Log Xorg
X.Org X Server 1.7.7
Release Date: 2010-05-04
X Protocol Version 11, Revision 0 Build
Operating System: Linux 3.0.0-1-amd64 x86_64 Debian
Current
Operating System: Linux debian 3.2.0-0.bpo.4-amd64 #1 SMP Debian 3.2.35-2~bpo60+1 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-0.bpo.4-amd64 root=UUID=e20af14b-3e65-4992-a2ad-298addc1c351 ro quiet i8042.reset=1
Build Date: 29 October 2011 06:58:14PM
xorg-server 2:1.7.7-14 (Julien Cristau <jcristau@debian.org>)
Current version of pixman: 0.16.4
Before reporting problems, check [URL]http://wiki.x.org[/URL]
Markers: (--) probed,
(**) from config file,
(==) default setting,
(++) from command line,
(!!) notice, (II) informational,
(WW) warning, (EE) error,
(NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Mar 2 20:15:36 2013
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) ServerLayout "Layout0"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Device0"
(**) |-->Input Device "Keyboard0"
(**) |-->Input Device "Mouse0"
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,built-ins
(WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
(WW) Disabling Keyboard0
(WW) Disabling Mouse0
(II) Loader magic: 0x7c8a40
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(--) using VT number 7
(--) PCI:*(0:0:2:0) 8086:0166:17aa:3977 Intel Corporation rev 9, Mem @ 0xf3400000/4194304,
0xd0000000/268435456, I/O @ 0x00004000/64
(--) PCI: (0:1:0:0) 10de:0de9:17aa:3902 nVidia Corporation
rev 161, Mem @ 0xf2000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x00003000/128,
BIOS @ 0x????????/524288
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation" compiled for 1.7.7, module version = 1.0.0
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module 310.32 Mon Jan 14 15:02:04 PST 2013
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
(II) NVIDIA dlloader X Driver 310.32 Mon Jan 14 14:42:46 PST 2013
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 00@00:02:0
(EE) No devices detected.
Fatal server error: no screens found
Please consult the The X.Org Foundation support at [URL]http://wiki.x.org[/]URL] for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:
version 310.32 (buildmeister@swio-display-x86-rhel47-01) Mon Jan 14 15:51:51 PST 2013
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
