Uzupełniam informacje:
hwinfo --framebuffer:
> hal.1: read hal dataprocess 6437: arguments to dbus_move_error() were incorrect, assertion "(dest) == NULL || !dbus_error_is_set ((dest))" failed in file ../../dbus/dbus-errors.c line 282.
This is normally a bug in some application using the D-Bus library.
libhal.c 3483 : Error unsubscribing to signals, error=The name org.freedesktop.Hal was not provided by any .service files
02: None 00.0: 11001 VESA Framebuffer
[Created at bios.464]
Unique ID: rdCR.ASuPo0kgwJ1
Hardware Class: framebuffer
Model: "(C) 1988-2010, AMD Technologies Inc. WRESTLER"
Vendor: "(C) 1988-2010, AMD Technologies Inc. "
Device: "WRESTLER"
SubVendor: "AMD ATOMBIOS"
SubDevice:
Revision: "01.00"
Memory Size: 16 MB
Mode 0x0307: 1280x1024 (+1280), 8 bits
Mode 0x0310: 640x480 (+1280), 15 bits
Mode 0x0311: 640x480 (+1280), 16 bits
Mode 0x0313: 800x600 (+1600), 15 bits
Mode 0x0314: 800x600 (+1600), 16 bits
Mode 0x0316: 1024x768 (+2048), 15 bits
Mode 0x0317: 1024x768 (+2048), 16 bits
Mode 0x0319: 1280x1024 (+2560), 15 bits
Mode 0x031a: 1280x1024 (+2560), 16 bits
Mode 0x030d: 320x200 (+640), 15 bits
Mode 0x030e: 320x200 (+640), 16 bits
Mode 0x0320: 320x200 (+1280), 24 bits
Mode 0x0393: 320x240 (+320), 8 bits
Mode 0x0395: 320x240 (+640), 16 bits
Mode 0x0396: 320x240 (+1280), 24 bits
Mode 0x03b3: 512x384 (+512), 8 bits
Mode 0x03b5: 512x384 (+1024), 16 bits
Mode 0x03b6: 512x384 (+2048), 24 bits
Mode 0x03c3: 640x350 (+640), 8 bits
Mode 0x03c5: 640x350 (+1280), 16 bits
Mode 0x03c6: 640x350 (+2560), 24 bits
Mode 0x0333: 720x400 (+768), 8 bits
Mode 0x0335: 720x400 (+1472), 16 bits
Mode 0x0336: 720x400 (+2944), 24 bits
Mode 0x0353: 1152x864 (+1152), 8 bits
Mode 0x0355: 1152x864 (+2304), 16 bits
Mode 0x0356: 1152x864 (+4608), 24 bits
Mode 0x0363: 1280x960 (+1280), 8 bits
Mode 0x0365: 1280x960 (+2560), 16 bits
Mode 0x0366: 1280x960 (+5120), 24 bits
Mode 0x0321: 640x480 (+2560), 24 bits
Mode 0x0322: 800x600 (+3200), 24 bits
Mode 0x0323: 1024x768 (+4096), 24 bits
Mode 0x0324: 1280x1024 (+5120), 24 bits
Mode 0x0343: 1400x1050 (+1408), 8 bits
Mode 0x0345: 1400x1050 (+2816), 16 bits
Mode 0x0346: 1400x1050 (+5632), 24 bits
Config Status: cfg=new, avail=yes, need=no, active=unknown
xorg.conf
Section "ServerLayout"
Identifier "aticonfig Layout"
Screen 0 "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Module"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-0"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
BusID "PCI:0:1:0"
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection
Rafal_F"], sporo tego, nie chce zaciemniać, jakie informacje według Ciebie by się jeszcze przydały?
uname -a
Linux debian 3.2.0-4-amd64 #1 SMP Debian 3.2.35-2 x86_64 GNU/Linux
Xorg.0.log:
[ 9.678] X.Org X Server 1.12.4
Release Date: 2012-08-27
[ 9.678] X Protocol Version 11, Revision 0
[ 9.678] Build Operating System: Linux 3.2.0-4.drm-amd64 x86_64 Debian
[ 9.678] Current Operating System: Linux debian 3.2.0-4-amd64 #1 SMP Debian 3.2.35-2 x86_64
[ 9.679] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-amd64 root=UUID=ecb13fae-af15-4332-a914-50a5a9631479 ro quiet video=vesafb vga=795
[ 9.679] Build Date: 29 November 2012 07:18:16PM
[ 9.679] xorg-server 2:1.12.4-4 (Julien Cristau <jcristau@debian.org>)
[ 9.679] Current version of pixman: 0.26.0
[ 9.679] Before reporting problems, check http://wiki.x.org
[ 9.679] Markers: (--) probed, (**) from config file, (==) default setting,
[ 9.679] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jan 26 19:52:19 2013
[ 9.685] (==) Using config file: "/etc/X11/xorg.conf"
[ 9.685] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 9.694] (==) ServerLayout "aticonfig Layout"
[ 9.694] (**) |-->Screen "aticonfig-Screen[0]-0" (0)
[ 9.694] (**) | |-->Monitor "aticonfig-Monitor[0]-0"
[ 9.695] (**) | |-->Device "aticonfig-Device[0]-0"
[ 9.695] (==) Automatically adding devices
[ 9.695] (==) Automatically enabling devices
[ 9.707] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 9.707] Entry deleted from font path.
[ 9.712] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 9.712] Entry deleted from font path.
[ 9.712] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 9.712] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 9.712] (II) The server relies on udev to provide the list of input devices.
[ 9.712] (II) Loader magic: 0x7f721f17cae0
[ 9.712] (II) Module ABI versions:
[ 9.712] X.Org ANSI C Emulation: 0.4
[ 9.712] X.Org Video Driver: 12.1
[ 9.712] X.Org XInput driver : 16.0
[ 9.712] X.Org Server Extension : 6.0
[ 9.715] (--) PCI:*(0:0:1:0) 1002:9802:105b:0e29 rev 0, Mem @ 0xc0000000/268435456, 0xfeb00000/262144, I/O @ 0x0000f000/256
[ 9.715] (II) Open ACPI successful (/var/run/acpid.socket)
[ 9.715] (II) "extmod" will be loaded by default.
[ 9.715] (II) "dbe" will be loaded by default.
[ 9.715] (II) "glx" will be loaded by default.
[ 9.715] (II) "record" will be loaded by default.
[ 9.715] (II) "dri" will be loaded by default.
[ 9.716] (II) "dri2" will be loaded by default.
