messege
Jan 1 00:00:24 raspberry-pi kernel: imklog 5.8.11, log source = /proc/kmsg started.Jan 1 00:00:24 raspberry-pi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="747" x-info="http://www.rsyslog.com"] start
Jan 1 00:00:24 raspberry-pi kernel: Initializing cgroup subsys cpu
Jan 1 00:00:24 raspberry-pi kernel: Linux version 3.1.9+ (root@laptop) (gcc version 4.6.3 (Gentoo 4.6.3 p1.3, pie-0.5.2) ) #1 PREEMPT Wed Jun 6 16:26:14 CEST 2012
Jan 1 00:00:24 raspberry-pi kernel: CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Jan 1 00:00:24 raspberry-pi kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jan 1 00:00:24 raspberry-pi kernel: Machine: BCM2708
Jan 1 00:00:24 raspberry-pi kernel: Memory policy: ECC disabled, Data cache writeback
Jan 1 00:00:24 raspberry-pi kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 56896
Jan 1 00:00:24 raspberry-pi kernel: Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x1000002 bcm2708.serial=0x9323ad1e smsc95xx.macaddr=B8:27:EB:23:AD:1E dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
Jan 1 00:00:24 raspberry-pi kernel: PID hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:24 raspberry-pi kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 1 00:00:24 raspberry-pi kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:24 raspberry-pi kernel: Memory: 224MB = 224MB total
Jan 1 00:00:24 raspberry-pi kernel: Memory: 222976k/222976k available, 6400k reserved, 0K highmem
Jan 1 00:00:24 raspberry-pi kernel: Virtual kernel memory layout:
Jan 1 00:00:24 raspberry-pi kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Jan 1 00:00:24 raspberry-pi kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Jan 1 00:00:24 raspberry-pi kernel: DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
Jan 1 00:00:24 raspberry-pi kernel: vmalloc : 0xce800000 - 0xd8000000 ( 152 MB)
Jan 1 00:00:24 raspberry-pi kernel: lowmem : 0xc0000000 - 0xce000000 ( 224 MB)
Jan 1 00:00:24 raspberry-pi kernel: modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Jan 1 00:00:24 raspberry-pi kernel: .text : 0xc0008000 - 0xc03b7000 (3772 kB)
Jan 1 00:00:24 raspberry-pi kernel: .init : 0xc03b7000 - 0xc03d5000 ( 120 kB)
Jan 1 00:00:24 raspberry-pi kernel: .data : 0xc03d6000 - 0xc03f45e0 ( 122 kB)
Jan 1 00:00:24 raspberry-pi kernel: .bss : 0xc03f4604 - 0xc0441138 ( 307 kB)
Jan 1 00:00:24 raspberry-pi kernel: NR_IRQS:85
Jan 1 00:00:24 raspberry-pi kernel: Console: colour dummy device 80x30
Jan 1 00:00:24 raspberry-pi kernel: console [tty1] enabled
Jan 1 00:00:24 raspberry-pi kernel: Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Jan 1 00:00:24 raspberry-pi kernel: pid_max: default: 32768 minimum: 301
Jan 1 00:00:24 raspberry-pi kernel: Mount-cache hash table entries: 512
Jan 1 00:00:24 raspberry-pi kernel: CPU: Testing write buffer coherency: ok
Jan 1 00:00:24 raspberry-pi kernel: devtmpfs: initialized
Jan 1 00:00:24 raspberry-pi kernel: NET: Registered protocol family 16
Jan 1 00:00:24 raspberry-pi kernel: vc-mem: mm_vc_mem_phys_addr = 0x00000000
Jan 1 00:00:24 raspberry-pi kernel: vc-mem: mm_vc_mem_size = 0x10000000 (256 MiB)
Jan 1 00:00:24 raspberry-pi kernel: mailbox: Broadcom VideoCore Mailbox driver
Jan 1 00:00:24 raspberry-pi kernel: bcm2708_vcio: mailbox at f200b880
Jan 1 00:00:24 raspberry-pi kernel: bcm_power: Broadcom power driver
Jan 1 00:00:24 raspberry-pi kernel: bcm_power_open() -> 0
Jan 1 00:00:24 raspberry-pi kernel: bcm_power_request(0, 8)
Jan 1 00:00:24 raspberry-pi kernel: bcm_mailbox_read -> 00000080, 0
Jan 1 00:00:24 raspberry-pi kernel: bcm_power_request -> 0
Jan 1 00:00:24 raspberry-pi kernel: Serial: AMBA PL011 UART driver
Jan 1 00:00:24 raspberry-pi kernel: dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
Jan 1 00:00:24 raspberry-pi kernel: console [ttyAMA0] enabled
Jan 1 00:00:24 raspberry-pi kernel: bio: create slab <bio-0> at 0
Jan 1 00:00:24 raspberry-pi kernel: SCSI subsystem initialized
Jan 1 00:00:24 raspberry-pi kernel: usbcore: registered new interface driver usbfs
Jan 1 00:00:24 raspberry-pi kernel: usbcore: registered new interface driver hub
Jan 1 00:00:24 raspberry-pi kernel: usbcore: registered new device driver usb
Jan 1 00:00:24 raspberry-pi kernel: Switching to clocksource stc
Jan 1 00:00:24 raspberry-pi kernel: FS-Cache: Loaded
Jan 1 00:00:24 raspberry-pi kernel: CacheFiles: Loaded
Jan 1 00:00:24 raspberry-pi kernel: Switched to NOHz mode on CPU #0
Jan 1 00:00:24 raspberry-pi kernel: NET: Registered protocol family 2
Jan 1 00:00:24 raspberry-pi kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 00:00:24 raspberry-pi kernel: TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Jan 1 00:00:24 raspberry-pi kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 00:00:24 raspberry-pi kernel: TCP: Hash tables configured (established 8192 bind 8192)
Jan 1 00:00:24 raspberry-pi kernel: TCP reno registered
Jan 1 00:00:24 raspberry-pi kernel: UDP hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 00:00:24 raspberry-pi kernel: UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 00:00:24 raspberry-pi kernel: RPC: Registered named UNIX socket transport module.
Jan 1 00:00:24 raspberry-pi kernel: RPC: Registered udp transport module.
Jan 1 00:00:24 raspberry-pi kernel: RPC: Registered tcp transport module.
Jan 1 00:00:24 raspberry-pi kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan 1 00:00:24 raspberry-pi kernel: bcm2708_dma: DMA manager at ce808000
Jan 1 00:00:24 raspberry-pi kernel: vc-mem: Videocore memory driver
Jan 1 00:00:24 raspberry-pi kernel: VFS: Disk quotas dquot_6.5.2
Jan 1 00:00:24 raspberry-pi kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jan 1 00:00:24 raspberry-pi kernel: FS-Cache: Netfs 'nfs' registered for caching
Jan 1 00:00:24 raspberry-pi kernel: msgmni has been set to 435
Jan 1 00:00:24 raspberry-pi kernel: io scheduler noop registered
Jan 1 00:00:24 raspberry-pi kernel: io scheduler deadline registered
Jan 1 00:00:24 raspberry-pi kernel: io scheduler cfq registered (default)
Jan 1 00:00:24 raspberry-pi kernel: BCM2708FB: registering framebuffer (656x416@16)
Jan 1 00:00:24 raspberry-pi kernel: bcm2708_fb_set_par info(cd88a000) 656x416 (656x416), 0, 16
Jan 1 00:00:24 raspberry-pi kernel: BCM2708FB: start = ce900000,4f387000 width=656, height=416, bpp=16, pitch=1312 size=548864 success=0
Jan 1 00:00:24 raspberry-pi kernel: Console: switching to colour frame buffer device 82x26
Jan 1 00:00:24 raspberry-pi kernel: BCM2708FB: register framebuffer (0)
Jan 1 00:00:24 raspberry-pi kernel: brd: module loaded
Jan 1 00:00:24 raspberry-pi kernel: loop: module loaded
Jan 1 00:00:24 raspberry-pi kernel: vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
Jan 1 00:00:24 raspberry-pi kernel: vcos: [1]: vchiq_init_state: called
Jan 1 00:00:24 raspberry-pi kernel: usbcore: registered new interface driver smsc95xx
Jan 1 00:00:24 raspberry-pi kernel: cdc_ncm: 04-Aug-2011
Jan 1 00:00:24 raspberry-pi kernel: usbcore: registered new interface driver cdc_ncm
Jan 1 00:00:24 raspberry-pi kernel: dwc_otg: version 2.90b 6-MAY-2010 (platform bus)
Jan 1 00:00:24 raspberry-pi kernel: Core Release: 2.80a
Jan 1 00:00:24 raspberry-pi kernel: Setting default values for core params
Jan 1 00:00:24 raspberry-pi kernel: Finished setting default values for core params
Jan 1 00:00:24 raspberry-pi kernel: ce840008 -> 1
Jan 1 00:00:24 raspberry-pi kernel: Using Buffer DMA mode
Jan 1 00:00:24 raspberry-pi kernel: Periodic Transfer Interrupt Enhancement - disabled
Jan 1 00:00:24 raspberry-pi kernel: Multiprocessor Interrupt Enhancement - disabled
Jan 1 00:00:24 raspberry-pi kernel: Dedicated Tx FIFOs mode
Jan 1 00:00:24 raspberry-pi kernel: dwc_otg bcm2708_usb: DWC OTG Controller
Jan 1 00:00:24 raspberry-pi kernel: dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
Jan 1 00:00:24 raspberry-pi kernel: dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
Jan 1 00:00:24 raspberry-pi kernel: Init: Port Power? op_state=1
Jan 1 00:00:24 raspberry-pi kernel: Init: Power Port (0)
Jan 1 00:00:24 raspberry-pi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jan 1 00:00:24 raspberry-pi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 1 00:00:24 raspberry-pi kernel: usb usb1: Product: DWC OTG Controller
Jan 1 00:00:24 raspberry-pi kernel: usb usb1: Manufacturer: Linux 3.1.9+ dwc_otg_hcd
Jan 1 00:00:24 raspberry-pi kernel: usb usb1: SerialNumber: bcm2708_usb
Jan 1 00:00:24 raspberry-pi kernel: hub 1-0:1.0: USB hub found
Jan 1 00:00:24 raspberry-pi kernel: hub 1-0:1.0: 1 port detected
Jan 1 00:00:24 raspberry-pi kernel: usbcore: registered new interface driver uas
Jan 1 00:00:24 raspberry-pi kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:24 raspberry-pi kernel: usbcore: registered new interface driver usb-storage
Jan 1 00:00:24 raspberry-pi kernel: USB Mass Storage support registered.
