SCO (Voice Link) ver 0.6
[ 13.843883] Bluetooth: SCO socket layer initialized
[ 14.339541] lp0: using parport0 (interrupt-driven).
[ 14.411853] ppdev: user-space parallel port driver
[ 20.791121] CPU0 attaching NULL sched-domain.
[ 20.791137] CPU1 attaching NULL sched-domain.
[ 20.820642] CPU0 attaching sched-domain:
[ 20.820649] domain 0: span 0-1 level MC
[ 20.820651] groups: group ffff88000180fbf0 cpus 0 group ffff88000188fbf0 cpus 1
[ 20.820661] CPU1 attaching sched-domain:
[ 20.820662] domain 0: span 0-1 level MC
[ 20.820664] groups: group ffff88000188fbf0 cpus 1 group ffff88000180fbf0 cpus 0
[ 32.761806] wlan0: direct probe to AP 00:27:19:de:a8:2c (try 1)
[ 32.764637] wlan0: direct probe responded
[ 32.764643] wlan0: authenticate with AP 00:27:19:de:a8:2c (try 1)
[ 32.766253] wlan0: authenticated
[ 32.766281] wlan0: associate with AP 00:27:19:de:a8:2c (try 1)
[ 32.769032] wlan0: RX AssocResp from 00:27:19:de:a8:2c (capab=0x431 status=0 aid=2)
[ 32.769039] wlan0: associated
[ 32.769821] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 33.813867] padlock: VIA PadLock not detected.
[ 35.568648] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 43.736025] wlan0: no IPv6 routers present
[31370.316029] No probe response from AP 00:27:19:de:a8:2c after 500ms, disconnecting.
[31371.211016] wlan0: direct probe to AP 00:27:19:de:a8:2c (try 1)
[31371.213761] wlan0: direct probe responded
[31371.213769] wlan0: authenticate with AP 00:27:19:de:a8:2c (try 1)
[31371.215464] wlan0: authenticated
[31371.215492] wlan0: associate with AP 00:27:19:de:a8:2c (try 1)
[31371.217861] wlan0: RX AssocResp from 00:27:19:de:a8:2c (capab=0x431 status=0 aid=2)
[31371.217865] wlan0: associated
[54539.692525] wlan0: deauthenticating from 00:27:19:de:a8:2c by local choice (reason=3)
[54547.830122] wlan0: direct probe to AP 00:27:19:de:a8:2c (try 1)
[54547.832864] wlan0: direct probe responded
[54547.832875] wlan0: authenticate with AP 00:27:19:de:a8:2c (try 1)
[54547.834569] wlan0: authenticated
[54547.834666] wlan0: associate with AP 00:27:19:de:a8:2c (try 1)
[54547.836930] wlan0: RX AssocResp from 00:27:19:de:a8:2c (capab=0x431 status=0 aid=2)
[54547.836934] wlan0: associated
[56183.327527] rhythmbox: sending ioctl 2285 to a partition!
[67800.640028] hda-intel: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