[ 9.716] (II) LoadModule: "extmod"
[ 9.734] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 9.740] (II) Module extmod: vendor="X.Org Foundation"
[ 9.740] compiled for 1.12.4, module version = 1.0.0
[ 9.740] Module class: X.Org Server Extension
[ 9.740] ABI class: X.Org Server Extension, version 6.0
[ 9.740] (II) Loading extension SELinux
[ 9.740] (II) Loading extension MIT-SCREEN-SAVER
[ 9.740] (II) Loading extension XFree86-VidModeExtension
[ 9.740] (II) Loading extension XFree86-DGA
[ 9.740] (II) Loading extension DPMS
[ 9.740] (II) Loading extension XVideo
[ 9.740] (II) Loading extension XVideo-MotionCompensation
[ 9.740] (II) Loading extension X-Resource
[ 9.740] (II) LoadModule: "dbe"
[ 9.741] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 9.743] (II) Module dbe: vendor="X.Org Foundation"
[ 9.743] compiled for 1.12.4, module version = 1.0.0
[ 9.743] Module class: X.Org Server Extension
[ 9.743] ABI class: X.Org Server Extension, version 6.0
[ 9.743] (II) Loading extension DOUBLE-BUFFER
[ 9.743] (II) LoadModule: "glx"
[ 9.743] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[ 9.749] (II) Module glx: vendor="Advanced Micro Devices, Inc."
[ 9.749] compiled for 6.9.0, module version = 1.0.0
[ 9.750] (II) Loading extension GLX
[ 9.750] (II) LoadModule: "record"
[ 9.751] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 9.753] (II) Module record: vendor="X.Org Foundation"
[ 9.753] compiled for 1.12.4, module version = 1.13.0
[ 9.753] Module class: X.Org Server Extension
[ 9.753] ABI class: X.Org Server Extension, version 6.0
[ 9.753] (II) Loading extension RECORD
[ 9.753] (II) LoadModule: "dri"
[ 9.754] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 9.759] (II) Module dri: vendor="X.Org Foundation"
[ 9.759] compiled for 1.12.4, module version = 1.0.0
[ 9.759] ABI class: X.Org Server Extension, version 6.0
[ 9.759] (II) Loading extension XFree86-DRI
[ 9.759] (II) LoadModule: "dri2"
[ 9.761] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 9.762] (II) Module dri2: vendor="X.Org Foundation"
[ 9.762] compiled for 1.12.4, module version = 1.2.0
[ 9.762] ABI class: X.Org Server Extension, version 6.0
[ 9.762] (II) Loading extension DRI2
[ 9.762] (II) LoadModule: "fglrx"
[ 9.763] (II) Loading /usr/lib/xorg/modules/drivers/fglrx_drv.so
[ 9.906] (II) Module fglrx: vendor="FireGL - AMD Technologies Inc."
[ 9.906] compiled for 1.4.99.906, module version = 8.98.2
[ 9.906] Module class: X.Org Video Driver
[ 9.906] (II) Loading sub module "fglrxdrm"
[ 9.906] (II) LoadModule: "fglrxdrm"
[ 9.906] (II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
[ 9.909] (II) Module fglrxdrm: vendor="FireGL - AMD Technologies Inc."
[ 9.909] compiled for 1.4.99.906, module version = 8.98.2
[ 9.909] (II) AMD Proprietary Linux Driver Version Identifier:8.98.2
[ 9.909] (II) AMD Proprietary Linux Driver Release Identifier: 8.982.13
[ 9.909] (II) AMD Proprietary Linux Driver Build Date: Jul 19 2012 20:59:44
[ 9.909] (++) using VT number 7
[ 9.909] (WW) Falling back to old probe method for fglrx
[ 9.933] (II) Loading PCS database from /etc/ati/amdpcsdb
[ 9.939] (--) Chipset Supported AMD Graphics Processor (0x9802) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:1:1) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:17:0) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:18:0) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:18:2) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:0) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:2) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:0) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:1) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:2) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:3) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:4) found
[ 9.941] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:5) found
[ 9.942] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:21:0) found
[ 9.942] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:21:1) found
[ 9.942] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:21:2) found
[ 9.942] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:22:0) found
[ 9.942] (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:22:2) found
[ 9.948] (II) AMD Video driver is running on a device belonging to a group targeted for this release
[ 9.950] (II) AMD Video driver is signed
[ 9.952] (II) fglrx(0): pEnt->device->identifier=0x7f7220aa1700
[ 9.952] (II) fglrx(0): === [xdl_xs112_atiddxPreInit] === begin
[ 9.953] (II) Loading sub module "vgahw"
[ 9.953] (II) LoadModule: "vgahw"
[ 9.953] (II) Loading /usr/lib/xorg/modules/libvgahw.so
[ 9.958] (II) Module vgahw: vendor="X.Org Foundation"
[ 9.958] compiled for 1.12.4, module version = 0.1.0
[ 9.958] ABI class: X.Org Video Driver, version 12.1
[ 9.958] (**) fglrx(0): Depth 24, (--) framebuffer bpp 32
[ 9.958] (II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 9.958] (==) fglrx(0): Default visual is TrueColor
[ 9.959] (**) fglrx(0): Option "DPMS" "true"
[ 9.959] (==) fglrx(0): RGB weight 888
[ 9.959] (II) fglrx(0): Using 8 bits per RGB
[ 9.959] (==) fglrx(0): Buffer Tiling is ON
[ 9.961] (II) Loading sub module "fglrxdrm"
[ 9.961] (II) LoadModule: "fglrxdrm"
[ 9.961] (II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
[ 9.961] (II) Module fglrxdrm: vendor="FireGL - AMD Technologies Inc."