Jan 1 00:00:24 raspberry-pi kernel: usbcore: registered new interface driver libusual
Jan 1 00:00:24 raspberry-pi kernel: mousedev: PS/2 mouse device common for all mice
Jan 1 00:00:24 raspberry-pi kernel: cpuidle: using governor ladder
Jan 1 00:00:24 raspberry-pi kernel: cpuidle: using governor menu
Jan 1 00:00:24 raspberry-pi kernel: sdhci: Secure Digital Host Controller Interface driver
Jan 1 00:00:24 raspberry-pi kernel: sdhci: Copyright(c) Pierre Ossman
Jan 1 00:00:24 raspberry-pi kernel: bcm_power_open() -> 1
Jan 1 00:00:24 raspberry-pi kernel: mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
Jan 1 00:00:24 raspberry-pi kernel: mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
Jan 1 00:00:24 raspberry-pi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Jan 1 00:00:24 raspberry-pi kernel: usbcore: registered new interface driver usbhid
Jan 1 00:00:24 raspberry-pi kernel: usbhid: USB HID core driver
Jan 1 00:00:24 raspberry-pi kernel: TCP cubic registered
Jan 1 00:00:24 raspberry-pi kernel: Initializing XFRM netlink socket
Jan 1 00:00:24 raspberry-pi kernel: NET: Registered protocol family 17
Jan 1 00:00:24 raspberry-pi kernel: Registering the dns_resolver key type
Jan 1 00:00:24 raspberry-pi kernel: VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Jan 1 00:00:24 raspberry-pi kernel: Waiting for root device /dev/mmcblk0p2...
Jan 1 00:00:24 raspberry-pi kernel: mmc0: new SDHC card at address aaaa
Jan 1 00:00:24 raspberry-pi kernel: mmcblk0: mmc0:aaaa SU08G 7.40 GiB
Jan 1 00:00:24 raspberry-pi kernel: mmcblk0: p1 p2 p3 p4 < p5 >
Jan 1 00:00:24 raspberry-pi kernel: usb 1-1: new high speed USB device number 2 using dwc_otg
Jan 1 00:00:24 raspberry-pi kernel: usb 1-1: New USB device found, idVendor=0424, idProduct=9512
Jan 1 00:00:24 raspberry-pi kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jan 1 00:00:24 raspberry-pi kernel: hub 1-1:1.0: USB hub found
Jan 1 00:00:24 raspberry-pi kernel: hub 1-1:1.0: 3 ports detected
Jan 1 00:00:24 raspberry-pi kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 1 00:00:24 raspberry-pi kernel: VFS: Mounted root (ext4 filesystem) on device 179:2.
Jan 1 00:00:24 raspberry-pi kernel: Freeing init memory: 120K
Jan 1 00:00:24 raspberry-pi kernel: usb 1-1.1: new high speed USB device number 3 using dwc_otg
Jan 1 00:00:24 raspberry-pi kernel: usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Jan 1 00:00:24 raspberry-pi kernel: usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jan 1 00:00:24 raspberry-pi kernel: smsc95xx v1.0.4
Jan 1 00:00:24 raspberry-pi kernel: smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:23:ad:1e
Jan 1 00:00:24 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 4 using dwc_otg
Jan 1 00:00:24 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Jan 1 00:00:24 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Jan 1 00:00:24 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Jan 1 00:00:24 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Jan 1 00:00:24 raspberry-pi kernel: scsi0 : usb-storage 1-1.2:1.0
Jan 1 00:00:24 raspberry-pi kernel: scsi1 : usb-storage 1-1.2:1.1
Jan 1 00:00:24 raspberry-pi kernel: scsi 0:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:24 raspberry-pi kernel: scsi 1:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:24 raspberry-pi kernel: sd 1:0:0:0: [sda] Attached SCSI removable disk
Jan 1 00:00:24 raspberry-pi kernel: sr0: scsi-1 drive
Jan 1 00:00:24 raspberry-pi kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
Jan 1 00:00:24 raspberry-pi kernel: sd 1:0:0:0: [sda] 7744512 512-byte logical blocks: (3.96 GB/3.69 GiB)
Jan 1 00:00:24 raspberry-pi kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jan 1 00:00:24 raspberry-pi kernel: sda: sda1
Jan 1 00:00:24 raspberry-pi kernel: Adding 195580k swap on /dev/mmcblk0p3. Priority:-1 extents:1 across:195580k SS
Jan 1 00:00:24 raspberry-pi kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Jan 1 00:00:24 raspberry-pi kernel: NET: Registered protocol family 10
Jan 1 00:00:24 raspberry-pi kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jan 1 00:00:24 raspberry-pi kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jan 1 00:00:24 raspberry-pi kernel: smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Feb 2 12:43:18 raspberry-pi kernel: imklog 5.8.11, log source = /proc/kmsg started.
Feb 2 12:43:18 raspberry-pi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="4416" x-info="http://www.rsyslog.com"] start
Feb 2 12:43:31 raspberry-pi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="4416" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Feb 2 12:43:50 raspberry-pi shutdown[5197]: shutting down for system reboot
Jan 1 00:00:18 raspberry-pi kernel: imklog 5.8.11, log source = /proc/kmsg started.
Jan 1 00:00:18 raspberry-pi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="1125" x-info="http://www.rsyslog.com"] start
Jan 1 00:00:18 raspberry-pi kernel: Initializing cgroup subsys cpu
Jan 1 00:00:18 raspberry-pi kernel: Linux version 3.1.9+ (root@laptop) (gcc version 4.6.3 (Gentoo 4.6.3 p1.3, pie-0.5.2) ) #1 PREEMPT Wed Jun 6 16:26:14 CEST 2012
Jan 1 00:00:18 raspberry-pi kernel: CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Jan 1 00:00:18 raspberry-pi kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jan 1 00:00:18 raspberry-pi kernel: Machine: BCM2708
Jan 1 00:00:18 raspberry-pi kernel: Memory policy: ECC disabled, Data cache writeback
Jan 1 00:00:18 raspberry-pi kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 56896
Jan 1 00:00:18 raspberry-pi kernel: Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x1000002 bcm2708.serial=0x9323ad1e smsc95xx.macaddr=B8:27:EB:23:AD:1E dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
Jan 1 00:00:18 raspberry-pi kernel: PID hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:18 raspberry-pi kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 1 00:00:18 raspberry-pi kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:18 raspberry-pi kernel: Memory: 224MB = 224MB total
Jan 1 00:00:18 raspberry-pi kernel: Memory: 222976k/222976k available, 6400k reserved, 0K highmem
Jan 1 00:00:18 raspberry-pi kernel: Virtual kernel memory layout:
Jan 1 00:00:18 raspberry-pi kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Jan 1 00:00:18 raspberry-pi kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Jan 1 00:00:18 raspberry-pi kernel: DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
Jan 1 00:00:18 raspberry-pi kernel: vmalloc : 0xce800000 - 0xd8000000 ( 152 MB)
Jan 1 00:00:18 raspberry-pi kernel: lowmem : 0xc0000000 - 0xce000000 ( 224 MB)
Jan 1 00:00:18 raspberry-pi kernel: modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Jan 1 00:00:18 raspberry-pi kernel: .text : 0xc0008000 - 0xc03b7000 (3772 kB)
Jan 1 00:00:18 raspberry-pi kernel: .init : 0xc03b7000 - 0xc03d5000 ( 120 kB)
Jan 1 00:00:18 raspberry-pi kernel: .data : 0xc03d6000 - 0xc03f45e0 ( 122 kB)
Jan 1 00:00:18 raspberry-pi kernel: .bss : 0xc03f4604 - 0xc0441138 ( 307 kB)
Jan 1 00:00:18 raspberry-pi kernel: NR_IRQS:85
Jan 1 00:00:18 raspberry-pi kernel: Console: colour dummy device 80x30
Jan 1 00:00:18 raspberry-pi kernel: console [tty1] enabled
Jan 1 00:00:18 raspberry-pi kernel: Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Jan 1 00:00:18 raspberry-pi kernel: pid_max: default: 32768 minimum: 301
Jan 1 00:00:18 raspberry-pi kernel: Mount-cache hash table entries: 512
Jan 1 00:00:18 raspberry-pi kernel: CPU: Testing write buffer coherency: ok
Jan 1 00:00:18 raspberry-pi kernel: devtmpfs: initialized
Jan 1 00:00:18 raspberry-pi kernel: NET: Registered protocol family 16
Jan 1 00:00:18 raspberry-pi kernel: vc-mem: mm_vc_mem_phys_addr = 0x00000000
Jan 1 00:00:18 raspberry-pi kernel: vc-mem: mm_vc_mem_size = 0x10000000 (256 MiB)
Jan 1 00:00:18 raspberry-pi kernel: mailbox: Broadcom VideoCore Mailbox driver
Jan 1 00:00:18 raspberry-pi kernel: bcm2708_vcio: mailbox at f200b880
Jan 1 00:00:18 raspberry-pi kernel: bcm_power: Broadcom power driver
Jan 1 00:00:18 raspberry-pi kernel: bcm_power_open() -> 0
Jan 1 00:00:18 raspberry-pi kernel: bcm_power_request(0, 8)
Jan 1 00:00:18 raspberry-pi kernel: bcm_mailbox_read -> 00000080, 0
Jan 1 00:00:18 raspberry-pi kernel: bcm_power_request -> 0
Jan 1 00:00:18 raspberry-pi kernel: Serial: AMBA PL011 UART driver
Jan 1 00:00:18 raspberry-pi kernel: dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
Jan 1 00:00:18 raspberry-pi kernel: console [ttyAMA0] enabled
Jan 1 00:00:18 raspberry-pi kernel: bio: create slab <bio-0> at 0
Jan 1 00:00:18 raspberry-pi kernel: SCSI subsystem initialized
Jan 1 00:00:18 raspberry-pi kernel: usbcore: registered new interface driver usbfs
Jan 1 00:00:18 raspberry-pi kernel: usbcore: registered new interface driver hub
Jan 1 00:00:18 raspberry-pi kernel: usbcore: registered new device driver usb
Jan 1 00:00:18 raspberry-pi kernel: Switching to clocksource stc
Jan 1 00:00:18 raspberry-pi kernel: FS-Cache: Loaded
Jan 1 00:00:18 raspberry-pi kernel: CacheFiles: Loaded
Jan 1 00:00:18 raspberry-pi kernel: Switched to NOHz mode on CPU #0
Jan 1 00:00:18 raspberry-pi kernel: NET: Registered protocol family 2
Jan 1 00:00:18 raspberry-pi kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 00:00:18 raspberry-pi kernel: TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Jan 1 00:00:18 raspberry-pi kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 00:00:18 raspberry-pi kernel: TCP: Hash tables configured (established 8192 bind 8192)
Jan 1 00:00:18 raspberry-pi kernel: TCP reno registered
Jan 1 00:00:18 raspberry-pi kernel: UDP hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 00:00:18 raspberry-pi kernel: UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 00:00:18 raspberry-pi kernel: RPC: Registered named UNIX socket transport module.