[ 9.961] compiled for 1.4.99.906, module version = 8.98.2
[ 9.967] ukiDynamicMajor: found major device number 251
[ 9.967] ukiOpenByBusid: Searching for BusID PCI:0:1:0
[ 9.967] ukiOpenDevice: node name is /dev/ati/card0
[ 9.968] ukiOpenDevice: open result is 12, (OK)
[ 9.968] ukiOpenByBusid: ukiOpenMinor returns 12
[ 9.968] ukiOpenByBusid: ukiGetBusid reports PCI:0:1:0
[ 9.969] (**) fglrx(0): NoAccel = NO
[ 9.969] (**) fglrx(0): AMD 2D Acceleration Architecture enabled
[ 9.969] (--) fglrx(0): Chipset: "AMD Radeon HD 6310 Graphics" (Chipset = 0x9802)
[ 9.969] (--) fglrx(0): (PciSubVendor = 0x105b, PciSubDevice = 0x0e29)
[ 9.969] (==) fglrx(0): board vendor info: third party graphics adapter - NOT original AMD
[ 9.969] (--) fglrx(0): Linear framebuffer (phys) at 0xc0000000
[ 9.969] (--) fglrx(0): MMIO registers at 0xfeb00000
[ 9.969] (--) fglrx(0): I/O port at 0x0000f000
[ 9.969] (==) fglrx(0): ROM-BIOS at 0x000c0000
[ 9.972] (II) fglrx(0): AC Adapter is used
[ 10.021] (II) fglrx(0): Primary V_BIOS segment is: 0xc000
[ 10.023] (II) Loading sub module "vbe"
[ 10.023] (II) LoadModule: "vbe"
[ 10.023] (II) Loading /usr/lib/xorg/modules/libvbe.so
[ 10.025] (II) Module vbe: vendor="X.Org Foundation"
[ 10.025] compiled for 1.12.4, module version = 1.1.0
[ 10.025] ABI class: X.Org Video Driver, version 12.1
[ 10.027] (II) fglrx(0): VESA BIOS detected
[ 10.027] (II) fglrx(0): VESA VBE Version 3.0
[ 10.027] (II) fglrx(0): VESA VBE Total Mem: 16384 kB
[ 10.027] (II) fglrx(0): VESA VBE OEM: AMD ATOMBIOS
[ 10.027] (II) fglrx(0): VESA VBE OEM Software Rev: 12.36
[ 10.027] (II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2010, AMD Technologies Inc.
[ 10.027] (II) fglrx(0): VESA VBE OEM Product: WRESTLER
[ 10.027] (II) fglrx(0): VESA VBE OEM Product Rev: 01.00
[ 10.043] (II) fglrx(0): AMD Video BIOS revision 9 or later detected
[ 10.043] (--) fglrx(0): Video RAM: 393216 kByte, Type: DDR3
[ 10.043] (II) fglrx(0): PCIE card detected
[ 10.043] (--) fglrx(0): Using per-process page tables (PPPT) as GART.
[ 10.043] (WW) fglrx(0): board is an unknown third party board, chipset is supported
[ 10.055] (II) fglrx(0): Using adapter: 0:1.0.
[ 11.324] (II) fglrx(0): [FB] MC range(MCFBBase = 0xf00000000, MCFBSize = 0x18000000)
[ 11.597] (II) fglrx(0): Interrupt handler installed at IRQ 45.
[ 11.598] (II) fglrx(0): RandR 1.2 support is enabled!
[ 11.598] (II) fglrx(0): RandR 1.2 rotation support is enabled!
[ 11.598] (==) fglrx(0): Center Mode is disabled
[ 11.598] (II) Loading sub module "fb"
[ 11.598] (II) LoadModule: "fb"
[ 11.623] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 11.635] (II) Module fb: vendor="X.Org Foundation"
[ 11.635] compiled for 1.12.4, module version = 1.0.0
[ 11.635] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.635] (II) Loading sub module "ddc"
[ 11.635] (II) LoadModule: "ddc"
[ 11.635] (II) Module "ddc" already built-in
[ 11.781] (II) fglrx(0): Finished Initialize PPLIB!
[ 11.783] (II) fglrx(0): Output DFP1 using monitor section aticonfig-Monitor[0]-0
[ 11.784] (II) fglrx(0): Output DFP2 has no monitor section
[ 11.784] (II) fglrx(0): Output CRT1 has no monitor section
[ 11.784] (II) Loading sub module "ddc"
[ 11.784] (II) LoadModule: "ddc"
[ 11.784] (II) Module "ddc" already built-in
[ 11.784] (II) fglrx(0): Connected Display0: DFP1
[ 11.784] (II) fglrx(0): Display0 EDID data ---------------------------
[ 11.784] (II) fglrx(0): Manufacturer: ACR Model: 198 Serial#: 272639795
[ 11.784] (II) fglrx(0): Year: 2011 Week: 4
[ 11.784] (II) fglrx(0): EDID Version: 1.3
[ 11.784] (II) fglrx(0): Digital Display Input
[ 11.784] (II) fglrx(0): Max Image Size [cm]: horiz.: 48 vert.: 27
[ 11.784] (II) fglrx(0): Gamma: 2.20
[ 11.784] (II) fglrx(0): DPMS capabilities: Off
[ 11.784] (II) fglrx(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 11.784] (II) fglrx(0): First detailed timing is preferred mode
[ 11.784] (II) fglrx(0): redX: 0.631 redY: 0.349 greenX: 0.341 greenY: 0.622
[ 11.784] (II) fglrx(0): blueX: 0.152 blueY: 0.058 whiteX: 0.313 whiteY: 0.329
[ 11.784] (II) fglrx(0): Supported established timings:
[ 11.784] (II) fglrx(0): 720x400@70Hz
[ 11.784] (II) fglrx(0): 640x480@60Hz
[ 11.784] (II) fglrx(0): 640x480@67Hz
[ 11.784] (II) fglrx(0): 800x600@56Hz
[ 11.784] (II) fglrx(0): 800x600@60Hz
[ 11.784] (II) fglrx(0): 1024x768@60Hz
[ 11.784] (II) fglrx(0): 1024x768@70Hz
[ 11.784] (II) fglrx(0): Manufacturer's mask: 0
[ 11.784] (II) fglrx(0): Supported standard timings:
[ 11.784] (II) fglrx(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 11.784] (II) fglrx(0): #1: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 11.784] (II) fglrx(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 11.785] (II) fglrx(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 11.785] (II) fglrx(0): #4: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 11.785] (II) fglrx(0): Supported detailed timing:
[ 11.785] (II) fglrx(0): clock: 148.5 MHz Image Size: 477 x 268 mm
[ 11.785] (II) fglrx(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 11.785] (II) fglrx(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 11.785] (II) fglrx(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 11.785] (II) fglrx(0): Monitor name: Acer P226HQL
[ 11.785] (II) fglrx(0): Serial No: LNJ0W0034320
[ 11.785] (II) fglrx(0): EDID (in hex):
[ 11.785] (II) fglrx(0): 00ffffffffffff000472980133274010
[ 11.785] (II) fglrx(0): 0415010380301b782a9535a159579f27
[ 11.785] (II) fglrx(0): 0e5054b30c00714f810081809500d1c0
[ 11.785] (II) fglrx(0): 010101010101023a801871382d40582c
[ 11.785] (II) fglrx(0): 4500dd0c1100001e000000fd00384b1e
[ 11.785] (II) fglrx(0): 5311000a202020202020000000fc0041
[ 11.785] (II) fglrx(0): 636572205032323648514c0a000000ff
[ 11.785] (II) fglrx(0): 004c4e4a3057303033343332300a002c
[ 11.785] (II) fglrx(0): End of Display0 EDID data --------------------
[ 11.787] (II) fglrx(0): EDID for output DFP1
[ 11.787] (II) fglrx(0): Manufacturer: ACR Model: 198 Serial#: 272639795
[ 11.787] (II) fglrx(0): Year: 2011 Week: 4
[ 11.787] (II) fglrx(0): EDID Version: 1.3
[ 11.787] (II) fglrx(0): Digital Display Input
[ 11.787] (II) fglrx(0): Max Image Size [cm]: horiz.: 48 vert.: 27
[ 11.787] (II) fglrx(0): Gamma: 2.20
[ 11.787] (II) fglrx(0): DPMS capabilities: Off
[ 11.787] (II) fglrx(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 11.787] (II) fglrx(0): First detailed timing is preferred mode
[ 11.787] (II) fglrx(0): redX: 0.631 redY: 0.349 greenX: 0.341 greenY: 0.622
[ 11.787] (II) fglrx(0): blueX: 0.152 blueY: 0.058 whiteX: 0.313 whiteY: 0.329
[ 11.787] (II) fglrx(0): Supported established timings:
[ 11.787] (II) fglrx(0): 720x400@70Hz
[ 11.787] (II) fglrx(0): 640x480@60Hz
[ 11.787] (II) fglrx(0): 640x480@67Hz
[ 11.787] (II) fglrx(0): 800x600@56Hz
[ 11.787] (II) fglrx(0): 800x600@60Hz
[ 11.787] (II) fglrx(0): 1024x768@60Hz
[ 11.787] (II) fglrx(0): 1024x768@70Hz
[ 11.787] (II) fglrx(0): Manufacturer's mask: 0
[ 11.787] (II) fglrx(0): Supported standard timings:
[ 11.787] (II) fglrx(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 11.787] (II) fglrx(0): #1: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 11.787] (II) fglrx(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 11.787] (II) fglrx(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 11.787] (II) fglrx(0): #4: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 11.787] (II) fglrx(0): Supported detailed timing:
[ 11.787] (II) fglrx(0): clock: 148.5 MHz Image Size: 477 x 268 mm
[ 11.788] (II) fglrx(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 11.788] (II) fglrx(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 11.788] (II) fglrx(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 11.788] (II) fglrx(0): Monitor name: Acer P226HQL
[ 11.788] (II) fglrx(0): Serial No: LNJ0W0034320
[ 11.788] (II) fglrx(0): EDID (in hex):
[ 11.788] (II) fglrx(0): 00ffffffffffff000472980133274010
[ 11.788] (II) fglrx(0): 0415010380301b782a9535a159579f27
[ 11.788] (II) fglrx(0): 0e5054b30c00714f810081809500d1c0
[ 11.788] (II) fglrx(0): 010101010101023a801871382d40582c
[ 11.788] (II) fglrx(0): 4500dd0c1100001e000000fd00384b1e
[ 11.788] (II) fglrx(0): 5311000a202020202020000000fc0041
[ 11.788] (II) fglrx(0): 636572205032323648514c0a000000ff
[ 11.788] (II) fglrx(0): 004c4e4a3057303033343332300a002c
[ 11.788] (II) fglrx(0): EDID vendor "ACR", prod id 408
[ 11.789] (II) fglrx(0): Using EDID range info for horizontal sync
[ 11.789] (II) fglrx(0): Using EDID range info for vertical refresh
[ 11.789] (II) fglrx(0): Printing DDC gathered Modelines:
[ 11.789] (II) fglrx(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 11.789] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 11.789] (II) fglrx(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 11.789] (II) fglrx(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 11.789] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 11.789] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 11.789] (II) fglrx(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 11.789] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 11.789] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 11.789] (II) fglrx(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 11.789] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 11.789] (II) fglrx(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 11.789] (II) fglrx(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[ 11.790] (II) fglrx(0): Printing probed modes for output DFP1
[ 11.790] (II) fglrx(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz)
[ 11.790] (II) fglrx(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1776x1000"x50.0 148.50 1776 2304 2348 2640 1000 1004 1009 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1680x1050"x60.0 148.50 1680 2008 2052 2200 1050 1084 1089 1125 +hsync +vsync (67.5 kHz)
[ 11.790] (II) fglrx(0): Modeline "1680x1050"x50.0 148.50 1680 2448 2492 2640 1050 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1400x1050"x60.0 148.50 1400 2008 2052 2200 1050 1084 1089 1125 +hsync +vsync (67.5 kHz)
[ 11.790] (II) fglrx(0): Modeline "1400x1050"x50.0 148.50 1400 2448 2492 2640 1050 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1600x900"x50.0 148.50 1600 2304 2348 2640 900 1004 1009 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1280x1024"x50.0 148.50 1280 2448 2492 2640 1024 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 11.790] (II) fglrx(0): Modeline "1440x900"x50.0 148.50 1440 2448 2492 2640 900 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1440x900"x60.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz)
[ 11.790] (II) fglrx(0): Modeline "1280x960"x50.0 148.50 1280 2448 2492 2640 960 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1280x960"x60.0 108.00 1280 1328 1440 1688 960 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 11.790] (II) fglrx(0): Modeline "1280x800"x50.0 148.50 1280 2448 2492 2640 800 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1280x800"x60.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz)