Jan 1 00:00:18 raspberry-pi kernel: RPC: Registered udp transport module.
Jan 1 00:00:18 raspberry-pi kernel: RPC: Registered tcp transport module.
Jan 1 00:00:18 raspberry-pi kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan 1 00:00:18 raspberry-pi kernel: bcm2708_dma: DMA manager at ce808000
Jan 1 00:00:18 raspberry-pi kernel: vc-mem: Videocore memory driver
Jan 1 00:00:18 raspberry-pi kernel: VFS: Disk quotas dquot_6.5.2
Jan 1 00:00:18 raspberry-pi kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jan 1 00:00:18 raspberry-pi kernel: FS-Cache: Netfs 'nfs' registered for caching
Jan 1 00:00:18 raspberry-pi kernel: msgmni has been set to 435
Jan 1 00:00:18 raspberry-pi kernel: io scheduler noop registered
Jan 1 00:00:18 raspberry-pi kernel: io scheduler deadline registered
Jan 1 00:00:18 raspberry-pi kernel: io scheduler cfq registered (default)
Jan 1 00:00:18 raspberry-pi kernel: BCM2708FB: registering framebuffer (656x416@16)
Jan 1 00:00:18 raspberry-pi kernel: bcm2708_fb_set_par info(cd88a000) 656x416 (656x416), 0, 16
Jan 1 00:00:18 raspberry-pi kernel: BCM2708FB: start = ce900000,4f387000 width=656, height=416, bpp=16, pitch=1312 size=548864 success=0
Jan 1 00:00:18 raspberry-pi kernel: Console: switching to colour frame buffer device 82x26
Jan 1 00:00:18 raspberry-pi kernel: BCM2708FB: register framebuffer (0)
Jan 1 00:00:18 raspberry-pi kernel: brd: module loaded
Jan 1 00:00:18 raspberry-pi kernel: loop: module loaded
Jan 1 00:00:18 raspberry-pi kernel: vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
Jan 1 00:00:18 raspberry-pi kernel: vcos: [1]: vchiq_init_state: called
Jan 1 00:00:18 raspberry-pi kernel: usbcore: registered new interface driver smsc95xx
Jan 1 00:00:18 raspberry-pi kernel: cdc_ncm: 04-Aug-2011
Jan 1 00:00:18 raspberry-pi kernel: usbcore: registered new interface driver cdc_ncm
Jan 1 00:00:18 raspberry-pi kernel: dwc_otg: version 2.90b 6-MAY-2010 (platform bus)
Jan 1 00:00:18 raspberry-pi kernel: Core Release: 2.80a
Jan 1 00:00:18 raspberry-pi kernel: Setting default values for core params
Jan 1 00:00:18 raspberry-pi kernel: Finished setting default values for core params
Jan 1 00:00:18 raspberry-pi kernel: ce840008 -> 1
Jan 1 00:00:18 raspberry-pi kernel: Using Buffer DMA mode
Jan 1 00:00:18 raspberry-pi kernel: Periodic Transfer Interrupt Enhancement - disabled
Jan 1 00:00:18 raspberry-pi kernel: Multiprocessor Interrupt Enhancement - disabled
Jan 1 00:00:18 raspberry-pi kernel: Dedicated Tx FIFOs mode
Jan 1 00:00:18 raspberry-pi kernel: dwc_otg bcm2708_usb: DWC OTG Controller
Jan 1 00:00:18 raspberry-pi kernel: dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
Jan 1 00:00:18 raspberry-pi kernel: dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
Jan 1 00:00:18 raspberry-pi kernel: Init: Port Power? op_state=1
Jan 1 00:00:18 raspberry-pi kernel: Init: Power Port (0)
Jan 1 00:00:18 raspberry-pi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jan 1 00:00:18 raspberry-pi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 1 00:00:18 raspberry-pi kernel: usb usb1: Product: DWC OTG Controller
Jan 1 00:00:18 raspberry-pi kernel: usb usb1: Manufacturer: Linux 3.1.9+ dwc_otg_hcd
Jan 1 00:00:18 raspberry-pi kernel: usb usb1: SerialNumber: bcm2708_usb
Jan 1 00:00:18 raspberry-pi kernel: hub 1-0:1.0: USB hub found
Jan 1 00:00:18 raspberry-pi kernel: hub 1-0:1.0: 1 port detected
Jan 1 00:00:18 raspberry-pi kernel: usbcore: registered new interface driver uas
Jan 1 00:00:18 raspberry-pi kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:18 raspberry-pi kernel: usbcore: registered new interface driver usb-storage
Jan 1 00:00:18 raspberry-pi kernel: USB Mass Storage support registered.
Jan 1 00:00:18 raspberry-pi kernel: usbcore: registered new interface driver libusual
Jan 1 00:00:18 raspberry-pi kernel: mousedev: PS/2 mouse device common for all mice
Jan 1 00:00:18 raspberry-pi kernel: cpuidle: using governor ladder
Jan 1 00:00:18 raspberry-pi kernel: cpuidle: using governor menu
Jan 1 00:00:18 raspberry-pi kernel: sdhci: Secure Digital Host Controller Interface driver
Jan 1 00:00:18 raspberry-pi kernel: sdhci: Copyright(c) Pierre Ossman
Jan 1 00:00:18 raspberry-pi kernel: bcm_power_open() -> 1
Jan 1 00:00:18 raspberry-pi kernel: mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
Jan 1 00:00:18 raspberry-pi kernel: mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
Jan 1 00:00:18 raspberry-pi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Jan 1 00:00:18 raspberry-pi kernel: usbcore: registered new interface driver usbhid
Jan 1 00:00:18 raspberry-pi kernel: usbhid: USB HID core driver
Jan 1 00:00:18 raspberry-pi kernel: TCP cubic registered
Jan 1 00:00:18 raspberry-pi kernel: Initializing XFRM netlink socket
Jan 1 00:00:18 raspberry-pi kernel: NET: Registered protocol family 17
Jan 1 00:00:18 raspberry-pi kernel: Registering the dns_resolver key type
Jan 1 00:00:18 raspberry-pi kernel: VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Jan 1 00:00:18 raspberry-pi kernel: Waiting for root device /dev/mmcblk0p2...
Jan 1 00:00:18 raspberry-pi kernel: mmc0: new SDHC card at address aaaa
Jan 1 00:00:18 raspberry-pi kernel: mmcblk0: mmc0:aaaa SU08G 7.40 GiB
Jan 1 00:00:18 raspberry-pi kernel: mmcblk0: p1 p2 p3 p4 < p5 >
Jan 1 00:00:18 raspberry-pi kernel: EXT4-fs (mmcblk0p2): recovery complete
Jan 1 00:00:18 raspberry-pi kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 1 00:00:18 raspberry-pi kernel: VFS: Mounted root (ext4 filesystem) on device 179:2.
Jan 1 00:00:18 raspberry-pi kernel: Freeing init memory: 120K
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1: new high speed USB device number 2 using dwc_otg
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1: New USB device found, idVendor=0424, idProduct=9512
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jan 1 00:00:18 raspberry-pi kernel: hub 1-1:1.0: USB hub found
Jan 1 00:00:18 raspberry-pi kernel: hub 1-1:1.0: 3 ports detected
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1.1: new high speed USB device number 3 using dwc_otg
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jan 1 00:00:18 raspberry-pi kernel: smsc95xx v1.0.4
Jan 1 00:00:18 raspberry-pi kernel: smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:23:ad:1e
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 4 using dwc_otg
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Jan 1 00:00:18 raspberry-pi kernel: scsi0 : usb-storage 1-1.2:1.0
Jan 1 00:00:18 raspberry-pi kernel: scsi1 : usb-storage 1-1.2:1.1
Jan 1 00:00:18 raspberry-pi kernel: scsi 0:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:18 raspberry-pi kernel: scsi 1:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:18 raspberry-pi kernel: sd 1:0:0:0: [sda] Attached SCSI removable disk
Jan 1 00:00:18 raspberry-pi kernel: sr0: scsi-1 drive
Jan 1 00:00:18 raspberry-pi kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
Jan 1 00:00:18 raspberry-pi kernel: sd 1:0:0:0: [sda] 7744512 512-byte logical blocks: (3.96 GB/3.69 GiB)
Jan 1 00:00:18 raspberry-pi kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jan 1 00:00:18 raspberry-pi kernel: sda: sda1
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 4
Jan 1 00:00:18 raspberry-pi kernel: sd 1:0:0:0: [sda] Synchronizing SCSI cache
Jan 1 00:00:18 raspberry-pi kernel: sd 1:0:0:0: [sda] Unhandled error code
Jan 1 00:00:18 raspberry-pi kernel: sd 1:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00
Jan 1 00:00:18 raspberry-pi kernel: sd 1:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 01 10 00 00 08 00
Jan 1 00:00:18 raspberry-pi kernel: Adding 195580k swap on /dev/mmcblk0p3. Priority:-1 extents:1 across:195580k SS
Jan 1 00:00:18 raspberry-pi kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 5 using dwc_otg
Jan 1 00:00:18 raspberry-pi kernel: scsi2 : usb-storage 1-1.2:1.0
Jan 1 00:00:18 raspberry-pi kernel: scsi3 : usb-storage 1-1.2:1.1
Jan 1 00:00:18 raspberry-pi kernel: scsi 2:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:18 raspberry-pi kernel: scsi 3:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:18 raspberry-pi kernel: sd 3:0:0:0: [sda] Attached SCSI removable disk
Jan 1 00:00:18 raspberry-pi kernel: sda: detected capacity change from 3965190144 to 0
Jan 1 00:00:18 raspberry-pi kernel: NET: Registered protocol family 10
Jan 1 00:00:18 raspberry-pi kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jan 1 00:00:18 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 5
Jan 1 00:00:18 raspberry-pi kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jan 1 00:00:18 raspberry-pi kernel: smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Jan 1 00:00:21 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 6 using dwc_otg
Jan 1 00:00:21 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Jan 1 00:00:21 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Jan 1 00:00:21 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Jan 1 00:00:21 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Jan 1 00:00:21 raspberry-pi kernel: scsi4 : usb-storage 1-1.2:1.0
Jan 1 00:00:21 raspberry-pi kernel: scsi5 : usb-storage 1-1.2:1.1
Jan 1 00:00:22 raspberry-pi kernel: scsi 4:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:22 raspberry-pi kernel: scsi 5:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:22 raspberry-pi kernel: sr0: scsi-1 drive
Jan 1 00:00:22 raspberry-pi kernel: sd 5:0:0:0: [sda] Attached SCSI removable disk
Jan 1 00:00:25 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 6
Feb 2 12:49:35 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 7 using dwc_otg
Feb 2 12:49:35 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Feb 2 12:49:35 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Feb 2 12:49:35 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 12:49:35 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 12:49:35 raspberry-pi kernel: scsi6 : usb-storage 1-1.2:1.0
Feb 2 12:49:35 raspberry-pi kernel: scsi7 : usb-storage 1-1.2:1.1
Feb 2 12:49:36 raspberry-pi kernel: scsi 6:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Feb 2 12:49:36 raspberry-pi kernel: scsi 7:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Feb 2 12:49:36 raspberry-pi kernel: sr0: scsi-1 drive
Feb 2 12:49:36 raspberry-pi kernel: sd 7:0:0:0: [sda] Attached SCSI removable disk
Feb 2 12:56:41 raspberry-pi shutdown[2714]: shutting down for system reboot
Jan 1 00:00:19 raspberry-pi kernel: imklog 5.8.11, log source = /proc/kmsg started.
Jan 1 00:00:19 raspberry-pi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="1162" x-info="http://www.rsyslog.com"] start
Jan 1 00:00:19 raspberry-pi kernel: Initializing cgroup subsys cpu
Jan 1 00:00:19 raspberry-pi kernel: Linux version 3.1.9+ (root@laptop) (gcc version 4.6.3 (Gentoo 4.6.3 p1.3, pie-0.5.2) ) #1 PREEMPT Wed Jun 6 16:26:14 CEST 2012
Jan 1 00:00:19 raspberry-pi kernel: CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Jan 1 00:00:19 raspberry-pi kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jan 1 00:00:19 raspberry-pi kernel: Machine: BCM2708
Jan 1 00:00:19 raspberry-pi kernel: Memory policy: ECC disabled, Data cache writeback
Jan 1 00:00:19 raspberry-pi kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 56896
Jan 1 00:00:19 raspberry-pi kernel: Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x1000002 bcm2708.serial=0x9323ad1e smsc95xx.macaddr=B8:27:EB:23:AD:1E dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
Jan 1 00:00:19 raspberry-pi kernel: PID hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:19 raspberry-pi kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 1 00:00:19 raspberry-pi kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:19 raspberry-pi kernel: Memory: 224MB = 224MB total
Jan 1 00:00:19 raspberry-pi kernel: Memory: 222976k/222976k available, 6400k reserved, 0K highmem
Jan 1 00:00:19 raspberry-pi kernel: Virtual kernel memory layout:
Jan 1 00:00:19 raspberry-pi kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Jan 1 00:00:19 raspberry-pi kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Jan 1 00:00:19 raspberry-pi kernel: DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
Jan 1 00:00:19 raspberry-pi kernel: vmalloc : 0xce800000 - 0xd8000000 ( 152 MB)
Jan 1 00:00:19 raspberry-pi kernel: lowmem : 0xc0000000 - 0xce000000 ( 224 MB)
Jan 1 00:00:19 raspberry-pi kernel: modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Jan 1 00:00:19 raspberry-pi kernel: .text : 0xc0008000 - 0xc03b7000 (3772 kB)
Jan 1 00:00:19 raspberry-pi kernel: .init : 0xc03b7000 - 0xc03d5000 ( 120 kB)
Jan 1 00:00:19 raspberry-pi kernel: .data : 0xc03d6000 - 0xc03f45e0 ( 122 kB)
Jan 1 00:00:19 raspberry-pi kernel: .bss : 0xc03f4604 - 0xc0441138 ( 307 kB)
Jan 1 00:00:19 raspberry-pi kernel: NR_IRQS:85
Jan 1 00:00:19 raspberry-pi kernel: Console: colour dummy device 80x30
Jan 1 00:00:19 raspberry-pi kernel: console [tty1] enabled
Jan 1 00:00:19 raspberry-pi kernel: Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Jan 1 00:00:19 raspberry-pi kernel: pid_max: default: 32768 minimum: 301
Jan 1 00:00:19 raspberry-pi kernel: Mount-cache hash table entries: 512
Jan 1 00:00:19 raspberry-pi kernel: CPU: Testing write buffer coherency: ok
Jan 1 00:00:19 raspberry-pi kernel: devtmpfs: initialized
Jan 1 00:00:19 raspberry-pi kernel: NET: Registered protocol family 16
Jan 1 00:00:19 raspberry-pi kernel: vc-mem: mm_vc_mem_phys_addr = 0x00000000
Jan 1 00:00:19 raspberry-pi kernel: vc-mem: mm_vc_mem_size = 0x10000000 (256 MiB)
Jan 1 00:00:19 raspberry-pi kernel: mailbox: Broadcom VideoCore Mailbox driver
Jan 1 00:00:19 raspberry-pi kernel: bcm2708_vcio: mailbox at f200b880
Jan 1 00:00:19 raspberry-pi kernel: bcm_power: Broadcom power driver
Jan 1 00:00:19 raspberry-pi kernel: bcm_power_open() -> 0
Jan 1 00:00:19 raspberry-pi kernel: bcm_power_request(0, 8)
Jan 1 00:00:19 raspberry-pi kernel: bcm_mailbox_read -> 00000080, 0
Jan 1 00:00:19 raspberry-pi kernel: bcm_power_request -> 0
Jan 1 00:00:19 raspberry-pi kernel: Serial: AMBA PL011 UART driver
Jan 1 00:00:19 raspberry-pi kernel: dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
Jan 1 00:00:19 raspberry-pi kernel: console [ttyAMA0] enabled
Jan 1 00:00:19 raspberry-pi kernel: bio: create slab <bio-0> at 0
Jan 1 00:00:19 raspberry-pi kernel: SCSI subsystem initialized
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new interface driver usbfs
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new interface driver hub
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new device driver usb
Jan 1 00:00:19 raspberry-pi kernel: Switching to clocksource stc
Jan 1 00:00:19 raspberry-pi kernel: FS-Cache: Loaded
Jan 1 00:00:19 raspberry-pi kernel: CacheFiles: Loaded
Jan 1 00:00:19 raspberry-pi kernel: Switched to NOHz mode on CPU #0
Jan 1 00:00:19 raspberry-pi kernel: NET: Registered protocol family 2
Jan 1 00:00:19 raspberry-pi kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 00:00:19 raspberry-pi kernel: TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Jan 1 00:00:19 raspberry-pi kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 00:00:19 raspberry-pi kernel: TCP: Hash tables configured (established 8192 bind 8192)
Jan 1 00:00:19 raspberry-pi kernel: TCP reno registered
Jan 1 00:00:19 raspberry-pi kernel: UDP hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 00:00:19 raspberry-pi kernel: UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 00:00:19 raspberry-pi kernel: RPC: Registered named UNIX socket transport module.