[ 11.790] (II) fglrx(0): Modeline "1152x864"x60.0 148.50 1152 2008 2052 2200 864 1084 1089 1125 +hsync +vsync (67.5 kHz)
[ 11.790] (II) fglrx(0): Modeline "1152x864"x50.0 148.50 1152 2448 2492 2640 864 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
[ 11.790] (II) fglrx(0): Modeline "1280x768"x50.0 148.50 1280 2448 2492 2640 768 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1280x768"x60.0 83.50 1280 1352 1480 1680 768 803 809 831 -hsync +vsync (49.7 kHz)
[ 11.790] (II) fglrx(0): Modeline "1280x720"x50.0 148.50 1280 2448 2492 2640 720 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1280x720"x60.0 83.50 1280 1352 1480 1680 720 803 809 831 -hsync +vsync (49.7 kHz)
[ 11.790] (II) fglrx(0): Modeline "1024x768"x50.0 148.50 1024 2448 2492 2640 768 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1024x768"x70.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 11.790] (II) fglrx(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 11.790] (II) fglrx(0): Modeline "1024x600"x50.0 148.50 1024 2448 2492 2640 600 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "1024x600"x70.0 75.00 1024 1048 1184 1328 600 771 777 806 -hsync -vsync (56.5 kHz)
[ 11.790] (II) fglrx(0): Modeline "1024x600"x60.0 65.00 1024 1048 1184 1344 600 771 777 806 -hsync -vsync (48.4 kHz)
[ 11.790] (II) fglrx(0): Modeline "800x600"x50.0 148.50 800 2448 2492 2640 600 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "800x600"x60.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 11.790] (II) fglrx(0): Modeline "800x600"x56.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 11.790] (II) fglrx(0): Modeline "800x480"x50.0 148.50 800 2448 2492 2640 480 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.791] (II) fglrx(0): Modeline "800x480"x60.0 40.00 800 840 968 1056 480 601 605 628 +hsync +vsync (37.9 kHz)
[ 11.791] (II) fglrx(0): Modeline "800x480"x56.0 36.00 800 824 896 1024 480 601 603 625 +hsync +vsync (35.2 kHz)
[ 11.791] (II) fglrx(0): Modeline "640x480"x50.0 148.50 640 2448 2492 2640 480 1084 1089 1125 +hsync +vsync (56.2 kHz)
[ 11.791] (II) fglrx(0): Modeline "640x480"x67.0 27.28 640 664 728 816 480 481 484 499 -hsync +vsync (33.4 kHz)
[ 11.791] (II) fglrx(0): Modeline "640x480"x60.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 11.791] (II) fglrx(0): EDID for output DFP2
[ 11.791] (II) fglrx(0): EDID for output CRT1
[ 11.791] (II) fglrx(0): Output DFP1 connected
[ 11.791] (II) fglrx(0): Output DFP2 disconnected
[ 11.791] (II) fglrx(0): Output CRT1 disconnected
[ 11.791] (II) fglrx(0): Using exact sizes for initial modes
[ 11.791] (II) fglrx(0): Output DFP1 using initial mode 1920x1080
[ 11.791] (II) fglrx(0): Display dimensions: (480, 270) mm
[ 11.791] (II) fglrx(0): DPI set to (101, 101)
[ 11.791] (II) fglrx(0): Adapter AMD Radeon HD 6310 Graphics has 2 configurable heads and 1 displays connected.
[ 11.791] (==) fglrx(0): PseudoColor visuals disabled
[ 11.791] (II) Loading sub module "ramdac"
[ 11.791] (II) LoadModule: "ramdac"
[ 11.791] (II) Module "ramdac" already built-in
[ 11.791] (==) fglrx(0): NoDRI = NO
[ 11.791] (==) fglrx(0): Capabilities: 0x00000000
[ 11.791] (==) fglrx(0): CapabilitiesEx: 0x00000000
[ 11.791] (==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
[ 11.791] (==) fglrx(0): UseFastTLS=0
[ 11.791] (--) Depth 24 pixmap format is 32 bpp
[ 11.792] (II) Loading extension ATIFGLRXDRI
[ 11.792] (II) fglrx(0): doing swlDriScreenInit
[ 11.792] (II) fglrx(0): swlDriScreenInit for fglrx driver
[ 11.792] ukiDynamicMajor: found major device number 251
[ 11.792] ukiOpenByBusid: Searching for BusID PCI:0:1:0
[ 11.792] ukiOpenDevice: node name is /dev/ati/card0
[ 11.792] ukiOpenDevice: open result is 13, (OK)
[ 11.792] ukiOpenByBusid: ukiOpenMinor returns 13
[ 11.792] ukiOpenByBusid: ukiGetBusid reports PCI:0:1:0
[ 11.792] (II) fglrx(0): [uki] DRM interface version 1.0
[ 11.792] (II) fglrx(0): [uki] created "fglrx" driver at busid "PCI:0:1:0"
[ 11.792] (II) fglrx(0): [uki] added 8192 byte SAREA at 0x2000
[ 11.792] (II) fglrx(0): [uki] mapped SAREA 0x2000 to 0x7f721ed89000
[ 11.793] (II) fglrx(0): [uki] framebuffer handle = 0x3000
[ 11.793] (II) fglrx(0): [uki] added 1 reserved context for kernel
[ 11.793] (II) fglrx(0): swlDriScreenInit done
[ 11.793] (II) fglrx(0): Kernel Module Version Information:
[ 11.793] (II) fglrx(0): Name: fglrx
[ 11.793] (II) fglrx(0): Version: 8.98.2
[ 11.793] (II) fglrx(0): Date: Jul 19 2012
[ 11.793] (II) fglrx(0): Desc: AMD FireGL DRM kernel module
[ 11.793] (II) fglrx(0): Kernel Module version matches driver.
[ 11.793] (II) fglrx(0): Kernel Module Build Time Information:
[ 11.793] (II) fglrx(0): Build-Kernel UTS_RELEASE: 3.2.0-4-amd64
[ 11.793] (II) fglrx(0): Build-Kernel MODVERSIONS: no
[ 11.793] (II) fglrx(0): Build-Kernel __SMP__: no
[ 11.793] (II) fglrx(0): Build-Kernel PAGE_SIZE: 0x1000
[ 11.793] (II) fglrx(0): [uki] register handle = 0x00004000
[ 11.837] (II) fglrx(0): DRI initialization successfull
[ 11.839] (II) fglrx(0): FBADPhys: 0xf00000000 FBMappedSize: 0x0102c000
[ 11.843] (==) fglrx(0): Backing store disabled
[ 11.843] (II) Loading extension FGLRXEXTENSION
[ 11.843] (**) fglrx(0): DPMS enabled
[ 11.843] (II) fglrx(0): Initialized in-driver Xinerama extension
[ 11.843] (**) fglrx(0): Textured Video is enabled.
[ 11.843] (II) LoadModule: "glesx"
[ 11.844] (II) Loading /usr/lib/xorg/modules/glesx.so
[ 11.879] (II) Module glesx: vendor="X.Org Foundation"
[ 11.879] compiled for 1.4.99.906, module version = 1.0.0
[ 11.879] (II) Loading extension GLESX
[ 11.879] (II) fglrx(0): GLESX enableFlags = 592
[ 11.881] (II) fglrx(0): GLESX is enabled
[ 11.881] (II) LoadModule: "amdxmm"
[ 11.882] (II) Loading /usr/lib/xorg/modules/amdxmm.so
[ 11.887] (II) Module amdxmm: vendor="X.Org Foundation"
[ 11.887] compiled for 1.4.99.906, module version = 2.0.0
[ 11.900] (II) Loading extension AMDXVOPL
[ 11.900] (II) Loading extension AMDXVBA
[ 11.906] (II) fglrx(0): UVD feature is enabled(II) fglrx(0):
[ 11.910] (II) fglrx(0): Enable composite support successfully
[ 11.910] (WW) fglrx(0): Option "VendorName" is not used
[ 11.910] (WW) fglrx(0): Option "ModelName" is not used
[ 11.910] (II) fglrx(0): X context handle = 0x1
[ 11.910] (II) fglrx(0): [DRI] installation complete
[ 11.911] (==) fglrx(0): Silken mouse enabled
[ 11.911] (==) fglrx(0): Using HW cursor of display infrastructure!
[ 11.912] (II) fglrx(0): Disabling in-server RandR and enabling in-driver RandR 1.2.
[ 12.071] (II) fglrx(0): Framebuffer compression enabled: mcAddr=0xf0f790000 width=0x800 height=0x258
[ 12.071] (--) RandR disabled
[ 12.071] (II) Initializing built-in extension Generic Event Extension
[ 12.071] (II) Initializing built-in extension SHAPE
[ 12.071] (II) Initializing built-in extension MIT-SHM
[ 12.071] (II) Initializing built-in extension XInputExtension
[ 12.071] (II) Initializing built-in extension XTEST
[ 12.071] (II) Initializing built-in extension BIG-REQUESTS
[ 12.071] (II) Initializing built-in extension SYNC
[ 12.071] (II) Initializing built-in extension XKEYBOARD
[ 12.071] (II) Initializing built-in extension XC-MISC
[ 12.071] (II) Initializing built-in extension SECURITY
[ 12.071] (II) Initializing built-in extension XINERAMA
[ 12.071] (II) Initializing built-in extension XFIXES
[ 12.071] (II) Initializing built-in extension RENDER
[ 12.071] (II) Initializing built-in extension RANDR
[ 12.071] (II) Initializing built-in extension COMPOSITE
[ 12.071] (II) Initializing built-in extension DAMAGE
[ 12.071] (II) SELinux: Disabled on system
[ 12.075] ukiDynamicMajor: found major device number 251
[ 12.076] ukiOpenByBusid: Searching for BusID PCI:0:1:0
[ 12.076] ukiOpenDevice: node name is /dev/ati/card0
[ 12.076] ukiOpenDevice: open result is 14, (OK)
[ 12.076] ukiOpenByBusid: ukiOpenMinor returns 14
[ 12.076] ukiOpenByBusid: ukiGetBusid reports PCI:0:1:0
[ 12.500] (II) AIGLX: Loaded and initialized OpenGL driver(II) GLX: Initialized DRI GL provider for screen 0
[ 12.581] (II) fglrx(0): Enable the clock gating!
[ 12.582] (II) fglrx(0): Setting screen physical size to 508 x 285
[ 12.796] (II) config/udev: Adding input device Power Button (/dev/input/event5)
[ 12.796] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 12.796] (II) LoadModule: "evdev"
[ 12.796] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 12.798] (II) Module evdev: vendor="X.Org Foundation"
[ 12.798] compiled for 1.12.1, module version = 2.7.0
[ 12.798] Module class: X.Org XInput Driver
[ 12.798] ABI class: X.Org XInput driver, version 16.0
[ 12.798] (II) Using input driver 'evdev' for 'Power Button'
[ 12.798] (**) Power Button: always reports core events
[ 12.798] (**) evdev: Power Button: Device: "/dev/input/event5"
[ 12.798] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 12.798] (--) evdev: Power Button: Found keys
[ 12.798] (II) evdev: Power Button: Configuring as keyboard
[ 12.798] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input5/event5"
[ 12.798] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 12.798] (**) Option "xkb_rules" "evdev"
[ 12.798] (**) Option "xkb_model" "pc105"
[ 12.798] (**) Option "xkb_layout" "pl"
[ 12.863] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 12.863] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 12.863] (II) Using input driver 'evdev' for 'Power Button'
[ 12.863] (**) Power Button: always reports core events
[ 12.863] (**) evdev: Power Button: Device: "/dev/input/event3"
[ 12.864] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 12.864] (--) evdev: Power Button: Found keys
[ 12.864] (II) evdev: Power Button: Configuring as keyboard
[ 12.864] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input3/event3"
[ 12.864] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 12.864] (**) Option "xkb_rules" "evdev"
[ 12.864] (**) Option "xkb_model" "pc105"
[ 12.864] (**) Option "xkb_layout" "pl"
[ 12.865] (II) config/udev: Adding input device Sleep Button (/dev/input/event4)
[ 12.865] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 12.865] (II) Using input driver 'evdev' for 'Sleep Button'
[ 12.865] (**) Sleep Button: always reports core events
[ 12.865] (**) evdev: Sleep Button: Device: "/dev/input/event4"
[ 12.865] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 12.865] (--) evdev: Sleep Button: Found keys
[ 12.865] (II) evdev: Sleep Button: Configuring as keyboard
[ 12.865] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input4/event4"
[ 12.865] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 12.865] (**) Option "xkb_rules" "evdev"
[ 12.865] (**) Option "xkb_model" "pc105"
[ 12.865] (**) Option "xkb_layout" "pl"
[ 12.866] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event8)
[ 12.866] (II) No input driver specified, ignoring this device.
[ 12.866] (II) This device may have been added with another device file.