Jan 1 00:00:19 raspberry-pi kernel: RPC: Registered udp transport module.
Jan 1 00:00:19 raspberry-pi kernel: RPC: Registered tcp transport module.
Jan 1 00:00:19 raspberry-pi kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan 1 00:00:19 raspberry-pi kernel: bcm2708_dma: DMA manager at ce808000
Jan 1 00:00:19 raspberry-pi kernel: vc-mem: Videocore memory driver
Jan 1 00:00:19 raspberry-pi kernel: VFS: Disk quotas dquot_6.5.2
Jan 1 00:00:19 raspberry-pi kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jan 1 00:00:19 raspberry-pi kernel: FS-Cache: Netfs 'nfs' registered for caching
Jan 1 00:00:19 raspberry-pi kernel: msgmni has been set to 435
Jan 1 00:00:19 raspberry-pi kernel: io scheduler noop registered
Jan 1 00:00:19 raspberry-pi kernel: io scheduler deadline registered
Jan 1 00:00:19 raspberry-pi kernel: io scheduler cfq registered (default)
Jan 1 00:00:19 raspberry-pi kernel: BCM2708FB: registering framebuffer (656x416@16)
Jan 1 00:00:19 raspberry-pi kernel: bcm2708_fb_set_par info(cd88a000) 656x416 (656x416), 0, 16
Jan 1 00:00:19 raspberry-pi kernel: BCM2708FB: start = ce900000,4f387000 width=656, height=416, bpp=16, pitch=1312 size=548864 success=0
Jan 1 00:00:19 raspberry-pi kernel: Console: switching to colour frame buffer device 82x26
Jan 1 00:00:19 raspberry-pi kernel: BCM2708FB: register framebuffer (0)
Jan 1 00:00:19 raspberry-pi kernel: brd: module loaded
Jan 1 00:00:19 raspberry-pi kernel: loop: module loaded
Jan 1 00:00:19 raspberry-pi kernel: vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
Jan 1 00:00:19 raspberry-pi kernel: vcos: [1]: vchiq_init_state: called
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new interface driver smsc95xx
Jan 1 00:00:19 raspberry-pi kernel: cdc_ncm: 04-Aug-2011
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new interface driver cdc_ncm
Jan 1 00:00:19 raspberry-pi kernel: dwc_otg: version 2.90b 6-MAY-2010 (platform bus)
Jan 1 00:00:19 raspberry-pi kernel: Core Release: 2.80a
Jan 1 00:00:19 raspberry-pi kernel: Setting default values for core params
Jan 1 00:00:19 raspberry-pi kernel: Finished setting default values for core params
Jan 1 00:00:19 raspberry-pi kernel: ce840008 -> 1
Jan 1 00:00:19 raspberry-pi kernel: Using Buffer DMA mode
Jan 1 00:00:19 raspberry-pi kernel: Periodic Transfer Interrupt Enhancement - disabled
Jan 1 00:00:19 raspberry-pi kernel: Multiprocessor Interrupt Enhancement - disabled
Jan 1 00:00:19 raspberry-pi kernel: Dedicated Tx FIFOs mode
Jan 1 00:00:19 raspberry-pi kernel: dwc_otg bcm2708_usb: DWC OTG Controller
Jan 1 00:00:19 raspberry-pi kernel: dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
Jan 1 00:00:19 raspberry-pi kernel: dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
Jan 1 00:00:19 raspberry-pi kernel: Init: Port Power? op_state=1
Jan 1 00:00:19 raspberry-pi kernel: Init: Power Port (0)
Jan 1 00:00:19 raspberry-pi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jan 1 00:00:19 raspberry-pi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 1 00:00:19 raspberry-pi kernel: usb usb1: Product: DWC OTG Controller
Jan 1 00:00:19 raspberry-pi kernel: usb usb1: Manufacturer: Linux 3.1.9+ dwc_otg_hcd
Jan 1 00:00:19 raspberry-pi kernel: usb usb1: SerialNumber: bcm2708_usb
Jan 1 00:00:19 raspberry-pi kernel: hub 1-0:1.0: USB hub found
Jan 1 00:00:19 raspberry-pi kernel: hub 1-0:1.0: 1 port detected
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new interface driver uas
Jan 1 00:00:19 raspberry-pi kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new interface driver usb-storage
Jan 1 00:00:19 raspberry-pi kernel: USB Mass Storage support registered.
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new interface driver libusual
Jan 1 00:00:19 raspberry-pi kernel: mousedev: PS/2 mouse device common for all mice
Jan 1 00:00:19 raspberry-pi kernel: cpuidle: using governor ladder
Jan 1 00:00:19 raspberry-pi kernel: cpuidle: using governor menu
Jan 1 00:00:19 raspberry-pi kernel: sdhci: Secure Digital Host Controller Interface driver
Jan 1 00:00:19 raspberry-pi kernel: sdhci: Copyright(c) Pierre Ossman
Jan 1 00:00:19 raspberry-pi kernel: bcm_power_open() -> 1
Jan 1 00:00:19 raspberry-pi kernel: mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
Jan 1 00:00:19 raspberry-pi kernel: mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
Jan 1 00:00:19 raspberry-pi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new interface driver usbhid
Jan 1 00:00:19 raspberry-pi kernel: usbhid: USB HID core driver
Jan 1 00:00:19 raspberry-pi kernel: TCP cubic registered
Jan 1 00:00:19 raspberry-pi kernel: Initializing XFRM netlink socket
Jan 1 00:00:19 raspberry-pi kernel: NET: Registered protocol family 17
Jan 1 00:00:19 raspberry-pi kernel: Registering the dns_resolver key type
Jan 1 00:00:19 raspberry-pi kernel: VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Jan 1 00:00:19 raspberry-pi kernel: Waiting for root device /dev/mmcblk0p2...
Jan 1 00:00:19 raspberry-pi kernel: mmc0: problem reading SD Status register.
Jan 1 00:00:19 raspberry-pi kernel: mmc0: new SDHC card at address aaaa
Jan 1 00:00:19 raspberry-pi kernel: mmcblk0: mmc0:aaaa SU08G 7.40 GiB
Jan 1 00:00:19 raspberry-pi kernel: mmcblk0: p1 p2 p3 p4 < p5 >
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1: new high speed USB device number 2 using dwc_otg
Jan 1 00:00:19 raspberry-pi kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 1 00:00:19 raspberry-pi kernel: VFS: Mounted root (ext4 filesystem) on device 179:2.
Jan 1 00:00:19 raspberry-pi kernel: Freeing init memory: 120K
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1: New USB device found, idVendor=0424, idProduct=9512
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jan 1 00:00:19 raspberry-pi kernel: hub 1-1:1.0: USB hub found
Jan 1 00:00:19 raspberry-pi kernel: hub 1-1:1.0: 3 ports detected
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.1: new high speed USB device number 3 using dwc_otg
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jan 1 00:00:19 raspberry-pi kernel: smsc95xx v1.0.4
Jan 1 00:00:19 raspberry-pi kernel: smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:23:ad:1e
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 4 using dwc_otg
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Jan 1 00:00:19 raspberry-pi kernel: scsi0 : usb-storage 1-1.2:1.0
Jan 1 00:00:19 raspberry-pi kernel: scsi1 : usb-storage 1-1.2:1.1
Jan 1 00:00:19 raspberry-pi kernel: scsi 0:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:19 raspberry-pi kernel: scsi 1:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:19 raspberry-pi kernel: sd 1:0:0:0: [sda] Attached SCSI removable disk
Jan 1 00:00:19 raspberry-pi kernel: sr0: scsi-1 drive
Jan 1 00:00:19 raspberry-pi kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
Jan 1 00:00:19 raspberry-pi kernel: sd 1:0:0:0: [sda] 7744512 512-byte logical blocks: (3.96 GB/3.69 GiB)
Jan 1 00:00:19 raspberry-pi kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jan 1 00:00:19 raspberry-pi kernel: sda: sda1
Jan 1 00:00:19 raspberry-pi kernel: DEBUG:handle_hc_chhltd_intr_dma:: XactErr without NYET/NAK/ACK
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 4
Jan 1 00:00:19 raspberry-pi kernel: sd 1:0:0:0: [sda] Synchronizing SCSI cache
Jan 1 00:00:19 raspberry-pi kernel: sd 1:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00
Jan 1 00:00:19 raspberry-pi kernel: Adding 195580k swap on /dev/mmcblk0p3. Priority:-1 extents:1 across:195580k SS
Jan 1 00:00:19 raspberry-pi kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 5 using dwc_otg
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=1506
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Jan 1 00:00:19 raspberry-pi kernel: scsi2 : usb-storage 1-1.2:1.4
Jan 1 00:00:19 raspberry-pi kernel: scsi3 : usb-storage 1-1.2:1.5
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new interface driver usbserial
Jan 1 00:00:19 raspberry-pi kernel: USB Serial support registered for generic
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new interface driver usbserial_generic
Jan 1 00:00:19 raspberry-pi kernel: usbserial: USB Serial Driver core
Jan 1 00:00:19 raspberry-pi kernel: USB Serial support registered for GSM modem (1-port)
Jan 1 00:00:19 raspberry-pi kernel: option 1-1.2:1.0: GSM modem (1-port) converter detected
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Jan 1 00:00:19 raspberry-pi kernel: option 1-1.2:1.2: GSM modem (1-port) converter detected
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Jan 1 00:00:19 raspberry-pi kernel: option 1-1.2:1.3: GSM modem (1-port) converter detected
Jan 1 00:00:19 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Jan 1 00:00:19 raspberry-pi kernel: usbcore: registered new interface driver option
Jan 1 00:00:19 raspberry-pi kernel: option: v0.7.2:USB Driver for GSM modems
Jan 1 00:00:19 raspberry-pi kernel: scsi 2:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:19 raspberry-pi kernel: scsi 3:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:19 raspberry-pi kernel: sd 3:0:0:0: [sda] Attached SCSI removable disk
Jan 1 00:00:19 raspberry-pi kernel: sda: detected capacity change from 3965190144 to 0
Jan 1 00:00:19 raspberry-pi kernel: NET: Registered protocol family 10
Jan 1 00:00:19 raspberry-pi kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jan 1 00:00:19 raspberry-pi kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jan 1 00:00:19 raspberry-pi kernel: smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Feb 2 13:00:00 raspberry-pi kernel: PPP generic driver version 2.4.2
Feb 2 13:00:00 raspberry-pi pppd[1239]: pppd 2.4.5 started by root, uid 0
Feb 2 13:00:00 raspberry-pi pppd[1239]: Using interface ppp0
Feb 2 13:00:00 raspberry-pi pppd[1239]: Connect: ppp0 <--> /dev/ttyUSB0
Feb 2 13:00:00 raspberry-pi pppd[1239]: CHAP authentication succeeded: Welcome!!
Feb 2 13:00:00 raspberry-pi pppd[1239]: kernel does not support PPP filtering
Feb 2 13:00:00 raspberry-pi kernel: PPP BSD Compression module registered
Feb 2 13:00:00 raspberry-pi kernel: PPP Deflate Compression module registered
Feb 2 13:00:03 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 5
Feb 2 13:00:03 raspberry-pi pppd[1239]: Modem hangup
Feb 2 13:00:03 raspberry-pi pppd[1239]: Connection terminated.
Feb 2 13:00:03 raspberry-pi pppd[1239]: Exit.
Feb 2 13:00:03 raspberry-pi kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Feb 2 13:00:03 raspberry-pi kernel: option 1-1.2:1.0: device disconnected
Feb 2 13:00:03 raspberry-pi kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Feb 2 13:00:03 raspberry-pi kernel: option 1-1.2:1.2: device disconnected
Feb 2 13:00:03 raspberry-pi kernel: option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Feb 2 13:00:03 raspberry-pi kernel: option 1-1.2:1.3: device disconnected
Feb 2 13:00:09 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 6 using dwc_otg
Feb 2 13:00:09 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Feb 2 13:00:09 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Feb 2 13:00:09 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:00:09 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:00:09 raspberry-pi kernel: scsi4 : usb-storage 1-1.2:1.0
Feb 2 13:00:09 raspberry-pi kernel: scsi5 : usb-storage 1-1.2:1.1
Feb 2 13:00:10 raspberry-pi usb_modeswitch: switching device 12d1:14fe on 001/006
Feb 2 13:00:10 raspberry-pi kernel: DEBUG:handle_hc_chhltd_intr_dma:: XactErr without NYET/NAK/ACK
Feb 2 13:00:10 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 6
Feb 2 13:00:15 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 7 using dwc_otg
Feb 2 13:00:15 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=1506
Feb 2 13:00:15 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Feb 2 13:00:15 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:00:15 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:00:15 raspberry-pi kernel: option 1-1.2:1.0: GSM modem (1-port) converter detected
Feb 2 13:00:15 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Feb 2 13:00:15 raspberry-pi kernel: option 1-1.2:1.2: GSM modem (1-port) converter detected
Feb 2 13:00:15 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Feb 2 13:00:15 raspberry-pi kernel: option 1-1.2:1.3: GSM modem (1-port) converter detected
Feb 2 13:00:15 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Feb 2 13:00:15 raspberry-pi kernel: scsi6 : usb-storage 1-1.2:1.4
Feb 2 13:00:15 raspberry-pi kernel: scsi7 : usb-storage 1-1.2:1.5
Feb 2 13:00:16 raspberry-pi logger: usb_modeswitch: switched to 12d1:1506 on 001/007
Feb 2 13:00:16 raspberry-pi kernel: scsi 6:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:00:16 raspberry-pi kernel: scsi 7:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:00:16 raspberry-pi kernel: sr0: scsi-1 drive
Feb 2 13:00:16 raspberry-pi kernel: sd 7:0:0:0: [sda] Attached SCSI removable disk
Feb 2 13:01:23 raspberry-pi pppd[1325]: pppd 2.4.5 started by root, uid 0
Feb 2 13:01:23 raspberry-pi pppd[1325]: Using interface ppp0
Feb 2 13:01:23 raspberry-pi pppd[1325]: Connect: ppp0 <--> /dev/ttyUSB0
Feb 2 13:01:23 raspberry-pi pppd[1325]: CHAP authentication succeeded: Welcome!!
Feb 2 13:01:23 raspberry-pi pppd[1325]: kernel does not support PPP filtering
Feb 2 13:01:26 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 7
Feb 2 13:01:26 raspberry-pi pppd[1325]: Modem hangup
Feb 2 13:01:26 raspberry-pi pppd[1325]: Connection terminated.
Feb 2 13:01:26 raspberry-pi pppd[1325]: Exit.
Feb 2 13:01:26 raspberry-pi kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Feb 2 13:01:26 raspberry-pi kernel: option 1-1.2:1.0: device disconnected
Feb 2 13:01:26 raspberry-pi kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Feb 2 13:01:26 raspberry-pi kernel: option 1-1.2:1.2: device disconnected
Feb 2 13:01:26 raspberry-pi kernel: option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Feb 2 13:01:26 raspberry-pi kernel: option 1-1.2:1.3: device disconnected
Feb 2 13:01:32 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 8 using dwc_otg
Feb 2 13:01:32 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Feb 2 13:01:32 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Feb 2 13:01:32 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:01:32 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:01:32 raspberry-pi kernel: scsi8 : usb-storage 1-1.2:1.0
Feb 2 13:01:32 raspberry-pi kernel: scsi9 : usb-storage 1-1.2:1.1
Feb 2 13:01:33 raspberry-pi usb_modeswitch: switching device 12d1:14fe on 001/008
Feb 2 13:01:33 raspberry-pi kernel: DEBUG:handle_hc_chhltd_intr_dma:: XactErr without NYET/NAK/ACK
Feb 2 13:01:33 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 8
Feb 2 13:01:38 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 9 using dwc_otg
Feb 2 13:01:38 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=1506
Feb 2 13:01:38 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Feb 2 13:01:38 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:01:38 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:01:38 raspberry-pi kernel: option 1-1.2:1.0: GSM modem (1-port) converter detected
Feb 2 13:01:39 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Feb 2 13:01:39 raspberry-pi kernel: option 1-1.2:1.2: GSM modem (1-port) converter detected
Feb 2 13:01:39 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Feb 2 13:01:39 raspberry-pi kernel: option 1-1.2:1.3: GSM modem (1-port) converter detected
Feb 2 13:01:39 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Feb 2 13:01:39 raspberry-pi kernel: scsi10 : usb-storage 1-1.2:1.4
Feb 2 13:01:39 raspberry-pi kernel: scsi11 : usb-storage 1-1.2:1.5
Feb 2 13:01:39 raspberry-pi logger: usb_modeswitch: switched to 12d1:1506 on 001/009
Feb 2 13:01:40 raspberry-pi kernel: scsi 10:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:01:40 raspberry-pi kernel: sr0: scsi-1 drive
Feb 2 13:01:40 raspberry-pi kernel: scsi 11:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:01:40 raspberry-pi kernel: sd 11:0:0:0: [sda] Attached SCSI removable disk
Feb 2 13:02:37 raspberry-pi pppd[1401]: pppd 2.4.5 started by root, uid 0
Feb 2 13:02:37 raspberry-pi pppd[1401]: Using interface ppp0
Feb 2 13:02:37 raspberry-pi pppd[1401]: Connect: ppp0 <--> /dev/ttyUSB0
Feb 2 13:02:37 raspberry-pi pppd[1401]: CHAP authentication succeeded: Welcome!!
Feb 2 13:02:37 raspberry-pi pppd[1401]: kernel does not support PPP filtering
Feb 2 13:02:40 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 9
Feb 2 13:02:40 raspberry-pi pppd[1401]: Modem hangup
Feb 2 13:02:40 raspberry-pi pppd[1401]: Connection terminated.
Feb 2 13:02:40 raspberry-pi pppd[1401]: Exit.