[ 12.867] (II) config/udev: Adding input device Logitech Unifying Device. Wireless PID:101d (/dev/input/event1)
[ 12.867] (**) Logitech Unifying Device. Wireless PID:101d: Applying InputClass "evdev pointer catchall"
[ 12.867] (II) Using input driver 'evdev' for 'Logitech Unifying Device. Wireless PID:101d'
[ 12.867] (**) Logitech Unifying Device. Wireless PID:101d: always reports core events
[ 12.867] (**) evdev: Logitech Unifying Device. Wireless PID:101d: Device: "/dev/input/event1"
[ 12.867] (--) evdev: Logitech Unifying Device. Wireless PID:101d: Vendor 0x46d Product 0xc52b
[ 12.867] (--) evdev: Logitech Unifying Device. Wireless PID:101d: Found 20 mouse buttons
[ 12.867] (--) evdev: Logitech Unifying Device. Wireless PID:101d: Found scroll wheel(s)
[ 12.867] (--) evdev: Logitech Unifying Device. Wireless PID:101d: Found relative axes
[ 12.867] (--) evdev: Logitech Unifying Device. Wireless PID:101d: Found x and y relative axes
[ 12.867] (II) evdev: Logitech Unifying Device. Wireless PID:101d: Configuring as mouse
[ 12.867] (II) evdev: Logitech Unifying Device. Wireless PID:101d: Adding scrollwheel support
[ 12.867] (**) evdev: Logitech Unifying Device. Wireless PID:101d: YAxisMapping: buttons 4 and 5
[ 12.867] (**) evdev: Logitech Unifying Device. Wireless PID:101d: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 12.867] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb6/6-4/6-4:1.2/0003:046D:C52B.0003/input/input1/event1"
[ 12.867] (II) XINPUT: Adding extended input device "Logitech Unifying Device. Wireless PID:101d" (type: MOUSE, id 9)
[ 12.868] (II) evdev: Logitech Unifying Device. Wireless PID:101d: initialized for relative axes.
[ 12.868] (**) Logitech Unifying Device. Wireless PID:101d: (accel) keeping acceleration scheme 1
[ 12.868] (**) Logitech Unifying Device. Wireless PID:101d: (accel) acceleration profile 0
[ 12.868] (**) Logitech Unifying Device. Wireless PID:101d: (accel) acceleration factor: 2.000
[ 12.868] (**) Logitech Unifying Device. Wireless PID:101d: (accel) acceleration threshold: 4
[ 12.869] (II) config/udev: Adding input device Logitech Unifying Device. Wireless PID:101d (/dev/input/mouse0)
[ 12.869] (II) No input driver specified, ignoring this device.
[ 12.869] (II) This device may have been added with another device file.
[ 12.869] (II) config/udev: Adding input device Logitech Unifying Device. Wireless PID:4004 (/dev/input/event2)
[ 12.870] (**) Logitech Unifying Device. Wireless PID:4004: Applying InputClass "evdev keyboard catchall"
[ 12.870] (II) Using input driver 'evdev' for 'Logitech Unifying Device. Wireless PID:4004'
[ 12.870] (**) Logitech Unifying Device. Wireless PID:4004: always reports core events
[ 12.870] (**) evdev: Logitech Unifying Device. Wireless PID:4004: Device: "/dev/input/event2"
[ 12.870] (--) evdev: Logitech Unifying Device. Wireless PID:4004: Vendor 0x46d Product 0xc52b
[ 12.870] (--) evdev: Logitech Unifying Device. Wireless PID:4004: Found 1 mouse buttons
[ 12.870] (--) evdev: Logitech Unifying Device. Wireless PID:4004: Found scroll wheel(s)
[ 12.870] (--) evdev: Logitech Unifying Device. Wireless PID:4004: Found relative axes
[ 12.870] (II) evdev: Logitech Unifying Device. Wireless PID:4004: Forcing relative x/y axes to exist.
[ 12.870] (--) evdev: Logitech Unifying Device. Wireless PID:4004: Found absolute axes
[ 12.870] (II) evdev: Logitech Unifying Device. Wireless PID:4004: Forcing absolute x/y axes to exist.
[ 12.870] (--) evdev: Logitech Unifying Device. Wireless PID:4004: Found keys
[ 12.870] (II) evdev: Logitech Unifying Device. Wireless PID:4004: Configuring as mouse
[ 12.870] (II) evdev: Logitech Unifying Device. Wireless PID:4004: Configuring as keyboard
[ 12.870] (II) evdev: Logitech Unifying Device. Wireless PID:4004: Adding scrollwheel support
[ 12.870] (**) evdev: Logitech Unifying Device. Wireless PID:4004: YAxisMapping: buttons 4 and 5
[ 12.870] (**) evdev: Logitech Unifying Device. Wireless PID:4004: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 12.870] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb6/6-4/6-4:1.2/0003:046D:C52B.0003/input/input2/event2"
[ 12.870] (II) XINPUT: Adding extended input device "Logitech Unifying Device. Wireless PID:4004" (type: KEYBOARD, id 10)
[ 12.870] (**) Option "xkb_rules" "evdev"
[ 12.870] (**) Option "xkb_model" "pc105"
[ 12.870] (**) Option "xkb_layout" "pl"
[ 12.871] (II) evdev: Logitech Unifying Device. Wireless PID:4004: initialized for relative axes.
[ 12.871] (WW) evdev: Logitech Unifying Device. Wireless PID:4004: ignoring absolute axes.
[ 12.871] (**) Logitech Unifying Device. Wireless PID:4004: (accel) keeping acceleration scheme 1
[ 12.871] (**) Logitech Unifying Device. Wireless PID:4004: (accel) acceleration profile 0
[ 12.871] (**) Logitech Unifying Device. Wireless PID:4004: (accel) acceleration factor: 2.000
[ 12.871] (**) Logitech Unifying Device. Wireless PID:4004: (accel) acceleration threshold: 4
[ 12.872] (II) config/udev: Adding input device Wacom Bamboo1 (/dev/input/event7)
[ 12.872] (**) Wacom Bamboo1: Applying InputClass "evdev tablet catchall"
[ 12.872] (**) Wacom Bamboo1: Applying InputClass "Wacom class"
[ 12.872] (II) LoadModule: "wacom"
[ 12.872] (II) Loading /usr/lib/xorg/modules/input/wacom_drv.so
[ 12.874] (II) Module wacom: vendor="X.Org Foundation"
[ 12.875] compiled for 1.12.4, module version = 0.15.0
[ 12.875] Module class: X.Org XInput Driver
[ 12.875] ABI class: X.Org XInput driver, version 16.0
[ 12.875] (II) Using input driver 'wacom' for 'Wacom Bamboo1'
[ 12.875] (**) Wacom Bamboo1: always reports core events
[ 12.875] (**) Option "Device" "/dev/input/event7"
[ 12.875] (II) Wacom Bamboo1: type not specified, assuming 'stylus'.
[ 12.875] (II) Wacom Bamboo1: other types will be automatically added.
[ 12.875] (--) Wacom Bamboo1 stylus: using pressure threshold of 27 for button 1
[ 12.875] (--) Wacom Bamboo1 stylus: Wacom USB Bamboo1 tablet maxX=5104 maxY=3712 maxZ=511 resX=40000 resY=40000 tilt=disabled
[ 12.875] (II) Wacom Bamboo1 stylus: hotplugging dependent devices.