Feb 2 13:02:40 raspberry-pi kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Feb 2 13:02:40 raspberry-pi kernel: option 1-1.2:1.0: device disconnected
Feb 2 13:02:40 raspberry-pi kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Feb 2 13:02:40 raspberry-pi kernel: option 1-1.2:1.2: device disconnected
Feb 2 13:02:40 raspberry-pi kernel: option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Feb 2 13:02:40 raspberry-pi kernel: option 1-1.2:1.3: device disconnected
Feb 2 13:02:46 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 10 using dwc_otg
Feb 2 13:02:46 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Feb 2 13:02:46 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Feb 2 13:02:46 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:02:46 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:02:46 raspberry-pi kernel: scsi12 : usb-storage 1-1.2:1.0
Feb 2 13:02:46 raspberry-pi kernel: scsi13 : usb-storage 1-1.2:1.1
Feb 2 13:02:47 raspberry-pi usb_modeswitch: switching device 12d1:14fe on 001/010
Feb 2 13:02:47 raspberry-pi kernel: DEBUG:handle_hc_chhltd_intr_dma:: XactErr without NYET/NAK/ACK
Feb 2 13:02:47 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 10
Feb 2 13:02:52 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 11 using dwc_otg
Feb 2 13:02:52 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=1506
Feb 2 13:02:52 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Feb 2 13:02:52 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:02:52 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:02:52 raspberry-pi kernel: option 1-1.2:1.0: GSM modem (1-port) converter detected
Feb 2 13:02:52 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Feb 2 13:02:52 raspberry-pi kernel: option 1-1.2:1.2: GSM modem (1-port) converter detected
Feb 2 13:02:52 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Feb 2 13:02:52 raspberry-pi kernel: option 1-1.2:1.3: GSM modem (1-port) converter detected
Feb 2 13:02:52 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Feb 2 13:02:52 raspberry-pi kernel: scsi14 : usb-storage 1-1.2:1.4
Feb 2 13:02:52 raspberry-pi kernel: scsi15 : usb-storage 1-1.2:1.5
Feb 2 13:02:53 raspberry-pi logger: usb_modeswitch: switched to 12d1:1506 on 001/011
Feb 2 13:02:53 raspberry-pi kernel: scsi 14:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:02:53 raspberry-pi kernel: sr0: scsi-1 drive
Feb 2 13:02:53 raspberry-pi kernel: scsi 15:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:02:53 raspberry-pi kernel: sd 15:0:0:0: [sda] Attached SCSI removable disk
Feb 2 13:03:16 raspberry-pi pppd[1477]: pppd 2.4.5 started by root, uid 0
Feb 2 13:03:16 raspberry-pi pppd[1477]: Using interface ppp0
Feb 2 13:03:16 raspberry-pi pppd[1477]: Connect: ppp0 <--> /dev/ttyUSB0
Feb 2 13:03:16 raspberry-pi pppd[1477]: CHAP authentication succeeded: Welcome!!
Feb 2 13:03:16 raspberry-pi pppd[1477]: kernel does not support PPP filtering
Feb 2 13:03:19 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 11
Feb 2 13:03:19 raspberry-pi pppd[1477]: Modem hangup
Feb 2 13:03:19 raspberry-pi pppd[1477]: Connection terminated.
Feb 2 13:03:19 raspberry-pi pppd[1477]: Exit.
Feb 2 13:03:19 raspberry-pi kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Feb 2 13:03:19 raspberry-pi kernel: option 1-1.2:1.0: device disconnected
Feb 2 13:03:19 raspberry-pi kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Feb 2 13:03:19 raspberry-pi kernel: option 1-1.2:1.2: device disconnected
Feb 2 13:03:19 raspberry-pi kernel: option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Feb 2 13:03:19 raspberry-pi kernel: option 1-1.2:1.3: device disconnected
Feb 2 13:03:24 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 12 using dwc_otg
Feb 2 13:03:24 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Feb 2 13:03:24 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Feb 2 13:03:24 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:03:24 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:03:24 raspberry-pi kernel: scsi16 : usb-storage 1-1.2:1.0
Feb 2 13:03:24 raspberry-pi kernel: scsi17 : usb-storage 1-1.2:1.1
Feb 2 13:03:25 raspberry-pi usb_modeswitch: switching device 12d1:14fe on 001/012
Feb 2 13:03:25 raspberry-pi kernel: DEBUG:handle_hc_chhltd_intr_dma:: XactErr without NYET/NAK/ACK
Feb 2 13:03:25 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 12
Feb 2 13:03:31 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 13 using dwc_otg
Feb 2 13:03:31 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=1506
Feb 2 13:03:31 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Feb 2 13:03:31 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:03:31 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:03:31 raspberry-pi kernel: option 1-1.2:1.0: GSM modem (1-port) converter detected
Feb 2 13:03:31 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Feb 2 13:03:31 raspberry-pi kernel: option 1-1.2:1.2: GSM modem (1-port) converter detected
Feb 2 13:03:31 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Feb 2 13:03:31 raspberry-pi kernel: option 1-1.2:1.3: GSM modem (1-port) converter detected
Feb 2 13:03:31 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Feb 2 13:03:31 raspberry-pi kernel: scsi18 : usb-storage 1-1.2:1.4
Feb 2 13:03:31 raspberry-pi kernel: scsi19 : usb-storage 1-1.2:1.5
Feb 2 13:03:32 raspberry-pi logger: usb_modeswitch: switched to 12d1:1506 on 001/013
Feb 2 13:03:32 raspberry-pi kernel: scsi 18:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:03:32 raspberry-pi kernel: scsi 19:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:03:32 raspberry-pi kernel: sr0: scsi-1 drive
Feb 2 13:03:32 raspberry-pi kernel: sd 19:0:0:0: [sda] Attached SCSI removable disk
Feb 2 13:16:14 raspberry-pi pppd[1590]: pppd 2.4.5 started by root, uid 0
Feb 2 13:16:14 raspberry-pi pppd[1590]: Using interface ppp0
Feb 2 13:16:14 raspberry-pi pppd[1590]: Connect: ppp0 <--> /dev/ttyUSB0
Feb 2 13:16:14 raspberry-pi pppd[1590]: CHAP authentication succeeded: Welcome!!
Feb 2 13:16:14 raspberry-pi pppd[1590]: kernel does not support PPP filtering
Feb 2 13:16:17 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 13
Feb 2 13:16:17 raspberry-pi pppd[1590]: Modem hangup
Feb 2 13:16:17 raspberry-pi pppd[1590]: Connection terminated.
Feb 2 13:16:17 raspberry-pi pppd[1590]: Exit.
Feb 2 13:16:17 raspberry-pi kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Feb 2 13:16:17 raspberry-pi kernel: option 1-1.2:1.0: device disconnected
Feb 2 13:16:17 raspberry-pi kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Feb 2 13:16:17 raspberry-pi kernel: option 1-1.2:1.2: device disconnected
Feb 2 13:16:17 raspberry-pi kernel: option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Feb 2 13:16:17 raspberry-pi kernel: option 1-1.2:1.3: device disconnected
Feb 2 13:16:22 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 14 using dwc_otg
Feb 2 13:16:22 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Feb 2 13:16:22 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Feb 2 13:16:22 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:16:22 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:16:22 raspberry-pi kernel: scsi20 : usb-storage 1-1.2:1.0
Feb 2 13:16:22 raspberry-pi kernel: scsi21 : usb-storage 1-1.2:1.1
Feb 2 13:16:23 raspberry-pi usb_modeswitch: switching device 12d1:14fe on 001/014
Feb 2 13:16:23 raspberry-pi kernel: DEBUG:handle_hc_chhltd_intr_dma:: XactErr without NYET/NAK/ACK
Feb 2 13:16:23 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 14
Feb 2 13:16:29 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 15 using dwc_otg
Feb 2 13:16:29 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=1506
Feb 2 13:16:29 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Feb 2 13:16:29 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:16:29 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:16:29 raspberry-pi kernel: option 1-1.2:1.0: GSM modem (1-port) converter detected
Feb 2 13:16:29 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Feb 2 13:16:29 raspberry-pi kernel: option 1-1.2:1.2: GSM modem (1-port) converter detected
Feb 2 13:16:29 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Feb 2 13:16:29 raspberry-pi kernel: option 1-1.2:1.3: GSM modem (1-port) converter detected
Feb 2 13:16:29 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Feb 2 13:16:29 raspberry-pi kernel: scsi22 : usb-storage 1-1.2:1.4
Feb 2 13:16:29 raspberry-pi kernel: scsi23 : usb-storage 1-1.2:1.5
Feb 2 13:16:30 raspberry-pi logger: usb_modeswitch: switched to 12d1:1506 on 001/015
Feb 2 13:16:30 raspberry-pi kernel: scsi 22:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:16:30 raspberry-pi kernel: sr0: scsi-1 drive
Feb 2 13:16:30 raspberry-pi kernel: scsi 23:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:16:30 raspberry-pi kernel: sd 23:0:0:0: [sda] Attached SCSI removable disk
Feb 2 13:25:54 raspberry-pi pppd[1671]: pppd 2.4.5 started by root, uid 0
Feb 2 13:25:54 raspberry-pi pppd[1671]: Using interface ppp0
Feb 2 13:25:54 raspberry-pi pppd[1671]: Connect: ppp0 <--> /dev/ttyUSB0
Feb 2 13:25:54 raspberry-pi pppd[1671]: CHAP authentication succeeded: Welcome!!
Feb 2 13:25:54 raspberry-pi pppd[1671]: kernel does not support PPP filtering
Feb 2 13:25:56 raspberry-pi pppd[1671]: Modem hangup
Feb 2 13:25:56 raspberry-pi pppd[1671]: Connection terminated.
Feb 2 13:25:56 raspberry-pi pppd[1671]: Exit.
Feb 2 13:25:56 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 15
Feb 2 13:25:56 raspberry-pi kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Feb 2 13:25:56 raspberry-pi kernel: option 1-1.2:1.0: device disconnected
Feb 2 13:25:56 raspberry-pi kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Feb 2 13:25:56 raspberry-pi kernel: option 1-1.2:1.2: device disconnected
Feb 2 13:25:56 raspberry-pi kernel: option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Feb 2 13:25:56 raspberry-pi kernel: option 1-1.2:1.3: device disconnected
Feb 2 13:26:02 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 16 using dwc_otg
Feb 2 13:26:02 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Feb 2 13:26:02 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Feb 2 13:26:02 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:26:02 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:26:02 raspberry-pi kernel: scsi24 : usb-storage 1-1.2:1.0
Feb 2 13:26:02 raspberry-pi kernel: scsi25 : usb-storage 1-1.2:1.1
Feb 2 13:26:03 raspberry-pi usb_modeswitch: switching device 12d1:14fe on 001/016
Feb 2 13:26:03 raspberry-pi kernel: DEBUG:handle_hc_chhltd_intr_dma:: XactErr without NYET/NAK/ACK
Feb 2 13:26:03 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 16
Feb 2 13:26:08 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 17 using dwc_otg
Feb 2 13:26:08 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=1506
Feb 2 13:26:08 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Feb 2 13:26:08 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:26:08 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:26:08 raspberry-pi kernel: option 1-1.2:1.0: GSM modem (1-port) converter detected
Feb 2 13:26:08 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Feb 2 13:26:08 raspberry-pi kernel: option 1-1.2:1.2: GSM modem (1-port) converter detected
Feb 2 13:26:08 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Feb 2 13:26:08 raspberry-pi kernel: option 1-1.2:1.3: GSM modem (1-port) converter detected
Feb 2 13:26:09 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Feb 2 13:26:09 raspberry-pi kernel: scsi26 : usb-storage 1-1.2:1.4
Feb 2 13:26:09 raspberry-pi kernel: scsi27 : usb-storage 1-1.2:1.5
Feb 2 13:26:09 raspberry-pi logger: usb_modeswitch: switched to 12d1:1506 on 001/017
Feb 2 13:26:10 raspberry-pi kernel: scsi 26:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:26:10 raspberry-pi kernel: sr0: scsi-1 drive
Feb 2 13:26:10 raspberry-pi kernel: scsi 27:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:26:10 raspberry-pi kernel: sd 27:0:0:0: [sda] Attached SCSI removable disk
Feb 2 13:30:08 raspberry-pi pppd[1748]: pppd 2.4.5 started by root, uid 0
Feb 2 13:30:08 raspberry-pi pppd[1748]: Using interface ppp0
Feb 2 13:30:08 raspberry-pi pppd[1748]: Connect: ppp0 <--> /dev/ttyUSB0
Feb 2 13:30:08 raspberry-pi pppd[1748]: CHAP authentication succeeded: Welcome!!
Feb 2 13:30:08 raspberry-pi pppd[1748]: kernel does not support PPP filtering
Feb 2 13:30:11 raspberry-pi pppd[1748]: Modem hangup
Feb 2 13:30:11 raspberry-pi pppd[1748]: Connection terminated.
Feb 2 13:30:11 raspberry-pi pppd[1748]: Exit.
Feb 2 13:30:11 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 17
Feb 2 13:30:11 raspberry-pi kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Feb 2 13:30:11 raspberry-pi kernel: option 1-1.2:1.0: device disconnected
Feb 2 13:30:12 raspberry-pi kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Feb 2 13:30:12 raspberry-pi kernel: option 1-1.2:1.2: device disconnected
Feb 2 13:30:12 raspberry-pi kernel: option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Feb 2 13:30:12 raspberry-pi kernel: option 1-1.2:1.3: device disconnected
Feb 2 13:30:17 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 18 using dwc_otg
Feb 2 13:30:17 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Feb 2 13:30:17 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Feb 2 13:30:17 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:30:17 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:30:17 raspberry-pi kernel: scsi28 : usb-storage 1-1.2:1.0
Feb 2 13:30:17 raspberry-pi kernel: scsi29 : usb-storage 1-1.2:1.1
Feb 2 13:30:18 raspberry-pi usb_modeswitch: switching device 12d1:14fe on 001/018
Feb 2 13:30:18 raspberry-pi kernel: DEBUG:handle_hc_chhltd_intr_dma:: XactErr without NYET/NAK/ACK
Feb 2 13:30:18 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 18
Feb 2 13:30:23 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 19 using dwc_otg
Feb 2 13:30:24 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=1506
Feb 2 13:30:24 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Feb 2 13:30:24 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:30:24 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:30:24 raspberry-pi kernel: option 1-1.2:1.0: GSM modem (1-port) converter detected
Feb 2 13:30:24 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Feb 2 13:30:24 raspberry-pi kernel: option 1-1.2:1.2: GSM modem (1-port) converter detected
Feb 2 13:30:24 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Feb 2 13:30:24 raspberry-pi kernel: option 1-1.2:1.3: GSM modem (1-port) converter detected
Feb 2 13:30:24 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Feb 2 13:30:24 raspberry-pi kernel: scsi30 : usb-storage 1-1.2:1.4
Feb 2 13:30:24 raspberry-pi kernel: scsi31 : usb-storage 1-1.2:1.5
Feb 2 13:30:24 raspberry-pi logger: usb_modeswitch: switched to 12d1:1506 on 001/019
Feb 2 13:30:25 raspberry-pi kernel: scsi 30:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:30:25 raspberry-pi kernel: scsi 31:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:30:25 raspberry-pi kernel: sr0: scsi-1 drive
Feb 2 13:30:25 raspberry-pi kernel: sd 31:0:0:0: [sda] Attached SCSI removable disk
Feb 2 13:51:12 raspberry-pi pppd[2040]: pppd 2.4.5 started by root, uid 0
Feb 2 13:51:12 raspberry-pi pppd[2040]: Using interface ppp0
Feb 2 13:51:12 raspberry-pi pppd[2040]: Connect: ppp0 <--> /dev/ttyUSB0
Feb 2 13:51:12 raspberry-pi pppd[2040]: CHAP authentication succeeded: Welcome!!
Feb 2 13:51:12 raspberry-pi pppd[2040]: kernel does not support PPP filtering
Feb 2 13:51:15 raspberry-pi pppd[2040]: Modem hangup
Feb 2 13:51:15 raspberry-pi pppd[2040]: Connection terminated.
Feb 2 13:51:15 raspberry-pi pppd[2040]: Exit.
Feb 2 13:51:15 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 19
Feb 2 13:51:15 raspberry-pi kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Feb 2 13:51:15 raspberry-pi kernel: option 1-1.2:1.0: device disconnected
Feb 2 13:51:15 raspberry-pi kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Feb 2 13:51:15 raspberry-pi kernel: option 1-1.2:1.2: device disconnected
Feb 2 13:51:15 raspberry-pi kernel: option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Feb 2 13:51:15 raspberry-pi kernel: option 1-1.2:1.3: device disconnected
Feb 2 13:51:20 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 20 using dwc_otg
Feb 2 13:51:21 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
Feb 2 13:51:21 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Feb 2 13:51:21 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:51:21 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:51:21 raspberry-pi kernel: scsi32 : usb-storage 1-1.2:1.0
Feb 2 13:51:21 raspberry-pi kernel: scsi33 : usb-storage 1-1.2:1.1
Feb 2 13:51:21 raspberry-pi usb_modeswitch: switching device 12d1:14fe on 001/020
Feb 2 13:51:21 raspberry-pi kernel: DEBUG:handle_hc_chhltd_intr_dma:: XactErr without NYET/NAK/ACK
Feb 2 13:51:21 raspberry-pi kernel: usb 1-1.2: USB disconnect, device number 20
Feb 2 13:51:27 raspberry-pi kernel: usb 1-1.2: new high speed USB device number 21 using dwc_otg
Feb 2 13:51:27 raspberry-pi kernel: usb 1-1.2: New USB device found, idVendor=12d1, idProduct=1506
Feb 2 13:51:27 raspberry-pi kernel: usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Feb 2 13:51:27 raspberry-pi kernel: usb 1-1.2: Product: HUAWEI Mobile
Feb 2 13:51:27 raspberry-pi kernel: usb 1-1.2: Manufacturer: HUAWEI
Feb 2 13:51:27 raspberry-pi kernel: option 1-1.2:1.0: GSM modem (1-port) converter detected
Feb 2 13:51:27 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Feb 2 13:51:27 raspberry-pi kernel: option 1-1.2:1.2: GSM modem (1-port) converter detected
Feb 2 13:51:27 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Feb 2 13:51:27 raspberry-pi kernel: option 1-1.2:1.3: GSM modem (1-port) converter detected
Feb 2 13:51:27 raspberry-pi kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Feb 2 13:51:27 raspberry-pi kernel: scsi34 : usb-storage 1-1.2:1.4
Feb 2 13:51:27 raspberry-pi kernel: scsi35 : usb-storage 1-1.2:1.5
Feb 2 13:51:28 raspberry-pi logger: usb_modeswitch: switched to 12d1:1506 on 001/021
Feb 2 13:51:28 raspberry-pi kernel: scsi 34:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:51:28 raspberry-pi kernel: scsi 35:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
Feb 2 13:51:28 raspberry-pi kernel: sr0: scsi-1 drive
Feb 2 13:51:28 raspberry-pi kernel: sd 35:0:0:0: [sda] Attached SCSI removable disk
Tak jakby modem się rozłączał chwilę po ustanowieniu połączenia.