[ 12.875] (EE) Wacom Bamboo1 stylus: Invalid type 'touch' for this device.
[ 12.875] (EE) Wacom Bamboo1 stylus: Invalid type 'pad' for this device.
[ 12.875] (II) Wacom Bamboo1 stylus: hotplugging completed.
[ 12.904] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb6/6-5/6-5:1.0/input/input8/event7"
[ 12.904] (II) XINPUT: Adding extended input device "Wacom Bamboo1 stylus" (type: STYLUS, id 11)
[ 12.905] (**) Wacom Bamboo1 stylus: (accel) keeping acceleration scheme 1
[ 12.905] (**) Wacom Bamboo1 stylus: (accel) acceleration profile 0
[ 12.905] (**) Wacom Bamboo1 stylus: (accel) acceleration factor: 2.000
[ 12.905] (**) Wacom Bamboo1 stylus: (accel) acceleration threshold: 4
[ 12.907] (II) config/udev: Adding input device Wacom Bamboo1 (/dev/input/mouse1)
[ 12.907] (II) No input driver specified, ignoring this device.
[ 12.907] (II) This device may have been added with another device file.
[ 12.908] (II) config/udev: Adding input device HDA ATI SB Headphone (/dev/input/event9)
[ 12.908] (II) No input driver specified, ignoring this device.
[ 12.908] (II) This device may have been added with another device file.
[ 12.909] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 12.909] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 12.909] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 12.909] (**) AT Translated Set 2 keyboard: always reports core events
[ 12.909] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[ 12.909] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 12.909] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 12.909] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 12.910] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 12.910] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[ 12.910] (**) Option "xkb_rules" "evdev"
[ 12.910] (**) Option "xkb_model" "pc105"
[ 12.910] (**) Option "xkb_layout" "pl"
[ 12.912] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 12.912] (II) No input driver specified, ignoring this device.
[ 12.912] (II) This device may have been added with another device file.
[ 12.923] (**) Wacom Bamboo1 eraser: Applying InputClass "evdev tablet catchall"
[ 12.923] (**) Wacom Bamboo1 eraser: Applying InputClass "Wacom class"
[ 12.923] (II) Using input driver 'wacom' for 'Wacom Bamboo1 eraser'
[ 12.923] (**) Wacom Bamboo1 eraser: always reports core events
[ 12.923] (**) Option "Device" "/dev/input/event7"
[ 12.923] (**) Option "Type" "eraser"
[ 12.923] (--) Wacom Bamboo1 eraser: Wacom USB Bamboo1 tablet maxX=5104 maxY=3712 maxZ=511 resX=40000 resY=40000 tilt=disabled
[ 12.924] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb6/6-5/6-5:1.0/input/input8/event7"
[ 12.924] (II) XINPUT: Adding extended input device "Wacom Bamboo1 eraser" (type: ERASER, id 13)
[ 12.925] (**) Wacom Bamboo1 eraser: (accel) keeping acceleration scheme 1
[ 12.925] (**) Wacom Bamboo1 eraser: (accel) acceleration profile 0
[ 12.925] (**) Wacom Bamboo1 eraser: (accel) acceleration factor: 2.000
[ 12.925] (**) Wacom Bamboo1 eraser: (accel) acceleration threshold: 4
[ 12.926] (**) Wacom Bamboo1 cursor: Applying InputClass "evdev tablet catchall"
[ 12.926] (**) Wacom Bamboo1 cursor: Applying InputClass "Wacom class"
[ 12.926] (II) Using input driver 'wacom' for 'Wacom Bamboo1 cursor'
[ 12.926] (**) Wacom Bamboo1 cursor: always reports core events
[ 12.926] (**) Option "Device" "/dev/input/event7"
[ 12.926] (**) Option "Type" "cursor"
[ 12.926] (--) Wacom Bamboo1 cursor: Wacom USB Bamboo1 tablet maxX=5104 maxY=3712 maxZ=511 resX=40000 resY=40000 tilt=disabled
[ 12.927] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb6/6-5/6-5:1.0/input/input8/event7"
[ 12.927] (II) XINPUT: Adding extended input device "Wacom Bamboo1 cursor" (type: CURSOR, id 14)
[ 12.927] (**) Wacom Bamboo1 cursor: (accel) keeping acceleration scheme 1
[ 12.927] (**) Wacom Bamboo1 cursor: (accel) acceleration profile 0
[ 12.927] (**) Wacom Bamboo1 cursor: (accel) acceleration factor: 2.000
[ 12.927] (**) Wacom Bamboo1 cursor: (accel) acceleration threshold: 4
[ 12.928] (II) fglrx(0): Restoring Recent Mode via PCS is not supported in RANDR 1.2 capable environments
lspci:
00:00.0 Host bridge: Advanced Micro Devices [AMD] Family 14h Processor Root Complex
00:01.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Wrestler [Radeon HD 6310]
00:01.1 Audio device: Advanced Micro Devices [AMD] nee ATI Wrestler HDMI Audio [Radeon HD 6250/6310]
00:11.0 SATA controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode]
00:12.0 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:12.2 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:13.0 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:13.2 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:14.0 SMBus: Advanced Micro Devices [AMD] nee ATI SBx00 SMBus Controller (rev 42)
00:14.1 IDE interface: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 IDE Controller (rev 40)
00:14.2 Audio device: Advanced Micro Devices [AMD] nee ATI SBx00 Azalia (Intel HDA) (rev 40)
00:14.3 ISA bridge: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 LPC host controller (rev 40)
00:14.4 PCI bridge: Advanced Micro Devices [AMD] nee ATI SBx00 PCI to PCI Bridge (rev 40)
00:14.5 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
00:15.0 PCI bridge: Advanced Micro Devices [AMD] nee ATI SB700/SB800/SB900 PCI to PCI bridge (PCIE port 0)
00:15.1 PCI bridge: Advanced Micro Devices [AMD] nee ATI SB700/SB800/SB900 PCI to PCI bridge (PCIE port 1)
00:15.2 PCI bridge: Advanced Micro Devices [AMD] nee ATI SB900 PCI to PCI bridge (PCIE port 2)
00:16.0 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:16.2 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 0 (rev 43)
00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 3
00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 4
00:18.5 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 6
00:18.6 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 5
00:18.7 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 7
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
03:00.0 Network controller: Atheros Communications Inc. AR9285 Wireless Network Adapter (PCI-Express) (rev 01)
04:00.0 USB controller: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller
